hello
first thank you alot kg4wsv and dfraser and zitron for putting up this code and libraries, this saved me.
i'm having the same kind of problems than you btmcmahan, exept that i still don't have any characters displayed. i've managed to burn a new ascii table( i was thinking that would be the most difficult) i'm using an arduino mini with the atmel328, the max7456 board from sparkfun , already read every thread about it( arduino cc forum and sparkfun forums) my wirings are:
arduino==== max7456
pin10 ====cs
pin11====dout
pin12====din
pin13====sck
pin2====vsync
+5v to +5v and gnd to gnd i've tried rst to +5v with a resistor and without
i'm using the last libraries that you kg4wsv have posted here, the sketch that you have posted here, i've included the line for the pal mode and corrected the first line as i've a new ascii table.
i have no input
and the problem is my display is still black, flashing white every second( almost) and flashing blue every 10secs or so cause my tv is a kind of hightech thing and tries to understand the signal( normally she can switch on the right entry and to the right signal type(ntsc /pal/secam)
so i've opened up the lib and as i'm pretty new to c++ i was wondering what was the " #if ARDUINO > 22" at the begining? where did you specify the pin n° for the arduino it seems that it's in an integrer but i can't found it...? and in the comments of the sketch you speak about the 8mhz of the arduino, mine is 16mhz do this can cause problems for communication with the max7456? and how can i write something in the middle of the screen? i think maybe the writings are some kind of "off the screen" cause it's doing the same when my computer tries to send a signal with a wrong frequency/resolution.
i know there is a lot of questions and please excuse my bad english.
i hope thoses questions can lead to the solution.
