Yun to Google Spreadsheet through Temboo
Hello,
I am doing the Cloud-Connected Weather Station with the Arduino Yun & Temboo project found here: Connections | Cloud-Connected Weather Station with the Arduino Yun & Temboo | Adafruit Learning System
I have successfully been able to post data on my spreadsheet using an older version of the code but now I get an error after uploading my sketch to my Yun.
I have attached my old and new code. My TembooAccount.h file is not included, but it remains unchanged from old to new.
I have a google spreadsheet named YunB with lettered values in the first row as I did for my working spreadsheet YunA.
The error I get on the serial monitor is:
Error
A Step Error has occurred: "An input error has occurred. RowData and SpreadsheetTitle are required.". The error occurred in the Stop (Missing request parameters) step.
HTTP_CODE
500
Any help would be greatly appreciated and let me know if any more information is needed to help.
OldCode.ino (3.38 KB)
NewCode.ino (6.3 KB)
Append a spreadsheet in google docs without Temboo.
http://forum.arduino.cc/index.php?topic=198347.msg1569706#msg1569706
Is your Yun upgraded to latest image? If not please update it.
Then download the latest Arduino IDE and try the Temboo example SendDataToGoogleSpreadsheet
I have been able to solve my problem. It turned out to be a RAM problem, which was solved by deleting an unnecessary (to me) section of the sketch that sent an email notification.
I have included the updated code for anyone else who may encounter this problem:
// Include required libraries
#include <Bridge.h>
#include <Temboo.h>
#include <Process.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
// Contains Temboo account information
#include "TembooAccount.h"
// Variables
int lightLevel;
float humidity;
float temperature;
unsigned long time;
// Process to get the measurement time
Process date;
// Your Google Docs data
const String GOOGLE_USERNAME = "myrealemail@gmail.com";
const String GOOGLE_PASSWORD = "myrealpassword";
const String SPREADSHEET_TITLE = "Yun";
#include "DHT.h"
// DHT11 sensor pins
#define DHTPIN 8
#define DHTTYPE DHT11
// DHT & BMP instances
DHT dht(DHTPIN, DHTTYPE);
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
// Debug mode ?
boolean debug_mode = true;
  // Start Serial
  if (debug_mode == true){
    delay(4000);
    while(!Serial);
  // Initialize DHT sensor
  dht.begin();
  // Start bridge
  Bridge.begin();
  // Start date process
  time = millis();
  if (!date.running())  {
    date.begin("date");
    date.addParameter("+%D-%T");
    date.run();
  if (debug_mode == false){
    Serial.println("Setup complete. Waiting for sensor input...\n");
  // Initialise the sensor
  if(!bmp.begin())
    if (debug_mode == true){Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");}
    while(1);
  // Measure the humidity & temperature
  humidity = dht.readHumidity();
  // Measure pressure & temperature from BMP sensor
  sensors_event_t event;
  bmp.getEvent(&event);
  float pressure = event.pressure;
   bmp.getTemperature(&temperature);
   float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA;
   float altitude;
   altitude = bmp.pressureToAltitude(seaLevelPressure,
                                        event.pressure,
                                        temperature);
    Serial.println("\nCalling the /Library/Google/Spreadsheets/AppendRow Choreo...");
  // Append data to Google Docs sheet
  runAppendRow(humidity, pressure, temperature, altitude);
  // Repeat every 10 minutes
  delay(600000);
// Function to add data to Google Docs
void runAppendRow(float humidity, float pressure, float temperature, float altitude) {
  TembooChoreo AppendRowChoreo;
  // Invoke the Temboo client
  AppendRowChoreo.begin();
  // Set Temboo account credentials
  AppendRowChoreo.setAccountName(TEMBOO_ACCOUNT);
  AppendRowChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
  AppendRowChoreo.setAppKey(TEMBOO_APP_KEY);
  // Identify the Choreo to run
  AppendRowChoreo.setChoreo("/Library/Google/Spreadsheets/AppendRow");
  // your Google username (usually your email address)
  AppendRowChoreo.addInput("Username", GOOGLE_USERNAME);
  // your Google account password
  AppendRowChoreo.addInput("Password", GOOGLE_PASSWORD);
  // the title of the spreadsheet you want to append to
  AppendRowChoreo.addInput("SpreadsheetTitle", SPREADSHEET_TITLE);
  // Restart the date process:
    date.begin("date");
    date.run();
  // Get date
  String timeString = date.readString();
  // Format data
  String data = "";
  data = data + timeString + "," + String(humidity) + "," + String(pressure) + "," + String(temperature) + "," + String(altitude);
  // Set Choreo inputs
  AppendRowChoreo.addInput("RowData", data);
  // Run the Choreo
  unsigned int returnCode = AppendRowChoreo.run();
  // A return code of zero means everything worked
  if (returnCode == 0) {
      Serial.println("Completed execution of the /Library/Google/Spreadsheets/AppendRow Choreo.\n");
    // A non-zero return code means there was an error
    // Read and print the error message
    while (AppendRowChoreo.available()) {
      char c = AppendRowChoreo.read();
      if (debug_mode == true){ Serial.print(c); }
    if (debug_mode == true){ Serial.println(); }
  AppendRowChoreo.close();
Thanks mate! I had the same problem and deleting the email notification solved it!!
Thanks for sharing!
hai,
I have used the same code available in the net to send data to the spread sheet. I am getting an error stating that my header file is not included. But I have added it to my main file following the steps"Sketch - Add file".
I have also included my header file in the main file stating: #include"TembooAcount.h"
The error is as follows:" TembooAccount.h : NO SUCH FILE OR DIRECTORY - COMPILATION TERMINATED"
Please suggest any solutions
