Thank you for the fast answer...
did i get it right that i have to create a index and make there the definition about the letters?
now in the demofile is it a (i) called index
char i;
is making this index ??
and:
for(i=font.Font_FirstChar; i<= font.Font_LastChar; i++)
is putting life into the index.
Now i have a font that is called: f15x22.h made by H. Reddmann
looks like this:
struct FONT {
// common shared fields
uint16_t font_Size_in_Bytes_over_all_included_Size_it_self;
uint8_t font_Width_in_Pixel_for_fixed_drawing;
uint8_t font_Height_in_Pixel_for_all_Characters;
uint8_t font_Bits_per_Pixels;
// if MSB are set then font is a compressed font
uint8_t font_First_Char;
uint8_t font_Last_Char;
uint8_t font_Char_Widths[font_Last_Char - font_First_Char +1];
// for each character the separate width in pixels,
// characters < 128 have an implicit virtual right empty row
// characters with font_Char_Widths[] == 0 are undefined
// if compressed font then additional fields
uint8_t font_Byte_Padding;
// each Char in the table are aligned in size to this value
uint8_t font_RLE_Table[3];
// Run Length Encoding Table for compression
uint8_t font_Char_Size_in_Bytes[font_Last_Char - font_First_Char +1];
// for each char the size in (bytes / font_Byte_Padding) are stored,
// this get us the table to seek to the right beginning of each char
// in the font_data[].
// for compressed and uncompressed fonts
uint8_t font_data[];
// bit field of all characters
#include <inttypes.h>
#include <avr/pgmspace.h>
#ifndef f15x22_H
#define f15x22_H
#define f15x22_WIDTH 15
#define f15x22_HEIGHT 22
static uint8_t attribute ((progmem)) f15x22[] = {
0x07, 0xDE, 0x0F, 0x16, 0x81, 0x18, 0x7E,
0x09, 0x0B, 0x0B, 0x0A, 0x08, 0x08, 0x08, 0x09, 0x07, 0x02, 0x05, 0x0B, 0x08, 0x0E, 0x0A, 0x02,
0x05, 0x05, 0x06, 0x0A, 0x02, 0x05, 0x02, 0x05, 0x08, 0x05, 0x08, 0x08, 0x09, 0x08, 0x08, 0x08,
0x08, 0x08, 0x02, 0x02, 0x08, 0x08, 0x08, 0x08, 0x0E, 0x0B, 0x09, 0x0A, 0x0A, 0x09, 0x09, 0x0B,
0x0A, 0x02, 0x07, 0x0A, 0x08, 0x0D, 0x0A, 0x0B, 0x09, 0x0B, 0x0B, 0x09, 0x0A, 0x0A, 0x0B, 0x0D,
0x0B, 0x0C, 0x0A, 0x04, 0x05, 0x04, 0x07, 0x0A, 0x03, 0x08, 0x08, 0x07, 0x08, 0x08, 0x06, 0x08,
0x08, 0x02, 0x03, 0x07, 0x02, 0x0C, 0x08, 0x08, 0x08, 0x08, 0x05, 0x07, 0x05, 0x08, 0x09, 0x0D,
0x08, 0x09, 0x08, 0x06, 0x02, 0x06, 0x08,
0x01, 0x02, 0x03, 0x07,
0x1B, 0x1A, 0x1A, 0x15, 0x18, 0x12, 0x12, 0x14, 0x09, 0x06, 0x09, 0x1B, 0x17, 0x27, 0x18, 0x04,
0x0B, 0x0B, 0x0D, 0x13, 0x05, 0x0A, 0x05, 0x09, 0x11, 0x0A, 0x14, 0x14, 0x14, 0x14, 0x14, 0x12,
0x16, 0x14, 0x05, 0x05, 0x12, 0x12, 0x12, 0x11, 0x27, 0x18, 0x17, 0x16, 0x14, 0x19, 0x13, 0x1B,
0x12, 0x04, 0x0E, 0x15, 0x0F, 0x18, 0x14, 0x16, 0x14, 0x18, 0x1A, 0x1A, 0x12, 0x12, 0x15, 0x18,
0x18, 0x17, 0x19, 0x09, 0x0A, 0x09, 0x0E, 0x10, 0x05, 0x16, 0x11, 0x10, 0x12, 0x15, 0x0B, 0x12,
0x10, 0x06, 0x07, 0x10, 0x04, 0x18, 0x11, 0x11, 0x11, 0x11, 0x0B, 0x14, 0x0B, 0x11, 0x11, 0x18,
0x15, 0x13, 0x18, 0x0E, 0x04, 0x0E, 0x0F,
0x0B, 0xC1, 0x4D, 0x9F, 0x74, 0x73, 0x72, 0x08, 0xC2, 0x1C, 0x2C, 0x82, 0xF2, 0x2A, 0x10, 0x14,
0xBA, 0x0A, 0x04, 0x85, 0xAE, 0x02, 0x41, 0xA1, 0x43, 0x97, 0x2A, 0x5B, 0xBA, 0xC5, 0x9E, 0x72,
0x4A, 0xD5, 0x3B, 0x14, 0xB6, 0x3A, 0xA1, 0xEB, 0x04, 0x5B, 0x1D, 0xAA, 0x77, 0xA8, 0x74, 0x6E,
0x82, 0xBD, 0x49, 0x15, 0x00, 0xFB, 0xA4, 0x9B, 0x93, 0x67, 0xA5, 0xF0, 0x62, 0xA1, 0xE8, 0x84,
0xAE, 0x13, 0xBA, 0x4E, 0xA8, 0x50, 0x78, 0xB1, 0xD0, 0x78, 0x9E, 0x6E, 0x4E, 0xFA, 0x00, 0xBA,
0x3B, 0xFD, 0x4A, 0x27, 0x59, 0xE8, 0xD6, 0x4D, 0xEA, 0x26, 0x55, 0xE8, 0x56, 0xA1, 0x93, 0x3A,
0xFC, 0xC3, 0xDD, 0x01, 0x0B, 0x65, 0x2E, 0x4D, 0x63, 0x0F, 0x45, 0x53, 0x75, 0x42, 0x53, 0x75,
0x42, 0x53, 0x71, 0x29, 0x8A, 0xAA, 0x4B, 0x71, 0x73, 0xCA, 0x2D, 0x00, 0xCB, 0xA7, 0xE6, 0x5D,
0x0A, 0x2B, 0x9E, 0xD0, 0x75, 0x42, 0xD7, 0xA1, 0xB0, 0xE2, 0xA1, 0x79, 0xB7, 0x4B, 0xBB, 0x97,
0xE2, 0xE6, 0xD0, 0xC5, 0x9B, 0xD4, 0x4D, 0xEA, 0xD0, 0xA5, 0x4B, 0x71, 0x73, 0xC2, 0x4D, 0x01,
0xCA, 0xED, 0xE1, 0x9F, 0x37, 0xA5, 0x13, 0x97, 0xCA, 0xF2, 0xF0, 0x0A, 0x1D, 0x4C, 0x55, 0xDD,
0x62, 0x6F, 0x32, 0x15, 0xDB, 0xB6, 0x6D, 0xDB, 0xB6, 0x6D, 0xDB, 0xB6, 0x01, 0xBA, 0x99, 0xEE,
0x66, 0x2A, 0x00, 0x72, 0x37, 0xB9, 0xDB, 0x36, 0xC1, 0xDD, 0xE4, 0x6E, 0xAB, 0xBA, 0xA1, 0x2A,
0x3C, 0xA1, 0x38, 0xA7, 0x7B, 0x39, 0xD1, 0x09, 0x46, 0xD5, 0x0D, 0x55, 0xE1, 0x09, 0xC5, 0x39,
0xDD, 0xCB, 0x89, 0x4E, 0x30, 0xAA, 0x0E, 0x8A, 0xA9, 0x74, 0xB2, 0x05, 0x0F, 0x8E, 0x05, 0xAF,
0x42, 0x95, 0x4A, 0xBF, 0xA9, 0x54, 0xA9, 0xD0, 0xC1, 0xFA, 0x54, 0xC1, 0x95, 0x00, 0x8A, 0xB9,
0x0E, 0xB6, 0xE2, 0x55, 0xA8, 0x3C, 0x54, 0x68, 0xBC, 0x54, 0x28, 0x3C, 0xC1, 0x86, 0x27, 0x99,
0xF0, 0x26, 0x18, 0xE6, 0x24, 0xC3, 0x9E, 0x60, 0x54, 0xE8, 0xE2, 0x54, 0xE8, 0x60, 0x55, 0xE8,
0xAC, 0xD8, 0x43, 0x67, 0x2A, 0x53, 0xCC, 0x4D, 0xF6, 0xE4, 0x54, 0xDE, 0xA9, 0x74, 0x95, 0x95,
0xAE, 0x32, 0x85, 0xCE, 0x8E, 0xD1, 0xC5, 0x94, 0xBB, 0xA9, 0xF0, 0x36, 0x2A, 0x72, 0x37, 0xB9,
0x1B, 0xCB, 0xA7, 0xDC, 0x9E, 0x3B, 0x57, 0xF0, 0x24, 0x8B, 0x9B, 0x08, 0xE2, 0x26, 0xCA, 0x93,
0x2C, 0xB8, 0x73, 0x77, 0x7B, 0xCA, 0x25, 0x42, 0xB7, 0x11, 0xDD, 0xE2, 0x6E, 0x72, 0x37, 0x85,
0xE8, 0xA6, 0x6E, 0x01, 0x13, 0xBA, 0x49, 0xDD, 0xA4, 0x6E, 0x52, 0x37, 0x9D, 0xDB, 0xB9, 0xA9,
0x9B, 0xD4, 0x4D, 0xEA, 0x26, 0x75, 0x01, 0x5B, 0x1A, 0x6E, 0x32, 0x03, 0x13, 0xBA, 0x49, 0xDD,
0xA4, 0x6E, 0x52, 0x37, 0xA9, 0x0B, 0x5B, 0xBA, 0x49, 0x15, 0x00, 0x93, 0xDC, 0xED, 0x13, 0x3E,
0xE5, 0x1B, 0xBC, 0x05, 0xD2, 0x3B, 0xE1, 0xF6, 0xE0, 0xC5, 0xEB, 0x84, 0xAE, 0x13, 0x3A, 0x2F,
0x1E, 0x6E, 0x4F, 0x78, 0x07, 0xEB, 0xA6, 0x74, 0x53, 0xBA, 0x09, 0x3F, 0xF7, 0x53, 0x00, 0x4A,
0x97, 0x0E, 0x9E, 0x39, 0xAF, 0xE8, 0xBA, 0xA6, 0xAB, 0x54, 0x75, 0x96, 0x85, 0x0E, 0x57, 0xBA,
0x98, 0xAB, 0x00, 0x4A, 0xD7, 0xC9, 0xF3, 0xE0, 0xC5, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0x73,
0x4C, 0x79, 0x70, 0xF1, 0xC9, 0x72, 0x25, 0x13, 0xBC, 0xC9, 0xDD, 0x60, 0xA2, 0x93, 0x4C, 0x75,
0x82, 0xA9, 0x74, 0xC2, 0xCF, 0xFD, 0xDC, 0xD2, 0x4D, 0xEA, 0x00, 0x33, 0xD5, 0xE5, 0x94, 0x07,
0x13, 0x55, 0xBC, 0xAA, 0x52, 0x57, 0x55, 0xEA, 0x2A, 0x0B, 0x5E, 0x85, 0x73, 0x83, 0x3B, 0xD2,
0x3B, 0xE1, 0xF6, 0x52, 0x55, 0xF0, 0xAA, 0x4A, 0x5D, 0x55, 0xA9, 0x73, 0x2C, 0x78, 0x70, 0xCE,
0xA9, 0xB2, 0x25, 0xEA, 0x26, 0x75, 0x93, 0xBA, 0x98, 0xAB, 0x72, 0xAE, 0xB2, 0x27, 0x14, 0xE6,
0x06, 0x73, 0x13, 0xBA, 0x09, 0x8A, 0x19, 0x77, 0xBA, 0x3D, 0x38, 0xA6, 0xBC, 0x0A, 0x55, 0xBA,
0x0A, 0x55, 0x3A, 0xC7, 0x94, 0x87, 0xDB, 0x93, 0x19, 0x57, 0x02, 0x8A, 0xAD, 0x4E, 0x67, 0x3C,
0x58, 0x70, 0xBC, 0x4A, 0x55, 0x57, 0xA9, 0xEA, 0x2C, 0x54, 0x5D, 0x6E, 0x4F, 0x38, 0x07, 0xEB,
0x3A, 0xA1, 0xAB, 0x00, 0xEB, 0x1A, 0x0E, 0x9D, 0x19, 0x8B, 0x37, 0xC5, 0x9B, 0x50, 0x74, 0x53,
0xD1, 0x2D, 0x55, 0xB7, 0x2A, 0x9D, 0x54, 0xA5, 0x53, 0xBA, 0x4A, 0xAB, 0xBA, 0xA1, 0xEA, 0x86,
0xAA, 0x1B, 0xAA, 0x6E, 0xA8, 0xBA, 0xA1, 0xEA, 0x86, 0xAA, 0x1B, 0xAA, 0x0E, 0x4A, 0xD7, 0x29,
0x55, 0x3A, 0xA9, 0x4A, 0xB7, 0xAA, 0x5B, 0x8A, 0x6E, 0x2A, 0xBA, 0x09, 0xDE, 0x14, 0x4F, 0x4A,
0x37, 0xC5, 0x9B, 0xE0, 0x4D, 0xE9, 0x8C, 0xAE, 0x8A, 0x8B, 0xCE, 0xF2, 0xF6, 0x2D, 0xE6, 0x24,
0xCB, 0x39, 0xE9, 0xE6, 0x64, 0xC9, 0x1C, 0xBC, 0x78, 0x95, 0x29, 0x54, 0xAA, 0x1E, 0x2B, 0x55,
0x63, 0x55, 0xA9, 0x0A, 0x53, 0x55, 0xAA, 0xAB, 0x52, 0xE3, 0x34, 0x96, 0xAC, 0x38, 0x1D, 0x2C,
0xA7, 0xD3, 0xD3, 0x49, 0x16, 0x28, 0x00, 0x5B, 0xBA, 0xC5, 0x9E, 0x72, 0x4E, 0x78, 0x27, 0xD8,
0xEA, 0x84, 0xAE, 0x13, 0x6C, 0x75, 0xD2, 0xBB, 0xE5, 0xDC, 0x04, 0x7B, 0x93, 0x2A, 0x00, 0xFA,
0xB9, 0x9F, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0x73, 0x4C,
0x79, 0x70, 0xF1, 0xC9, 0x72, 0x25, 0xFB, 0xA4, 0x9B, 0x93, 0xE7, 0xC1, 0x8B, 0xD7, 0x09, 0x5D,
0x27, 0x74, 0x9D, 0x3C, 0x78, 0x5E, 0x4C, 0xC1, 0x9C, 0x52, 0xA1, 0x03, 0xFA, 0xB9, 0x9F, 0xEB,
0x84, 0xAE, 0x13, 0xBA, 0x4E, 0xE8, 0x3A, 0xA1, 0xF3, 0xE2, 0xC1, 0xF3, 0x74, 0x73, 0xD2, 0x07,
0xFA, 0xB9, 0x9F, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0xAB,
0x50, 0xA5, 0xAB, 0x50, 0xA5, 0xAB, 0x50, 0xA5, 0x02, 0xFA, 0xB9, 0x9F, 0xAB, 0xD0, 0xAD, 0x42,
0xB7, 0x0A, 0xDD, 0x2A, 0x74, 0xAB, 0xD0, 0xAD, 0x42, 0xB7, 0x6E, 0x02, 0xFB, 0xA4, 0x9B, 0x93,
0xE7, 0xA5, 0x4B, 0x87, 0x4E, 0xE8, 0x3A, 0xA1, 0xAB, 0x52, 0xA1, 0xAB, 0x52, 0xA1, 0x43, 0x85,
0xAA, 0x8B, 0x99, 0x4F, 0x68, 0x6C, 0x09, 0xFA, 0xB9, 0x9F, 0x93, 0xBA, 0x49, 0xDD, 0xA4, 0x6E,
0x52, 0x37, 0xA9, 0x9B, 0xD4, 0xED, 0xE7, 0x7E, 0x0A, 0xFA, 0xB9, 0x9F, 0x02, 0x93, 0xBC, 0x29,
0xE6, 0x26, 0x79, 0x93, 0xBA, 0x49, 0xDD, 0x3F, 0xDC, 0x96, 0x00, 0xFA, 0xB9, 0x9F, 0x5B, 0x37,
0xC1, 0x9B, 0xE0, 0x6E, 0x69, 0xCC, 0x49, 0x55, 0x3C, 0x79,
and some more HEX code...
is the hex code a letter?
