YX6300 Burns When Sharing Power with Amplifier - Grounding Issue?
Hello everyone,
I’m experiencing an issue where my YX6300 keeps burning out when it shares power with both an amplifier and a development board (ESP32). Here’s a bit of context:
  • The ESP32 is powered by 5V from the development board, which also powers the YX6300.
  • The amplifier is powered by a 12V adapter and is connected to the audio output of the YX6300.
  • The problem arises when both the amplifier and the development board share the same power supply. As soon as they share a common ground, the YX6300 burns.
It seems like everything works fine when the amplifier and YX6300 are powered separately, but the YX6300 seems to fail whenever the ground is shared between the devices. I’m suspecting it could be related to grounding issues or voltage spikes caused by the high current draw from the amplifier, but I’m not entirely sure.
Has anyone faced a similar issue? Any suggestions on how to properly manage the power and ground setup to avoid damaging the YX6300?
Thanks in advance for your help!
Here is a schematic
The amplifier is a pam8610, and am using a ESp32 Wroom
Not enough information. Please read and follow the instructions in the "How to get the best out of this forum" post, linked at the head of every forum category.
Your schematic is impossible to follow, please redo it.
You might find this helpful when creating a schematic:
What is a YX6300?
Hi, @fryan22
Thanks for the diagram, but it needs to be clearer.
Please spread it out and use a ruler if possible.
Can you please post a link to data/specs of the YX6300?
Can you also post some images of your project?
So we can see your component layout.
Tom.... :smiley: :+1: :coffee: :australia:
Burns like 'smoke coming out' or like 'does not work anymore'?
Do you have schematics of the two devices?
Two series capacitors in L and R may work.
Plus directed to amplifier... or use ceramic cap without polarity...
Here is a improved schematic, The YX6300 and The amplifier are connected via audio jack 3mm
Smoke burn
https://amperkot.ru/static/3236/uploads/datasheets/YX6300%20Serial%20MP3%20Player%20v1.0%20Manual.pdf?srsltid=AfmBOoqtXOIeCkSqpKimZ2ktcWXStoUHkSS2x7AYL2TnKwTrPeyXc46X, You can find the schematic of YX6300 in the link send above or in the pdf
YX6300 Serial MP3 Player v1.0 Manual.pdf (543.3 KB)
Just to note when i share the same 12 V adapter for the amplifier and the Esp32 dev board the YX6300 burns. When they had different 12V adapter the YX6300 didn't burn
Hi, @fryan22
Thanks for the information.
A suggestion, do not use the ESP32 as a power supply.
Can you please post a link to data/specs of the DC-DC converter?
Might very well be a converter (buck-boost or cuk) that has plus going to minus...
@fryan22 : measure voltage from minus to minus on the converter. Should be 0V...
Uou can also follow the minus trace...
It should go from minus to minus without interruption. If not: then this converter cannot be used here...
I am using this Esp32 expansion board Wich am not sure on how it reduces the volage buck converter (switching regulator) or a linear voltage regulator. Am powering the YX6300 with section 7 pins which intake from the esp32 directly.
That looks like a linear regulator...
will it be the same solution if it was a linear volage regulator?
Noted
