I haven't seen it mentioned anywhare, but I would assume the Arduino Analog input can only read a positive voltage.
So what would be the best way to reverse the polarity on a analog signal from -5volts to 0 to a positive voltage of 0 to +5v so it can be read by an ADC?
I would search for it, but I am not sure what to search for, is there such a thing as an Analog flipflop? I feel I should know the answer to this, so I feel a bit silly asking the question. :-/
Thanks Tektro69, But I will loose a lot accuracy that way.
I think the Op-Amp is a better way to go to maintain accuracy and I won't need to do any internale scaling in the software.
Why do you think that then? You can always change the values if you want to change the range. With equal resistors you will get the same voltage range. Watch out for negative voltages and put a catcher diode on the input.
then wouldn't that make the voltage between 0 snd 2.5 volts?
Yes it would, sorry I was having a bad day.
You have to make the pull up larger than the pull down to extend the range over half. It should be possible to easily get a 4v range if not a bit bigger, keep the pull down to something like 470R and see where you get.
If the resistors are equal then you will get a value of 0V to the Arduino's input when you have -5V in.
Therefore when you change this to 0V there will be only +2.5V on the analogue input, as you rightly pointed out.
Any less in the bottom bit and you will have a negative input on the Arduino's analogue input with the full -5V input.
However what you could do is to change the Vref to 1.1V and get the full digitisation range with a smaller swing. Then you make the bottom resistor bigger.
Ok, I understand the concept here, but would anyone want to explain to me what is actually happening with this divider on an elementury level? I like to understand the "why" instead of just "because".
Voltage divider is simple :
Let have two voltages : Vminus and Vplus, if I understand you have them as -5V and +5V. Mark resistors as Ra and Rb.
A current through divider is I = (Vplus - Vminus) / (Ra + Rb)
It creates a voltage drop on Ra resistor : Vdrop = I * Ra
So you have on analog input pin : Vminus + I * Ra
Practical example, with your values -5V and +5V and let say both 10 kOhm resistors :
I = (5 - - 5) / (10 + 10) = 10 / 20 = 0.5mA
Voltage on resistor V = 0.5mA * 10 kOhm = 5V
Added to -5V you have -5 + 5 = 0 V
Let your input voltage is 0V :
I = (5 - 0) / (10 + 10) kOhm = 0.25mA
On resistor V = 0.25 mA * 10 kOhm = 2.5V
Added to OV : 0 + 2.5 = 2.5V
Practical remark : to have stable results, +5V supply must be stabilized nad 2.5V reference voltage (TL 431, LM336 ...) is recomended for full range conversion result.
