Hi there!
I have an arduino board with lcd and I want to display the total arduino running time, since I plugged it into power.
So i am using an unsigned long. What will happen if it overflows? Will the code given below,work after 49 days correctly?
unsigned long time= 0;
void loop(){
time=millis();
In what units? Let's say seconds.
Make another variable, and add to it when 1000+ milliseconds pass. Something like this:
unsigned long seconds = 0;
unsigned long lastSecond = 0;
void setup () {}
void loop ()
if (millis () - lastSecond >= 1000)
seconds++;
lastSecond += 1000;
// display seconds
} // end of loop
That will work for 49710 days. Should be enough before the battery runs out.
I think that will handle overflow correctly. No doubt someone will say if I am wrong.
I don't know the answer to your question off the top of my head, and I am not even going to attempt to find out. Instead, I want to encourage you to think about the problem slightly differently:
You have a variable that is holding an incrementing value, and, at some point, will "roll over". You want it to continue counting, though, for a much longer period. So what should you do? How about:
- Set up -two- variables, both unsigned longs - one called "counter", the other "rollover"
- Increment counter as normal (however you do that is up to you)
- When "counter" rolls over (ie, hits its highest number and resets to zero), increment "rollover"
- Number of count = rollover * max_value + counter
If both are unsigned longs, and you are counting milliseconds, then you'll have about 213503982334 days until it "fails" (even if my math is slightly wrong - believe me, you and possibly humanity itself will be long dead)...
Condition not met. Consider this post the else-clause. 8)
My example is wrong. It doesn't handle the rollover. Eg. If we were using byte rather than unsigned long, and adding 10 each time and not 1000, consider:
lastSecond = 250;
lastSecond += 10;
lastSecond is now 4.
The comparison:
if (millis () - lastSecond >= 10)
would be met for millis() of 251, 252, 253, 254, 255.
It's correct.
lastSecond = 250;
The only way for this line of code to execute...
lastSecond += 10;
...is if this condition is true...
...which means millis has to already be 4 or greater. This is the timeline...
millis lastSecond delta result
255 250 5 condition not met
0 250 6 condition not met
1 250 7 "
2 250 8 "
3 250 9 "
4 250 10 condition met; lastSecond incremented
5 4 1 condition not met
6 4 2 "
Much as I hate to try to prove myself wrong, try this, which substitutes byte for unsigned long, and "makes up" a one-byte millis:
#include <Streaming.h>
byte seconds = 0;
byte lastSecond = 0;
byte myMillis = 0;
int count;
void setup ()
Serial.begin (115200);
Serial.println ();
void loop ()
myMillis++;
if (myMillis - lastSecond >= 10)
seconds++;
lastSecond += 10;
// display seconds
Serial << "myMillis = " << _DEC (myMillis) << endl;
Serial << "lastSecond = " << _DEC (lastSecond) << endl;
Serial << "seconds = " << _DEC (seconds) << endl;
// stop if enough done
if (count++ > 300)
while (true) {}
} // end of loop
Output:
myMillis = 1
lastSecond = 0
seconds = 0
... blah blah ...
lastSecond = 250
seconds = 25
myMillis = 251
lastSecond = 250
seconds = 25
myMillis = 252
lastSecond = 250
seconds = 25
myMillis = 253
lastSecond = 250
seconds = 25
myMillis = 254
lastSecond = 250
seconds = 25
myMillis = 255
lastSecond = 250
seconds = 25
myMillis = 0
lastSecond = 250
seconds = 25
myMillis = 1
lastSecond = 250
seconds = 25
myMillis = 2
lastSecond = 250
seconds = 25
myMillis = 3
lastSecond = 250
seconds = 25
myMillis = 4
lastSecond = 250
seconds = 25
myMillis = 5
lastSecond = 250
seconds = 25
myMillis = 6
lastSecond = 250
seconds = 25
myMillis = 7
lastSecond = 250
seconds = 25
myMillis = 8
lastSecond = 250
seconds = 25
myMillis = 9
lastSecond = 250
seconds = 25
myMillis = 10
lastSecond = 250
seconds = 25
myMillis = 11
lastSecond = 250
seconds = 25
myMillis = 12
lastSecond = 250
seconds = 25
myMillis = 13
lastSecond = 250
seconds = 25
myMillis = 14
lastSecond = 250
seconds = 25
myMillis = 15
lastSecond = 250
seconds = 25
myMillis = 16
lastSecond = 250
seconds = 25
myMillis = 17
lastSecond = 250
seconds = 25
myMillis = 18
lastSecond = 250
seconds = 25
myMillis = 19
lastSecond = 250
seconds = 25
myMillis = 20
lastSecond = 250
seconds = 25
myMillis = 21
lastSecond = 250
seconds = 25
myMillis = 22
lastSecond = 250
seconds = 25
myMillis = 23
lastSecond = 250
seconds = 25
myMillis = 24
lastSecond = 250
seconds = 25
myMillis = 25
lastSecond = 250
seconds = 25
myMillis = 26
lastSecond = 250
seconds = 25
myMillis = 27
lastSecond = 250
seconds = 25
myMillis = 28
lastSecond = 250
seconds = 25
myMillis = 29
lastSecond = 250
seconds = 25
myMillis = 30
lastSecond = 250
seconds = 25
myMillis = 31
lastSecond = 250
seconds = 25
myMillis = 32
lastSecond = 250
seconds = 25
myMillis = 33
lastSecond = 250
seconds = 25
myMillis = 34
lastSecond = 250
seconds = 25
myMillis = 35
lastSecond = 250
seconds = 25
myMillis = 36
lastSecond = 250
seconds = 25
myMillis = 37
lastSecond = 250
seconds = 25
myMillis = 38
lastSecond = 250
seconds = 25
myMillis = 39
lastSecond = 250
seconds = 25
myMillis = 40
lastSecond = 250
seconds = 25
myMillis = 41
lastSecond = 250
seconds = 25
myMillis = 42
lastSecond = 250
seconds = 25
myMillis = 43
lastSecond = 250
seconds = 25
myMillis = 44
lastSecond = 250
seconds = 25
myMillis = 45
lastSecond = 250
seconds = 25
myMillis = 46
lastSecond = 250
seconds = 25
Once we reach lastSecond = 250, seconds gets stuck on 25.
if ( (byte)(myMillis - lastSecond) >= (byte)(10) )
...otherwise the operation is promoted to int. Type-casting is not necessary for unsigned long because there is no promotion.
So I was right all along? How does that work?
That's what I've been saying.
How does that work?
Don't ask me. You're the one who convinced yourself you were wrong.
