BME688 returning 0
Having trouble with dashboard value returning 0. Uploaded Blink so my ESP board is working (blink component works). any help getting the dashboard to work would be appreciated. Here is the code I am using:
  Sketch generated by the Arduino IoT Cloud Thing "Cloud Blink"
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float temperature;
  bool led;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME680 bme; // I2C
//Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO,  BME_SCK);
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  pinMode(LED_BUILTIN, OUTPUT);
  ArduinoCloud.update();
  digitalWrite(LED_BUILTIN, led);
  temperature=bme.temperature;
/*Since Led is READ_WRITE variable, onLedChange() is
  executed every time a new value is received from IoT Cloud.
void onLedChange()  {
  Serial.print("Led status changed:");
  Serial.println(led);
  Since Temperature is READ_WRITE variable, onTemperatureChange() is
void onTemperatureChange()  {
  // Add your code here to act upon Temperature change
Hi @buz12. The reason the reading is always 0 is that your sketch is missing some essential code to initialize and read from the BME688.
You can study this example to learn how to use the "Adafruit_BME680" library:
Thanks! checked closely and I was able to get thing working!
You are welcome. I'm glad it is working now.
Regards,
Per
