[Q]: Tailoring the Due to Eclipse..
Still got 135 errors but all in USBcore.cpp
But Im able to build I got a libArduinoDueCore.a in my Release folder.
But I think the linker script isnt working for de MyProject
If I build your example I only get a main.o and a syscalls_sam3.o in my release folder..
EDIT
All the errors about USBcore.ccp are could not be resolved errors like:
Field 'UOTGHS_DEVCTRL' could not be resolved
Clean your ArduinoDueCore project :
  • clean ArduinoDueCore project
  • in the "Problems" tab right click on the root errors node, when the popup is open, click on "Delete" item. You can do the same for warnings.
  • bluid ArduinoDueCore.
Build MyProject.
Nassa.
No more errors or warnings!
But nothing in the release folder of myprojects..
I'll try to make a new project
EDIT
Got a .map file in my release folder but not a hex..
Hi Nassa ,
I played a bit with arduino uno elipse integration and looking at your guide I don't see the define which says which board is beeng compiled.
In case of Aduino due it is -DARDUINO=151.
Zad
Hi Nassa,
if I well understood ,to use the PROGRAMMING port with bossac you shall use one of the two procedures reported in the AduinoDue main page. that are :
  1. pressing the erase button on the arduino while running bossac
  2. Open the serial port without bossac, which activates the Erase and Reset sequence , and then launch the bossac .
Unfortunately I can only use the bossac via command line while pressing the erase button, if I do that using the eclipse external tool it doesn't works.
I'll do a script which opens the port ,closes it and then run the bossac.
By the way, to understand how the bossac is actually run by the arduino IDE , I substituted the original bossac with a simple shell script and run the upload procedure on the IDE.
Here the code :
echo $@ >/Applications/Arduino-due.app/Contents/Resources/Java/hardware/tools/bossac.arg
/Applications/Arduino-due.app/Contents/Resources/Java/hardware/tools/bossac.orig $@
Zad
I've got these error's now in myProject
These error's keep coming back I defined -L but it seems i't cant find the library or something if I build like 3 times in a row it completes but only shows the .o files
undefined reference to `digitalWrite'	main.cpp	/MyProject/src	 	C/C++ Problem
undefined reference to `USBDevice'	main.cpp	/MyProject/src	 	C/C++ Problem
undefined reference to `USBDevice_::attach()'	main.cpp	/MyProject/src	 	C/C++ Problem
undefined reference to `pinMode'	main.cpp	/MyProject/src	 	C/C++ Problem
undefined reference to `delay'	main.cpp	/MyProject/src	 	C/C++ Problem
undefined reference to `init'	main.cpp	/MyProject/src	 	C/C++ Problem
EDIT:
Fixed it now I got a elf file!
I resolved the problem with bossac in Eclipse , for some reasons ,in my case , if as first parameter in the arguments list is placed --port=tty.usbmodemfd121 the command ends with :
No device found on tty.usbmodemfd121 also when I press the erase button.
if --port is used as seconds parameter, using the erase button, eclipse and bossac run like a charm.
Erase flash
Write 9556 bytes to flash
[                              ] 0% (0/38 pages)
[=======                       ] 26% (10/38 pages)
[===============               ] 52% (20/38 pages)
[=======================       ] 78% (30/38 pages)
[==============================] 100% (38/38 pages)
Verify 9556 bytes of flash
[                              ] 0% (0/38 pages)
Verify successful
Set boot flash true
CPU reset.
I tried to open the programming port and then to launch bossac , but I have still the uploading problem.
For the moment it works fine with the erase button.
@joppuh123:
It seems your core library doesn't contain wiring_digital.c , do you have it in yours library files? it is contained inside variants/arduino_due_x
Cheers
zad
I do got a wiring_digital.c I have it in /src/core not in variants...
I got an elf file I was able to upload the elf file but the led doesn't blink...
Is it because I dont got the -DARDUINO=151 define.
Also the library does build but is was browsing the source file and an error poped up.
Field 'PIO_OSR' could not be resolved	wiring_digital.c	/ArduinoDueCore/src/core	line 62	Semantic Error
Getting an stm32 working in eclipse is easier than this!
HI All,
finally I did it !
I'm able to build the blinky led program and upload it using the external tool all done in eclipse.
The last tiny problem is the bossac manually operation...
I've followed a different path from the one proposed by Nassa, obviously is due to him if I'm at this stage.
I will soon post how I did it .
Cheers
Zad
Congrats I'm excited to hear how you did it!
Hi Zad,
What file .h .c .cpp the ARDUINO define is it used, I don't found it ?
I resolved my Bossac problem last night in this topic : http://arduino.cc/forum/index.php/topic,141628.0.html
I used the terminal to erase the memory of the MCU :
  • I open the terminal from eclipse.
  • I close the terminal from eslipse.
  • I launch the Bossac command line from eclipse.
The software upload running...
Thanks very much Zad.
Nassa.
Hi ,
Here what I did :
Arduino Ide version 1.5.1
Note Path character separator differs from the windows system, I build it on OSX
## ArduinoDueCoreLibrary
Make New C++ Project -> Arm Cross Target Library -> Sourcery G++ lite.
Import... -> file System-> /Contents/Resources/Java/hardware/arduino/sam/cores/arduino all files + USB directory
import... -> file System-> /Contents/Resources/Java/hardware/arduino/sam all content of directory variants/
Note that in the last import there is also a precompiled library : libsam_sam3x8e_gcc_rel.a
Project Properties-> C/C++ Build:
->Environment : add PATH Variable with Append option enabled and the following vaulue /Contents/Resources/Java/hardware/tools/g++_arm_none_eabi/bin/
->Settings->Target Processor= cortex-m3 ; Thumb enabled
->Settings->Debug = None
->Settings->Assembler GCC-> Preprocessor:
Use PreProcessor checked
-defined symbols (I defined those also here , but I think it can be skipped)
printf=iprintf
F_CPU=84000000L
ARDUINO=151
__SAM3X8E__
USB_PID=0x003e
USB_VID=0x2341
USBCON
It is possible to copy the above lines and paste directly in the eclipse "Defined Symbols" area.
->Settings->Assembler GCC C->Warnings: -Wall
->Settings->Assembler GCC C->Misc : I removed the Assembler Listing lines
->Settings->Compiler GCC C-> Preprocessor : the same of Assembler
->Settings->Compiler GCC C-> Directories :
/Applications/Arduino-due.app/Contents/Resources/Java/hardware/arduino/sam/system/libsam/
"${workspace_loc:/${ProjName}/USB}"
"${workspace_loc:/${ProjName}}"
"${workspace_loc:/${ProjName}/variants/arduino_due_x}"
/Applications/Arduino-due.app/Contents/Resources/Java/hardware/arduino/sam/system/CMSIS/CMSIS/Include/
/Applications/Arduino-due.app/Contents/Resources/Java/hardware/arduino/sam/system/CMSIS/Device/ATMEL/
Also the above code can be copied and pasted directly inside the include path area, note that the absolute paths fit in my case , you have to tailor those in respect of your situation.
->Settings->Compiler GCC C-> Optimization
Level : -Os
Function sections checked Data sections checked
->Settings->Compiler GCC C->Warnings: -Wall
->Settings->Compiler GCC C->Misc :
Optional : -c --param max-inline-insns-single=500 -nostdlib
Language Standard: Compiler Default
->Settings->Compiler GCC C++-> Every things like GCC C Compiler except for :
Do not use exception: checked
Do not use RTTI : checked
Then you can build the arduinoDueCore libraries.
## ArduinoDue Blink example
Make New C++ Project -> Arm Cross Target Application -> Sourcery G++ lite.
Create a cpp file like the following one:
 * Blinker.cpp
 *  Created on: Jan 9, 2013
 *      Author: zad
#include <Arduino.h>
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
->Settings->Additional Tools:
Create FlashImage : Checked
Create Extended Listings: Checked
Print Size: Checked
The same used in the library
->Settings->Compiler GCC C-> Preprocessor : the same used in library
"${workspace_loc:/ArduinoDueLib/USB}"
"${workspace_loc:/ArduinoDueLib}"
"${workspace_loc:/ArduinoDueLib/variants/arduino_due_x}"
->Settings->Compiler GCC C-> Optimization:the same used in library
->Settings->Compiler GCC C->Warnings: the same used in library
->Settings->Compiler GCC C->Misc : the same used in library
->Settings->Compiler GCC C++-> the same used in library except for the directories :
->Settings->Linker GCC C++
Command line pattern:
${COMMAND} ${FLAGS} ${OUTPUT_FLAG}  ${OUTPUT_PREFIX}${OUTPUT} -Wl,--start-group ${INPUTS} -Wl,--end-group[\code]
->Settings->Linker GCC C++->General
Script File:/Applications/Arduino-due.app/Contents/Resources/Java/hardware/arduino/sam/variants/arduino_due_x/linker_scripts/gcc/flash.ld
->Settings->Linker GCC C++->Libraries
libraries area:
[code]
ArduinoDueLib
sam_sam3x8e_gcc_rel
the first entry above is the output of the arduinoDueCore libraries there you need to wire the output without the lib part and .a suffix , i.e. libArduinoDueLib.a becomes ArduinoDueLib
libraries search paths:
"${workspace_loc:/ArduinoDueLib/Debug}"
In my case the output of the lib was in Debug others may have Release it depends on the C++ project and build conf.
->Settings->Linker GCC C++->Misc
Other object area add :
"${workspace_loc:/ArduinoDueLib/Debug/syscalls_sam3.o}"
Other Flags:
-lm -lgcc  -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols
For
->Settings->Create Flash
->Settings->Create Listing
leave defaults
->Settings->Print->General
I preferred the Barkeley format and Show total checked;
->Settings-> Build Steps Tab and add a post-build command:
/Applications/Arduino-due.app/Contents/Resources/Java/hardware/tools/g++_arm_none_eabi/bin/arm-none-eabi-objcopy -O binary ${ProjName}.elf ${ProjName}.bin
Then you can build the Blink program the program elf shall be about 9548bytes
######## Extern Tool Configurations:
new launch conf chose a name , mine was ARduino_due
Main-> Location:
Main-> Arguments:
-U false
-e
-w
-v
-b
"${workspace_loc:}/${project_name:}/Debug/${project_name:}.bin"
 -R
Build
I have disable build before launch
Finally you can run , but before you need to press the erase button or open and close a the serial via eclipse as described by Nassa :http://arduino.cc/forum/index.php/topic,141628.0.html
Cheers
Zad[/code]
Very good Job Zad,
I was just doing the same job ...
The sketch compilation is :
C:\ARM\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin\arm-none-eabi-g++
-c -g -Os -w
-ffunction-sections
-fdata-sections
-nostdlib
-fno-rtti
-fno-exceptions
-Dprintf=iprintf
-mcpu=cortex-m3
-DF_CPU=84000000L
-DARDUINO=151
-D__SAM3X8E__
-mthumb
-DUSB_PID=0x003e
-DUSB_VID=0x2341
-DUSBCON
-IC:\ARM\arduino-1.5.1r2\hardware\arduino\sam\system/libsam
-IC:\ARM\arduino-1.5.1r2\hardware\arduino\sam\system/CMSIS/CMSIS/Include/
-IC:\ARM\arduino-1.5.1r2\hardware\arduino\sam\system/CMSIS/Device/ATMEL/
-IC:\ARM\arduino-1.5.1r2\hardware\arduino\sam\cores\arduino
-IC:\ARM\arduino-1.5.1r2\hardware\arduino\sam\variants\arduino_due_x Blink.cpp -o Blink.cpp.o
The Arduino core compilation for C file
command:C:\ARM\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin\arm-none-eabi-gcc
-c -g -Os -w
-ffunction-sections
-fdata-sections
-nostdlib
-Dprintf=iprintf
-mcpu=cortex-m3
-DF_CPU=84000000L
-DARDUINO=151
-D__SAM3X8E__
-mthumb
-DUSB_PID=0x003e
-DUSB_VID=0x2341
-DUSBCON
C:\ARM\arduino-1.5.1r2\hardware\arduino\sam\cores\arduino\cortex_handlers.c -o cortex_handlers.c.o
The Arduino core compilation for C++ file :
command:C:\ARM\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin\arm-none-eabi-g++
-c -g -Os -w
-ffunction-sections
-fdata-sections
-nostdlib
-fno-rtti
-fno-exceptions
-Dprintf=iprintf
-mcpu=cortex-m3
-DF_CPU=84000000L
-DARDUINO=151
-D__SAM3X8E__
-mthumb
-DUSB_PID=0x003e
-DUSB_VID=0x2341
-DUSBCON
C:\ARM\arduino-1.5.1r2\hardware\arduino\sam\cores\arduino\cxxabi-compat.cpp -o cxxabi-compat.cpp.o
Lib building :
command:C:\ARM\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin\arm-none-eabi-ar
rcs
C:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp/core.a
cortex_handlers.c.o
Link :
-Os
-Wl,--gc-sections
-mcpu=cortex-m3
-TC:\ARM\arduino-1.5.1r2\hardware\arduino\sam\variants\arduino_due_x/linker_scripts/gcc/flash.ld
-Wl,-Map,C:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp/Blink.cpp.map
-o C:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp/Blink.cpp.elf
-LC:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp
-lm
-lgcc
-mthumb
-Wl,--cref
-Wl,--gc-sections
-Wl,--warn-common
-Wl,--start-group
C:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp/syscalls_sam3.c.o
Blink.cpp.o
C:\ARM\arduino-1.5.1r2\hardware\arduino\sam\variants\arduino_due_x/libsam_sam3x8e_gcc_rel.a
C:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp/core.a -Wl,--end-group
Binary file :
command:C:\ARM\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin\arm-none-eabi-objcopy
-O binary
C:\Users\XXX\AppData\Local\Temp\build3490308093235427635.tmp/Blink.cpp.bin
This is a command line used by ArduinoDue IDE.
Nassa.
Next challenge is integrating additional libraries like Servo and company.
Cheers
Zad
Nassarane:
Hi Zad,
Nassa.
About the bossac problem , It seems that in the Arduino due main page, the figure displaying the arduino shows a wrong indication of the native port.
I've tried to open and close the programming port, the one near the power jack , using the Target Terminal plugin without be able to run the bossac. it works instead when the serial port is opened and closed at a rate of 1200, which shall be the behavior of the native port http://arduino.cc/en/Guide/ArduinoDue .
BTW to upload the arduinoDue without have to press the erase button I've made a little java program wich uses RXTX library. This because I don't know how automatically use the "Target Terminal Management" plugin in eclipse, if someone knows how to open and close a serial connection in eclipse using external tool configuration please let me know.
So using this little program which open the serial at 1200 , I've created a run configuration, with two external tool configurations:
First download the file in attach
and expand it inside the AduinoDueLibrary
A new directory called tools is expanded.
Create a new external tool : Run->External Tool -> External tool configurations...
Create a new program and name it as you wish , mine is ArduinoDue_eraseViaSerial
Then in Location: /usr/bin/java (Put your specific path to java)
in Working directory : the path to the expanded zip : ${workspace_loc:/ArduinoDueLib/tools/}
in Args:
-jar
${workspace_loc:/ArduinoDueLib/tools/openSerial_fat.jar}
usbmodemfd121
In place of usbmodemfd121 the specific name of the arduino port shall be used.
in the Build tab uncheck "Build before launch"
then Save.
in Eclipse menu : Run -> Run Configurations
Create a new launch groups and choose a name , I used Arduino_upload.
In the Launches tab press add and select Program->"NameYouGaveToTheReaseProcedure" and as Post Launch action select "wait until terminated"
Then add the other Program , which is the one that uses bossac.
In Common Tab is possible to show the run configuration in the preferite, I have checked it.
Save it .
It shall appear on the eclipse play icon , pushing the down arrow near it.
The java program has been tested in a OSX 1.6.0 intel 64 bit, let me know if it works also in windows, in the zip are contained dll for win32 bit , libraries and dll has been downloaded from her
http://rxtx.qbang.org/pub/rxtx/rxtx-2.1-7-bins/
Unfortunately aren't provided 64 bit dll library , you can search them on the net if you need.
Cheers
Zad
tools.zip (223 KB)
zad80:
Cheers
Zad
Library Used successfully , just import from filesystem , choose the library you want to import and check the "create top level directory" just to keep the project clean.
Add the new directory inside the include
"${workspace_loc:/${ProjName}/uOLED}"
and compile.
I've try the uOLED library and here the result in attach.
Ok the image quality isn't so good, I'm sorry.
Cheers
Zad
Hi Zad,
It is not necessary to use a JAVA program to request the flash erasing.
Here's a batch for Windows to send erase flash request and upload program :
@mode com5:1200,n,8,1
@sleep 1
@C:\arduino-1.5.1r2\hardware\tools\bossac.exe %*
Copy this MS-DOS program in the "upload.bat" file and replace bossac.exe by upload.bat in your Eclipse External Tools.
(Here, it is the com5 is used, change the value and the bossac path if necessary)
You can find the equivalent for OSX / Linux.
Nassa.
Oops : you can use this simplified command line :
@mode com5:1200
@sleep 1
Nassa.
Not necessary to set your com port with this script :
@mode %2:1200
@sleep 1
Nassa.
