Yun wireless (lan) fails when eth1 (wan) is disconnected
Arduino Yun is working fine. I can load scripts over either network. Both have a unique static IP configured for my private network.
So now I want to go completely wireless. If I unplug the ethernet cable from the YUN the wireles port (lan) goes down. With the ethernet connected I can ping both IP addresses, run the arduino YUN setup page over either port. I have read through the configuration settings. I know I am missing something.
LAN (wireless) settings from /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option hwmode '11ng'
option path 'platform/ar933x_wmac'
option htmode 'HT20'
list ht_capab 'SHORT-GI-20'
list ht_capab 'SHORT-GI-40'
list ht_capab 'RX-STBC1'
list ht_capab 'DSSS_CCK-40'
option disabled '0'
option channel 'auto'
option country 'US'
config wifi-iface
option device 'radio0'
option mode 'sta'
option ssid 'zzzzzzz'
option encryption 'psk2'
option key 'xxxxxxxxxxx'
option network 'lan'
/etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config interface 'lan'
option _orig_ifname 'wlan0'
option _orig_bridge 'false'
option ipaddr '192.168.169.238'
option netmask '255.255.255.0'
option gateway '192.168.169.254'
option broadcast '192.168.169.255'
config interface 'wan'
option _orig_ifname 'eth1'
option ipaddr '192.168.169.239'
option ifname 'eth1'
So I owe an update on this issue. The simple answer is - KEEP IT SIMPLE. I reset the linino with a +30 second press of the wifi button and no ethernet cable plugged in. Then Joined the the arduino network per the instructions, and then followed the instuctions. Bottom line is - don't get fancy with it. I am sure all my messing around confused the poor thing. I now have a wireless YUN. Just for reference:
/etc/config/network looks like this now - which is basically off.
option ifname 'lo'
option proto 'dhcp'
option proto 'dhcp'
option metric '10'
and /etc/config/wireless is now like this
option disabled '0'
option country '00'
config wifi-iface
option mode 'sta'
option ssid 'xxxxxxxxx'
