Yun Rev2 USB port sketch-upload problem.
When I upload a sketch via WiFi, it works ok, avrdude reports: avrdude: Device signature = 0x1e9587 (probably m32u4) and everything loads ok. :slight_smile: The WiFi side works great I can access via SSH etc.
However, when I load over USB, its fails and avrdude reports: avrdude: Device signature = 0xff0d0d
avrdude: Expected signature for ATmega32U4 is 1E 95 87 :slightly_frowning_face:
I can use the serial monitor on USB just fine, just not upload sketches. And I can use the sketch terminal to access the linux side of the yun.
Anyone know a fix? I cannot find anything on google or the forums... Complete log (verbose) for USB failed load:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/snap/arduino/42/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/dlinano/snap/arduino/42/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: butterfly_recv(): programmer is not responding
################################################## | 100% 5.00s
Double check chip, or use -F to override this check.
