I have a voltage divider measuring a car battery
Volts +-20k <> 10K - Ground with a ATtiny85 ADC connected to the junction of the 2 resistors. (with a 100nf cap on the input to the ADC to ground)
Everything works fine but I added a 5.1Volt Zener to stop any spikes and this is dragging /affecting the ADC reading down from 1023 for 15v (5v at the pin) down to 1014 for 15V.
If I remove the zener and just measure the voltage with a fluke scope it also affects the reading, i just tried a basic DVM and this doesn't affect the reading so I am assuming its a capacitive issue rather than the voltage being dragged down.
I've built two prototypes and both do the same.
Has anyone else had a similar issue, I did try searching but couldn't find any answers.
Where is the diagram - I saw it for a second then it disappeared
What I did see was no ground connection between the divider and the arduino
Edit : Oops it's back.
can only suggest that the zener is tripping in slightly "early". Although it is specified as 5.1 volts there is usually a +- tolerance of around 0.1 to 0.2 volts
I just took one of the Zener's I'm using and put it straight across my bench PSU and it limits dead on 5.1V so I'm happy I'm outside of the knee.
Also just having a poke around again, if I put 12volts into the circuit I would expect to see 4volts at the junction of the 2 resistors.
Without the Zener I see 4volts, but as soon at I put the Zener in circuit it drops to 3.1volts.
I also just swapped the resistors out for 1/2w type in case it was this.
The resistor values are too high, they are being affected by the current that the zener is taking close to the knee. Drop them from 20K to 200R and 10K to 100R.
I'll wil have a read and will have a play with your circuit.
Again thanks for taking the time to reply.
Grumpy_Mike
I thought about lower values but thought the values you suggest would draw 50ma which make be a little excess and generate heat.
Also I thought the sweet spot for ADC inputs was 10k?
Or am I wrong?
Yes you are wrong in this case. The value of 10K is a maximum not a optimal. Anything lower is just as good. The ammount of current will not cause you any problems with heat. If you want to fix the problem lower the absoloute value, if you don't want to solve the problem then why bother asking.
Zeners need a certain minimum current thru them before they will act to limit voltage spikes. My experience is that putting a zener on the wiper of something like a 10k pot may not limit the voltage on the wiper as I thought. Check the data sheet for your zener.
Grumpy_Mike:
what about 20k down to 2k
and
10k down to 1k?
Or would that have no impact on how this circuit behaves?
The lower you have the resistors the less affect the load from the zener has on the potential divider. So dropping them to that value will improve matters. You never know it might even cure it.
