Hey all, long timer lurker here. Finally caved on a problem that I just can't figure out myself.
So I have been using tmrPCM for about a week now and it's really a great tool but I am now starting to run into an issue where if I play a sound enough times, my entire Mega will just freeze up and I will have no choice but to reset it.
I have since removed all other libraries and made it play a short sound on repeat every one second in the loop to try and isolate the problem. Still it persists, after about 4-5 minutes of playing on repeat it has frozen. The only thing going on is the bare-minimum in order to make this sound play. What gives?
That seems to have done the trick! I will report back with a summary to finish off the thread in a day or two after I have finished playing around with it. Thank you for all your help, this information may be useful to newbies to the library like myself.
So bad news. I left it running over night. I put the sound back on a trigger (Sound is supposed to be played when certain data comes through the serial port). When I came back down in the morning to test it, it worked a couple of times and froze up once again. I will post the full code later tonight when I am back home, but for now this case still seems to be open. Though, it is much better after stopping playback!
