YUN reading/getting REST values
I have two YUN's and I would like them to communicate with each other via REST:
Here is the catch: I want the second YUN to GET/FETCH the value of the temperature sensor from the first YUN. I don NOT want the fist YUN to initiate the transaction, it MUST be initiated by the second YUN
I believe the coding of the first YUN is more or less standard as I followed the above mentioned example - Through a browser I can get/fetch the value of the Temperature sensor
My question relates to the programing of the second YUN and how to program it to get/fetch the data from the first YUN. How do I go about doing this ?
The best solution I can think of is using the Process.h library and execute curl command to get/fetch the data from the first YUN. Am I missing something ? Is there a better method of getting/fetching the data ?
Thanks
Gregg
This is what I have come up with:
#include <Bridge.h>
#include <Process.h>
#include <Console.h>
   // Bridge startup
   pinMode(13,OUTPUT);
   digitalWrite(13, LOW);
   Bridge.begin();
   digitalWrite(13, HIGH);
   Console.begin();
   while (!Console){
       ; // wait for Console port to connect.
   Console.println("Console Connected"); Console.println("");
   char result;
   String rest_temp;
   Console.println("Getting REST information...");
   Process temp;
   temp.runShellCommand("curl http://x.x.x.x/arduino/rest_test");
   while(temp.running());
   Console.print("Receiving data... ");
   while (temp.available()>0) {
      char result = temp.read();
      Console.print(result);
      rest_temp = rest_temp + result;
   Console.print("Temperature via REST: ");
   Console.println(rest_temp);
   // Ensure the last bit of data is sent.
   Serial.flush();
   Console.println("DONE!!!");
   delay(2000);
It works, but is it the best method ?
