I am trying to understand this behavior.... I have connected the YUN to my network. I ran the "WiFi Status" example to check/confirm it is connected to "MYNETWORK"
From the Serial Monitor
Current WiFi configuration
SSID: MYNETWORK
Mode: Client
Signal: 60%
Encryption method: WPA2 PSK (NONE)
Interface name: wlan0
Active for: 1 minutes
IP address: 192.168.30.207/255.255.255.0
MAC address: B4:21:8A:F0:40:DE
RX/TX: 75/9 KBs
However when I type in the address into a browser (on the same network) it does not always connect. i.e. it appears to connect intermittently.
Note: In all cases the "WiFi Status" example does report a successful connection. However I can rarely connect to the device via a browser. I also rarely see the connection when I go to "tools > serial monitor"....
I suspected from reading other posts that this might be because the signal strength hovers between 50 - 60%; but if so I cannot understand why the "WiFi Status" example works every time
Regards
Phil
