I have made a binary clock, which works fine. With two buttons you can set the time, that also works fine. What doesn't work fine is the zeroing of the seconds at the end of the "set time" process.
I am using the "Arduino Time library" and I want the seconds to be 00 when you have set the time so you can set it precise to the second.
My approach was this:
//Set the seconds to zero
time_t seconds = t % 60;
t -= seconds;
//Finally set the selected time
setTime(t);
The variable "t" is the seconds since Jan 1 1970. First I tried Integer seconds but that didn't work either.
I hope I have made my problem understandable and you have some advice for me. :)
Tried it now. Didn't work.
I have thrown in some print lines and now I am really confused:
Serial.println(t);
int seconds = t % 60;
t -= seconds;
Serial.println(t);
setTime(t);
Serial.println(now());
Serial.println("----------");
It seems to add random seconds to the number. I hope this is my fault somewhere and not a bug in the library.
By the way, the number is so small because I have set the date to the 1. 1. 1970 since my clock doesn't need the date.
