Zigbee relay, output common opposed to +V
Good morning fine fellas. I've got a circuit where I'm using limit switches to stop a motor. I'm using the ground through the switch and as an "input" into the arduino. I'd like to add a zigbee relay switch where I could either push the button or trigger the relay remotely. How do I get the relay to output a ground signal opposed to +V? I could link to the specific zigbee relay I'm using; however, I've gotten my hand slapped to linking to outside pages....so I want to be respectful of the rules. Please let me know what I can do to help you, help me. Thank you!
Hand slapped for linking to data? Hope it was no me.
Links to datasheets are often needed. I don't know what a zigbee is but readibg specs works...
It was not you, you've always been extremely helpful @Railroader (thank you!). Zigbee is just a wireless protocol that allows you to control devices remotely (in this case relays). I don't have the datasheet, so I hope it's ok to link to the online retailer (Amazon). If not, I will promptly remove:
