Blackfin:
I don't think that's it. I'm (in theory) just checking step numbers from the Hall effect "sync" pulse.So to start debugging, can you try this code: it toggles the on-board LED on each SYNC event telling us the rising-edge interrupt from the Hall sensor is working.
- Sketch: zoetrope.ino
- Target: Mega2560
#define HALL_TO_OBJ0_DEGREES 20.0f //deg offset from Hall sensor rising edge to centre of first object
#define NUM_OBJECTS 12 //# number of objects
#define STEPS_PER_REV 3200 //# number of steps per revolution
#define DEGREES_PER_REV 360 //# degrees in a circle
#define LED_ON_DEGREES 10.0f //deg number of degrees LED is on for each object
#define TIME_STEP_DIV2 80ul //uS microseconds per toggle of step pin (steps/sec = 1 / (2 x E))
#define TIME_BUTTON_READ 50ul //mS milliseconds between button reads
#define ON HIGH //state LED on pin state
#define OFF LOW //state LED off pin state
uint16_t
grLED_ON_Steps[NUM_OBJECTS],
grLED_OFF_Steps[NUM_OBJECTS];
const uint8_t pinDebugLED = LED_BUILTIN;
const uint8_t ledPin = 2;
const uint8_t buttonPin = 68;
const uint8_t dirPin = 60;
const uint8_t enablePin = 23;
const uint8_t stepPin = 22;
const uint8_t hallPin = 18;
volatile uint16_t
cntLEDSync;
volatile bool
bSync = false;
uint8_t
objNum,
bLEDState,
swNow,
swLast,
motorPinState = LOW,
ledState = LOW;
bool
stateMotorPin = false,
bEnable = false;
pinMode( buttonPin, INPUT_PULLUP );
swLast = digitalRead( buttonPin );
pinMode( pinDebugLED, OUTPUT );
pinMode( ledPin, OUTPUT );
pinMode( stepPin, OUTPUT );
pinMode( dirPin, OUTPUT );
pinMode( enablePin, OUTPUT );
//set up on and off step tables for LED
for( uint8_t obj=0; obj<NUM_OBJECTS; obj++ )
float fNominalObjDegrees = HALL_TO_OBJ0_DEGREES + (obj * (float)DEGREES_PER_REV / (float)NUM_OBJECTS);
float fLED_ON_Degrees = fNominalObjDegrees - (LED_ON_DEGREES / 2.0);
float fLED_OFF_Degrees = fNominalObjDegrees + (LED_ON_DEGREES / 2.0);
grLED_ON_Steps[obj] = (uint16_t)(0.5 + (fLED_ON_Degrees * (float)STEPS_PER_REV / (float)DEGREES_PER_REV));
grLED_OFF_Steps[obj] = (uint16_t)(0.5 + (fLED_OFF_Degrees * (float)STEPS_PER_REV / (float)DEGREES_PER_REV));
}//for
- debug
- print tables to console for check
for( uint8_t i=0; i<NUM_OBJECTS; i++ )
Serial.print( "ON :" ); Serial.println( grLED_ON_Steps[i] );
Serial.print( "OFF :" ); Serial.println( grLED_OFF_Steps[i] );
//initial state
digitalWrite( enablePin, HIGH ); //motor driver disabled
bLEDState = OFF; //LED off
digitalWrite( ledPin, LOW );
stateMotorPin = false; //step pin low
digitalWrite( stepPin, LOW );
digitalWrite( dirPin, HIGH ); //dir pin high (default)
}//setup
ReadButton(); //check the button for change of state
motorStateMachine(); //process motor and LED state machine
}//loop
void ReadButton( void )
static uint32_t
timeButton = 0;
uint32_t
timeNow = millis();
//time for a button read?
if( (timeNow - timeButton) < TIME_BUTTON_READ )
return;
timeButton = timeNow;
//read the pin
swNow = digitalRead( buttonPin );
//if not the same as the last read, state has changed
if( swNow != swLast )
//save new value
swLast = swNow;
//if changed to low state...
if( swNow == LOW )
//toggle the enable flag
bEnable ^= true;
//if we're now enabled...
if( bEnable )
//enable the motor driver
digitalWrite( enablePin, LOW );
//force sync-up and enable the Hall sensor interrupt
bSync = false;
attachInterrupt( digitalPinToInterrupt( hallPin ), isrHall, RISING );
}//if
//we just disabled so:
//disable motor driver
//disconnect Hall interrupt
detachInterrupt( digitalPinToInterrupt( hallPin ) );
//turn off the LED
bLEDState = OFF;
//and set motor step pin low
}//else
}//if
}//if
}//ReadButton
void motorStateMachine( void )
static uint32_t
timeMotor = 0;
uint32_t
timeNow = micros();
//if not enabled, just return
if( !bEnable )
return;
//time for a pin toggle?
if( (timeNow - timeMotor) < TIME_STEP_DIV2 )
return;
timeMotor = timeNow;
//toggle the pin
stateMotorPin ^= HIGH;
digitalWrite( stepPin, stateMotorPin );
//if the Hall shows sync'd and the motor pin is now low...
if( bSync && stateMotorPin == LOW )
//bump the step counter
cntLEDSync++;
//is the LED on or off now?
switch( bLEDState )
case OFF:
//is now off; are we at the turn-on step #?
if( cntLEDSync == grLED_ON_Steps[objNum] )
//yes; turn on the LED
digitalWrite( ledPin, HIGH );
bLEDState = ON;
}//if
case ON:
//is on now; are we at the turn-off step #?
if( cntLEDSync == grLED_OFF_Steps[objNum] )
//no; turn off the LED
bLEDState = OFF;
//after an LED turns off, bump the object counter
objNum++;
//if we just turned off the last one...
if( objNum == NUM_OBJECTS )
//we can resync now by clearing the sync flag and re-enabling the Hall interrupt
//digitalWrite( pinDebugLED, LOW );
bSync = false;
}//if
}//if
}//switch
}//if
}//motorStateMachine
void isrHall( void )
static bool
bOBLEDState = false;
//we we get the rising edge of the Hall sensor we're sync'd
//first object to be lit
objNum = 0;
//counts to zero
cntLEDSync = 0;
//done with the interrupt now; disable it
//and show in SYNC to mainline
bSync = true;
bOBLEDState ^= true;
digitalWrite( pinDebugLED, bOBLEDState );
}//isrHall
The debug light just turned on permanently after i pressed the button to deactive the script and then pressed it again the led flashed correctly for a very brief time frame and now i'm getting very confused
