Z parameters online
Hi All
I am not sure this is the good place to ask this question
Following picture shows the two port network to measure Z parameters
Is there any software or online calculator to have Z parameters when we changed the Resistor values. it is compulsory to change the resistor values
Please advise
Thanks in advanced
Hello PA3040
Take a search engine of your choice and ask the WWW for 'Z parameters calculator'.
Hi
Thanks for reply
I did it..... so I found only parameter calculator when change the impedance but I could not found the location change the resistor values
Please advice
I can't remember the difference between a resistance value and an impedance. The lectures on this were in the last millennium. :wink:
Your instructor probably expects you to do the math, and show it.
Yes but I need to check that answer's are correct
