Hey guys,
I had posted about my google earth project, things are workin great on processing and the joystick.
Now my problem I couldn t figure out how to make my two digital buttons zoom in and out.
I found on the reference of processing the scale code, didn t work.
I ll post my code and u guys tell me what is wrong
thanks
Sonia
//Arduino*******
- Sample code to send multiple analog inputs to Processing
- from Arduino
int analogInput1 = 0;
int analogInput2 = 1;
int digitalInput3 = 2;
int digitalInput4 = 3;
int ledPin = 13;
int val1 = 0;
int val2 = 0;
int val3 = 0;
int val4 = 0;
// an identifier for each value
char label1 = 'A';
char label2 = 'B';
Serial.begin(9600); //setup the serial port
val1 = analogRead(analogInput1); //read pins ito variables
val2 = analogRead(analogInput2);
val3 = digitalRead(digitalInput3);
val4 = digitalRead(digitalInput4);
Serial.print (label1, BYTE);
Serial.print (val1, DEC);
Serial.print (10, BYTE);
Serial.print(label2, BYTE);
Serial.print (val2, DEC);
delay(300); // pause to prevent comm errors
if (val3 & val4 == HIGH) {
digitalWrite(ledPin, LOW);
}else{
digitalWrite(ledPin, HIGH);
delay(200);
delay(300);
//**************** PROCESSING****************
- Processing code to receive multiple analog sensor readings
- from Arduino
- Uses string buffers to hold values larger than 0-255 (byte size)
import processing.serial.*;
Serial port;
int val; //holds serial line data to send to parser
String bufA="";
String bufB=""; //buffer strings for each value
int inputFlag; // switches between sensor data for as many sensors as used
int val1; //global variables to hold the analog sensor values
int val2;
int val3;
int val4;
PImage b;
//float xCoordinate = 0;
//float yCoordinate = 0;
void setup(){
size(799,799);
port = new Serial(this,Serial.list()[0],9600); //open serial port
stroke(0);
strokeWeight(4);
b = loadImage("main.png");
void draw (){
if(port.available() > 0){
val = port.read();
serialEvent(val); // send the port.read data to the serial parser function
background(0);
image(b, (val1/3-700),(val2/3-500));
/* if(val3==390) {
image(b, (val1/3),(val2/3));
else {
//image(b, (val3/3-700),(val4/3-500));
//ellipse (val1/3, val2/3, 30, 30);
//smooth();
//line(20,40,80,40);
//print ("A = " );
//println ( val1 );
//print ("B = " );
//println ( val2 );
void serialEvent(int serial){
if(serial!=10) { // 10 is the line end sent from Arduino
if (serial=='A') { //check that buffer is at initial value
inputFlag = 1;
if (serial=='B') {
inputFlag = 2;
if (inputFlag == 1){ // fill data into buffer string
if (serial!='A') {
bufA += char(serial);
if (inputFlag == 2){
if (serial!='B') { // fill data into buffer string
bufB+= char(serial);
else {
val1 = int(bufA); // load data into variable from the buffer
bufA=""; //clear the buffer
if (inputFlag == 2) {
val2 = int(bufB); // load data into variable from the buffer
bufB=""; // clear the buffer
