Cactusface:
Hi A.R.TY,
That backpack has the same component layout as mine, the printing is slighty different,
Mel,
While we don't know for sure which board A.R.Ty has since we haven't see an actual photo
of the board he is using, the one in the photo we have seen is slightly different from yours.
The layout of the components on the left of the PCF8574 are different.
You can see the placing of the transistor and jumper is different and also
the location of the LED.
A.R.Ty,
I think at this point, there will need be a careful visual done on the board
to follow all the traces to create the schematic of the board,
or at least figure which where each of Px pins on the PCF8574 are connected on the LCD.
Check a datasheet for the PCF8574 pinout but the
the Px pins are: P0=4, P1=5, P2=6, P3=7, P4=9, P5=10, P6=11, P7=12
It only takes a minute or so. An ohm meter can be helpful if the traces are not fully visible.
Once we know which PCF output pins are connected to which LCD pins,
coming up with the constructor is very easy.
The jumper should be easy to tell what it does, just follow the traces
and see what it is connected to.
Normally on most of these boards the jumper breaks the connected to the
transistor base. i.e. it will force the backlight to be off.
--- bill
