1 button 1 led fade
Hi newbie @codynutbrain
Kindly go through this
Keyword or is a synonym for || for long time.
As and for &&
In case you want something more "Beginner friendly", here is what I came up with :
int8_t led = 9;
int8_t button = 8;
int16_t brightness = 0;
int8_t fadeAmount = 1;
int8_t InvDir;
  Serial.println("LED Dimmer V2");
  pinMode(button, INPUT_PULLUP);
  pinMode(led, OUTPUT);
  while (digitalRead(button) == LOW) {
    InvDir = 1;
    brightness += fadeAmount; // identical to brightness = brightness + fadeAmount
    if (brightness < 0) {
      brightness = 0;
    else if (brightness > 255) {
      brightness = 255;
    analogWrite(led, brightness);
    Serial.println(brightness);
    delay(30);
  if (InvDir) {
    InvDir = 0;
    fadeAmount = -fadeAmount;
    Serial.println("Button Released");
This code however does block other activities...
Here is a simple non blocking version (no software debouncing though => hardware debouncing if required)
int8_t led = 9;
int8_t buttonPin = 8;
uint8_t buttonState;
uint8_t prevBtnState = HIGH;
uint32_t currentMillis;
uint32_t previousMillis;
uint8_t intervalUp = 30;
void updateBrightness() {
    brightness = 0;
  } else if (brightness > 255) {
    brightness = 255;
  pinMode(buttonPin, INPUT_PULLUP);
  buttonState = digitalRead(buttonPin);
  if (buttonState == LOW) {
    if (prevBtnState == HIGH) {
      updateBrightness();
      Serial.println("Button Pressed");
    else {
      currentMillis = millis();
      if (currentMillis - previousMillis > intervalUp) {
        updateBrightness();
        Serial.println("New Brightness");
  else {
    if (prevBtnState == LOW) {
  prevBtnState = buttonState;
And a cheap and easy debouncing solution :
int8_t led = 9;
uint8_t debouncingDelay = 25;
    brightness = 0;
    brightness = 255;
      updateBrightness();
      previousMillis = millis();
      delay(debouncingDelay);
    else {
        updateBrightness();
  else {
Updates welcome...
For your reference,
Link: Wokwi Simulation
#include "Debounce.h"
#define pbPin 5
#define ledPin 3
#define millisec(t) (t * 1000UL)
bool input;
bool prevInput;
bool fade;
uint8_t brightness;
Debounce inputDebounce;
unsigned long startTime;
unsigned long repeatRate;
unsigned long debounceTime;
void InputCondition();
void Fade();
void PrintBrightness(uint8_t brightness);
  pinMode(pbPin, INPUT_PULLUP);       // Pin Mode
  pinMode(LED_BUILTIN, OUTPUT);       // Pin Mode
  repeatRate = millisec(10);          // Button Repeat Rate 10 milliseconds
  inputDebounce.setDebounceTime(20);  // Debounce time 20 milliseconds
  brightness = 0;                     // Initial brightness
  fade = false;                       // Initial fade (TRUE = Fade-In, FALSE = Fade-Out)
  digitalWrite(LED_BUILTIN, !fade);   // Next Fade Status (ON = Fade-In, OFF = Fade-Out)
  PrintBrightness(brightness);        // Print brightness
  InputCondition(); // Button Input Condition
  Fade();           // Fade-In/Out
void InputCondition() {
  bool pbValue = !digitalRead(pbPin);       // Read Input
  input = inputDebounce.debounce(pbValue);  // Debounce Input
  if (input & !prevInput) {                 // Risign Edge Detector
    startTime = micros();                   // Reload startTime
    fade = !fade;                           // Toggle Fade (TRUE = Fade-In, FALSE = Fade-Out)
  if (!input & prevInput) {                // Falling Edge Detector
  prevInput = input;
void Fade() {
  if (!input) return;
  if (micros() - startTime < repeatRate) return;  // Repeat Rate Detector
  if (fade) {                       // Fade-In
    if (brightness > 254) return;   // brightness equal to 255, return
    brightness++;                   // Fade-In
  } else {                          // Fade-Out
    if (brightness < 1) return;     // brightness equal to 0, return
    brightness--;                   // Fade-Out
  analogWrite(ledPin, brightness);  // Update brightness
void PrintBrightness(uint8_t brightness) {
  Serial.print("Brightness:= ");
MicroBeaut (μB)
this is exactly what i wanted thank you
Is that by any chance someone to do the homework for you ?
no this was for my grandpas train set and when he cant figure something out he sees if i can
I stand with you : many helpers (of good will, no argument there) design Heavy Duty Trucks when OP just requires a bicycle.
Below link may help with code by " gcjr"
Single button dimmer
