Hello everyone
I am doing a circuit to read three different frequencies but in the code I can only make me read one of the frequencies how could I fix the interruptions so I read the other two frequencies? because what I see that performs is reading only the pin 2 and not the other how can you fix that?
Please post your code again, but this time correctly. In the IDE, press Ctrl-T, then copy the code into a new post using code tags so it looks likethis
I think that when you see your code properly indented, you will see one of the problems: your { and } do not match. Another useful way to spot these problems is to put the cursor next to a }. The matching { will be highlighted and vice versa (if there is a matching one).
int contador=0;
unsigned long LastConnectionTime=millis();
const unsigned long postingInterval1 = 1L * 1000L;
int Tiempo=0;
pinMode(2,(INPUT_PULLUP));
attachInterrupt(0,Zero_Cross,FALLING);
Serial.println(millis());
if (millis() - LastConnectionTime > postingInterval1){
Serial.print("Frecuencia 1: ");
Serial.print(contador/3);
Serial.print(" ");
Serial.println("Hz");
LastConnectionTime= millis();
contador=0;
pinMode(3,(INPUT_PULLUP));
Serial.print("Frecuencia 2: " );
Serial.print(" ");
contador=0;
pinMode(18,(INPUT_PULLUP));
Serial.print("Frecuencia 3: " );
Serial.print(" ");
contador=0;
delay(3000);
void Zero_Cross()
{contador ++;}
See my previous suggestion about using Ctrl-T. I guess you are trying to do the formatting/indentation by hand (on a phone?)
:o :o nop but I can usining ctrl -T it generates another sale in the browser help me i new
Do the CTRL-T in the IDE where you wrote your code.
NOT the browser.
Tom..
