I know zero ohm resistors have been discussed before, and I understand their purposes in manufacturing, but I can't quite find the answer I'm looking for.
I'll be making my own single sided, THT, PCBs with a desktop CNC machine.
There are one or two places where having a surface jumper would make routing simpler. (Most notably eliminating islands for GND fills.)
Is there any advantage (or good practice) to using a zero ohm resistor rather than eg the cut-off leg of any other THT component (R/C/D/etc) or hook-up wire?
(I can see a nominal advantage of using insulated hook-up wire if it's a long jumper, but if it's much less than 0.5", I find the insulation has melted before the solder ... and is it really worth it?)
Zero ohm resistors are usually used in high volume production.
To make a on board "jumper"
Component leads are not pure copper. In a low current application it will likely work fine, however in a higher current design it will cause a small voltage drop which may or may not be OK.
Depending on the size of the jumper you likely don't need to have it insulated. If you do need it insulated purchase some Teflon insulated wire on ebay, the teflon won't melt as soldering temperatures.
You can alos purchase silicone insulated wire on ebay but this wire has many many strands making it super flexible but a little clumsy for a jumper.
