HI
I'm trying to program an arm with 3 servos. The first 2 servos control the movement/position and the 3rd one is for a grabber.
I won't have my arduino until next week but I have to present some code before. Since this is my first project I would like to know if this code could work.
A better description:
-First I want to get the data from a computer via the serial connection.
-Then the two position servos move to the desired position.
-When in position the grabber servo grab an object
-Then a new position is provided and the arm is moved to the new position and the grabber release the object
-If there are no commands from the computer the arm wait in a special position
#include <Servo.h>
//Holds the servo ID
char bigChannel=0;
char smallChannel=1;
//switch for gripper
char i=0;
//These are the objects for each servo.
Servo servoBig
Servo servoSmall
Servo servoGripper
//This is the space that will hold data from the Serial port.
char serialChar=0;
//Attach servos to pins and give starting positions
void setup(){
servoBig.attach(2);
servoSmall.attach(3);
servoGripper.attach(4);
servoBig.write(90);
servoSmall.write(90);
servoGripper.write(0);
Serial.begin(9600); //Set up serial connection for 9600 bps.
Serial.write("Power On")
void loop()]{
while(Serial.available() >= 0){ //Wait for data on the serial port.
serialChar = Serial.read(); //Copy one byte from serial buffert
if(serialChar == bigChannel){ //Check to se if the character is the servo ID
while(Serial.available() >= 0); //wait for the second byte
servoBig.write(Serial.read()); //set the Big motor to the recived position
i=i+1;
else if(serialChar == smallChannel){
servoSmall.write(Serial.read());
i=i+1;
if(i == 2 ){ //gripper closes
delay(3000);
servoGripper.write(180);
else if (i == 4){ //gripper open
delay(3000)
i=0;
while(Serial.available() < 0){ //Arm to neutral position
if servoBig != 90;{
servoBig.write(90);
if servoSmall != 90; {
servosmall.write(90);
One more question: the position of the servos, do i calculate it from the movement divided by the time it move or could i just send an angle?
if(Serial.available() > 0){ //Wait for data on the serial port.
i=i+1;
else if(serialChar == smallChannel){ //Check to se if the character is the servo ID
servoSmall.write(Serial.read()); //set the small motor to the recived position
i=i+1;
How do you know which command is intended for which servo?
My intension is to first send a byte with the servo ID
char bigChannel=0;
and then check
It could, but it doesn't.
Think - you decide that there is at least one character to read, then read two of them.
One letter global variable names, especially the ubiquitous i, is not a good idea.
char bigChannel=0;
One for each of the three servos, huh?
I guess this could make more sense?
No. Determining that there is one byte to read, and then reading 2 is never a good idea.
Just be patient. You mentioned serial data and servos in the same post. Zoomkat will be along shortly to post code for you. Or, if you aren't patient, you could use the search field and figure out that you aren't the first person to try to read serial data, or to use that serial data to control a servo.
Thanks for all the feedback.
I have tried to think about what you said and here is my result:
#include <Servo.h>
char bigChannel=0;
char gripperChar=0;
Servo servoBig
Servo servoSmall
Servo servoGripper
char serialChar=0;
void setup(){
servoBig.attach(2);
servoBig.write(90);
Serial.begin(9600); //Set up serial connection for 9600 btp.
void loop()]{
if(Serial.available() > 1){ //Wait for data on the serial port.
if(serialChar == bigChannel){ //Check to see if the character is the servo ID
gripperChar=gripperChar+1; //tell the gripper one servo have been moved
else if(serialChar == smallChannel){ //Check to see if the character is the servo ID
if(gripperChar == 2 ){ //gripper closes if the other servos have made 2 moves
delay(3000); //wait for the arm to be in position
delay(2000); //wait for the gripper to make its move
else if (gripperChar == 4){ //gripper open when the other servos done another 2 moves
delay(3000)
delay(2000);
gripperChar=0; //resets the gripperChar so the gripper will close after the next two moves
else{ //Arm to neutral position if there is no data waiting
if servoBig != 90;{
servoBig.write(90);
What is sending the serial data? Is the data sent in binary form?
char bigChannel=0;
char gripperChar=0;
Is gripperChar really a servo ID? How is the Arduino supposed to distinguish between two servos with the same ID?
No. It does something if one of the other servos has made two moves or if each of the other servos has made a move. If you are going to have silly comments, you should make them correct.
delay(2000);
You must have the worlds slowest servos.
if servoBig != 90;{
servoBig.write(90);
Why are you nearly constantly setting these positions back to 90? Your arm will never accomplish anything.
It's polite to get your code to at least compile before you post it for review. You will need to make several changes before this compiles:
if servoBig != 90;{
servoBig.write(90);
Your code layout is all over the place and will make it hard to spot mistakes in your control structure. I suggest you get into the habit of putting each { and } on lines on their own with matching pairs indented by the same amount and the code between them indented one extra level.
Simple servo test code for controlling two servos, which could be expanded to three. Lots of different ways to code to do basically the same thing. myservo1.write(n1) could be used instead of myservo1.writeMicroseconds(n1) to use degrees instead of microseconds if desired. This code should allow you to test your hardware wiring.
// zoomkat 11-22-10 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1; // create servo object to control a servo
Servo myservo2;
myservo1.attach(6); //the pin for the servo control
myservo2.attach(7);
Serial.println("servo-test-21"); // so I can keep track of what is loaded
while (Serial.available()) {
delay(1);
if (Serial.available() >0) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
if (readString.length() >0) {
Serial.println(readString); //see what was received
// expect a string like 07002100 containing the two servo positions
servo1 = readString.substring(0, 4); //get the first four characters
servo2 = readString.substring(4, 8); //get the next four characters
Serial.println(servo1); //print to serial monitor to see results
Serial.println(servo2);
int n1; //declare as number
int n2;
int n1 = servo1.toInt();
int n2 = servo2.toInt();
/*char carray1[6]; //magic needed to convert string to a number
servo1.toCharArray(carray1, sizeof(carray1));
n1 = atoi(carray1);
char carray2[6];
servo2.toCharArray(carray2, sizeof(carray2));
n2 = atoi(carray2); */
myservo1.writeMicroseconds(n1); //set servo position
myservo2.writeMicroseconds(n2);
readString="";
Just a tip. You can download the Arduino software right now from this site (for free). Before your board arrives. Then you can get rid of the syntax errors from your code at least.
