Yun Rev 2, Temboo Stuck Waiting
Hi All!
I am new to using Temboo and my Yun Rev 2. I am trying to get any Temboo sketch working, but no matter which one it is, SQS, Yahoo Weather, Twitter. It get’s stuck just printing “waiting” in the serial monitor. Here’s the code for the Yahoo Weather example sketch from the IDE
#include <Bridge.h>
#include <Temboo.h>
#include "TembooAccount.h" // contains Temboo account information
                           // as described in the footer comment below
// the address for which a weather forecast will be retrieved
String ADDRESS_FOR_FORECAST = "104 Franklin St., New York NY 10013";
int numRuns = 1;   // execution count, so that this doesn't run forever
int maxRuns = 10;  // max number of times the Yahoo WeatherByAddress Choreo should be run
  // for debugging, wait until a serial console is connected
  delay(4000);
  while(!Serial);
  Bridge.begin();
  // while we haven't reached the max number of runs...
  if (numRuns <= maxRuns) {
    // print status
    Serial.println("Running GetWeatherByAddress - Run #" + String(numRuns++) + "...");
    // create a TembooChoreo object to send a Choreo request to Temboo
    TembooChoreo GetWeatherByAddressChoreo;
    // invoke the Temboo client
    GetWeatherByAddressChoreo.begin();
    // add your temboo account info
    GetWeatherByAddressChoreo.setAccountName(TEMBOO_ACCOUNT);
    GetWeatherByAddressChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
    GetWeatherByAddressChoreo.setAppKey(TEMBOO_APP_KEY);
    // set the name of the choreo we want to run
    GetWeatherByAddressChoreo.setChoreo("/Library/Yahoo/Weather/GetWeatherByAddress");
    // set choreo inputs; in this case, the address for which to retrieve weather data
    // the Temboo client provides standardized calls to 100+ cloud APIs
    GetWeatherByAddressChoreo.addInput("Address", ADDRESS_FOR_FORECAST);
    // add an output filter to extract the name of the city.
    GetWeatherByAddressChoreo.addOutputFilter("city", "/rss/channel/yweather:location/@city", "Response");
    // add an output filter to extract the current temperature
    GetWeatherByAddressChoreo.addOutputFilter("temperature", "/rss/channel/item/yweather:condition/@temp", "Response");
    // add an output filter to extract the date and time of the last report.
    GetWeatherByAddressChoreo.addOutputFilter("date", "/rss/channel/item/yweather:condition/@date", "Response");
    // run the choreo
    GetWeatherByAddressChoreo.run();
    // when the choreo results are available, print them to the serial monitor
    while(GetWeatherByAddressChoreo.available()) {
      char c = GetWeatherByAddressChoreo.read();
      Serial.print(c);
    GetWeatherByAddressChoreo.close();
  Serial.println("Waiting...");
  Serial.println("");
  delay(30000); // wait 30 seconds between GetWeatherByAddress calls
It never gets the weather and every sketch from Temboo just get’s stuck waiting. I have all my correct Temboo details in the header file. Also my Yun Rev 2 has been connected to both WiFi and Ethernet and nothing changes.
