I am planning to build a toy car using Arduino and two high torque 12 volts gear motors.
I am also planning to use Arduino motor shield to derive the motors.
Can I control the shield using the zumo robot motors library ?
Zumo motors PWM pins are 9 and 10 , and direction pins are 7 and 8.
motor shield PWM are 3 and 11, and direction pins to 12 and 13.
Thanks.
system
2
Without seeing a link to the library, your guess is as good as anyone else's.
It's hard to see why you need a library to set the direction and speed of a motor, though.
I want to use the code for the pixy pet camera project linked below in a another project with bigger motors,
