just after some help what im looking for is for a motion sensor to active "track 1 " and then for it to stop and play "track 2" upon a phone being picked up (so when a switch is lifted est )
but when track to is playing i dont want the motion of people to re trigger track 1
im really new to this anyone who can help id be greatly appreciate
below is the code iv started to write
// void setup() {
Serial.begin(9600); // start serial interface
pinMode (Sensor, INPUT);
pinMode (Switch, INPUT_PULLUP);
mp3.begin(9600);// start MP3-comunication at baud 9600
delay(500); //wait for init
Serial.println ("Mp3 Config Started ");
mp3.sendCommand(CMD_SEL_DEV, 0, 2);//select SD card
Serial.println("SD Card Selected");
Serial.println("Sensor Config.........");
delay(10000);//int
Serial.println("Sensor Config Completed ");
pinMode (Switch, INPUT);
// the loop function runs over and over again forever
if (digitalRead(Switch) == LOW) { ;// message to play when phone answered
mp3.play(1);
Serial.print ("RING");
else {
if (digitalRead (Switch) == HIGH){
Serial.println ("stoped");
mp3.stop();
Couple questions:
A) What kind of Arduino are you using for the YX5300 module?
B) What kind of motion sensor? WIth link to specs if possible?
C) Does this code work at all? I would assume not?
D) Is this a one time program till you reset the Arduino, or does it loop at some point?
Guessing some type of escape room prop here?
int Sensor = 12;
int LED = 3;
pinMode (LED, OUTPUT);
Serial.println("Waiting for motion");
int val = digitalRead(Sensor); //Read Pin as input
if((val > 0) && (flg==0))
digitalWrite(LED, HIGH);
Serial.println("Motion Detected");
flg = 1;
if(val == 0)
digitalWrite(LED, LOW);
Serial.println("NO Motion");
flg = 0;
PLEASE do not use an Arduino Nano for this. The Arduino Uno would be a much better choice. It shouldn't be a space issue as you don't need to "hide" the Arduino in the phone.
With the example sketch above, you should be on your way. All you need to do is add the other input (your phone switch) on the pin of your choice and change the output LED to your YX5300 Track 1 and then Track 2. I would think the easiest way to do this would be to reset the Arduino after every game to keep the background music/motion sensor from interfering.
We try not to entirely write the code for you here, but if you want to write it on your own we will do our best to guide you. We want you to learn the arduino code so you can understand the process.
Should you feel you need more help than that you can post into Jobs and Paid consultancy on this forum and they will help you for a modest fee. This program should be fairly easy to adapt from the example program above though IMHO. I would actually try to get the example program working on your Arduino and RCWL-0516 sensor first with an LED if you can get one and then go from there.
