YunDiskSpaceExpander - Compile Errors
Arduino: 1.5.8 (Windows Vista), Board: "Arduino Yún"
sketch_oct29a.ino:9:19: error: variable or field 'debugProcess' declared void
sketch_oct29a.ino:9:19: error: 'Process' was not declared in this scope
YunDiskSpaceExpander.ino: In function 'void setup()':
YunDiskSpaceExpander.ino:30:6: error: redefinition of 'void setup()'
sketch_oct29a.ino:1:6: error: 'void setup()' previously defined here
YunDiskSpaceExpander.ino: In function 'void loop()':
YunDiskSpaceExpander.ino:60:6: error: redefinition of 'void loop()'
sketch_oct29a.ino:6:6: error: 'void loop()' previously defined here
Error compiling.
Has Anyone had this difficulty?
heggood:
Error compiling.
Please post your code, otherwise it is impossible to tell what you are doing wrong. Best guess is that you improperly mix the YunDiskSpaceExander.ino code with your own sketch (sketch_oct29a.ino), hence the redefinition and scope errors...
Ralf
