Yun WiFi/Ethernet configuration
Hi all,
I’ve two Yun boards with different OS and both of them exhibit the same problem.
The WiFi has a dynamic address while the Ethernet has a static address. Both of them run fine my projects when using Blynk with no physical connections to the router.
However, I cannot ping neither of them nor the addresses are shown on the Arduino’s IDE. If I plug in the Ethernet cable to both of them, then I can ping fine the 4 addresses and they’re seen as well by the Arduino’s IDE.
Obviously, I failed to configure them the correctly by I just cannot find the error so I’d appreciate some guidance.
TIA
