Hi - I must be missing something basic but I have a sketch using Temboo to send SMS. With Yun plugged into my laptop via usb, the sketch works great. It sends me a sms every minute.
I need this however to run plugged into wall. I cant simply leave my laptop connected to Yun.
When I plug the Yun into the wall, its powers up. All seems normal, but it seems as though the sketch never runs.
The same is true when I plug the Yun back into my laptop. I must upload the sketch again in order to get it to run.
Given that the sketch is uploaded, is there a way to 'start,' or run the sketch while the Yun is plugged in to a wall socket?
Going to guess its the wait…I have this…its coming to me now…yes its the BLINK sketch…Nope Oh well
And your sketch is what exactly ?
Post it here and you should know to use CODE TAGS ( </> )
Also asking this thread be moved to … wait I have another guess in my mind…Dang its gone but lets see if they will put it in the YUN section for us. (yup there is a section for them)
Thanks Ballscrewbob. Code for sketch is below. This works well with the arduino yun connected via usb to my laptop, but it seems not to run when I connect the Yun to an outlet.
SendAnSMS
Demonstrates sending an SMS via Twilio using Temboo from an Arduino Yún.
#include <Bridge.h>
#include <Temboo.h>
#include "TembooAccount.h" // contains Temboo account information
// as described in the footer comment below
/*** SUBSTITUTE YOUR VALUES BELOW: ***/
// Note that for additional security and reusability, you could
// use #define statements to specify these values in a .h file.
// the Account SID from your Twilio account
const String TWILIO_ACCOUNT_SID = "";
// the Auth Token from your Twilio account
const String TWILIO_AUTH_TOKEN = "";
// your Twilio phone number, e.g., "+1 555-222-1212"
const String TWILIO_NUMBER = "+";
// the number to which the SMS should be sent, e.g., "+1 555-222-1212"
const String RECIPIENT_NUMBER = "+";
// a flag to indicate whether we've attempted to send the SMS yet or not
boolean attempted = false;
int sensorSlidingDoor = 2;
// for debugging, wait until a serial console is connected
while(!Serial);
Bridge.begin();
// prep sensor for input:
pinMode(sensorSlidingDoor, INPUT_PULLUP);
Serial.println("starting");
int sensorState = digitalRead(sensorSlidingDoor);
// only try to send the SMS if we haven't already sent it successfully
if (sensorState == 1){
Serial.println("Door open, running SendAnSMS...");
// should get time door is open
// we need a Process object to send a Choreo request to Temboo
TembooChoreo SendSMSChoreo;
// invoke the Temboo client
// NOTE that the client must be reinvoked and repopulated with
// appropriate arguments each time its run() method is called.
SendSMSChoreo.begin();
// set Temboo account credentials
SendSMSChoreo.setAccountName(TEMBOO_ACCOUNT);
SendSMSChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
SendSMSChoreo.setAppKey(TEMBOO_APP_KEY);
// identify the Temboo Library choreo to run (Twilio > SMSMessages > SendSMS)
SendSMSChoreo.setChoreo("/Library/Twilio/SMSMessages/SendSMS");
// set the required choreo inputs
// see https://www.temboo.com/library/Library/Twilio/SMSMessages/SendSMS/
// for complete details about the inputs for this Choreo
// the first input is a your AccountSID
SendSMSChoreo.addInput("AccountSID", TWILIO_ACCOUNT_SID);
// next is your Auth Token
SendSMSChoreo.addInput("AuthToken", TWILIO_AUTH_TOKEN);
// next is your Twilio phone number
SendSMSChoreo.addInput("From", TWILIO_NUMBER);
// next, what number to send the SMS to
SendSMSChoreo.addInput("To", RECIPIENT_NUMBER);
// finally, the text of the message to send
SendSMSChoreo.addInput("Body", "Sliding door open at 8 Winding Way - matts arduino");
// tell the Process to run and wait for the results. The
// return code (returnCode) will tell us whether the Temboo client
// was able to send our request to the Temboo servers
unsigned int returnCode = SendSMSChoreo.run();
// a return code of zero (0) means everything worked
if (returnCode == 0) {
Serial.println("Success! SMS sent!");
// a non-zero return code means there was an error
// read and print the error message
while (SendSMSChoreo.available()) {
char c = SendSMSChoreo.read();
Serial.print(c);
SendSMSChoreo.close();
// set the flag indicatine we've tried once.
attempted=true;
delay(4000);
Remove or comment out the line
" while(!Serial); "
That is waiting until it senses a full USB connection.
That should fix your issue.
Wow. Interesting Ballscrewbob. Will be testing this shortly and will share feedback. Many thanks.
