Hello I am trying to convert the playground code for detecting presence using PIRs Arduino Playground - PIRsense into a library so I can connect several PIRs together.
I am new to C++ but have followed a few examples. The code compiles but doesn't seem to work as expected. I get readings from two PiRs the first few times but then I only get readings from one of them (the second object initialised). I have the suspicion that objects don't work as I think in C++ and one object is overwriting variables for all, I have declared variables protected but not much luck.
all comments, suggestions much appreciated.
PIR.h
#ifndef PIR_H
#define PIR_H
#include "WProgram.h"
#include "inttypes.h"
class PIR
public:
PIR(int nodeId, int pinId, long pause);
void initialise();
void checkStatus();
protected:
int _nodeId;
int _pinId;
unsigned long lowIn;
unsigned long start;
unsigned long end;
int _pause;
bool _ready;
bool lockLow;
bool takeLowTime;
#endif
PIR.cpp
#include "PIR.h"
* The Parallax PIR Sensor is an easy to use digital infrared motion sensor module.
* (http://www.parallax.com/detail.asp?product_id=555-28027)
* The sensor?s output pin goes to HIGH if motion is present.
* However, even if motion is present it goes to LOW from time to time,
* which might give the impression no motion is present.
* This program deals with this issue by ignoring LOW-phases shorter than a given time,
* assuming continuous motion is present during these phases.
bool lockLow = true;
PIR::PIR(int nodeId, int pinId, long pause){
_nodeId = nodeId;
_pinId = pinId;
_pause = pause;
void PIR::initialise(){
pinMode(_pinId, INPUT);
digitalWrite(_pinId, LOW);
//give the sensor some time to calibrate
for(int i = 0; i < 30; i++){
Serial.print(".");
Serial.println("SENSOR ACTIVE");
_ready = true;
void PIR::checkStatus(){
if (_ready == true) {
if(digitalRead(_pinId) == HIGH){
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
start = millis()/1000;
delay(50);
takeLowTime = true;
if(digitalRead(_pinId) == LOW){
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > _pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
end = (millis() - _pause)/1000;
Serial.print( _nodeId );
Serial.print( " " );
Serial.print( _pinId );
Serial.print( end - start );
delay(50);
