I have a yun shield in my robot and it stopped working. I replaced the yun shield with another one I have and my robot works again.
As linux does not seem to boot (only the green power light is on and the white led never turns on), I'm trying to debrick the yun shield. I put the shield on a leonardo and uploaded the "yun serial terminal" sketch I found here. https://www.arduino.cc/en/Tutorial/YunSerialTerminal
This is the output I get
[ 7.320000] random: mktemp urandom read with 11 bits of entropy available
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 10.440000] mount_root: loading kmods from internal overlay
[ 10.830000] jffs2: error: (394) jffs2_build_inode_pass1: child dir "#83456aa0" (ino #95) of dir ino #72 appears to be a hard link
[ 10.840000] jffs2: notice: (394) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 10.850000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 10.860000] block: extroot: not configured
[ 10.940000] jffs2: error: (391) jffs2_build_inode_pass1: child dir "#83456aa0" (ino #95) of dir ino #72 appears to be a hard link
[ 10.940000] jffs2: notice: (391) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 10.950000] jffs2: warning: (391) jffs2_get_inode_nodes: Eep. No valid nodes for ino #95.
[ 10.950000] jffs2: warning: (391) jffs2_do_read_inode_internal: no data nodes found for ino #95
[ 10.960000] jffs2: iget() failed for ino #95
[ 11.150000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 11.160000] block: extroot: not configured
[ 11.160000] mount_root: switching to jffs2 overlay
[ 11.190000] jffs2: warning: (401) jffs2_get_inode_nodes: Eep. No valid nodes for ino #95.
[ 11.190000] jffs2: warning: (401) jffs2_do_read_inode_internal: no data nodes found for ino #95
[ 11.190000] jffs2: iget() failed for ino #95
/etc/preinit: line 1: cat: Input/output error
[ 11.200000] jffs2: warning: (403) jffs2_get_inode_nodes: Eep. No valid nodes for ino #95.
[ 11.210000] jffs2: warning: (403) jffs2_do_read_inode_internal: no data nodes found for ino #95
[ 11.210000] jffs2: iget() failed for ino #95
[ 11.220000] jffs2: warning: (404) jffs2_get_inode_nodes: Eep. No valid nodes for ino #95.
[ 11.220000] jffs2: warning: (404) jffs2_do_read_inode_internal: no data nodes found for ino #95
[ 11.230000] jffs2: iget() failed for ino #95
/etc/preinit: line 1: grep: Input/output error
[ 11.230000] jffs2: warning: (1) jffs2_get_inode_nodes: Eep. No valid nodes for ino #95.
[ 11.230000] jffs2: warning: (1) jffs2_do_read_inode_internal: no data nodes found for ino #95
[ 11.240000] jffs2: iget() failed for ino #95
[ 81.770000] random: nonblocking pool is initialized
This doesn't help me any further. Someone has A clue what I can do?
Best regards
Jantje
