Yun ports closed
Hi all,
I'm new connecting arduino to Internet, I tried to open a port for my Yun in my router, but when I tried to verify if port 1883 (in this case) is open the test tell me that it is closed. I tried this several times using different ports and I discovered that the only way to open the port is change the configuration of SSH 22 port in the advanced page configuration, then the port appears open, unfortunately if I do this I cant program the Yun via WiFi, I'm not sure if I'm doing this well. I thing it should be a way to open a different ports. Any idea is welcome.
Regards.
@Coxon22,
It is not clear what you are trying to do. Either rewrite with appropriate punctation, or draw a diagram.
Jess
