I'm trying to make a led bar that indicates the distance between two objects. I'm using a HC SR04 ultrasonic sensor and 74hc595 shift register for the 8 leds.
The ultrasonic sensor is tested and it works(it stores the distance to an integer). And the 74hc595 is working with the shiftout tutorial examples.
The problem is 7 of 8 leds are on and when I move the objects closer than 5cm the last lights up. In the serial monitor I only get distances less then 5 cm(5 cm is max dont know why)
this is my code I'm a beginner so it might be a stupid mistake
#include <NewPing.h>
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 13 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 4;
////Pin connected to DS of 74HC595
int dataPin = 7;
byte broj = B00000000;
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
//set pins to output so you can control the shift register
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
delay(50);
int cm = sonar.ping_cm(); // Send out the ping, get the results in centimeters.
Serial.print("Udaljenost: ");
Serial.print(cm); // Print the result (0 = outside the set distance range, no ping echo)
Serial.println("cm");
//LEDS
if (cm <=3 && cm>1){
broj = B11111111;}
else if(cm>100 || cm==0){
broj = B00000000;}
else if(75<cm && cm<=100){
broj = B00000001;}
else if(50<cm && cm<=75){
broj = B00000011;}
else if(30<cm && cm<=50){
broj = B00000111;}
else if (15<cm && cm<=30){
broj = B00001111;}
else if(10<cm && cm<=15){
broj = B00011111;}
else if(5<cm && cm<=10){
broj = B00111111;}
else if(3<cm && cm<=5){
broj = B01111111;}
shiftOut(dataPin, clockPin, MSBFIRST, broj);
digitalWrite(latchPin, HIGH);
delay(100);
digitalWrite(latchPin, LOW);
