How to get the best out of this forum
See the forum guidelines for general rules on forum behavior and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us.
The people who try to help with your project are volunteers doing this for free in their spare time. If you follow these guidelines it helps us to help you and gets your project working quickly.
Without the correct information, it is difficult or impossible to give you the help you need.
Preferred language
If English is not your preferred language there are categories in other languages
Essentials
Below are some things we need which are often missed by people posting for the first time
Choose the right category of the Forum
There are lots of different categories to choose from. Choosing the right one is important because not everyone who might be able to help you reads every category. Some questions might reasonably fit in to more than one category but please do not post the same question in two or more different categories. Also, if you have more than one question but the questions are all about the same project then it is usually preferable to keep the questions in one topic. Keeping them together helps get better answers as the answer to one provides the context for the next. Creating the same question multiple times or creating lots of different questions about the same project is against the forum rules and will incur the wrath of the moderators when they see it.
Hardware
We need to know exactly what hardware you have. We need to know what Arduino board (or other brand, such as ESP32) you are using and exactly what other hardware you are connecting it to. The more details we have, the easier it is to help.
If you are using something that is a non-Arduino product then it helps to have a link to its technical data sheet or a link to where you bought it.
Code problems
We can only find problems in code we can see. Please supply your complete code in code tags <CODE/> More about posting code and using code tags. If you are using Arduino Cloud then you can post a link to your project (but keep in mind that not everyone uses Arduino Cloud).
Posting a snippet of code is generally useless. The problem is usually in another part of the program.
Before posting code, please use Tools / Auto Format at the top of the IDE. It makes the code much easier to read and you will probably find it very helpful yourself. Once you've done that, use Edit / Copy for Forum.
Always use code tags (<CODE/>) when posting code or compiler error messages.
Using code tags makes the code easier to read and easy to copy. Not using code tags means some of the code gets displayed with smiley faces and other stuff that should not be there. Be aware that there is a limit of 120000 characters for a post. If your code takes you above this limit then you can add your .ino file as an attachment. However, it will be much easier to help you if you can write a short program that illustrates the problem you are having and post that.
Please don't post an image of code instead of the code itself, or an image of error messages instead of the error messages themselves.
It is very important to be clear about what is expected from code and what happens instead. Code ALWAYS works; that is the nature of code. Whether it does what you expect is a different thing altogether. We need to know what you expected the code to do and what happened instead.
More about posting code and common code problems.
Schematics or circuit diagrams
The language of electronics is a schematic or circuit diagram. Long descriptions of what is connected to what are generally useless. A schematic is a drawing of what connects to what; please make one and photograph it. We don't mind if it's hand drawn, scruffy and does not use the correct symbols, but please make sure it is accurately and completely labelled.
If you want to use computer software to create a schematic, then you might like to try Circuit Diagram or KiCad, although any software capable of creating a schematic will be fine.
More about creating a schematic of your project including how to upload an image.
General
Please try to avoid posting links to other sites where code or photos or schematics are hosted. Most of us will not follow such links, partly due to the risk that they hold malware or other unwanted content, partly to maintain everything on this site for the benefit of future users looking for an answer to a similar question, and partly because we feel that if you want our help you should provide everything we need on this site not expect us to go hunting elsewhere for it.
Research
Please do some research before posting. Most beginner problems have already been dealt with on the Forum so please use the forum search tool and the Arduino Help Center to try and find an answer to your question. You can also use your favorite search engine to find answers.
Be specific
Please ask a specific question about the problem you are having so we can provide a clear, specific answer.
If you don't understand some of the advice that you get, please say so. Then we can explain in more detail. If you want to know more about how to ask a question that is likely to get a really helpful answer, then have a read of this, admittedly rather long, tutorial How To Ask Questions The Smart Way and use the principles explained there to ask a really effective question here.
AI generated content
Artificial intelligence (AI) services such as ChatGPT are able to generate Arduino project code and answers for Arduino-related questions. As with other non-authoritative sources of information found on the Internet, this should be used with caution.
Questions about information provided by an AI
If you would like to ask for assistance with AI-generated code or information here on the forum, please clearly identify the source.
Using AI-generated content to provide assistance
When providing assistance, copy/pasting content without giving any thought to the information is irresponsible, regardless of the source of that information.
Please carefully evaluate AI-generated content for accuracy, relevance, and appropriateness within the context before using it to provide assistance. If you are not able to make such an evaluation, then please don't share the content here on the forum.
About us
Those of us answering questions have a wide variety of backgrounds and electronics knowledge, some through working in electronics or computing, some through electronics or computing as a hobby, some both. Most of us are not trained as teachers so probably miss the finer points of how to teach and explain things effectively. We are not, with the odd exception, employees or representatives of Arduino.
Please also remember we are volunteers doing this for free in our spare time and are more inclined to help people who make it easy for us to provide help by providing the information we ask for.
About you
We only know about you and your project what you tell us. If you tell us your level of experience with electronics or microcontrollers, we can tailor our answer to your level of knowledge. We also don't know if you have problems with English or language or communication in general unless you tell us. We can be sympathetic about things we know about, but if you don't tell us we don't know.
More information
There is more information below.
Making your first post
Now please go to the forum index, select the right category and make your first post.
Thank you.
1. Choose the right category
It is important to choose the right category and the right language so that the people most likely to be able to help you will see your question. Not everyone here reads questions in every category so please take your time and post in a category related to your question.
If English is not your preferred language then scroll down and choose from one of the other language categories.
Please only post in English in the English language categories. If your language is not shown then please use Google Translate and post in an English language category using English.
Forum categories
2. Make a topic
Once you have found the right category you can start your post. Click on New Topic
3. Write your post
Enter a title and a description of your problem:
Don't forget to include code in code tags <CODE/> and a schematic of your circuit.
For your first two posts, the right hand side of the post composer pane will show a welcome message. Once you have closed that message, you will see a preview of how your post will look once you have submitted it.
4. Publish your topic
When you are happy with your post click on + Create Topic to post it.
That's your first post completed.
Posting code and common code problems
Post all your code
Without your code, all your code, we cannot provide any answers about your code, other than the most vague and probably unhelpful of answers. One of the frustrating things about writing code is that a mistake in one place can produce an error in what seems like a completely different, unrelated place. This is a nightmare if you are new to writing code, but often easy to spot for anyone who is experienced in looking for such problems. It is for this reason we want all your code, not just the bit with the error or the bit you think is causing the problem.
Format your code
Before copying your code for the forum, look in Tools on the menu bar of the Arduino IDE and select Auto Format. This will format the code correctly. If you prefer, Ctrl+T will do the same thing. Once formatted, you can copy and paste your code with code tags.
Use code tags
Code should be be in code tags, these are the <CODE/> in the tool bar above where you edit your post, and correctly formatted, like this:
char message[][4] = { "hi", "bye" };
  //Serial.begin() configures the serial port
  for (byte x = 0; x < 2; x++) {
    Serial.println(message[x]);
If you don't use code tags then it ends up like this:
char message[][4] = { "hi", "bye" }; // <---- There's a box now
//Serial.begin() configures the serial port // <---- Some strange link
Serial.begin(9600); // <---- Indentation lost
Serial.println(message[x]); // <---- There's a checkbox
There's more than one way to add code tags, you can:
  • Paste your code in the box where you are editing your post, select all the code and click on <CODE/>.
  • In the Arduino IDE under the 'Edit' menu there is 'Copy for Forum', this puts your code on the clipboard with code tags added ready to paste into your question.
Minimal, Reproducible Example
The forum has a limit of 120000 characters per post, which means that you can't post a program longer than this directly. In this case, you can attach the .ino file to your post or, if you are using Arduino Cloud, you can post a link to your project.
However, consider that the longer your program, the harder it is for anyone to understand it and help you. For this reason, consider writing a short program that illustrates the problem and post or link to that instead. You are more likely to get help with a short, easy to understand program than with a long, complicated one. For more about this see How to create a Minimal, Reproducible Example.
Error messages
When you compile your code the Arduino IDE will check for certain problems with the code and generate error messages to indicate any problems it finds. If this happens then we need to see the error messages as well as the complete code, as the error messages offer clues to what the problem is. If you have error messages then in the bottom right hand corner of the IDE there will be a button 'Copy error messages'. Click the button and paste the result into your question, don't forget to add the code tags.
Common mistakes with code and posting code
Posting a screenshot of code or error messages. A screenshot is useless, with a screenshot it is impossible for us to paste the code into the IDE and test it. Please post your code and error messages, not an image of them.
Only posting the part of the code you think has the problem. Often code problems are not in the place they might obviously seem to be, often a mistake in one place shows up as a problem elsewhere. The only way to see this is to see all the code. Also be aware that some mistakes cause a cascade of multiple errors. If this happens, deal with the first one and see if the other disappear.
It is essential that every opening bracket has a corresponding closing bracket. Check that every { has a corresponding }, every ( has a corresponding ) and every [ has a corresponding ] before you post your code. In the IDE if you place your cursor next to any bracket of any kind the IDE will draw a rectangle round its partner, if there's no corresponding bracket, or there is a corresponding bracket but it's not the one you expected then you have found your problem. Also, if you use Auto Format (Tools > Auto Format or Ctrl+T) your code will be tidied up and missing brackets of all kinds should become a lot easier to see.
Forum rules and netiquette
The instructions above are to help you make a successful post, 'successful' meaning you get a useful and satisfactory answer to your question. In order to keep the forum working smoothly there are some rules that apply to everyone, breaches of which can lead to suspension or being removed from the forum altogether.
The forum rules are defined here.
Only ask your question once, in one category of the forum
We know you are anxious to get an answer to your problem, but re-posting the same question to multiple categories of the forum causes duplicate effort, and divides the focus on your problem. You'll get a better answer if everyone can discuss it in one place. Asking the same question multiple times is called cross-posting. Cross-posting is very annoying to people trying to help you. If you cross-post, the moderators will delete your extra posts, and you will get a warning. Save all the hassle, and just post the question once. It will be noticed.
If you aren't sure which category to post in (Programming, General Electronics, etc.), make a guess. Don't cross-post "just in case".
Start a new topic; don't hijack an existing topic
You might see an existing topic related to what you want to ask and think about tagging your question on the end. Please don't do this. If the existing question is just what you were looking for and the answer helps you then there is no need. Otherwise, the existing topic isn't what you were looking for and you should create a new topic. There's no harm including a link back to the existing discussion if you think there's some relevance.
Don't bump!
Don't bump your topic after an hour. Because of the different time zones, the person who knows the answer may be asleep, or away for the day or maybe on holiday. Maybe after a couple of days, but even then think about whether you have provided enough information and asked a question that can be answered. You could even ask us 'what else can I provide in order to get some help?'.
Getting help from a particular person
You might have read answers from a particular person and think that person would be the best person to help you. You can bring your question to someone's attention by using @ followed by their username, for example @username. If you do this, they will get a notification. Please do not send a PM (private message) to someone you don't know asking a question; most will ignore you.
Commercial projects
One thing really guaranteed to ensure you don't get help is to tell us you can't provide all the information because it is commercially confidential. If it's commercially confidential then you should consider paying someone to help you and ensure a confidentiality agreement is in place with them. If you want help with a commercial project then create a topic in Jobs and Paid Consultancy - Arduino Forum and indicate what your terms are, including how much your budget is. This is a hobby forum, not a place for free help with commercial projects.
Ready written code
Ready written code for every possible application does not exist, including for your application. Asking for the code for what you are trying to do will not get you anywhere, other than possibly some annoyed replies. You either have to write your own, which we are here to help with when you get stuck, or you can pay for someone else to write it for you. If you want someone to write code for you the place to ask is Jobs and Paid Consultancy - Arduino Forum. If you neither want to learn to write code yourself nor pay someone else to do it for you then this is probably not the right place for you.
Be polite
A little courtesy and politeness goes a long way. Even if you think a question has been asked before, or you don't see the point of it, try to answer politely. Remember a lot of the posters with high post counts see the same questions every day, and they may get a bit terse if you appear not to have tried very hard to help yourself in the first place. You will find that if you respond in a friendly way, people will stick with you and you will almost certainly get your problem solved. Personal insults, rudeness and offensive language are not acceptable and will result in a ban. Stick to the topic.
DON'T SHOUT
TYPING IN ALL UPPER CASE is considered to be SHOUTING. It won't get you an answer any quicker, it will just annoy people.
Homework
We get a lot of questions from students wanting help with their homework. Such questions are generally one of two kinds: Questions by students who are obviously making a real effort but have got stuck; these get helpful answers. Questions from students who are obviously not making any effort at all and just want someone to do their homework for them; these usually get a lecture. By all means, post homework questions when you are stuck, but make sure you've put some effort in first.
Thank people who help you
Those of us who answer questions on here are doing so for free, out of community spirit. Please thank people who provide helpful answers and don't forget to give :heart:s as well.
It also helps if you click the :check_box_with_check: Solution button at the bottom of the reply that answered your question. This will make it easy for helpers to see that it is solved and for others with the same question to find the answer quickly.
Credits
Much of this tutorial has been inspired by or copied from the original forum instructions created by Nick Gammon.
My thanks to Ballscrewbob, Robin2 and Idahowalker all of whom have provided a great deal of support and feedback, without which this tutorial would contain far more errors than it does and would be a lot less clear than it is.
Feedback
Please provide comments, feedback or suggestions for improvements for these instructions here.
Thank you.
How to get the best from this forum feedback and comments
DHT11 gives only 0% humidity en 0°C
Code Request - 3 100k NTC Data Logging - Teensy LC
Object measurements
How to add bus in arduino
How to Serial Communication
Concatenate Char* and uint64_t
[SOLVED] Nano Every behaving strangely with daisy chained 74HC595
Does ATMEGA32U4RC-Au ic come with bootloader?
Failed to verify certificate. : x509 certificate signed unknown Authority
'LED' was not declared in this scope
LED array with LEDs that require different amounts of mA
Relay do not switch
NEXTION Display connect to STM32F103 with Arduino IDE
Analog TDS and Turbidity Calibration
Circuit Simulator + Block Programming + Arduino Upload = Holy Grail? 🚀
Uno + MC522 + SD not working
How to unbrick STS3215 servo motor?
How to solve plotter problems in Sim808 Gsm GPRS GPS Module
"ON" led not working when supplied 11V in Barrel Jack
Controlling Various Vibration Motors Individually
BLE Peripheral Not connecting…
Using the TMC2660-eval with an Arduino Mega
Arcade swipe card thing with arduino and rfid
Message in hindi language
Read & write data from serial devices over ethernet by arduino
Potentiometer problem on Arduino
Slow upload speed
Unexpected negative values
Traspasado [cerrado]
Problem with library installation
Program creation
GxEPD2 using Waveshare 1.54inch b/w epaper with partial update in combination with low current consumption
Proffieboard troubleshooting
ESP32 with web socket client
Need assistance
ADC Attiny85 code need
Problem Esc SoftwareSerial
Crear escáner con Arduino para Nissan Pick Up D21
Button on/off Servo
Failed to install platform: esp8266:esp8266
[REGOLAMENTO] Come usare questa sezione del forum
Arduino push button car project help needed
Bluetooth module delay
No matching function or call, but there is?
How Upload Sketch to Nano33 IOT without IOT Cloud?
Encoder and counter help
Commands via grbl
Max 4466 mic &Arduino R4 WIFI
Arduino Code for 4G LTE SIM A7670C Development board
Help me find the solution. The code is correct, and the Switch settings on the dashboard are properly configured, but I still can't control the light
Has anyone used nrf24L01, H-Bridge, Servo code together?
NRF24L01+ en ESP32 y ESP8266
My robot's CANbus won't talk?
I am having a problem with my TDS sensor
[Solved] Atmega328p -au bootloader and execution failures
Include H and Cpp file in main sketch
Magnetic Latching relay? or not
Problem while uploading to board
28BYJ-48 stops and does not start again
Display led p7.62 Problem with no character show
Getting error in the MFRC522.h library while connecting ESP 32 with RFID reader
How to read flow using flow meter without interrupts
Need help printing 6 digit value after decimal point
Add an On/Off proximity switch to Clearpath MC Motor
How to know the syntax needed for each library?
NTP Montreal date and time - need to turn this into a function in another script
How to design Library
Uno wifi r3 digital pins dont work
Turn a sensor on or off using the rest of Arduinio IOT Cloud APIs
LCD 16x2 need HELP please
Help ,Please,afr gauge Newbie to Arduino
I need help in the debug the esp32
Sdr radio frequency knob
Stepper motor slows down with analog read
My encoder not working with leonardo
MAX30100 Pulseoxymeter showing random characters
Arduino Project 12
Uploading failure on Arduino Nano with CH340 chip
I am facing problem to upload my arduino code in arduino board
Please slove this error
A time delay alarm
GY-91 Sendor - avrdude errors
LCD screen, help me with the code
Ethernet Example LAN8720 with ESP32 ETH01 module not working
Hello every one , I want help pleas , i want to mointor the battery voltag with web server page
Transmit date de HX711 by 433 Mhz RF transmissor
Alguien sabe cómo hacer que mi zumbador pille más rapido?:(
DS18B20 simulator
6 digit 7 segment 2812 clock/stopwatch
Sending Arduino Serial print to Raspberry Pi
Requesting for help in my program ,pleas help me out
Como usar esp32 devkit v1 como un programador isp
Wie man dieses Forum benutzt - bitte lesen
Need help with some Radar System code
The code does not show the values
Clear CANbus buffer
What is the best way to snub a bipolar stepper motor coil
Can I use a React to create the UI for my IOT project and how can I connect the two together?
Help with RTC DS1307 on my project with Arduino Mega
CLK and DT 3V while Vcc 5V
ATtiny84&Bluetooth hc-05
My code was working, now all the outputs are 1
Error when burning the bootloader,
PT100 Temperature not getting correct output
Cannot find -larm_cortexM0l_math
12V Relay Drive circuits conflicting with AnalogRead of Battery
Use of hardware
Seven segment LED for cathode
How to solve: error: expected constructor, destructor, or type conversion
Exit status 1 Error code
Stuck on activating a relay
How to shift binary into a shift register (serial in, parallel out) sequentially
Getting 12 volts from Arduino?
MAME ARCADE STICK with 16 keyboard keys using Arduino Leonardo
Rotary switch to control the menu on lcd display 16x2
Using millis() in for loop. Delay is not constant
Relay resets the atmega328p
Arduino button press
My LED strip doesn't want to light up
How to program Pin D5&D6 in Arduino nano both at a time?
Help needed: generation of 2 PWM outputs using the same Timer
Expanded scale on a LCD bargraph?
Cd player controller
MPU6050 as basic compass
Controlling brushless motor with PCA9685
Automated Segregation trash bin
Send commands from ATMEGA2560 to Vantage Pro 2 (weather station) via UART
Nano serial com issue
Since installation IDE 2.0.3 problems with verify code
Does anyone know what's wrong?
Assigning binary values to ranges?
Looking for Robot car and line tracking code
Timing with using millis()
Arduino Uno / TinyUSBisp bootloader problems again
Difference in Serial Communication UnoR3 Uno R4
Using 2 linear actuator with 4 limit switches
No i2c device found
Best way to connect Photodiode to get Boolean result?
Noise and miss sound from MUX channel
Start the void.loop with a command
How to wire Emergency Stop
Will anyone code for cash?
Delay in Bluetooth
Serial communication Error
ArduinoFFT library Compute returns NAN on NANO
How to take analog signal sample at one perticular period
Master and slave at the same time
Best powersupply for Arduino Mkr 1000
Stepper Vibrate - Empty Arduino
SdFat - ENABLE_EXTENDED_TRANSFER_CLASS
Same timing variable returning two different times
Problemas con la letra ñ y las tildes en las vocales usando SIM800L
Guitar Envelope Follower Help
Issue with reading CAN data using UART serial CAN Bus device
MCP23S08 Questions
Flash sequence numbers
Coin operated water dispenser help!
Read data from energy meter (ISKRE ME172) using RS485 and arduino uno
So many Ports on on the Official Arduino starter kit and the one that worked has gone into hiding?
How to merge two codes together?
Using namespace to separate two "functions" in one ino file
Ayuda es para hoy
How to add a countdown timer with pause feature?
How can I turn off my buzzer esp32?
Arduino joystick doesnt work
RTC ds3231 - 165:165:85
Manual override
Nano - Nextion - Stepper
Serial Monitor error, using ESP32
JDY - 23 BLE Battery info
Envoyer un string entre deux ESP32
Help needed with RTC1307 Code :)
Can Arduino analog input tolerate 5.6V?
Motion Sensor Light timer
Proyecto ESP32, con modulo xbee
Arduino Speen sensor from Joy it
Weird compilation error
Execute "If statement" only one time
Problème d’alimentation : câble trop long?
Very Broken program
Implementing a DND feature on an intercom
Firebase stops working
MR24FDB1-Sensor incorrect data
Can't upload to arduino
My stepper motor driver LED won’t turn on when the power is on. Is it meant to?
Header file error
Engine coolant sensor trouble
Zwei verschiedene Frequenzen abwechselnd erzeugen
Arduino short pulse issue
Tradução dos textos fixos do Fórum em Português
Lcd I2C 16x2 doesn't work
Arduino Uno in Science Fair Project
Would this Nano every code runs on a Nano Atmega?
Short Circuit Detector using Arduino Uno
Best display for Arduino Mega 2560
Issues Controlling LED Using Serial Reading of Potentiometer
Facing problem with EEPROM results
Cording error i don't know how to fix this ...someone can help me?
How to precisely stop stepper motor with Arduino code
LED Cube Verticle Animation Failure
Can't load sketch to ESP8266-12E
Can't find MPU6050 connected to TCA9548A multiplexer
Need help my code dost work properly
Serial.readString and pasreInt printing random data
Controlling in Solenoid valve
SIM800L not responding to messages
The merits of delay() vs millis()
Timing Sensor input
Analog Pressure Sensors
CAN-BUS Shield interface with 7 segment display
Electronics for Sonic Screwdriver prop HELP
IDE hangs on startup: "EPERM: operation not permitted, mkdir"
How to add velocity to your code
Hola querria ajuntar dos codigos pero me esta dando problemas, si alguien estaria dispuesto ayudarme
Multiple NRF24L01 arduino r4 e esp32
Alguien me puede decir cual es el error para arreglar es un alcoholímetro lo que no vale es la pantalla lcd16x2 que el texto sale daño y no se lee
How do you operate the buzzer with the desired motion after machine learning?
Capacitive Sensor Not Working on Long Cables?
TFT LCD shield shows a blank white screen
Activar una válvula solenoide en funcion de un Termopar K
NRF24L01 Transmitter and Reciver Not working
Offset pwm signals
Odd problem with PCF8574 expansion board
Need to know if what i try to do is possible
Tds meter not working
Problems with Potentiometer
Error ; before teptimer
I'm doing tds and temperature project but
Making esp32 working with ILI9488
Self Balancing Robot project- wheels only spin in one direction
Coding in arduino ide
Arduino relay and motor issue
Elechouse Voice Recognition Module V3.1 is not saving recordings to permanent memory
Powering and Controlling Separate LED Strips
Move servo motor at a distance of 6 meters
Millis() not delaying
00 scale turntable project
New User MQTT help
Hey guys my Serial is not displaying the information scanned from the GM65, i tried using the usb instead of UART it seems the GM65 is working, help
ARDUINO DUE -HeartBeat Pulse Sensor
Controlling a Stepper Motor Using a Photoresistor
Momentary Push Button - One Push for Entire Code
2 HC-SR04 (1 as trigger 1 as echo)
Conexión de I2C a un Arduino Uno CH340
Not receiving data to the app
Need Help with programming this code
WS2812B Don't light more than 31 leds. Need help!
Need help with rf24l01 modules [SOLVED]
Trying to display Serial Data on my LCD Screen
Re: creating alert when system crosses geofence
433mhz led control button
Use Rfm9x without antenna?
ESP 32 keeps restarting with AsyncWebServer
Error de complilación
help to solve it please
Wireless Communication between arduino and ESP 32
Mega/Motor Shield Power Problem
Need input please
School project, automatic closed box solar system
I need help with my code to control 4 servo with 3 Potentiometers on different sequence
Problem with if()
Problem Using STM32 with Arduino IDE
ATtiny 13a issues
Adding Libraries- No luck
Lcd printing 2 glitched letters
How many ADC Pins Portenta H7?
Braccio arm no power to servos, UNO R3 not taking code
Help with P channel transistors
Arduino Fingerprint Coding
Ignore rotation when calculating direction?
SingleTact sensor
Hilfe brauche ein kurprogram abschnitt
How to stop repeat? basic questiom
Starting and stopping 2 DC motors with limit switches
Hello I am doing a project but it gives an error
Multiple servo with multiple sensors
I need help with project
Show up text on a 8X8 LED matrix, character by character
28BYJ-48 stepper motor with ULN2003
Esp32 cam error
Building a BMX gate and having sound issues
Giga Display Blank (No Graphics)
Do the micro servos break?
Arduino showing an error for some reason
COM port not being read
Using digipot to control water temperature
Lora Ra-02 arduino current consumption
Arduino Uno Variable frequency generator
Trying to run python on NANOESP32
Recommendation for a VCR - FET
Arduino snap rover
Aruino UnO connected to SM sensor
Need help for adding limit switches
How to fix this
Programming BL602 (Ai-WB2-32S) with Arduino
Two programs in arfuino
Writing in CSV file on SD Card
How to display both value of adc on excel
Basic OOK with the RFM69
Fan Speed AND DHT22 (temp/humidity)
Arduino uno r3 , Esp8266
I have problem with project
RGB LED controlled using IR Remote
Thingproperties.h no such file or directory
Giga + motor encoder + digitalread
Confused about max amp on boards
Stepper motor not turning correctly
Error overring baud rate
PIR Sensor analog value oscillation?
Help on my Electronic Project Deployment
48V to 12V dc stepdown using TIP35C and 7812
Sketch seems to be skipping data
Help! How to Control speed of a water pump AC 220V with C code
Bend labs one_axis_ads
Serial commands from serial monitor queuing
How can I specify this task in if ? is this even possible?
How useful is an Arduino Sensor Shield?
Parsing SMS Message
Read Duty Cycle and Drive Leds
Help cant work this out
Communication speed of NRF24L01
I have a problem with pins
Formating serial command
Two or more data types in declaration of 'timeout'
Developing an Arduino Uno
Multiple leds on ONE PWM pin
SK6812 RGBW Jim Bumgardner hack
Can anyone elaborate me this code
Homework Help Section
What would be the connection system of a type K thermocouple with miini-thermocouple connector .792 mm (0.312 in) pin spacing to Arduino
How can print float to a TFT display
IR Reciver not working!
PLEASE HELP noob
Buid a TV Lifter
ADXL 345 SPI: Receiving zeroes as output data
Struggling with bouncing servos
Solar Powered tracker
Stepper motor Eleego Kit Starter
Nrf24l01 stm32 arduino uno communication
Can't get expected readings using PulseIn command
Frequency Counter using ATMega8A, 7 Segment display keeps flickering only shows 1 out of 4 digits
I'm new with arduino, I'm having difficulties
Drehimpulsgeber / BIN Ausbabe - Fehler beim Abwärtz Zählen
Three Phase Square Wave - An error occurred while uploading the sketch
Mp3-tf-16p with arduino nano
LCD keep flicking
Initializing SD card...initialization failed error
Timeout Error (serial)
Use of AI-generated content by forum helpers
Help please w.r.t <Do - While> instruction
Please help I'm new
How I can read Serial monitor on a device
Problem with code or compiler
Make a hoist control wireless
IR remote controlling nema 17 stepper motor CODE press/depress
NRF24 not receiving. Help needed
I want to add an action that repeats forward and backward indefinitely when I press the 't' button
RF remote control robot for school project
Uart does not name a type including MKRGSM.h
Arduino code MAX30100 and DS18B20 doesn't work
Wire.h me dice : Se encontraron varias bibliotecas para "Wire.h"
Ad5933 not I2C scan
Linear Encoder (suspension diagnostics)
Uno board not works fine
Striped lines instead of cymbols on startup program
Arduino Nano V3 only runs sketch correctly after hitting reset or starting serial monitor
Arduino Mega2560 dosen't proccessing routine command in loop when it send a data via serial port the delay about about 100ms per sending poreccess
I cannot read text correctly through the serial port
Help, error: expected constructor, destructor, or type conversion before '(' token
Simple keyboard string read won't work on Mega
Problems with serial.read()
Expected { at end of input
Problems with int errors
Generating varying frequencies on pin PA21 for ATSAMD21G18AU
Arduino Nano and Visual Show Automation
Unable to send RAW IR code to an AC
Light a LED based on a Sensors activity
I want to press the button to call the numbers available in the sim card
NRF24L01+PA not working
Smoothening flow sensor output
Ardino uno error uploding
Reading an ATTINY24a
How to split battery voltage and adaptor voltage?
Very simple Ultrasonic sensor and distance sensor
Securing firmware and storing secrets
Problems with a new board that cannot get stufff uploaded
Interrupt execution delay
Coding in Home Position for DC Motor
Code corruption? Thoughts?
Simple ultrasonic sensor
Why is each y position pos * 9 + 1
Problem in my lab
Sketch only works when plugged in via USB after a short
Problem with pot
Esp32 lora PCF8574ap
Błąd kompilacji dla płytki Generic ESP8266 Module.
Rgb tft lcd interfacing with a psoc mcu
Arduino and Loconet library
I don't know how to read an entire word in the serial
Adding Millis to program in youtube
Load cell + led arduino uno
Issues With Multiplexing 16 to 1
Code given error
Arduino UART with esp01
How to wire ESP8266 nodeMCU to powerbank/battery?
Code gets stuck on the last note of the melody after being played
Decimal to binary converter
Running the Arduino 2.0 with the specified board and its settings
I cant drive my dc motor with arduino and L293D IC
ledPin was not declared in this scope, unsure why?
Issues restarting SD card
Magnetic strip card reader project
Error compiling Esp32 Wrover Board
ESP8266 esp 01 wifi module
DPWM on Arduino Uno
Millis timer has a mind of its own
Tengo un esp32 que no lo detecta iot cloud pero arduino agent create si
No 1-wire devices on GPIO0 with putty/serial, works with Arduino/IDE
Connecting 9v 600mah battery and 2 1.5v 2500mah battery in series to the Arduino Uno r3
Library for LoRa communication in Arduino Nano 33 Iot, Ble, etc
Need help for this i got an error for this one
Error compiling for digispark board (default- 16.5mhz
It's been so long I've fprgotten what T do
Help with distance and moving to a particular place
Paging with LoRa and Oled
DFPlayer not working after multiples loops
Loadcell as a switch
Relay is being high at starting, Can we make it Low at start up until input matches
Problem About ADC Reading Potentiometer
ESP32 Wifiserver fix client ip address
Alexa NOT Controlling LED_BUILTIN
I need help because my lcd 16×2 screen with i2c module isn't working properly
Arduino code uploaded success but nothing happens arduino uno
Analog read and data upload
Single shot analogue read
A simple PWM beep using timers 1 and 2
Stepper motor+hall sensor+arduino
Nano Every LED Lamp Diagram Review
Run 12V through a MCP4151 Pot?
Water Glass weight with sensor JOY IT
Nano freezes after several loops
Help with millis() command
SoftwareSerial Bug?
Help please! Trouble using analog pins
Why my servo only run once?
Esp32 code compiling error
How do I declare for "sendCommand" and "getData"
HC-05 serial passthrough
Want to help someone who is code illiterate?
1.8 tft 128*160 lcd error
Can anyone help me in making paino using arduino using proteus with code
Help Error message!
LCD on arduino doesn't work after rewiring
ESP32 CAN bus not working
Trying to divide two variables to obtain value for another variable
Controlling Stepper Motor With Buttons Using Arduino
Continuous rotation servo motor problem
Error Codes TMRPCM
I don't know what's wrong with this code that bugging me, here's the code can any one find the error? this is the code for 128x64glcd oscilloscope
Hall sensor interference help
General Guidance and How to use the Forum
Generally asking about connect RC module
How to decode binary coming from the neurosky module?
Toggle on/off relay using hc-SR04 sensor
Pair a motor driver to fingerprint sensor
Trying to fix expected primary-expression before ')' token
Trouble with Coin Acceptor/120V triggering pulse
Arduino uno project sms type switch
For(....) loop seems doesn't work, I mean it doesn't take time
Servos causing laptop to shut off?
How to use barcode reader using usb shield
Receive for 30msc Low then send LOW for 30 msc and back to HIGH
Controlling multiple servos with Single push button
Arduino Nano Programmer
How to control led brightness with one keyboard button
I am facing some errors while compiling code. Please help
Forum Members Etiquette Rules proposal
Motorcycle Speedometer problem
Hi new to arduino need some help
4 Panel P10 RGB 32x16 paralel with Arduino Atmega 2560
I need help with my iron man faceplate project
Simulating EEPROM in flash memory
Arduino and OneDrive
DHT11 and esp 32
ESP32 con RTC1302 y modulo SD
Mbed end of life
I am trying to connect my arduino mega to esp8266 and get the data throught web using this code but it is not showing on the web and not working
Stepper motor not returning on its original position
Help whit code for a little project
Triggered event starts multiple things - Sooo confused :(
Multiple DHT22 on UNO with Adafruit Data logger shield
Port not recognized
2 Joysticks, 4 rotary encorder, 12 buttons and 2 hall effect sensors in one arduino board
Arduino PID Temperature control Increasing values
Motor accident project
Arduino Uno project
Understanding code tags
Unable to compile code
3 digits 7 segment display using 3 shift register and 4 push buttons
Push button is not functioning with "if (analogSensor>sensorThres)" loop
On/Off with Soft-start
Separate IR, Visible, Ultraviolet light
ESP32 Hall Effect Sensor Not Working
Usage of two Fingerprint Sensor at the same time (ESP32)
Using a button and a potentiometer to stop/start and change the speed of a dc motor with a h-bridge
Help me with this problem!
Having trouble with a program to set Modes
Design for two tightly looping ISRs
Dynamixel servo library wont even compile examples
Need help I don’t understand this error message
Code is uploaded to Arduino Nano, but not giving output
Help! Error compiling for board Arduino Mega or Mega 2560
Linking To Calibration Tool in W10
A short introductory video for Arduino forum
How to debug this code so that my accelerometer will work?
Automatic watering system with LCD Display
2 stepper motors with independent actions
Programming Project Problem with ESP32 + LCD I2C 16x2 + Pushbuttom
Problem with IR Sensor
Arduino mega OTA using ESP32 through UART
Digital read and bluetooth read
Potentiometer problem steering wheel
Problem with iot project
CAN bus programm code not getting compile
Beginner here needing some help
In function 'void loop()': 17:6: error: expected ';' before 'digitalWrite' 23:5: error: expected ';' before 'digitalWrite' exit status 1
Multi tasking structre for my arduino sketch
Passive buzzer wont stop after tune
Why does my sim800l does not receiving message when it was compile with oled screen?
One out of two servo motors will not run
Help........ 16*2 LCD display squares
How to fix a value
Limited loadcelll
Unformatted Code Detector
LiquidCrystal_i2c greater than i3
Can not open Ardurino hosted website
Multiple string command
High voltage current measurement
PWM converter, need help
analogWrite vs SoftPWM
Stay until new value comes
Footage Counter on a Sewer Camera
Help! Project 14 Tweak the Logo code error!
NRF24L01 COM problems
Need help with checking code and circuit diagram!
How I get 100 hz frequency in arduino mega 2560
FSR sensor comparison data in using Arduino Array
TTGO T3_V1.6.1 Bluetooth Functionality
Rc excavator project
Arduino to Arduino CRC
Need help with delay function
Display does not start on power on
How to set synchronous PWM channels on Due, that would have pulses shifted by half period?
SD.Begin does not initiate!
New Arduino Uno Mini Issue
Cc1101 receive from unknown transmitters problem
Clearcore modbusread and write using the erthenet port
Servo motor sweep and LED blinking using millis
Lm 35 temperature sensor
Program error questions
FastLED: Problems with rainbow cycle
Just starting and need help
Why always error when iam going to use simple http project, Is it because of the driver?`
Need help in Loop cycle
Guru Meditation Error: Core 0 panic'ed
Can i take these 3 bunches of code below
Arduino big project problems
Saving values in array by pressing button
Data sent api server with ethernet 400 bad requests
CAN BUS not displaying all data
</>(Uno R3) I'm trying to set up a temperature sensor and an LCD screen to display the temp. Can anybody Help?
Hello team help
How can i save some storage ? 104% is used and i dont know what to do better :(
Gardenpump problem - problem solved! Sorry - logic mistake: need to use long int or unsigned int
ESP8266 D1 Wifi board, can't find the port on MAC OS
Displaying error values if no input from Analog ports at MEGA2560
Check if the pump is High or Low
14 line error aa raha hai
SPI TFT LCD on Uno R4 Minima
Arduino Pico Project - Drop test of CANSAT model satellite
LPS28DFW arduino
Putting programs in flash
How to make tsop
Having trouble with void setup
Controlling Stepper using incrimental rotary encoder and arduino
The necessity of a power supply module
Arduino MP3 player controled by 433MHz RF receive
Checksum calculation leading to crash (dividing by 0)
Total Confusion
Cunsumtion of LoRa module is 1.2 mA in deep-sleep mode
Interfacing the RS232 to TTL with Raspberry pi pico using arduinoIDE
Appropriate connections
Controlling relays based on inputs
Two different components, two different baud rates
An light light ring with wifi and bluetooth
Unable to send notifications when creating a Bluetooth service using ArduinoBLE and FreeRTOS
Connecting sick scanner and arduino
Auto Reload Local ESP8266 Web Server
ESP8266 is not connecting to my wifi
How to reduce the size of a sketch if it's too big when using enc2860 module and arduino uno
Arduino uno Input problem
Tarda en compilar
Problems uploading to arduino nano
Project guidance
Wireless Platinum Resistor Sensor
Problem using tensorflowlite and esp32 cam
DRV8834 stepper motor not working
Esp32 tony bot code lost
How to know if something is receive in PWM
2 bluetooth HC-05 sending data to one Arduino containing another HC-05
Extract a number from a gsm module text
I2C and servo conflict?
Code and diagram help(i dont know why when i run the simulation the motors do not start miving)
Need help to replace delay() with millis()
HMC5883L not working
Vixen+Arduino lights
Ultrasonic sensor and sd card
Can't display animation using u8g2 library
Using the bool function to monitor led
Two I2Cs components works on uno but doesn't on nano
Arduino Reads Random Analog Input
Analog input spikes
Arduino Script for Triggering Stops after ~50 sec. on Nicla Sense ME
Led programmable
'countof' was not declared in this scope
Newbie Errors I’m working though, but need help please
Getting a motor to run for x amount of time then stop amd rum again for x amount of time
Error shown is this c:\Users\Zarulmiqhail\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp: In member function 'MFRC522::StatusCode MFRC522
ATTiny85 and long int
Using Arduino to glow LED with every pulse of Rotary Encoder
Project on automatic parking system
Faster sensor readings
Simple Button Issues
So I need help with a scoreboard for tennis
How do i get my sketch from arduino cloud?
Using nrf24l01 with nema17 and accelstepper library
Project for school- Input of sensor signals in the range 0.8 - 3.2 v
Building and displaying html on a TFT
Esp32 menu... please help..!
Hey may i know how to sum up a number up to infinity by 1?
lcd.setCursor(0,1) makes wrong value
Board Stability on OOP
Im working on the project to read data from the imu9250 with two TCA9548A mux by connecting each imu on the both mux
I want to set the PWM frequency to 500khz
How to use different fingers for different relays
Stopping a looping profram
Redefinition of "String UID"?
Inputs on clock keep going off
Arduino nano 33 iot compilation error
Stepper motor drivers designs implimations
My Rx, tx, and l is on but not uploading a sketch
Can someone help me please? pir program
Voltage converter for many inputs?
Open Loop BOOST Converter with Arduino
Servo Motor Freezing
ATtiny10 PWM generation
Help me with thissssssssssssss
About uhf arduino code?
LED Matrix not working correctly
What is it about this community?
Project discussion : water level indicator with auto cut off and purity checker
Help Needed for NILM-based Load Disaggregation of Fans and Mixer Grinders
Can't compile examples from Seeed KCT202 library
ESP8266 communication and wired network
Newbie: MAX7219 Problem LED's all are lit however NO TEXT
Compilation error Arduino
Stopping a remote control vehicle
Arduino Nano Compile Error
Writing a code for a bowling score calculator
Problems with interrupt function
Arduino Stepper motor Weird response
How to Change over relay 1 and relay 2
Cuestión de practica
Using a nano RP2040 to make a gimbal
FastLED, switch off Modul?
Need help with code to trigger a relay and a switch button together
Wireless Temp Monitoring UNO/MLX90614/NRF24L01/OLED
Audino pin voltage is low
Libraries not playing nice : AccelStepper + Adafruit_NeoPixel
Control y servomotor
Force Sensor Resistor to display weight and voltage
Graphical Programming Document SmartRobot Car 4.0
Need help with my code for a 8 digit 7 segment display that increases when a button is pressed
7 segment diaplay
Next bus stops notifications arduino
Trouble's with UNO R3 / LED's
Help whit thi program
Control stepper motor with single button
Placas expansivas
How do I connect an H bridge to arduino?
Arduino-cli work offline
Can someone please tell me what I am doing wrong?
My Buttons just start going haywire when theres a lcd i2c on it
Turnin on light in room with photoresistor
Help on turning song on and off
LCD Screen Glitching, Resetting
Rs232 to max232 timing issue
Can you guys help why this is blank for my monitor
Esp8266 stop send data
Using a potenciometar to set variable value
Controlling Baudet clock timing problem
Arduino no me funciona con el transformador
Arduino nano power supply
How do you go to a specific void that's in a order?
The two classes work perfectly independently, but not together
Conectar mas de una pantalla oled i2c en arduino
Question about led cube code
Connection problem with arduino nano every clone board
Make two serial.read run together
Mikroe 1577 that uses MPU6000
Need help! New to arduino
Multiple libraries: how are they chosen and updated?
Need help. thanks
How Transpose note of a MIDI keyboard with Arduino Mega
When will be Student Toolkit of Arduino available to buy?
How String Hex to dec
Connectivity between pins but one pin may have another signal
Arduino analog input causing problems
Sensor design with arduino
Esp8266 refuses to connect to wifi
Suggest parentheses around comparison in operand of '|' [-Werror=parentheses]
Arduino and Assembly
Not getting data from PMS5003
Arduino only works when connected to USB
Is it possible to execute a binary from LittleFS on ESP8266?
How Serial read work any explanation
Nano 33 BLE beacon advertising
How to run stepper motor NEMA 17 driver L298n and load cell HX711 simultaneously
Panasoni̇c cdc help please
What's wrong with the signs? I have reviewed the program many times
Servo motor problem in Serial data transmission between Arduino UNO and ESP8266
Telegram bot wifi
Can't get anything to work
HELP PLEASE: avrdude: WARNING: invalid value for unused bits in fuse "fuse5"
Error con sensor RFID y pantalla LCD I2C
Converting char array to string
LCD KetPad by Robot hookUp for Mega328p Rev 3
Using snore function for ATtiny 85
7 digit number voice command with DFrobot gravity
What relay to use?
Need help with the MEGO board with WiFi
Noritake VFD with BPI216 Interface
Delays to millis
ESP32 Dev Kit Compilation Error
Print distance and speed on one line
Unable to get a Gy-33 TCS34725 sensor to report colours
Sensor for when Arduino moves?
Cloning drives on the shield
Arduino Bluetooth Car
I2C freezes when more sensors are interfaced with arduino
Stepper motor stops every revolution
Please correct my code
2 analog values to one digital pin
Arduino BLE to micropython board
Help with GxEPD library
Arduino Nano 33 BLE code
Variables and constants in RAM (global, static), used 29640 / 80192 bytes (36%)
Error Currently nRF24 RX is only supported for ATmega328P
Ultrasonic sensor and vibrating motor are not working
Making a fountains show with Vixen 3
Arduino MKR1010 WiFi disconnecting
New Beee Web Editor intermittent connect
NeoPixels not lightning as programmed, it code or circuit?
Radiohead lib and SPI CS pin
Controlling multiple servos with potentiometers
DFplayer mini not playing any sound issue
I need help with mpu6050 library
Help for understand the operation of the circuit
No Matching Function for call MP3
Need help with building a Bluetooth NFC reader
M5STACK Serial.begin(9600) breaker serial
Sharp dust sensor with MHZ19 C02 sensors in lcd display
Acs712 Please help
GXEPD2 with RPI pico W
Stepper motor distance control
How to skip over a line of code when hardware isnt returning the result
Robot Moving Unsolicited
MPU605 with Accelstepper
Open smart rich shield two - looking for documentation
Some LED Trouble
DC Motor Control with IR Receiver and VNH2SP30 driver
I am trying to connect MPU9250 with my Arduino UNO and I am getting this error while uploading the code
Problems with libraries
Oonie Island Walking Stick 911
Servo Motor controlled by inductive sensor <HELP>
Using Arduino to Calculate a Value
Mcp4725 rectangular pulses
Data Logger for Solar Inverter
Communicating data from Arduino to Pc via HC-05
Contrast sensor Leuze KRTG20
GIGA R1 error message
Arduino Cloud Scheduler responding to UTC time instead of Local Time
Traffic Light System in RTOS
Alexgyver's nixie clock
Wrong spinning servo!
Using 4x water flow sensors (yf s401) with arduino mega
Problema con pcb y ATMEGA2560
Alphenol NPA700 sensor IIC address change
I need to read an RS485 port modbus half duplex communication and process data. I have rs 485 to ttl converter.can some one give code for reading data
Trouble ESP32 wroom with Vl53L0x and multiplexer PCA9548A
Help for an high and low on a pin
Arduino error :Error:expected unqualified-id before numeric constant
Arduino serial monitor giving constant value for pressure drop measurement
Joystick.h - Can I change the button count on runtime?
RTC Gives wrong time after few days
PWM reprate software
Busy Timeouts using Wavwshare Board
Cannot upload EX_Rail Sketch
Code to detect radio waves not working
If there is a service, feel free to talk about it
Joystick button, EEPROM, servo motor
RC car custom made
How do i solve this problem?
Writing to LCD (20x4) with SDA & SCL
ADS1015 ads.begin() and serial monitor not working
Bomba de agua-puente H
Error compiling for board LOLIN(WEMOS) D1 R2 & Mini (with Telegram & WiFi)
MCP2515 CAN Module Receiver not working
Compiling problem
Using MAX30100 and MPU6050 with ESP32
Calculate equilibrium potential Vq without current (Ip = 0) using ACS712
2x DFRobot Micro DC Motor with Encoder, TB6612FNG Motor Driver Board and HC-SR04 Ultrasonic distance sensor
Help with compiling
Add <IRremote> to library
I have problem in automatic transfer switch it doesnt update pins on arduino nano if i run when main supply is on it display supply but donot update
How to read more than 8 cascaded shift registers with SPI?
Controlling a Servo Motor with a Push Button
Arduino DC variable speed water pump speed regulation
No such file or directory found when save at different location
How to fix Exit Status 1 Error
Servo does not hold position/glitching
3.7 Designing a Motor Control System - COM port error when trying to run externally
Feather M0 Adalogger independent operation
Problemas con Arduino
I would like to know where to find more info! ("simple" wireless charging case)
Average Pressure Sensor Readings to Boyles Law
Como utilizo un ENC28J60 para mandar datos a ThingSpeak
Microstep driver settings
'player' does not name a type
Gsm sim900A not sending sms but showing symbols
Code for water level indicator
I am trying make 3 different types of mass measurements using 4 force sensor I got some errors
Help with Arduino Relay Motor Control
Connecting Water Level sensor to Digital pin
How to use random for button1 turn on one random led and turn led off with button2?
Problemas con los sensores digitales y analógicos en la conexion inmediata usando el esp32 ttgo sim7600g
Servo Motor MG90S is not working. Always givea a tick tick sound when passing a command through UGS
Home project, def not an expert
Control stepper motor by potentiometr
Ultrasonic sensor troubles
Arduino code uploaded succesfully but doesnt work
FastLED WS2812B ATtiny85 color change with button
Arduino halts and L LED blinks
I have this code, that moves a platform, but i want to put in the beginning one "read" to left or right and change the code to move to a different way
Poner un temporizador o leer entradas mientras esta un delay
Sensors Not Working Together #BMP280 #NEO6M #SDCard
School Bell System using ESP8266
Life meet lightning's FastLED tutorial not working
Bluetooth HC05 and Smartphone
TFT Movie Question
Need help in displaying data of device showing on it's LCD on a computer screen
Compare First Value with the New Values of Load Cell
Larson scanner coding issue. please help
Ardunio ethernet shield
Can someone help? I am new and I can't seem to get my functions to work an compile
ESP32 code for Digital lock
Using relays to operate a 12v Linear actuator with time delays
Esp32 keep restart after connect wifi
HELP, it's for a school project
Is this possible?
Convertidor ADC para Arduino
When the LDR hits a certain number spin motor for 10 seconds
Watch dog Example R4 nano
espALEXA port 80
Enabled, or enabled?
Need to control 37 digital I/O pins with different states at once
Faster speed microstep code
External clock/xtal not worked in atmega328p-au 32 pin MLF package
Inductive proximity sensor
How to show my random time on my 4times 7segment display
If statement problem
Trying to work with 3 analog sensors in one Arduino
MKR1310 CHRG led blinking and the device stops working properly
Unable to communicate with uno on serial
Error uploading the code
Smart Stick Project with Arduino
how to program new buttons using an existing sketch
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno" weatherSample:1:10: fatal error: Wire.h: No such file or directory
Arduino esp32/Photoresistor sensor not working
I need to connect these motors in an esp 8266 and control it with lot blynk app or other platform.
Interfacing Arduino UNO with Logitech 3D Pro: Code Troubleshooting
Countdown timer misbehaving
Trying to increase a variable when Ultrasonic senses a certain distance
Control the speed of servo motor
Transmit Arduino Sensors Data to Nodemcu using RF Module Transmitter & Receiver
Error in reading data from EM6400+ Energy meter
Nodemcu and LED
Sine Wave - recurring break in waveform pattern?
AS1115 do not blink feature problem
Uploading error in Arduinodroid
Nicla Vision how to upload RPC_m4 example Compilation error: exit status 1
Led pattern using push button to turn on all leds problems
Using nano to activated up to 8 songs on a dyhv20t after using a micro switch
Reading multiple Honeywell MPRLS pressure sensors on one Nano
NFC shield and Arduino
Not able to perform register level coding on Arduino MEGA (Atmega 2560)
Error code in setting up
Overheating FETs
Bluetooth problem, please help
Puting stuff on a grove 128x64 oled
Need wiring diagram for 5pin LED strip
Arduino_LED_Matrix should on() only turn on LED and off all the others?
Sketch Upload not possible on ARM Cortex-M0 Processor / SAMD21 Board
3,3V port doesnt work
Program ATmega328p using BT module HC-05
Passing steering wheel control signals via I2C
Working with Remote
Arduino data retention
Need Help A9G connect to internet
Arduino uno recognized as midi and not as Com (help)
A fatal error occurred: Timed out waiting for packet content esp32
Will my WebUI output still work if the Arduino UNO Q has no internet connection?
Arduino Uno error
Unable to upload to Nano Every 4808 /4809
EEPROM and AVRDUDE weirdness
Avrdude: ser_open(): can't set com-state for "\\.\COM7"
Sim Card can't get o the network with sim900A
N424l01 wireless fireworks ignition system
Http based project
Gsm A6 reproducir MP3
Controlar una placa de rele
I want some advice
Sms Controlled Servo Motor | Code stuck in sending STATE block
Got problem with coding call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
How can we solve the lag problem of push button?
Random movement of servo and adding neo pixels
Using the TTL to rs485 module, I'm using max485
ZMOD4510 Gas sensor RENESAS
Trouble Communicating with MaxiMet GMX600 via RS485 and Arduino (Modbus)
ESP32 not discovering BLE Device during scan?
Temp is coming out in the negitive
An initial blink issue
Servo turn every 12h with RTC
Dancing Tito 3D Printing Porject
Read issues on LCD 4 bit mode
Opta RS485 port not working
Need Help , How to show Serial data on blynk
Flux Capacitor by RadBench
Motorshield with 8 dc motors
RPLidar Values are inconsistent (Any help is appreciated)
Tutorial shiftOut12 werkt niet correct bij mij
Arduino bluetooth hc-06 car
Arduino Uno R3: The programmer is not responding
Sending serial commands while Serial Plotter is running
Serial.available bugged when Serial.print'ing while data are incoming
Arduino Uno - Windows 10 - Driver - Error
ESP-8266 Receive Data Thingspeak
Interrupt conflict
What board have I got for first project
Help needed for project due 6/3
Need help: my code dosen't work on my uno
Nextion display problem
My serial monitor is printing garbage
Float value on Nextion display
"PWM vs. Full Voltage with Gear Reduction: Which Yields Higher Output Torque?"
I'm selling my Arduino Uno and many more IoT components at half price
Code even for ESP32 too long? (can't be compiled)
Hola soy nuevo en esto y necesito ayuda. Me hace la función que quiero pero al momento de hacer el print hacer varios ala vez sin presionar el botón
Openrb-150 and ax-18a
Multiple serial devices , ESP8266 & E32 LoRa on Pro Mini
Ubicar libreria ds3231 que corresponde a este código
Strain gauges with arduino
Proposed change to the forum guide: ChatGPT
Issue with nRF24L01 module and arduino uno
Arduino curcuit keeps freezing
Using a Benewake TF mini plus Lidar to create a 3D point cloud using Arduino
How do I make my Mega 2560 check if something has changed ten times a second?
How to Read Speaker values from some device to use as if function
I want to make call using phonebook number
Help me please with this
Trouble LCD display(beginner)
Noise produced in Encoder signal using Arduino while noise absent when using alternate GND connection
Problem with IQS7211A and ESP32 while using Wire
Issue with Using libraries
Pressure sensor wrong output
Help selecting a MOSFET
Need help to store data to eeprom
How to change outcome if previous statement occurs
keypad error: Keypad was not declared in this scope
How to combine these two codes
Using nRF24L01 to create arudino transmitter and receiver
Led binary converter with manual number inout
Expected "}" at end of input
I2C sensor No device found
Changing the lenght of a millis with a potentiometer
Fatal error : EEPROMex.h: No such file or directory (Need Help NOOB)
Need help with factorial
Mosfet closes, but signal is not grounded fully
ESP32 compilation errors
Problem IOT remote app android
I am making a simple automated irrigation system but the arduino is resetting when the power supply is switch on
4 relay modules do not work sequentially
LED matrix 5 x 5 using arduino and breadboard UPDATED
USB Host Shield "OSC did not start"
Frequency meter
Help with arduino uno not uploading
Compialtion error on uplaod to Arduino Nano using Arduino IDE 2.3.2
Set font alternative
digitalRead timing out in while loop?
Turn on a pump on and solenoid valve
How do I access the rules of this forum ?
New to Arduino Need help with project
How do i make it accept the binary data using the stream , in an array and then in a for loop it will turn on 3 led's
Need help: microcontroller works when plugged in to computer, but not when connected to power supply. Ruled out as a software issue
LED light Strips coding help fade effects
DF Player Mini Working Problem
Controlling Speed of DC Motor using Serial Monitor
My Nano Clone is not working but I have the drivers installed!
Automotive Gauges using Arduino
Float() or (float)
I got this error while i try to compile my code
LED blinking when clicking at one button
Controling relay or valve pin with serial input
Hi i am trying to read some date using "uart" from the "UHF rfid reader"
A one wire communication program with problems
Cannot convert 'uint8_t (*)[160]' {aka 'unsigned char (*)[160]'} to 'uint8_t**' {aka 'unsigned char**'}
New to ESP32 chips. But IDE Refuses to Compile! (error 255)
My code for 5 servo motors are not running repeatedly on the hardware ,it just runs for one time . Kindly help me with rectifying the problem
Arduino Code is not working, Anything is Wrong with it?
integration of servo code into my programm
How to increase the frequency of data collection per second and record the data upto 4 decimal point
Lcd 2004A Show nothing with I2C
Joystick 2 servos x and y postitions
Need help with Mega Sensor Shield V2.0
Solar Powered Ventilation System
Arduino uno board
My stepper driver won't light up
RFID MFRC522 Read personal data
Device is not responding
Hello, how can I change this code with LCD 16x2 to LCD with I2C?
Need help combining sketches
Wireless serial communication doesn't pick up signals after reset or power cut of receiver side
Connecting multiple IMUs to an Arduino Nano 33 IoT
Arduino uno storage capacity
Analogous data from sensor & requirements
Not responding to software
Can i read pwm from an output and serial print it?
Not shure if connected dallas sensor correctly
Code Help, 4 inputs per hit
Fallo de comunicacion ST7789V
Servos keep failing after some time
Small Arduino code consumes high ram usage in VSCode compilation
Infrared Sensor not working
Line following robot package picker
BME/BMP280 code crashes at bmp.begin()
Nano Every burning hot and upload fails: "sign-on command: status -1"
Float value send
LCD with i2C connected to Raspberry pi 4 not working
Serial Port not working well
Serial port read error please help
Trying to figure out free fall detection with a LIS3DH module
Water Leak Detector
I have a HCM375B sensor
Convert from Blynk to Arduino iot cloud
Issue reading RPM of fan
Stepper control with buttons for both directions, loop for positioning
Read temperature from 6 PT100 with ESP32
Programming - EEPROM
Code Problems while trying to run Tensor Flow lite CNN model
Sequencing two sets of leds
Stepper motor driver for NEMA 34
Trying to create a smart bike lock whats wrong with my code/circuit
Several seconds of lag on serial processing
Debounce with keypad.h
Getting multiple readings of DHT22 sensors using esp32
How can i make automatic light switch? arduino
RS485 Soil Moisture and Temperature Sensor with ESP32
Neopixel Lamp - Animation Bleed Question
Motor speed and count control
Vehicle counter using Arduino and loop detector
Arduino relay not working bluetooth
Dc motor cant rotate
What could be the reason for these unstable analog readings, and how can I stabilise the output? Should I add a capacitor for smoothing, or modify the
Pules Counter with Output 3V
Led is blinking at starting of the code or ESP32 board
Exit status 1 'Serial' does not name a type
What code is necessary to make a potentionmeter work like a clutch?
Floating point number via serial
About Nano TX LED
Servo acting wierd, pls help
Laser Colour Sensor
Generation of sine wave using arduino due
Help with Serial Communication between Arduino Uno and Raspberry PI
Help writing code for actuator control
Sensor lm35 no da lectura
Can't use Adafruit_PWMServoDriver
Help simplifying nested code
Problems with communication between Wemos D1 Mini and Arduino Mega
Encoder knob count limits how do i do it
PIR sensor based security code for esp32
Ultra precise 29.9Hz ApertureWheel (with control and display)
Arduino pixelstrip battery issues
Parts Tracer - Arduino UNO
Problems in reading Temperature using MAX31865
Multiple weight sensors and results to appear simultaneously on a pc screen
Compile error: '(functionName)' was not declared in this scope
Fatal error in script
Expected HTML GET response only with cookie statement; And I can't get data for my website
Glucometro con arduino
Controlling temperature of Nest Thermostat with Arduino
Connecting problem to servo +moisture+ir sensor
Changing Motor Speed
Weather Station Compile Library Errors
USB Port Overload / Arduino Not Turning On
Hi every one I use mpu6050 for self balancing robot when I Scan the element i use this program but still shaw me 'scannig i2c devise'
Convert String to unsigned Char [16];
Esp32 reload program after wifi cut
Multiple Sensors Powered by single Arduino Mega
Image on the html page and get the value of the variable
Esp32 cam master and slave mesh network
Two different conditions in one function
Problem with the code for led project
What's wrong with this as the picture shown?
Me ayudan a unir estos dos codigos
Cant Read Linear Motorized Fader with Arduino Uno
Arduino should react to music on Computer without Microphone
Leer señal de un sensor de presion de 4-20mA con modulo ADS1115
How to add more meteors that overlaps and overtakes this first meteor at a faster speed
Arduinio Send TelNet Command for server
Forum member 'ranks' ('Jackson' for example')
Temperature Humidity Sensor
No data printing on serial monitor after sending data from xbee console to serial monitor through serial communication
GxEPD2 with multi displays
Code error I checked everything and didn't understand where I was wrong
Arduino and CAN bus module not in operation
"_ledonn_"was not declared in this scope
Digital dice using 7 segment (arduino)
Steper direction control help
Single/Auto ADC conversion in ATtiny
Esptool.py error wile uploading code
Why i can compile code with obvious error
I need help figuring out how to fix this error code. Can somebody please help?
Programming ESP32 without pressing the boot button
Lcd Screen not diplaying anything
Flow sensor and two relays!
Controlling coreless motors with Arduino via MOSFET
Interfacing AHT10 with 7 segment display
Need Help with Dim 7-Segment LED Displays Using PCF8575
Wiring Modbus mkr 485
Ardinyo123456789
Joystick was not declared in this scope error
SSR Relay latching
3 phase inverter using IGBT to convert DC to AC Voltage
Shock detection Arduino Nano ble
AS608 Fingerprint and ESP8266
Pride2015 code on attiny85
IR Sensor Detects One Time
Can you code use and code python on Arduino
Atmega64a not working
Attiny85/ etup_watchdog was not declared"
Help With ERROR- RTC SCOPE NOT DECTED
Arduino UNO + zdm-2ha865 Driver
Lto-wrapper failed (another one)
為什麼這樣不行!拜託大家幫忙看看 (Why doesn't this work! Please help everyone)
Using two hall effect sensors on a dc motor with multiple of these
Once procuctC =5 I want the boxC to add one to the boxC
Arduino offset from reading a mV voltage! HELP!
Oscilloscope repair
Slow optocoupler turn on/off time
I2C scanning (I2C scanning... )not show the device address
Need help! ASAP make a code for Water leveling sensor
Error compilation for Arduino IoT Cloud
analogRead after disconnecting ADC module
Error:- invalid header: 0xffffffff
Project 9 of the starter kit does not work for me
Problema de conexión ARDUINO UNO y driver L298N
Pure "C" Hello World
I can't convert string to int
Can not see the magnetometer values in the Serial Plotter
How to retrieve data simultaneous from three sensors and create a loop system?
I'm trying to activate different LED flashing modes via a push button
What do i need to make this circuit work
No USB connection after a long runtime
Multitasking led neopixel adding other function
How do I use RTC DS3231 to trigger a servo at a specific time of the day
Map() function data types
Generating 10us Pulse Width signals
Unable to transfer code form HC-05 to arduino nano
Stepper motor problems
My code output kept changing itself. How can I fix it?
My servo isn't working. PLEASE HELP!
Arduino-RPi communication via alternative UARTs
LED Pin Controller Help
Consistent -1 return from BTSerial
Dont know how to calculate what i need to have
How to store serial data to a variable for temperature data
Predict function predict(input, output) supports either int/int or float/float.?
Nano 33 BLE Sense Project
Need assistance with the loop function
Nrf24l01 problem occured
Nano Audio (Auduino Synth) Project Schematic Check
TIP120 switching 12v 5a
Using touchscreen to simultaneously control LEDs and servo
Help with multitask
Servo control with RTC on Arduino uno
Esp8266 + st7796S
Speed warning light
Code humidity sensor
Code for Multiple Lasers
Nano 33 IoT comnection help
Issues with arduino libraries
Can someone pls correct this code
Temperature sensor reading when disconnected
Unqualified ID before void
Uno HC-05 Software Serial No response to AT command
I have connected my stripLED connected to a pin set as an output and I would like to control it with 3 or more pin inputs and I couldn't. Help me
Need Help with the Arduino using a relay and a temprature switch
Arduino Uno board problem
Can’t make this stepper motors work
Arduino UNO, OLED y Serial - No responde
Constant Error with no Error Code shown on HM-10 with Micro:Bit
Arduino I2S Audio Sampling with Audio Smoothing Loud Sources
Always comes with one extra zero as an output in Available command
Can't differentiate Oxigenation sensor Max30100 and Max30102
Uploading Problem
Self stabilising spoon
UART communication problem - serial port monitor
Making MP3 file play through speaker using ESP32 and RFID-RC522
One_Wire_bus get 85 or -0.06
RFID not scanning
How to resolve this error
Trying to connect pH sensor to esp32
DFRobotDFPlayerMini.h Libra is not working
Servo Motor not working properly, moves on its own
Simple blink code or any other code not running in my UNO
LED Control with Nextion HMI
LDR Problem (Do I need to Add Something Here)
Arduino nano Flysky
Arduino Mega controlling large servo, noise/grounding issue
Retraso con el puerto serial de Arduino
Error when testing ip
Help with my arduino library: no such file
Nextion enhanced series - ComboBox
Downloading code
Ultrasonic sensor problem
Unprecise measurements with HX711 and Wemos D1 Mini v4
My code is not working it is not upluding to my arduino nano
Help me please :(
Read NMEA2000 from Airmar DST800
set servo angle
Luftalarm
HC05 - not working, any help? (arduino UNO)
Dc motor control with L293d and Arduino Uno
What Kind of Motor Is this?
LCD will not print when it is inside an if loop.
Device for traffic counting device
Upload problems
Redboard plus and weather shield
QTRX-HD-02A sensor reading only low values
Blynk and wifi problem
Arduino IDE support for Terasic DE10 Nano
All of you who love programming, I have a little challenge for you
Accelstepper with serial communication
Odd problem with Nano 33 IOT IMU
Waveboard esp32 hulp
Running Stepper Motor
60vdc, 50A pulsing with mosfets, 1-10Htz
SSD1306 and TM1637 incompatibility
Arduino error message jan21
Pen plotter-CDLC7
Serial monitor not displaying anything2
Battery selection for my project
Arte sonoro, Sensor PIR como pulsador en DFPlayer (reproductor de audio)
Maxon motor interfacing with ardunio
Unable to flash ESP8285
Initialization of the optical flow sensor (pmw3901) failed
Coin acceptor problem with false pulse reading
Apps Script link being moved
Sonoff TH16, Arduino nano, AJ-SR04M
Advice for building my own as simple as possibile stepper motor driver
My esp8266 overloads for no reason
4 button's to control 4 relay's
Connecting arduinonano via UART to tmc 2209
Error while compiling: "undefined reference to loop"
Need help with encryption for an arduino project
Connect keyence laser sensors to Arduino
No Voltage on pin 11 Arduino UNO
How to get a constant color from RGB LED?
Hilfe bei einem sketch,, Problem exit status 1
Program showing error
Uploading doesn't work
Sevseg kamu sama dengan aku namun saya susah mengatur desimal nya
Sensor MPXV7007DP
Countdown time using TM1637
How to use this forum - please read
Gpio pin not turning on
I am facing this error all the time with blynk on esp32
Nano not recognising board
Problems with led strip
Epson l805 - p50 - t50 Printer encoder pinout pls help me
XBEE conexion con arduino y emision y recepcion
Measure pH, conductivity, temperature, humidity, nitrogen, phosphorus, and potassium using the JXBS-3001-RS485- SOIL SENSOR
JuncTek KG-F Batterymonitor Library
When reset, should OPTA execute setup() again?
Is there a way to clear the screen and have autoscroll in the same loop?
Connecting a motor to an HMC5883L type magnetometer
PS/2 to MSX mouse converter
Car Doors Check Control using a OPEL TID Display
Compilation error: 'lt' was not declared in this scope..... line 78
Using Modbus (RS485) storing sensor values
Instrumentation project
Compile error ddddd
Catnip I2C Sensor not Working
Arduino only executing instruction once, then stop
Code Arduino Not Working
Simply running ESP01
Dummy question re neopixel
Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND) Camera init failed with error 0x105
I am making a biometric attendence system
Orbion 3d space mouse
Mdns-discovery problem
My encoder motor doesn't want to work with my programming; Why?
MPU6050 para controlar angulo de un instrumento que mide un motor
Problemas na programação
How to tune EKF for attitude estimation?
Unable to write to the modbus slave register
To receive a GET request from an NGROK tunnel on an ESP32
Please Help Me With the Circuit System
Interfacing an Ultrasonic Sensor with Arduino
How can i fade LEDs concurrently and at different rates on a PCA9685 chain ?
Introducing ArduForge - A visual node-based code generator for Arduino (Open Source)
BLE writevalue help
Interference between LCD and Stepper
Why Is My Arduino Code Not Producing the Expected Output?
Simple IR Sensor Program
Descriptor is empty in android logs, and only 5 characteristics are shown but i have defined 6
Esp32 WIfi manager auto connect and send sensor data
LD2420 Not Working with Arduino
I Need Help with Delay Function Code for Servo
Strange Analogue Input Readings. Is my board Broken?
Buzzer not working (problem in code)
Sim 800L false trigger
nRF24L01Communication not allowed immediately after reset on transmission
Serial data Transfer
Why can't I use if else to change the color of the RGB led?
MCP23017 Not Working
Arduino Nano LCD Display
Using rotary switch to toggle between microstepping options
How to control motors with a keyboard
Continuously read EEPROM value or read EEPROM at setup() once
My Motors work differently
Hardware Compatibility Check for Automatic Curtains
Hoe haal je het meeste uit het forum
Hid device programming help
USB Host Shield With Arduino And Keyboard Not Working
SD card modulator not working with pin moso and mosi
RC combat wing servo mixing and hardware
How to get the best out of this forum
Arduino nano connect and disconect repeatedly
Arduino program not working properly
Tips how to get working code from chatGPT
Multiple steppers with ContinousStepper.h library
I2C accelerometer not working with Arduino. MXC6255XU
Encender 8 LEDs y apagarlos cada uno con su respectivo push
Solid state relay and mosfet triggering using Arduino Mega
IoT dashboard help
PWM on Piezoelectric sensor
Best way to optimize Arduino sensor data logging without losing readings?
DS18B20 Strange Behaviour Using One Wire
Problem trying to publish library
Demultiplexar en CD74HC4067
NFC reader on Arruino Uno WiFi Rev2
3 floor elevator
Tree ethernet shield in network
Providing stable current on arduino Nano
Arduino Code Assistance
App syncing for DC motor, and servos
Problem with servo
IR Sensor operation
Sketch size and memory
Proportional Valve
Modify mpu6050 display
Problem in uploading the code
Libraries missing after updating "Arduino UNO R4 Boards" to 1.0.4
After connecting the display, the values are not updated
Modbus ESP32 Timeout
Troubleshooting I2C Communication and Data Inconsistencies with SHT85 Sensor in Arduino Project
Which arduino nano clone I have
Change of LSM6DS3 acceleration range
nRF24l01 not receiving data struct
Arduino Uno watering system with moisture sensor
Help not irritation
Control blinds with ESP8266 and Home Assistant (MQTT)
I want to turn off the components after 5 seconds if the distance remained constant
Help with ESPNOW and UART Serial Comms
Dim single color LED strip not working at max brightness
Problems with PulseSensor_Playground libraries
Sending data from arduino uno to ai thinker esp32
The error I am getting while I am running the code (RADIOHEAD)
K-LD7 with Arduino uno
Model railroad crossing gates
Problems with line follower
Ac motor speed control
Trabajar 2 Sensores DHT21 en Arduino Nano Esp32
Create plugin issue
Missing xcrun error message when uploadning code
ESP32 Partition and chip size
Arduino Nano BLE Transistor Issue
No encuentra puerto en mi Mac
I am Making an Voting Machine So How Could I Disable Switches So That I Can Receive One Vote at a time
MAX30102 led is not lighting
Ds3231 does not save when power is cut
Esp32s3 video server with motion detection and sms notification (sim900)
Arduino data to Siemens PLC
ESP-01- esp8266 + Ch340c does not work
eeprom_resetEeprom error
ESP32 BLE Unique Identifier
Atmega 328p microcontroller
Making RGBW LED's Change color with each button
Trying to use a rotary telephone handset as input
Problema con Esp8266 conectado con dos max7219 y displays de 7 segmentos
Print int value problems u8g2 lib
Why does it show me this when I select the arduino uno that I am connecting with my wire
Can anyone help me fix this for my ICT project?
Fatal error: bits/c++config.h: No such file or directory
"Blink LED" App fails to start: "error: 'MsgPack' does not name a type"
Arduino Mega+ESP8266 ESP-01S sending data to Google Sheets
Señal pin digital y sensor fotoelectrico
Leds to be turned off immediately when I turn off the switch
ESP32 static IP doesn't work with SMARTPHONE? NO SOLUTION POSSIBLE
Problème de précision de temps
Save data to array then plot in serial plotter
When I enter a digit on the project keyboard, it is overwritten and does not break the line to be displayed on the screen
Accepting x,y,z coordinates in real time
I need help with u8glib
Reverse loop for model railway`s
Mystery exit status 1, without comment, building from source
Bomba centrifuga con bluetooth
Water pump and strain gauges with arduino
How would I read the current from a moisture sensor connected to a analog pin in arduino?
Need AT Commands for RTL8720 bw16 module
Help Using STEMMA Connector on Adafruit VL6180X
Arduino R3/WAV trigger digital pin output
Arduino Oled code help needed
USB powered relay for arduino
Countdown timer with LCD
Exception shown in Serial Monitor when running sketch on ESP8266 board
I2C Magnetometer and Encoder conflict
How to stop buzzer sensor?
DIY Colorimiter
I have just a little problem
16*32 RGB LED matrix display issue
Using 2 sensors for 1 event. Having a problem writing the IF-ELSE
Ic l9110, esp32 doit devkit v1
PCF8575 expansion board input not pulling up
Programación mini motor
Suddenly change in value
Arduino Uno with IR receiver
GSM Module to Breadboard
Enviar caracter dependiendo del valor de giro de sensor mpu6050
Arduino UNO TX and RX LEDs are dim when ON
Text data to String var
Ui for arduino uno
Connecting printer encoder
Need Help! Can't get Servo motor to work with the Ir sensor!
Buzzer working fine when i use 2.0.3 version but does not work when i use 2.2.1 version of arduino
Does anybody used the RN131C in Arduino 2.x.x?
Trying to use HiLetgo ‎3-01-1247-25A
Help on my LCD project
Arduino Waveshare 7080G Vodafone M2M SIM
Arduino <--> Raspberry PiCM4 Serial communication very slow
Nearly SOLVED Using While function is only giving a partial answer
Can't print on Nextion from esp32
Energizing two arduinos
Advice on database for pet feeder
ESP01 pin rx tx no working L298N
Relay is not working when supplied 5V
Load cell display highest value
ESP32-S3 + ILI9488 (SPI) stays white with LovyanGFX, TFT_eSPI crashes inside tft.init()
Uploading issues
Aidé moi / help me
2 Player game with toggle switch on arduino
How do I use the Sensor laser distance LDBA B182 ?
Alternative to connect servo motor with arduino uno without male connector
Compilation error for teensy 4.0
Modbus Communication Issue between Arduino OPTA and Mega - CRC Error during Write Operation
Serial help wanted
¿Cómo sé si mi placa arduino esta dañada?
İyi günler Nrf modül kaç gb veri gönderebilir
Expert in arduino coding
Speed control of 24V DC submersible pump with arduino
Uno R3 Upload/Connection Issues
Bitmap does not display correct
DHT22 Component unknown name
Ayuda programación Arduino Uno
RL circuit problem
Servomotor with button
Conflict of TFT display and SD card SPI communication
Ayuda con sim800L y ESP32
Can reading too often from a pin burn it out?
Modbus RS485 communication Through ATMEGAmega2560p
Implementación Educacional Kit Arduino
Mkr wifi 1010 loop speed improvement plan
How to measure the most fastest way?
Can someone help me
Arduino LCD Counter issues
Audrino AI Xiaozhi development
Measure battery Voltage 4V using optocoupler and read voltage value use Arduino
Pedales y volante para simulador de carreras de autos con Arduino Leonardo
The timer loops when the milliseconds is higher than 32k instead of stopping why?
Robotic arm not working
Extra line print
Arduino and gsm
Red de recolección de datos (Conexión inalámbrica)
Arduino limit switch reading as high without pressing it
Problemas para mantener estable la lectura utilizando los Perifericos del arduino
Multiple GPS Outputs for a 1 second update
Sending data from mysql via php to arduino
Respuesta HTTPREAD no imprime la respuesta completa
Help me describing stop motors in the scope
A question about arduino programming
Basic RFNano question
Proyecto Arduino necesito código
Module nRF24L01 and E28-2G4M27SX comparation
Help with LED strip
DF-Robot URM13 Movement detection mmWave-Sensor
Is the SPIFFS sketch the same as LittleFS ?
Exit status 1Exit Status 1 on Nano and most recent ide
What would be the easiest way to sense a 110vac pulse?
OV7670 no fifo esp32
School Project Help - RFID
Compilation error: expected unqualified-id before 'int'
Encoder not working on Leonardo
Servo motor anomaly
Connecting two arduino boards by SPI
Smart Vacuum Cleaner Project,communication between esp32 cam and ardunio uno
Reduce I2C clock frequency
How to control a servo not by its position but by its speed ?
Help Arduino Compilation error: expected initializer before '.' token. Can any body help me with this
Voltage divider circuit for arduino
Add extra buttons to button box project
What does "expected unqualified-id before '{' token" mean?
Need help with connecting a LCD at the UNo Developing board
16 x 2 LCD half side not working, 8 out of 16 blocks nearly dead
Discord mod abusing power
Send data from Esp8266 to google sheet
Difference in serial reading en LCD reading
While uploding on arduino editor to esp32 it is showing Monitor: "serial port temporarily busy"
Limite de medicion con el ultrasonico
Fuente dc variable y fija
Deploying ML Model Onto an Arduino Nano 33 BLE Sense
Small project with NEMA23 and load cell
I need help for building arduino circuit
Arduino midi project doesn't work
Is there anything wrong with this code, everything looks fine, just doesn't work
Arduino ATMEGA32u4 Falla
Fatal error: password.h; No such file or directory in tinkercad
Compilation error: expected ',' or ';' before 'String'
PID v1.h only outputs 0
Porque no funciona sin USB a la computadora
VISUAL_TFT_Build v 461
Arduino mega overheats
Arduino uno Q, bridge api
Upload fails: "stk500_recv(): programmer is not responding"
Error Code not compatible with this board type
Why does the 5v output give me 3.62? please
Arduino leonardo bootloader dead
Will Arduino UNO and Arduino ATMEGA 2560 board USB port can be used to upload the compiled sketch into my new atmega2560 chip in custom board
Txt data search on Arduino SD card
Elevator project
Nema-17 running Slow
Jag vill att min rc-bil ska stanna gradvis. Vad ska man lägga till för att det ska funka? Är det något som inte låter mig lägga till den funktionen?
Contador ascendente y descendente con botón y display 7 segmentos
Can someone show me what's wrong
Automatics braking system using dc motor, arduino uno, ultrasonic sensor and L298n
Receiving data from 3 sensors
Hi, totally new here and beginner with Arduino. Please assist
Space in Lcd for no reason
Arduino spot welder v3
Niet opstarten 2560 na uploaden
MH ET Live Tiny88 to Rx/Tx Pins
Support on HX8369A TFT with ESP32-WROOM-32
Void onPhoneNumberChange() not triggering
How to use the IS31FL3731 PWM LED I2C Driver
Arduino zero and GDB Server
Arduino coin operated charging station
Patrol robot project
How to fix not in sync (arduino nano)
Expected declaration before '}' token
Connecting multiple sensors to ardino mega
Help with detecting the frequency of a modulated light wave
Swich a pin on the slave, from low to high, by a command on the master?
Extracting value from array
Arduino H7 Video Header File Missing
Bare Conductive
Problems with encoder and digital potentiometer. HELP
Is SFTP possible on ESP32 using Arduino IDE?
La Esp-32 no me quiere compilar-My ESP-32 won't compile
Arduino nano problem,the connected circuit not working
Custom frequency Inputs in SPISetting() function
[VMA430] - decoding Trame UBX_NAV output UART1
Problems calibrating pH Sensor
ESP32 Item Locator
Read analog (potentiometer) position and output 2 channel pwm for motorcontroller
Ultrasonic Sensor HCSR-04
I would like to build a safe with RC522
. Variables and constants in RAM (global, static), used 28652 / 80192 bytes (35%) ║ SEGMENT BYTES DESCRIPTION ╠══ DATA 1520 initialized
Cut ESP-32CAM Wifi antenna
I am arush and i am facing this problem
HC-05 quality of service
Port monitor error: command 'open' failed: Invalid serial port. Could not connect to COM6 serial port
DCC _decoder with min 3 sevo angles
(Arduino newbie) Ide says there is no such library when its right there
Rotary Encoder y Movimiento del motor
STM32 with DHT22
Arduino nano error
Flashing LED does not work
Servo position control using DS18B20 variable temperature
UNO reboots - unstable?
L led blinking problem
VL52L1X with Serial om Mega
Motor paso a paso posiciones
Anemometer suggestions without moving parts
Please help me I might fail the year
Schneider EM1200 with arduino uno via max485 to ttl module
Can you combine my code because i don't know how to combine
Help with 16-Bit LED Nixie Tube Driver (CH453) and Arduino Integration
Need help to setup device in Iot Cloud
I want to measure the current for my wind turbine using arduino and ACS758LCB-050B-PFF-T
Leonardo R3 connection
Pan, tilt and rotate Camera Rig
Recording when collision or movement
Need help with arduino microphone, got low sensitivity
Question, How to control frequency speed in PWM ports?
Why is MLX90614 found at address 0x7F?
Problem due with esp01
El esp32 mantiene parpadeando el led azul
ADS 1256 PGA settings
Windows 11 won't upload to Ardunio Nano
Arduino nano to dragino lorawan la66 shield
Current transformer + acs712
V enviarComandoAT("AT+CMQTTSTART", "OK");
No esp32_camera.h in arduino ide
Reset Arduino Leonardo
I am a novice, I want to ask a question, my board has been connected, but there is this error when running
Loading code to a Giga R1
Error code: unqualified id before if
Usage of extern key ward with union/structures and arrays
Bike Computer - help with touchscreen
Controlling servo via ESP8266 D1 MINI module
Arduino program freezing if RTC (DS3231) disconnected...?
Relay module is not working
Exit status 1 Error compiling for board Arduino Uno
Arduino leonardo r3 connection problem. please help me
I have the same issue; can you help me fix it?
16x2 LCD not displaying what it it's coded to do
Pcm audio, crossfading
To program output on and off
Please help arduino
ESP32-S3 Mass storage device
Arduino problems
MIDI Input? Synthesisers
Help connecting two AT-09 Modules
All in one esp32 robotic car
Problema actualizando valores termopar
Plot Voltage vs Speed using Encoder DC Motor with Arduino
Using Two Load Cells with a Single HX711 – Wiring and Calibration Issues
Measure resistance using a matrix configuration with Arduino
Im trying to make a for loop work but it just keeps printing the #6 into the serial moniter
What's the difference in wiring between common cathode and common anode RGB leds?
My stepper motor nema 23 23kgcm not proper rotating power supply 24v 10A this is enough for this?
Variable pressure control
Who can write code?
Using softwareSerial
Desperate need of help
Need help with this error
VRef on stepper driver
Spiedometer/Dash tester
Troubleshooting False Race Lane detection Finishes on Arduino Mega 2560
Newby question. Posting images to ESP8266 -> Waveshare e-ink
Micro Polarity Reverser
ESP32-S3-Touch 1.69 Image Display
Exec: "cmd": executable file not found in %PATH% Compilation error: exec: "cmd": executable file not found in %PATH%
Photoelectric sensor E3JK-R4M1 with ESP 32 Wroom 32D
Self balancing and following line robot car
Arduino codes how to operate 4 machines with only one coinslot with 5 screens and 4 buttons that can be used by 4 machines at the same time
NRF24L01 + PA + LNA modules not working
Elegoo Robot Car v4 modifying code
Problem with display
LCD timer with other parts
I2C Devices Interfering with Each Other When Powered via Transistors
Help Please- <Deque> not found
RTl8720DN COMPILE errors.. Please Help
Problem in arduino
ESP8266 issues with swipe on RC522
How to play sound using esp32s3 and a sd card
Save-able Custom Board Settings?
Ph-V2.0 problems connection with esp32
Three sensors for one ESP32 Devkit Version 1
Trouble to flash ATMEGA328-P R3 plus from Sharewave
DFPlayer Mini Serial and Hardware Buttons issue
Falla en el codigo o en la calibración de un medidor de pH
Deserialize Json Document Sent From Web Socket Client to Web Socket Server
How to Read Text From an NFC Card
About ADC in NodeMCU (ESP8266 with OLED integrated 0.96 inch)
Mean value calculation in parallel A0 and A1
Activar y desactivar bomba de gasolina de auto 12v
Anyone tried Meloni’s Arduino Potentiostat?
I cant conect my phone to BT-05 Module
Laser turns on during homing and axis movement – GRBL 1.1h + CNC Shield v3
Prop cannon for Halloween
Morse Code Project
Nano 33 Rev 2 BLE Suddenly Broke
Uploading error
Tmc2209 microstepping
One wire sensor data gets weird when I open the Arduino's serial monitor
Stepper motor have jerky motion with DRV8825 microstepping
Código solo en el que yo pueda hacer mi código
Kobling av Arduino UNO R3 til HL TNC DM 542 stepper motor til LDO Hybrid stepper motor Nema 17
OSC library - route causing error?
28BJY-48 and driver ULN2003 with buttons and endstop
Lcd blank even when connected properly
Arduino uno obstacle avoiding car not working
Aansluiten voeding Arduino en relais board
IR - Transmit Result differs from Received Result
ARDUINO R3 LAFVIN Expanding Board With Motor Driver Shield For Smart Robot Tank Kit
Cloning an Arduino Uno and Arduino Mini Pro 3.3V
Problem with code or hardware?
Power for Arduino + CNC shield
IDE 2.3.7 Network Ports list
Error de copia al portapapeles
Problema con sensor hc-sr04
GPS Module doesn't work after 3 day's of continuous working
No cargar la aplicacion de arduino
Help with P5 RGB64x32 Matrix Clock with ESP32
DIY-plotter pen lifting servo does not work
Arduino matter_time_sync example sketch issue
LcD leading 0 at start of top 2 lines
RFID rc522 modul
Problems in Windows 11?
[CRITICAL] Cannot setup Arduino Uno Q: App Lab blocked by 403 Forbidden on apt-repo (Debian)
Using AI to write Arduino code
Arduino and ultrasonic sensors
JRKG2 driver from Mega2560
How can i calibrate the following sensors MAX30102, DSB1820 to suit human body vitals ?
Nueva versión - clon - HC-05
MAX30102 not detected on breadboard (0x57 missing) but works with direct jumper wire connection – ESP32 I2C issue?
Sine Wave Sketch not appearing on Serial Plotter
My arduino LCD can't showing text
Uploaden lukt niet meer vanuit IoT Cloud
I've been trying to get HC-SR04 ultrasonic sensor readings to work through various tutorials. The duration from pulseIn wasn't working up until I stop
Configurar aceleracion de dos motores nema 17
Compilation error related to function millis()
NTP server best way to act on retrieve data
Need a little help arduino stepper motor with ir contol
Need help Arduino Guessing number
> Hello guys, in the code I want to run the Forward() function for 2 sec then proceed to the Table1() function. How can I do that?
Proofing code-IRremote servo controller issues
Ir remote control servo motor
Communication between LoRa SX1262 and Reyax rylr896
Arduino UNO Q flashing failure ?
Simulink code error in Arduino IDE
Code to calculate time in between two events
Micro resets when using more than two pots
Indoor Air Quality Measuring System
Hi, how to differenciate the voice of a male and female with arduino?
Servo motor with 3 push buttons and 2 limit switches
Schematic for lights
Arduino Uno ATMEGA heating up when plugged
Trouble with reading off my pressure sensor from more than 20metres away
Code and errors, debugging. (im not a coder)
Connecting arduino with stellarium
XM+ receiver and Taranis X9 Lite
Controlling Stepper Motor using RC transmitter
I have a question about i++ and i+=
Stepper motor slows down with analog read
Programming code with joysticks
Help, running 2 if statement on 1 click
Activación de servo cada cierto tiempo
Paso nivel con barrera y leds (SOLUCIONADO)
SevSeg freezes with I2C
Quadcopter with 2 arduino nano+ nrf2401l + MPU 6050
EPS8266 wifi + arduinomega "Thingspeak"
Example of multiple water pumps
A fatal error occurred: Packet content transfer stopped (received 8 bytes)a
Issue ion compling the code with HardwareSerial SerialAT(1);
Uno's digital Pins are not working
Sound sensor module sensitivity adjustment problems
Problem with looping led blinking script
Counting RPM inside a function
I am getting a ERROR Compilation error: expected unqualified-id before '{' token
When it is 60 C , the relay(role1) does not close and when the delay works, the screen temperature measurement stops. How can I solve these problems?
Degree symbol gets corrupted when sketch is saved
DF mini player integrating with arduino uno
IR receiver won’t work with nano
Stepper motor, encoder and zero angle
Problem with software, I think?
ESP32 bluetooth connection with buzzer
2 volts input to 2.5-3volts output
Push Button - Led on for 5 sec after push button press
Detectar sentido giro motor paso a paso
Automatic thermostatic mixing valve
Client fail to receive server message
Help please, I don't know how to solve this
DSS-m15S is not working
About Char Array variable assignment
I2c Write issue on ic ch455
Arduino programming counter
Error in the code please help
Stepper motor vibrates but not turining
Need Assistance concerning charging and accelerometer
Esp32 connot compile
Locking Bits while decoding a AC remote
Back to the Future Clock
Project with inductive proximity sensor
Can i interface two mcp4921 ic's with Arduino mega controller?
Impossible wireless communication using NRF24L01 + PA + LNA
Unable to change ESP32-S2 Power
Nano clone digital out only drops to 1.3v [Solved]
</> Marlin 2.0 does not compile while I define Display
How to stop the clock if i press the push button again?
SOLVED! Serial print works on IDE, but data gets changed when read by Python (Raspberry Pi Serial via USB)
Stepper motor with SEA5045
Problem with programmed via Arduino IDeESP8266 rst cause : 4 boot mode (3,7)-I'm driving crazy already
Fi̇nger pri̇nt module help
How to send message via bluetooth
Need help with led delay function
Code help losing my mind : read the top of the code/*here*/
Arduino UNO and PCA9685 problem
Connecting Arduino Nano 33 to smartphone
X and Y related project request
Help wiring sim racing wheel with buttons and ESP32
Excel-based automation timer & cycle logic generator (feedback welcome)
Paper to Coin Currency Exchange System
How to implement a timer on an arduino micro
PIR sensor with running light
Pick to Light system with PIR sensors
DHT22 NODEMCU problem uploading
Weird string conversion issue
Placa arduino y cinta led alimentada por un tranformador de 12v se calienta demasiado
Bluetooth GPS iPad
I Need Help With Breadboard wiring
Avrdude: ser_open(): can't open Access is denied
Test upload code via HTTP for Atmega2560
Creation of a Routine with a Button that triggers relays and 2 stepper motors. Arduino (UNO)
I dont know how to solve this problem
Connect esp node mcu 32s to arduino mega through wifi
I am unable to upload the code. Please provide troubleshooting suggestions. Thank you
Controlling a servo motor with a potentiometer using Millis
Issues with external relay triggered when it shouldn't be
ESP32, TMC2209, TMCStepper.h
Converting a Datastream into an Array
Please corect this code
Make a chessboard, just detect the position of pieces
Torque wont show in lcd when callibration factor is changed to a high value
IDE 2.1.0 - Changes made in Preferences are not saved
Login to a https webserver with username and password
Combine Rain Sensor and LDR sensor
DFRobot Humidity sensor with Sparkfun Thing Plus ESP32 - Sensor read const. 0.0
Lüfter mit mehreren MOS-Modulen ansteuern?
Need help to stand by mode
Motors behaving weird on quadcopter
VS2053B breakout board help required
Project with Ultrasonic Sensor, Stepmotor and Servomotor
Thickness Sensor for Arduino
Eps32 Voltmeter is measuring incorrectly. For example, when the voltage is 12.00, it is 10.50. Measures -1.5 volts
How do I use keyboard inputs to control a servo?
HELP! LEGO Millennium Falcon FASTLED engine starting sequence
Convert Single to Multiuser IoT Application
Help with function oder help
Why does the I2C LCD Module not displaying anything
Two PWM channels with 180 phase shift on Due
Best way to connect multiple outputs to 12v power supply
GPS not working properly
Using NPN transistor
Scrolling text on LCD
Issue with the code
Odd Characters When Reading From a AT24C32 and Using Serial.print()
People counter keeps counting
Wheel Encoder Tick counter error
How i can send my data from nodemcu to arduino via serial?
How to code 1 button push 2 input signals
Measuring the Center of pressure of human steps
Esp32 programming help needed
DS2431 EEPROM : READ and Write
which paramaters should taking on consederation to drive my stepper motors
Constant reset loop - Devia Robotics Control board v1.0 µC-type ATSAMD21G18 (same as Arduino ZERO) with AT-firmware ESP8266-module
Help needed - Error compiling for board Arduino Uno
IOT Cloud Problem
Buttons don't work
Coding help with servos
Connecting Multi MPU6050 using I2C on ESP32 Wroom 32D
How do you program 170 stepper motors for a DIY platform
Traffic lights with sensor
Coding doubt in serial monitor
Need help with my code my arduino code to turn on and off LED and also delay
Controlling Servo Motor and Stepper Motor with NRF24L01
Unable to upload to MKR wifi1010
Why I've got banned on discord server?
Creating a code for a servo motor to create a sine wave
Rotary Encoder with LCD2004A
Issue with neopixel and large power supply cable
How to disable EEPROM clean with USBASP upload (Arduino IDE 2.0.4, EESAVE)?
I am working on R307 i can perfectly enroll my finger print but when I go for fingerprint.ino on serial mointor it continuouslly give command of no finger dedected as it s in loop how can i solve this
See if condition last for 2 minutes
Help ! espnow to simplefoc bldc
Hello every body i need help for this code
Temperatura inicial y final
Automatic recognition
How can I reset the score after the results to 0 - 0?
Do this every 180 seconds if a button is pressed
Issues adding voltage feedback to pwm
How can I create a trigger for this
Highschool Project help
ESP8266 Stack error - Panic umm_malloc
Arduino codings
Sending an int = 1 from quest 2 to an esp32 through Bluetooth serialport is not working
Automatic door handle sanitiser
How to port this to esp32 (Captive Portal)
HC-05 not able to connect
NAN value a BIG problem
How can I mount my arduino on a wall?
ESP32S3 LyraT board with Arduino
Redefinition of init error when compiling verify
Waste Segregation
Nextion Transmitting Garbage on press/release events
MAX30100 vs MAX30102 vs MAX30105
SOLVED:How to read input from the serial monitor
Push Button with actuators
Call void(function) on webpage button click
Stepper mottor plus ultrasonic
Count pulses at the digital input pin into a time period
LED crossfade White to Orange
Cannot get data from arduino json UDP
28BYJ-48 stepper motor and ULN2003 driver board
Question [Heating Pad]
Good day! we would like to ask help about our code, another problem resurface and it's the part where the start is Left_ Tra and the end is the stop
ESP8266 undifine reference
PROGMEM problems with arrays
Receive data from Arduino in Python
Bluetooth + Serial Monitor = Trouble?
Error: 'init' is not a member of 'U8GLIB'
2.2 de TI e jardins aac
ILI9486 is down when i connect any sensor to SCL and SDA pins
Why my program doesn't work
Automatic Chicken Feeder
Do you know how this relay module connects?
Semáforo 2 Vías doble peatón, ¿Como interrumpo un ciclo?
MPR 121 for Daisy Seed, Sensor not found
Wireless data send arduino uno to esp8266 using nrf24l01
HX711 together with I2C devices on same pins
Anybody willing to help me?
RaspberryPi 3B+ and Simcom A7672s
Having trouble running a 360 fs90r servo
Help required with delayed countdown timer for relay
Modulo EPS-01 8266 con arduino mega
Ich bin hier neu und wollte etwas von euch wissen (habe es aber selber hin bekommen ), Hier ein kleines Programm zu m ES32 mini ,it Neopixel 60 und LDR
Programming Arduino Uno using SparkFun Serial Basic Breakout - CH340G
Oled display stuck with logo
Expected primary-expression before 'client' with WiFiEspClient client
100 MHZ crystal oscillator solved
Computer not recognize arduino uno when connected to motor drive sheild
[FIXED] IR remote switch help
MPU 6050 problem SOLVED
I want to learn about arduino
Can someone help me understand following code step by step? In this program sumDigits() calculates the sum of all the digits in an integer
MPU-6050 calibrating problem
Serial read string HEX ,find byte buffer to HEX to DEC as a float02
ESP32 with ArduinoIOTCloud throws ''GPIO0: ESP_ERR_TIMEOUT: ADC2 is in use by Wi-Fi''
Cannot fix my compiling error
Conexión de un electroimán a una placa Arduino con CNC shield en conexión serie con Raspberry Pi
Having issues with "D6 was not declared in this scope" for a wifi control led matrix
Sensor too sensitive
Reading data from Arduino into Python
Esp32 or Esp8266 Wemos resetting every several hours
detachInterrupt() not working?!
RGB Matrix 32x64 - Numbers and letters via push buttons
I am trying to connect 2 IR receiver on 2 different data pins of esp32
How to read adc port in code?
Trying to send data from ESP32 to MegunoLink
VL53L0X sensor not working
ArduinoBLE & high rate read/write = Error
Use sin() and cos()
Medir angulos en X,Y y Z
Dual H-Bridge L293D and 90 rmp 12V motor
How to connect multiple inputs like 150 sensor volatges to arduino mega
Encoder RPM Feedback
Need help ! combing two programs
Running a stepper while a sound is playing
Trabajo de un robot rastreador
Integrating Arduino with Website for Real-Time Pet Health Monitoring
Help with solar panel tracking project
Problemas con proyecto de control de riego
Check memory FLASH/ PROGMEM
1 Button and 1 pontetiometer
Wireless imaging system with ESP32
I would like to know how to control 2 rs775 dc motor and a servo using a nrf24l01 receiver and transmitter
My bluetooth car bluetooth is getting disconnected after sending a data to it
How to store EEPROM 10bit analog data
Smart bottle holder
Data getting and uplading it
Stuck at Uploading. Cannot upload anything!
A0221A4 ultrasonic sensor of RS-485 comm
Pro Micro HC06 or 05 Bluetooth pro micro gamepad
Error is: Attempting to use a port that is not open
Multiple SPI devices - RF24 and ST9720
Looking for guide for Arduino Mega R3 WiFi AVR ATmega 256016AU CH340 with Thingspeak
Help me to combine these codes and the servo motor to return to its original position
Adaptar arduino UNO a sistema limpiaparabrisas de un Auto
Unexpected output (A0) Uno R3
How to make a pc usb game controller with 40 plus buttons and 4 axis?
Arduino TCP no connection
Error in my code
Windows compiling issues
I want help creating a calculator that calculates a value like this 23*4+56
Weruiopfmniovmroiz
How to connect esp8266 to batteries and switch
Compilation error: wrong type argument to unary plus
Arduino Blynk Error
'float round_to_dp(float, int)' redeclared as different kind of symbol
My LCD Is not Displaying my Temperature
Issue using the ArduinoMqttClient.h library
Something is not working
Error: expected '(' before 'else'
GUIDANCE ON CONNECTING Arduino UNO TO A SIP SERVER HAVING SIM 800
I.m clearly thick.... dividing bytes
Liquid Crystal Adaptation 16x2
LR7843 MOSFET only lets through 17V out of 24V
[resolved] Problem with servo motor (FR/ENG)
Problems when comparing a String
Program creation
CONTROLLINO Mega Pure Digital low to high voltage
Arduino,hc 05,motor shield not working my hc-05 doesn't turn on
[solved] Arduino IDE 2.0.0-rc9.2 on Ubuntu 22.04 64bit not starting
DFPlayer Mini on ESP32 30 pin devkit
Connecting two programs into one
How to slow down the signal from a Hall effect sensor
ESP Camera cannot connecting WiFi while reset
Optocoupler for input
Flow sensor for shower on R4 board
Help me make an Arduino door lock
Using flow sensor to control dc motor for water sampling
ESP32 Project error
Keypad sending out random numbers
Cloud for your project and libraries
Steppermottor control with Loadcell reading
Connecting wifi module esp8266 01 into wifi
Switching circuit using relays and UPS with Arduino in case of a power failure!
LoRa RF Noise Generator: ISR, goto, while, best solution?
Creating more than one RTC variable
Steppermotor with tof10120
Esp32 wrover ib configuration with Arduino ide
How to control two servo motor each with a potentiometer controlled wirlessly through NRF24L01 and Arduino uno?
2 axis Joystick with Arduino Leonardo
Adafruit Motor Hat not connecting to Ardiuno Uno
How to control stepper motor with encoder using arduino
I am getting error in my arduino code
Feasibility - Three pushbuttons to control a single servo?
0802A 4bit LCD Interfacing with renesas R5F102AA
VL53L0X Problems
SRXL2 serial throttle value and nano
Big Numbers in Arabic font
VL53L1x out of range problem
Problem with an I2C Pin Expander
Serial communication between esp32 cheap yellow display and arduino mega 2560
Millis function is controlled by the counter
ESP 32 & waveshare 4.2 pinout
My code won't compiled
Trying to use button with Arduino Leonardo
Indefinite array display on LED matrix
Arduino Central Management
Conflicting declaration uint16
Arduino with adafruit data logger shield
Control RGB LED 5050 Stripe with IOT Remote
(SOLVED) Bluetooth to bluetooth latency problem
Carrito aspirador
Please help me write the code
I have a problem with the Arduino serial monitor, when I run it it's like this, please how do I fix it?
ESP 32 ADC giving wrong values
Compile Error: Undefined reference to 'main' when using Elegoo Mega2560
Stopping song with button input?
Can i use analog pins of Atmega328 for Toggle switches?
Wt32-eth01 pcb files
[SOLVED] ACS712 - Having second load is reducing the watt instead of adding it
First time encountering this error. Arduino UNO
Programación sin esfuerzo
How to have two veriables in a if...else sequence
Project find random number
Arduino based 12V coolant pump control
Compliation Error "Make sure you have 'Sanguino' selected" With Sanguino Already Selected
Speed limitations in basic data transfer
Como configuro el tiempo de apagado de una tira led?
How to find the PPM value of the MQ135 sensor
Use local variable in another function
2 Channel LED strip control with DMX
Using Laptop Keyboard to Trigger Interrupt
Channel N MOSFET to LED Strip PIR Sensor project
Ss49e linear hall sensor oled display progress bar
My Datalogger SCD30 code wont print values on Sd Card - SOLVED
Arduino Lora Wireless Authentication
Inverse Kinematics of Differential Drive Robots and Odometry
WeMos D1 R2 - (ESP8266) - Fan control (PWM) issue
Pin13 confusion al conectar con integrado
Code to blink an led to represent a number
Timed relay activation and billing using rfid card
Bitmap byte allocation
SOLVED - BMP180 Temperature Errors
Why is this code not working?
Motion detector on 4m wide
Upload images and/or new project file to the nextion via Arduino
Nano 32 with single WS2812 LED not working
Stepper motor code doesn't work
I cant use nrf24l01
I need help with my arduino uno
How to power arduino nanos
Bin file burn on adrino mega 2560
Running stepper motor at a set time interval
Trying to change the position of a servo using two click buttons
Arduino MEGA and TFT 3,5, cannot start SD
Examples go missing
Attiny85 servo control
I have a Uno board with the program in it, how to read it out
Write a program in C to switch on and off an LED
Counter on LCD display
Arduino Nano 33 BLE Sense REV2 get's hot really fast
Display "Low,Meduim,High" in LCD by potentiometer
Bluetooth data ASCII
Electromagnetic interference
Arduino and Esp32 serial communication and data to Thingspeak not working
Oscillator controlled by a potentiometer
Can someone help me? something about spi fast flash boot
Hydroponic monitoring project using solar panels?
Problema con atmega328p
Problem with serial communication between Arduino Mega 2560 Pro and ESP8266
HC SR04 to suspend the calculation until a button is pressed
NEMA 23 Schrittmtor mit Arduino Mega 2560 betreiben
Am i reading this wrong? or is the string missing a char
Monitoring a CR2032 voltage
What IoT platform do I use for esp32 cam?
Control massages then buttons i pressed
att7053cu or att7053
Bom dia, meu leitor rc522 não está reconhecendo uma TAG ativa, qual programação devo usar para conseguir ler?
Finding the maximum and minimum of a servo motor?
ESP32 code for forklift not working 100%
Wdt reset - firebase & esp8266
Multiple intervals
I am confused in sensor connection CSPPM127-E water level sensor which works on RS485 MODBUS protocol. I am using ATSAMD21 Mini dev kit by Robotdyne
Simple Script not Working
Facing Issue with connect SD card of ILI9341 with ESP32
I2C get stuck for 1sec
Arduino Looping states in Void Loop help needed for a novice.
Changing values in a code by using a potentiometer or selector switch
'timer' was not declared in scope
IRremote: receiving ok but transmitting don't work
End stop switch
Help with LDR + LED circuit on Arduino Uno
ESP32-CAM does not print anything on Serial Monitor
ESP 32 Sensor data collection
5 different Spectrum controller using one ldr sensor
What is adc raw,? How do it calculate
Firebeetle esp32 with GPS M8N won't communicate with each other
Trying to get a longer tone out of this code
Fighting Actuators
Stepper motors NOt workings
Need help with LCD and nRF24L01+
Tips for FireBeetle ESP32 (DFR0478) Circuit Design on PCB
Simple Stepper Motor
LCD 1602 Upgrade
Is it possible to turn on pins 4 to 13 all at once?
I have 2 flow sensor but now i can display 1 i want to add more how can i write
How to get this LSM9DS1 code run faster?
Setting up network botton not selectable (greyed Out)
PROBLEM - TFT display AND multiple SerialPorts on Uno R4 Wifi
GRBL compile error Arduino Uno
Can I integrate an IR breakbeam and stepper motor with only one one Arduino uno r3
Servo Motor Response From Tfmini Output Data
SIM 900 GSM Module issues with Arduino uno
Car gauges Nextion vs
My DC fan is not stopping
Help with Errors in code for using Arduino Mega as MIDI encoder
Unable to connect to websocket
Serial.print() didn't work same as usually
Blue pill stm32
When I enter second digit it replaces first one and starts from there
Digital output pull-up resistor off
Can't control speed of 4 DC motors using L298N
On-chip LDO bypass
Secure project using serial number
Lineer actuator does not behave as expected
(Solved...I think) Strange interrupt behavior on Teensy 4.1
Error with RadioHead library
Problem with led matrix on Esp8266
Arduino car not turning on and it will start smoking
Reading the current from ACS712 and displaying on Nextion
Cómo puedo conectar un servomotor mot-135 al Arduino?,
`exit status -1073741819` while compiling for ESP8266
Another DHT22 giving wrong values
I have a problem with 2 of my 4 ultrasonic sensor's
Setting up: problem
Keep getting error trying to upload
HELP - Fluid-o-tech BLDC Motor
Using IR Remote with LCD
Getting pins working
I2C LCD causes problems
Will i be able to control multiple 24v dc solenoids
WS2812 & SW 420 code help
Prender una moto electrica casera
Using millis() and if statement to run ultrasonic sensor and servo motors
Confusion about programming Logic
Fixing problem with uploading
Move to a postion then to another postion. Once at the postions stop for a short period of time
Fried Arduino Mega and my laptop - what did I do wrong ?
Adafruit motorshield v2.3 and nrf module
Serial monitor doesnt show up
ESP32 CAM not working
Include files in IDE v2
Start With Arduino - complete beginner
Schematic 'Frying' Arduino Zero
My DIY ambilight for PC stops working after random amount of time
Leonardo r3 usb host shield 2.0 as mouse
How to test with arduino
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system
Millis() question? ads1115 trials
Huskylens with arduino mega 2560
How to Add 12h time code
Play mp3 music immediately when it turns on
I need help to start a project
Making a transistor turn things in series
ESP32 cam cannot do face recognition
MPU6050 calibration
Arduino UNO R3 using two outputs dependent to different inputs
Looking for example of Modbus RTU Master for Controllino Maxi
Problem with ESP32-BLE-Combo-master library
How to create an Array
Can someone explaine to me how to use the stepper motor
Starter Kit Project 11 - HELP NEEDED!
Duo locking after a few reps
Issues with SN74HC574
Programming issues with ATTINY85 (Upload using programmer uses wrong programmer)
Display problem freezes
CNC laser machine
Slowing Down PCA9685 Controlled Servo Movement
Electronic Catan Board Program Crashing. Please Help
NPN with arduino
Relay Module Power Supply
Random shreds of texts in serial monitor
Motors only start if arduino is connected to a PC
Why my arduino leonardo not working with bluetooth module , However this same code is working with Arduino UNO, Plz suggest me changes
Engine Dyno Projekt
ESP32 problema con Shield/carcasa
"UNO+WiFi" board: Upload fails and RX led always on
How to use a 14HM11-0404S1 to create a robotic arm?
How to check which IC i can code with aurdino?
Help with speed controlled fan (pot) keyestudio components (INA and INB) fan type
First issue resolved - now there's an error when I try to verify in IDE
Solved how ac current can connect to ads1115?
Relays switch, transient noise and rc snubber
Getting started on Arduino
Cargador de teléfono utilizando arduino R4, ayudaaa
Hello Guys, i have a school project
Arduino nano rp2040 mqtt
LCD 1602 Upgrade
All sensors wrong reading
ESP32-C3 and P10
How to play kick drum & crash sounds simultaneously on an electric keyboard with arduino
Need pwm signal
Using Digital pins for IR 5 sensor array on Robotic car
Hey my Arduino r4 is limited my htttp request more than 8 is not accepting
Web Editor Server Issues
A fatal error occurred: Failed to connect to ESP32: No serial data received
Arduino codes with LoRa communication
Mqtt and while loop
Struggling to stop stepper motor for project after a loop
INA3221 loses i2c communication when power supply is connected
Code not working as expected,
Read data through HID
Stop loop, help us?
ARDUINO hardwarr help
"array-float" conversion problem
ATmega328p: Creating object file only using an AVRDUDE make file
Please Help, I want to make CNC with 2 axis
On Off keying Signal
Unable to burn bootloader using mkII
How to call an api on esp8266 using static ip setting
Problem with Compilation error: a function-definition is not allowed here before '{' token
Identifying the error in Arduino setup
Oled display flickers when I set time in code
Model railroad turntable
Troubleshooting RC Car project
I want to input position data to a motor in hexadecimal the data should be distributed among data 4,5,6 each containing 2 digits
How to display float value on LED dotmatrix display (MD Parola) ?
How can I count another var ?
MOSFET type issues
Connect transmitter Arduino NANO
ESP32-S3 ADC Read Issue
How can dedicate hardware ecraption
Driving 8 motors with off the shelf hardware
Remote monitoring
SIM 900 ne se conecte pas sur Free ?
Can I use another bracket inside a delay bracket?(Solved:nikoexcited:)
Question with arduino code
I have a problem with the Arduino Dimmer Library
Arduino software issue down load
Cannot get a LDR to work with the following
7segment common cathode display with rtc
Analog voltage input to power fan change of speed
How to wire L293N for running speaker
In Arduino ide 2.3.2 if i am enable bluetooth i am getting error in libaries
Avr-g++: no such file or directory on Mac
If(vw_get_message... fails always, transmitter seems to be functioning
Problem interfacing MLX90614 and MAX30100
Randomize servo motor work
FreeRTOS code causes crash on ESP32-S3 board
Nrf24l01 no me comunica
Compilation error: PubSubCilent.h: No such file or directory
Serial Exception Error While Uploading Code to ESP32-S3 WROOM-1
Solved Please explain why this code for displaying analog inputs dose not work
TFT showing white screen when wires are gently touched
How to capture peak frequency > 20kHz
Counting inputs
Phase shift while implementing timers in Atmega328p
I can`t install Adafruit library for oled display
Send UDP packet using Arduino problem
Can I use an array or other method to simplyfy my code?
UPLOADING error on Arduinop ide
Admin Responses to questions!
ATMEGA 328p PCINT-Resolution questions
Please help me guys
Please help me guys
SleepMode ArduinoNano ATmega328p
Please help how to set notify as my customKey
While connecting the Nodemcu with Adafruit server getting this error - expected initializer before 'mqtt'
MIDI plant music synthetiser
Hi can some one help make homing to work?
Need help with a stepper driver to run a stepper motor forward, hold, reverse, hold. used on a cnc to rotate the carousel ATC
New To Programing Registers
Arduino Car Parking system
Need some help with my code
Clone Hero Drums
256 Microsteps / TMC 2208
PLease help ! 99% done but
Proximity sensor error help
Help - move servos in 1 degree steps
Sampling rate problem with FFT (Max it is working correctly is 200Hz)
CANBUS Shield V1.2 can not receive data from battery
Making function to turn 2 LEDS ON and OFF on ESP32-WROOM-32 on Assembly in Arduino IDE
Arduino czujnik wody - Arduino water sensor
Arduino code not working
Qué significado tienen el eje y, y eje x en el serial plotter?
Can't get I2C To Work
Building an advanced guitar tuner with special features with a seeduino and a grove starter kit
[SOLVED] Unknown 1wire address detected
Error: invalid conversion from 'void*' to 'const char*' [-fpermissive]
Running on Arduino 2.3.4 (Windows) for a long time causes the computer to restart
'RTC' was not declared in the scope
Expected primary-expression before '<' token............................ I want to program an arduino board to control a fan at different speeds
Using multiple WS8212 led strips and controlling them with TFT Display --------
DYSON V7 charge control chip flashing
HC-12 returning gibberish words
L298 voltage dop too big?
How to understand this.. cant replace the the code
ESP32 does not start program at boot
Compass and GPS fail
Hoodloader2 Compilier Errors
LCD-Display showing phrase according to bluetooth input
Error de compilación de módulo AI Thinker ESP32-cam
Global or local variable problem
How to solve the error
Esp32 wroom 32e Bluttoht problem
LCD second row not working
Esp32 is not able to get data from I2C and send this data to aws iot hub at the same time
Arduino humming noise
Low power level when using TMC2209.h library
Question about Arduino Mega 2560
Could you tell me the mistake here?
What is the Problem?
[SOLVED] LoRa geophone issues setting sensitivity of sensor
Touch sensor with disc vibration motor
Blynk_firmware_type was not declared in this scope
Help with Serial library
Guidance on building and coding a automatic waste segregation Bin
Possible serial noise or corruption
L292 d motor driver sheild protues library
Arduino library on github not registered
I am using oled and spectral sensor together but they are not working with the code i wrote
Help using ds1302
Play certain mp3 files at every hour
One more question I also need to connect to D18 but I dont have the WROOM version
Open Smart Rich Shield projects
ESP32 and L298 module: Power Supply Issues
Wheatstone bridge-Instrumentation amplifier and Arduino
LEDs with PCF8574 chips
Midi usb problem on Leonardo with encoder ky040
Esp8266__Ap with open web server which itself opens an info page
Oled display progres bar I want to view but I couldn't Connect
Need help in using DS18b20 to calculate breath per minute
Bitte um ein Code-Review (Arduino Nano, Thermistor)
What is problem
Problem with Switch command
Reinitialise Serial communication after overclocking pico
Detection of motor position
Why GPS part of code is not working fast/need to restart 20 times to work
Controlling a digital and analogue servo with one arduino uno
Error reading device descriptor. Error code D6
Sending values from Nextion display to ESP32 Error code 777777
Face difficulty use oled with voice recognition
How to make this projekt
Tracking sun using gps
ArduinoHttpclient
How to connect two Arduino's to two REYAX LoRa modules?
Measure on time
Control Power led brightness and Brushless motor via ESC, using pwm signal and 4cell battery (burned 2 boards)
Linea de bloques en lcd 16 x 2 sin ic2 en esp32
Encender LCD i2c sin librerias
Push button w/Blink
Brushless foc drv8302 Arduino 2560
Rc car nrf24 I need help
2 DFMini mp3 players not working
Has someone read Arduino Due' Digital Pin whose incoming signal frequency is 1Mhz?
Mini mp3 and hc-sr04 can't get to next song
DF player mini - wrong mp3 play
Stepper motor doesnt working
Using esp 32Dwroom to build a car controlled via bluetooth
Signal: killed Compilation error: signal: killed
Serial read_int
Arduino uno executing program during power failure
Reading Serial Problems
Problem with callback function in ESP32 wifi library
Help getting data from digital pin 2 and 3 in pytnon
ADC noise on ESP32
Proplem in arduino nano
SPIClass has not been declared
Help with jsn-sr20-y1 schematic
Help needed for project due 6/3
.hex file on arduino
I need a help in my project
Compilation error: expected identifier before numeric constant
Error on App start after update: "Arduino_RouterBridge.h: No such file or directory"
Has anyone used nrf24L01, H-Bridge, Servo code together?
Python script cant control the Arduino motors
Is this code for recording and replaying the functions
2.1 inch round display code
Hex file and bin file are created but they both are empty
Sending message with ESP32
Wifi error with Board Uno + Wifi
Arduino terminal console
Feetech Continuos servo and arduino nano
Reading Data Using Modbus RTU Over RS-485
Problem: 'else' without a previous 'if'
Using Library's
Creating phase difference between two square signals
Arduino uno text to speech
Error compiling for board ESP32-WROOM-DA Module
HC-05 Windows 10 and 11
Cannot update the parking status data on the website using the NodeMCU:
A9G + Xiao ESP32-C3 problem with sending SMS
Help in esp32 and soil moisture
Display pin state on LCD display
The code that should be able to read temperature, pressure, and altitude data from a BMP280 sensor and display it on a 0.95 inch RGB OLED display:
Pulse a relay at a random time
Error setting up serial communication
STM32 documentation analogue for the Arduino platform
BME680 Sensor error
Can you help i always get compile error
Can you guys help me with this program?
Custom Air suspension Management system
Push button w/Blink
Unable to communicate with uno on serial
Esp8266 fail to upload values to hostinger database server response 301
Variable is not updating in arduino cloud
Potentiometer for Gaming Pedals
Progamar ardurino soy novato
Bluetooth CH-06 activa bucles al desvicular
Mini bomba de agua en NodeMCU
Led and motor work strangely
How to cotnroll multiple servos at once
Variables global,local,static and constants
Convert Calculated Weight from Load Cell Sensor into a Reward Points
Balanza con corte automático
ESP8266 Unreachable
Expected primary expression
Help me find the solution. The code is correct, and the Switch settings on the dashboard are properly configured, but I still can't control the light
Simple arduyino menu but dont know where the problem
Opta PLC IDE communicate to regular Arduino IDE over RS485
Help With Programing!
How to use Arduino by RTC
Atmega328p+esp8266 and pn532 serial communication failure
Need help for my school project
How to connect ESP32 s2 board to Arduino IoT cloud(Using API Keys and Arduino IDE)
How do configure Arduino with Arduino Seeeduino Cloud - Arduino Yun? Is there any configuration to do in PC?
How can I optimize Arduino code for faster sensor data processing?"
Adc in arduino due
Help with Arduino Header file confusion
SPI error after X times of calling the method
Read Variables Before Reset
Interface AD1263 with Arduino/ESP32
Failed to connect to esp 32 failed uploading
Access is denied when trying to upload sketch
Ws2812b transfo
(SOLVED) Solar System voltage switch some relay modules (Problem)
How I get two input from arduino via bluetooth
arduinoFFT.h code breaking switch case/ button For guitar tuner
SAMD21 I2C Not Working - Arduino Zero based Board
I am having a problem with my TDS sensor
Help on project
No reading no writing between i2c and ESP-12F
12C two Nano's having a chat <<CLOSED PLEASE>>
Get rid of delay(), solve buttons debounce [solved]
Nothing happens on button press
SN65HVD230 to ESP32 Devkit v1
DHT11 Sensor Frequent Data Spikes
[Solved]I need help with an error with no answers
Output to operate as (and in parallel with) momentary pushbutton
How to send .txt file from Arduino Uno SD Card to phone via HC05?
Hall Effect Sensor picking up Input PWM Frequency to the Motor
Problem with Cloud Agent: "openpgp: invalid signature: RSA verification failure"
Solved: #include header file not work
Undefined reference to countPulseASM when using pulseInLong function
Arduino Explore IoT Kit MRK 1010
Is there a difference between reuploading code and resetting an arduino?
Adafruit NeoPixel crashing with colorWipe
Correct mosfet for 220v DC Led strip
The code provided for sending health data (heart rate, oxygen level, and temperature) to Firebase Realtime Database using ESP32-C3 is not working. Whe
Drawing and Analog Clock on MSP2807 TFT Display
Obstacle Avoiding Robot
Can someone tell me what I'm doing wrong?
Cannot find the way to extract raw data of GT911 touchscreen
(Beginner) Logic understanding problem for a toggle switch
Arduino uno problem with the Nokia 5110
Portable temperature and humidity sensor with DHT11
How can I use PWM (Pulse Width Modulation) in Arduino for controlling the brightness of an LED?
Arduino Limit switch Interfacing Visual Basic .NET
STM32 w/FTDI - Uploads but won't run
Dmx512 Strobe problem
Servo.read function not working
ReadHolding register by Arduino uno
Help! modifing exist code
About the Uncategorized category
Generic arduino
Magnetic strip card reader project
Esp32 (sender-reciver) temperature sensor
PWM, MOC y foco
Blinking L LED (No Blink example) [solved]
Stepper Motor doesn't spin and vibrates
Upload problem error
DC motor with enconder
RGB LED Beginner Tutorial & Random Colors Every 2 Seconds [external source]
Controlling display
1 push button with multiple functions?
Capacitive sensor
Sad face on the led matrix
Compilation error: exit status 1 , ESP 32 interface with IR sensor , output serial monitor
Serial port not found
LED matrix word mirrored
Wifi connection error ESP32 Wroom: WiFi.status(): 255
Como conecto mi Arduino Uno con un max232 (DB9) o con un convertidor USB - TTL (ch340)
Circuit not working
Uno R4 problem with FastLED and WS2811
Digital compteur with NodeMCU.V3
Python Code to move the actuator Forward and Backward code not working - please help
I want to store the value of barcode in a char string
GUI on M4 rotated by 90 degrees, why?
I'm facing this problem please guide`
ESP8266 connection to Arduino Uno
Forum guide, software for making schematics
Failed to find MPU6050 chip
Error code 226 to reald holding registers from Elmeasure power meter LG6435
Connecting DC motors to encoder
Running 2 steppers for robot
Stepper Motor Wiring help needed
Guys please please please help me ASAP
Help me code this funtion
How many codes can be put into an arduino at the same time?
Problem with a simple code
[solved] tft screen with esp8266
Stepper Motor for solar panel cleaner doesn't operate after being runned for long
Issue with 380V (topic moved)
Looking for a two code fusion 1st for Relay 2nd for Servomotor Everything on a web page? need help I arrived at this result
Capacitive sensor
Serial communication (arduino to nodemcu) and max30100 problem
PWM error in compiling sketch
Wifi ESP8266 module
Trying to determine if my NANO 33BLE is stationary at any time for a designated time frame
8 Digit - 7-Segment display turns off after 10 seconds
Retrieving saved WiFiManager parameters - Help needed
Water sensor project1
Wire connection problem for transfer data of adxl345 to Sd card for given code
Power Distribution Question
Nano not starting on battery; needs power boost from usb
School project, SOLVED
#include giving me errors
I need help with my if statement
Hello I am not able to send a binary signal like from python to Arduino
Tengo dos problemas en un selector de alarmas
Sketch works when uploaded only from a specific computer
IF statement doesn’t work properly
Reading 40 KHz analog signal using Arduino
TCS3200 color sensor returning 0 values for RGB [solved]
Error compilación placa arduino uno (SOLUCIONADO)
Ultrasonic Sensor Code
Multiple DHT22 Sensors with LCD I2C display [SOLVED]
Can i connect esp12f (esp8266 chip) to oled display ?
Arduino Duemilanove Stk500_recv and the reset button doesn't work
Vivarium controller
NEMA17 & DRV8825 - HOW I CAN 1000RPM or HIGHER? I'M A BEGGINER
Problems with Potentiometer
How can I increase the sound of the buzzer?
Arduino Single axis solar tracker code
Detect key press while running algoirhtm
Arduino Code does not work together
Why are the MKR series USB ports so unreliable?
125KHz RFID code schrijven
ESP32 devkitC V4 No voltage
Automatic watering
Eliminate Interference in Bluetooth Audio Output
School Project-Error compiling for board Arduino Nano
Esp_camera_init() function makes my ESP32 cam Brownout
ESP8266 code error
My code for is not working?
KY-087 won't work
Pulsed frequency modulation
Is Ardunio Nano Suitable for My Project?
Constant restart after new update
Built in LED of pin 13 decreases in brightness (MEGA 2560)
A static const?
ADF5355 Not outputting any signal with code
Keyboard.press() not working on arduino mkr wifi 1010
How to view software serial data on a serial monitor
Problem with logic behind my code
RGB LED not responding to Serial Monitor Input
Need help on DF Mini Player activation
Arduino not working with FTDI Driver and USB
Need help Switching pipes on RF24
Problem interfacing GYML8511 UV Sensor an offset is always present
LCD screen, help me with the code
Estado de relé según temperatura, humedad y presencia de luz
Problema nema 17 con driver a4988
Arduino IDE doesn't see my arduino nano
Drone PID output
Thinkpad T470 Trackpad
MAX30100 Pulseoxymeter showing random characters
CAN BUS Output to a AIM solo2 DL
Pls how can I reduce noise in current sensor
Copy compile errors not copied to clipboard
RGB and Temperature sensor help needed
Fault detection in an optical fiber using arduino
How to use pin 4 and 5 for rotary encoder in Arduino Ono
Why isn't the client.available function working in this code
3.5" image display
MXP 5100AP (Absolute Pressure Sensor) UPDATE/EDIT
How to know ESP32s-CAM board model
ARDUINO OPTA, hosting a HTML on it
Vibration of stepper
IDE hangs on startup: "Unable to get Documents Folder: Access is denied"
Panasonic EVWAE/EVWAD position sensor
Wireless Data Transmission from MPPT to Computer Using Arduino and LoRa
Robot moving in a queue fo social distancing and mask detection this code is for the straight line movement please what is wrong in the code
Atmel IC Arduino
Dead arduino, no idea why – basic project with Adafruit Motor Shield V1 and NEMA17 stepper
Resistor messaurment: Value fluctuating
Reading RS232 data with arduino uno
SHA256 encryption for Dynamodb
Arduino Tetris MAX7219 controling trough Android (NodMCU and Blynk)
Please slove this error
Wie man das Forum benutzt - Kommentare und Verbesserungsvorschläge
Blood Pressure Measurement using Korotkoff Sounds
Translation of "International > Português" category's pinned topics
The port does not recognize the Arduino
Help/Assistance Needed Button Box
GPS is not working
Errors in ESP 32 Dev Module Code
Arduino Robot Car (limit switch)
Want to change sampling rate of a PIR sensor
I am making rotary car parking sysytem in which user press 1 for parking the place which is empty come down here motor is not stopping and rfid nowork
Controlling 12864 lcd with SPI
How would i serial print the entire binary her i.e "0000 1111" to serial monitor
RCWL-9620 ultrasonic distance
Help. p10 led matrix hub no zigzag
Using Arduino R4 Wifi as IoT Test
Sketch ?
General Guidance and How to use the Forum
Conflict between physical button and IR remote
4 digit 7 segment display hex conversion
Unable to display/print on the serial monitor #STM32
Help: ESP8266 to Firebase Firestore
Decode serial port output of MPU6050 sensor data with a second arduino
Controlling individual LEDs
Arduino not giving signals to LN298 or mistaken wiring
Photocell as switch to step a program?
Pushbutton problem
Millis timing relays start with a pushbutton
Two Charlieplex modules to one Arduino
MMA8452Q tilt sensor
Unable to load bootloader
Quick question about TCA9548A addressing
Need help with EEPROM
Arduino Nano and DS3231 led function problems
3 sensors on individual codes, processing interactive visuals
How To Use The Mills() Fonction
My cnc is not working properly
I need Help in connecting 5v relay module
Hello every one , I want help pleas , i want to mointor the battery voltag with web server page with ethernet
Power saving for IoT device
Websocket send data from ina219 help
I need a detailed schematic wiring all this components for a non soldering obstacle avoidance robot Components are Arduino, 4 DC motor, l298n, HC-sr0
Turn on LED with Bluetooth
Smart parking using iot
Storing and reading R307 finger print sensor data from sd card
Servo loops 5 times then turns continuously
How to use Arduino mega with lcd 128x64
How do i start my project?
How do i interface Eemprom with Linear Acuator
Connection to server fails after a while
Portenta WIFI and RPC compilation error
Same sketch doesnt work on 2 different arduino nanos
Max30102 heartrate sensor problem
MP3 shield interferring with Serial Monitor (I think). How can we all get along?
Troubleshooting
Buck converter usage
Merging codes with Arduino
No response from the servos
IR breakbeam sensor & LED display 7 segment together to make stopwatch
Arduino UNO Schematic
Activating coin vibration motor with arduino
Starting and breaking a loop with a joystick movement
Multiple software I2C, how?
Can we use analog inputs as analog outputs?
ESP32 arduino cloud Widget not working
Code for project w/ wireless communication between board w/ gyro sensor and board with LED
Trouble #DEFINE on a 74HC595
RC522 dropping a character from the middle of UID
A4988 Stepper Unsmooth/Not Reaching Destination Movement
7-segment display stops
Dm860h cnc arduino uno
Arducam Mini OV5642 Plus With Arduino Uno and Mega
Compilation error with Arduino mega board
Compilation error: 'sendStatus' was not declared in this scope
How To use the Kalman filter with the BMP280?
2 buttons pressed
Got scheduler's multiple blink to work on nano 2040 connect
First project RC car won't move
Digishark ATtiny85 is skipping lines
How to add ON/OFF button in blynk
Leonardo Servo Control
What is problem
How to use millis()
How to get the best out of this forum
How to use this forum - please read
L298N motor driver not same speeds for both of the motors
How to make HTTP GET by PIR only once
PWM to MOSFET - output too high
One pushbutton change led lighting timing
Can Somone Help Me Please!
LM35 & DTH11 Sensors getting hot
Double run setup
Not loading to LCD
Uno R3 onBoard Led
Sending through a signal
ESP8266 can't connect Bad Board?
Arduino Uno Not Working
Arduino quiz with LCD
Hello, do you know how to solve it with the code and the elements of electronics?
PN532 NFC Module I²C Pinout Confusion on ESP32 Dev Kit (30-Pin) with Shield
Arduino uno Loadcell "if statements error"
Ultrasonic sensors questions
Remote tractor Shutdown Ver 2.0
Issues with L298N heating up
0 votes 0 answers 21 views Arduino IDE on LINUX system, how to use the #include directive to get files specific from a NAS
Unknown Error while uploading code
How can I read data from a PS4 controller using an ESP32 and send it to an Arduino Mega?
Expected unqualified-id before 'else' help
Turning the arduino on and off frequently
Gpio pin not turning on
Motors attached to L298n not rotating withlower PWM values
Why aren't my servos moving?
Arduino pozyx multitag positioning
Stepper motor random direction change
Problema con output
I2c master and slave in the same board
FastLED Set color by HEX code received by Serial
Upload error: Failed uploading: uploading error: exit status 1
Hi everyone, i am getting error on code generation, can anyone help me?
Struggling with Ppm
The serial don't send me the same data with the same string
Arduino Uno and multiple shields
WeMos D1 R1 wont display any serial output unless reset button is pressed
DRV8825 arduino
Conflict when using IR sensor and MAX98357A
Relay stays open and keeps solenoid triggered
About the Getnumber() library
RC Kart Using MDDS30 and Arduino Uno V3
Difference in outcome Laptop / Tablett
DFPlayer mini Programe
Arduino e workshop4
Redefinition of 'RF24 radio' error message on compilation
Finding troble in upload blank sketch into nodemcu esp8266
Using #define to on and off functions
Sensing the signal and put delay based on RPM and then OUTPUT
PCM library is not working with Arduino uno R4 Wifi
ESP32-S3-DevKitC-1 compiling error
List the forum sub-categories as an actual list
Pausa de 5s al inicio
'class ModbusMaster' has no member named 'write
I am working with rdm6300 and arduino uno. I am able to read 16527278 But i want to read 252,12206. Please Help me. How can i read this? watch picture
PT100 Temperature not getting correct output
ESP8266 WiFi Smart Switch 230V
Aurdino is not accepting more than 8 http
Serial moniter not working with hc-05 bluetooth module
Seven segment LED for cathode
Duetimer incompatible with FastLED?
H-Bridge engines are not running
Problem with Adafruit Motor Shield and Arduino Uno and mecanum wheels
Arduino 1.8.3 IDE not opening
Trouble uploading
Jai fait ce code pour commander un palan electrique a distance a laide du app inventor et arduino .. ma seul probleme c est que le module relais ne fonctionne pas bien avec le programme
Create array and how to pass to a routine
I have a problem with programming tilt sensor
Using SPI for IO Expander
Mirco to sensor to input
Arduino PWM frequency change
Issue with Seven segment ghosting
TouchScreen Velleman VMA412
2 Ultrasonic Code with if
How do I reset variable after song finishes playing?
Having trouble getting two wheels to work
Need help using IR
Relay does not switch off although Arduino sends the signal
How can i make while loop work faster
Code for random alarm in 6 hour shift Arduino uno
Ironman Helmet with servo and sound help
Continuous rotation for stepper motors
Determine the average of several sensors
Visuino - Some basic questions
Help with program, can't figure it out!
Arduino2arduino communication
How to precisely stop stepper motor with Arduino code
Gyroscope L3GD20 erratic values reading
Hard Resetting via RTS Pin Problem on WT32-ETH01
Something is wrong with my millis() timer
Display stays blank after uploading
Encoder on PIN A2-A3
When Yelling at The Sound Sensor the Speaker Plays?
Modbus MultiCoils
The data loss of SPI on DUE board
URGENT circuit mysteriously stopped working
Problemas al subir mi sketch a arduino uno
I can't solve this error in verification mode
Help with PID Control Project
How to control Arduino from another 2 or 3 Arduino combine with Blynk IOT and timer
Interfacing piezoelectric sensor to sd card module
Arduino y GRBL, compatible con otras placas?
Remote command (internet)
Servo motor won't work right
Cierre para taquilla electronico
LED's not lighting up unless bridged
Arduino Online Editor not showing port options
I'm using Arduino Nano and it gives an error like "Low memory available, may cause stability problems"
Arduino Mega cannot run programs that need over 70kB of memory [solved]
Error push button
Problem with Serial.print frozen my sketch
Need help with MG99R pan tilt
Using Nextion displays with Arduino
7 Segment Display not working right
BLDC Motor Controller with Arduino, keeps broken
Error compiling LED/photodiode script from Arduino Mega to Arduino Nano Every
Integration Issue with Nodemcu ESP8266, ADXL345, and Micro SD Card Module
HC05 connection only working every other second
Three soil moisture sensors problem
Looking for help on a stepper sketch
Best Developer Board Suggestion
Using ESP 32 with a program to run Room and coil sensor
Pause code while keypad value not given
Help on displaying current step of stepper motor
Expected ',' or ';' before 'LiquidCrystal'
Controlling 8 BLDC motor with arduino
The system is getting stuck after a while
Error Compilling Screen tft LCD 2.8 + Sensor
Control de dirección de giro de un motor con potenciometro
RC522 RFID how to set-up
Nrf24L01 Antenna Problem
My stepper motor driver LED won’t turn on when the power is on. Is it meant to?
Uint8_t trigger meaning
Serial communication problems 2
How to reset every pin when changing between functions?
How do I code the motion in this animation using 4 servo motors?
Strange crash happening with Arduino Giga
IRremote + OLED I2C
NRF24 and arduino 2560
LEDs Help required
Hello i need a help for arduino uno
Freenove Tracking Line
Raspbian+arduino 1.8.13+nano don't work
Expected’,‘or’,‘before long’ error
DT6-1A-01 I2C Arduino UNO code (seat occupancy detection)
Arduino server stops responding after a while
Common ground and why you need one
I have problems with LDR in my project
CoinSlot and CoinHopper , COIN CHANGER CODE
Arduino mega to esp8266 communication via TX RX
Senior project assistance
LSR to control servo
LEDs Help required
Need garbage degradation project code
Cd player controller
Svietenie lediek cez potenciometer
Voltage Reading On digital input pins with PULLUP enabled
RTC error message "Not declared in scope"
MI ESP32-S se calienta
Merging codes togther
Programming errors using arduino IDE
Error carga ESP32
EK-3000I weight measurement to arduino from RS232C to max3232
Push button timed audio and disco ball
Relay with button
Problem with Circuit 1 in examples
Does a input need to be pulldown
L298N motor driver only takes IN1 and IN2 for inputs
[ESP32]Lilygo TTGO T-Relay with PWM Fan Speed Control via Blynk IoT?
Subprogram that does not work
Nextion no changing pages or printing text
Capteur de distance bouton actif ou inactif
RS485 how to send 2 integers and receive in slave
Can I use this relay?
Hey there, currently doing a project that is literally driving me insane
Upload sketches via USB Failed on 2560
Problemas con codigo
Is Arduino UNO going bad?
Forum Members Etiquette Rules proposal
Help for code stepper motor
Using ADXL345 with Arduino UNO R3 to Obtain Time Domain Vibration Signals and Convert to Frequency Domain via FFT
Need help at coding
How to enable SPI_FLASH_DANGEROUS_WRITE
7A/160W motor driver module
Servos are not running on this code
Error esp32 upload CAN ANYONE HELP
Name of motherboard
My LED won't blink with if statement
RF remote switching
Cannot pass AT commands to shield
Control 8 channel relay module by arduino uno and nodemcu
Floating numbers in LCD
Help with Intern RTC | ESP32
SD data logger SD.open() fails
Cannot compile sketch
I need code help for my servo motor
Charging Circuit
Error with code
Why is my Ultrosonic Sensor working on my car without power?
SD Library Works. SDFat library does not
Using Millis to blink two leds at differant durations Problem
UNO R4 WiFi and sending email
Need Intro Project Help!
Automatic break system for train
Arduino Tutors?
Unable to program ATMega
Ayuda! con el for
Power factor and current measurement
Problem saving Sketch after installing IDE 2.3.1
Arduino as skills
Control motor simultaneously using bluetooth module and joystick
Problem with non-stop calls using Arduino Uno and Blynk
'microsecondsToCentimeters' was not declared in this scope
Not working with Arduino Mega
Lm016*2 lcd doesn't work
Wireless charger module
Digital pin reading "High" when plugged into specific computer
Issues using Arduino micro to control volume keys
Low voltage on ATTINY85 output pins
Speaker won’t stop making background noises
Need 25 Pin as out put 2 pins for sensor & 23 for Relays
Button Matrix CD74HC4067 not working
Bosch 4 bar map sensor not reading after 2 bar?
[HELP] Serial Communication between an ESP32-CAM and Arduino uno
Imposible subir codigo a ESP32
Need Help, trying to make a neopixel flash (predetermined) random colors
Please help me with my stepper motor issue
Temp sensor how accurate
Dot Matrixes not displaying programmed display
Using PWM sequence with Arduino Uno
Help with motors - only forward or backward. [L293D & NodeMCU v2]
Multiple ultrasonic sensor not working but wroking indivisualy
Esp32 and 4-20mA industrial pressure sensor
L298n controlling only 1 motor direction esp8266
How to Code 28BYJ-48 Step Motor for Vending Machine
Help with code for fade loop
Adafruit Thermal Printer Bitmap (1/2)
Error in almost all functions
Function of time
Informing the location of libraries
Exception Code 3 when writing to multiple coils MODBUS
Can someone pls correct this code
Arduino code problem : change scrolling text when button is pressed (THANK YOU)
No port shown in Arduino IDE for my board
Inskape path problem
LM324N connection problem in a sensor circuit
Stepper motor making knocking noises when being programed please help!
My sensor was working 5 mins ago then it stoped working
Using 433MHz RF module and esp8266 WIFI module(not Nodemcu) in same arduino?
WS2812b fastled
Protocol for sending analog time-series data over Bluetooth
What does this mean? Arduino pro mini
Is there something wrong with my Ultrasonic code
Nano serial com issue
Mega 2650 solar tracker LDR Relay
ESP32 Bluetooth to Win10
Help with stepper motor code
Create code for Arduino
Estou usando um Medidor de Tensão DC 0-25V no Arduino Uno, e gostaria que ele desligasse quando chegasse em tal voltagem
TFT SPI 3.5 screen does not work
SMS read/write problem sim800 and arduino uno
Elegoo Smart Car v4.0 : code lost
Need help with motor
Storing Data from BMP280
Trouble with LED trigger
Ir sensor with ESP8266 (webinterface)
Best LiPo battery for Arduino and 2 Sg90 servos
Schottky diode for analog input protection
SoftwareSerial connection
Problems uploading my code to the board
Cant get grove white on blue lcd to work
Issue with project
RFID Sensor Code
Error with Serial does not name a type
Advise needed for shift registers and programming buttons on it with hold and multi press
Arduino Serial Output
Generating two PWM signals with 50% duty cycle, variable frequency and one signal is 30 degrees phase shifted with another
Error while burning bootloader with an arduino mega 2560
Led light up a soon as power applied
Nano 33 BLE as USB "Gaming Keyboard"
Can someone please help me combine two different codes and save data to USB flash drive?
Need help with compiling and translating binary
Another Weather Station (with e-Paper)
Serial.read() from Arduino IDE and Python different?
Coding issue while trying to connect my ESP8266 to Wifi
LCD and screen together
Arduino Losing Serial Connection
Reset Toner Chip from my Printer
Countdown timer using 4digit7segment with Hour:Min displayed
Testing transceiver using Arduino
Using Second Serial Port on Arduino Uno
IDE 2.0 Beta 7 ; Serial monitor displays the wrong switching states HIGH/LOW
Code help required
Nothing shows in serial monitor (EDIT: Managed to solve it)
SSD1306 display troubleshoot
Lights with Shift Registers and Buttons
Esp32 Not decoding Li-Fi
How to start a second sketch in web IDE
Problems with my code
Errors with .init
Servo motor not working
Fastest, Simplest, and Easiest Hall Effect Tachometer
Errors Onesheeld code please help me
Keyboard Instrument with Song Detection
For loop running twice
Caudalimetro con sensores ultrasonicos
Proyecto Dispensador fino graneador
Stepper on off with pushbutton please help
I2C Wire library clobbering my switch statement
Arduino 2 button calculator
LCD is functioning, will not display
Connection problem from RS-YL-N01-2 Rain gauge to 'max485 ttl to rs485 converter module' to Arduino UNO
Uploading Error after boxing it
Com port change with Nano 33 BLE Sense
Ocupo ayuda con mi tarea
Square wave on serial plotter
Reading Sensor Values from Myoware Muscle Sensor
Trying to make a series of Arduino leds with one pin
CT SENSOR Calibration (Very Important)
How often does an arduino check a value
Nano every at 3.3V
Problem with connecting a MCP23017 with arduino Uno
Is it necessary to power a motor via an encoder?
Dht11 sensor and servo motor
Sim 800L yazılım hata
Set Timer for automatic pet feeder
Arduino doesn't display anything
What software do I need for this...?
SoftwareSerial Bug?
Arduino ide expected primary-expression before }
Sum and casting suggest
Push button Switches Won't work
Want to combine these sketches
ILI9486 TFT touch screen caused unexpected circuit behavior
L led, and TX, RX lamps resetting void Loop
3x4 Keypad detecting "*" instead of "0"
Can you store a lines of code in a variable?
ESP32-Cam. It takes photo data even if the camera pins are out
Why is my if statement (bottom of code) causing an error in my #define string at the top?
Choosing microphone sensor for long range
Use of Adafruit_SH1106 library cause fatal error: avr/pgmspace.h: No such file or directory compilation terminated
I need some help making a disco ball
Servos motors with Arduino
DHT11 module doesn't seem to work
MCP4725 ardunio
Unable to Start Debugger in IDE 2.3.1
Issue in String Comparison
Arduino Door lock system using fingerprint and keypad both
Acceleration and button
IDE does not run on MacBook Pro
Arduino and sensor issue
Using Arduino Nano as a IR Remote Switch
8 relay module 12v not working as aspected
AS7262 color sensor
Program the arduino uno to control the speed in one direction of just one motor, using a remote trigger and bridge h BTS7960B
Using APC220 between Arduino Uno and Arduino Nano 33 BLE Sense Rev2
Error compiling for board LOLIN(WeMos) D1 R1
Arduino stepper motor driver
ESP32+MQTT fallas
Saving two things to sd
Modify arduino leonardo code
Common code problems
Stepper Motor with driver
ICM-20948 SDK out of memory when using DMP
Compare problem
Human following car using L293d motor shield
Multiple TFT Displays with Due using multiplexed SPI CS
Marlin firmware, 'init' is not a member of 'U8GLIB'
MPU6050 - Quaternion
IR Remote and Loop Codes
Ldr sensor problem
How to increase analog output pin current?
Using multiple ultrasonic sensors to give readings to a counter
Having trouble with the "if" function
5.1 volume control
Comm issue with SIM800L
Keypad problem with ghost keys
AtMega328p and Relays
(VISUINO)-ConstantProperty' is not a member of 'Mitov'
Turning relay on and off every 5 seconds
Reading a 5 bit encoder on a Port with 0ne instruction
Impedance matching system using SPDT relay
Ds18b20 2 wires
Keyestudio ccs811
Send HIGH or LOW signals from micro:bit to arduino using micro:bit pin 0
Data section exceeds available space in board
Programming problem expert level
The return value of millis () is incorrect
Integrating a switch
Code writing problem
Converting from byte to integer in arduino
How can i code a button outside a matrix sketch?
My MPU 6050 is not connecting
Problem with analogRead
Nrf24l01 module not working
Arduino robot stops working when I disconnect it from the laptop
Dolla Tek DS3231
Get a input from a relay
Code for Arduino uno from AI
Compiler errors with TFT ili9341
Unable to find string literal operator 'operator“”redmi' with 'const char [11]', 'unsigned int' arguments
Need help with my code ASAP
Color sensor RGB
Stepper motor driver power LED not switching on
How to implement arduino emergency button
Missing library board files
Sketch does does not execute on UNO R3 + WiFi ATmega328P+ESP8266 (32Mb memory) USB-TTL
Send String via Bluetooth
Mushroom Growroom Box
All Arduinos loading on COM1
HX711 Torque sensor
Force Sensor Resistor to display weight and voltage
ButtonPress - setting of variable
Rotary Encoder LCD Blinking text
Line follower robot with obstacle detection
Port monitor and Serial error
HTML Arduino Website
Serial connection issue
Adafruit SSD1306 & DHT Sensor libraries, any know issues?
Variating 5v voltage
Using NRF24L01+ or NRF24L01 promblem
Code needs double checking
Seeed Motor Shield V2.2 programming
Please my code is not uploading to the board
Transistors or resistors in parallel
Pls i need help for this error
NodeMCU does not light properly. Attendance system using RFID, nodeMCU and arduino uno
Error compiling code using VUSB-AVR board on Arduino IDE
fd_forward.h: No such file or directory
Help with counter and led light
Displays LCD but nothing logged on SD card
Help required with Arduino, TB6600 driver and Nema23 Stepper motor
Having issues adding a void() in this script
Can't Get AT Commands to appear in serial monitor for HM-10 or HC-05
Hi New here I want to learn as much as I can, Thank you
Portenta H7 with Nextion Serial Strings Read
How do I connect an Arduino MEGA 2560 With WiFi Built-in(ESP8266) to my computer to work purely as an Arduino MEGA?
RTC Alarm with DS331 Arduino Uno Sofrware Problem
I need help learning
Problem with generic arduino uno
I need some help with my sensors
Setting up the Relays to water for 30 seconds each when individually triggered
'class HMC5883L' has no member named 'begin'
Can i use two I2C devices at the same time?
Definition and Use of the Command WiFI.mode
First try with .h and .cpp, Multiple Definition issue
Arduino no lee dos sensores vl53l0x
"can't open device "\\.\COM1": The system cannot find the file specified"
Adafruit_SSD1306.h library is not recognized
New to arduino and coding
Arduino Editor Issue
Error? DHTPIN was not declared in this scope
Rs485 and arduino mini pro
I2C LCD(16,2) not displaying text
Node esp32s v1.1
Problem making a global variable for 2 functions local varible
Can someone help me, for my 4in1 5pin probe RS485 THPH+EC Sensor, I have code but it doesn't read anything. I am using arduino uno for this
Global Values - taking up too much memory
Actually i am new at forum , getting the error "expected primary-expression before ')' token"
display.clearDisplay();
Schematic for my useless box (first project)
Arduino UNO driver not working / Help to figure out it's label
Code can run on tinkercad but not in arduino board
I am having an issue sending and receiving $_POST values in my PHP script
Fatal error: Adafruit_GFX.h: No such file or directory
Trying to make a simple Lixie clock and cant Figure out the code
Problem in running two sensor in arduino
Flash radiotherapy project (aka cancer treatment)
Sorting data before averaging
Help ! Serial Monitor
All A Ports Reading Weird
Arduino water pump controller
DS18B20 Temperature Sensor *Amazon (Experts Help)
Remote control (on/off)
How a character is converted to a string. How to read data such as Esp32, bluetooth low energy Serial.readString ()
Problema com Relé 12v
Issue with interrupting Vl6180x x proximity sensor with esp8266 nodemcu v3?
Maximum channel frequency NRF24l01 - aboveGHz
Need help learning how to create a function with x inputs and returns a y value
I have problem with the if statment
My rfid won't read a card
Arduino UNO 4 wifi Blocked
My Ciphertext is not showing #esp32
How do i connect autonics temperature and humidity sensor with arduino
Script tag not working with Arduino and ESP8266
Increase the number of led matrix to 8
Error 0x44 en programacion de arduino ky 038
Serialtransfer.h using String Crash
I'm trying to write simple code to move my servo but cant figure it out!
Glcd project using arduino uno
Arduino not connected on raspberry pi reboot
An error occurred while uploading sketch
Relay activation even if the circuit remains closed or open [Solved]
Tradução dos textos fixos do Fórum em Português
Struggling with DC Motor Controller
Associate a serial2 port to megunolink
Run the Goldbach Conjecture
Arduino steering wheel help
How to get the best from this forum feedback and comments
Connect buzzer to temperature sensor arduino
chipKIT MAX32 - Serial Monitor
DC motor turn on if sensor triggerd untril button pressed
MPX4115 is not working in proteus 8
Arduino Nano Output pins are not working
Problem with two loops
Changing existing code to match a sensor
PCF8563(RTC) time ajust
Arrays in a library
Loop is broken (led is not blinking for long time it was broken)
Errors compiling for Arduino Uno. Is my code faulty?
Change a value from json
Error Playing a Mellodia "exit status 1 aggregate 'timer treplaceMe611347' has incomplete type and cannot be defined" using ProtoThreads Library and Timer
TFT_eSPI touch demo compile error
Good Rotary Encoder code
A simple question
Restar for each pulse
Obstacle avoidance robot wheel not working
SSD1306 allocation problem
Function-definition is not allowed here before ‘{’ token
Compiling error for Arduino Code
Arduino UNO controlling led's on outputs
Codigo arduino temperatura
Intercept modem calls
How do i make 2 arduino devices track each other?
How to fetch data from node mcu to arduino uno
I would like to ask why the screen of my wio terminal does not light up when running the program?
My Brushless Motor is beeping
Stepper Powered Tank - Please Help
1 year meter making
Gps tracking system by sms
Stepper motor code question
However i am getting the error code, expected unqualified-id before numeric constant, on line two. has any one got any ideas on how this can be solved?
Kalkulačka pomocou potenciometra a tlačidla
I'm new. Please help me with this coding
Finding the minimum, middle and maximum values
How can I output a signal from an electric guitar to an amp with arduino uno?
Old UNO sketch has failed
Me aparece Device OFFLINE
How to replace the pin 2 in arduino uno
Send data from python by nRF24L01 to arduino receive data by nRF24L01
A bug for grammar auto checking IDE 2.0. beta 7
Parking lot project
May I know why would this happened and how can I solve it?
Need help with explaining me a code
Code Request - 3 100k NTC Data Logging - Teensy LC
About Theatre Chase effect on LED strip with WS2812b
Looking for Advice on my project setup!
Trying to find the best way to power project
Flash sequence numbers
Automated Hydroponics Nutrient Solution Control and Monitoring
Problems with sending can bus message using arduino DUE
Servo motor with one button
OLED (SSD1306) and RTC (DS1307) not working together
How can I get 2 second delay on servo after pressing button?
Controlling BTS7960 with arduino and radio controller
Nano MobaTools Library - Speed Steps Needd Advice
I'm having servo trouble
Struggle to run Arduino Uno Wifi R2 for more than 5 minutes.... :|
I’m new. Please help me with this coding
Help with figuring out power supply required!
Trouble with ESP32 Interrupt Not Triggering on GPIO Pin
New guy trying to learn
MAX30105 heart rate sensor not recognized by its own library
Builtin Led is alway working
Rainbowduino ParticleSys error
TX to rx and RX to TX aint working correct
Serial Input from multiple characters
Basic Arduino GPS with LCD
Arduino 1 switch , 1 poten , 1 lcd , 1 buzzer
Ultrasonic to RCA out
Servo rotates 180 degrees with UNO, but only about 80 degrees with D1 Mini Pro (esp8266)
Bluetooth module lib
I want to write a ESP32 code about automatically controlling the brightness of the Neopixel light bar
SD Card fails to write every capture of IMU sensors
Usb sheild giving power to wireless charger and not keyboard
Motor with fixed frequency but changing amplitude
Esp32 code compiling error
Uneven blinking rate of LED without delay() without millis() overflow
Why cant I control relay using both light and motionsensor at the same time
Error message : a function-definition is not allowed here before '{' token
Arduino mega as LED controller?
Program for combination of falme and temprature sensor with 2 module relay
Sketch is too big
Creating a window of time using TimeAlarms
Serial Communication between Two Arduino Boards
ESP8622 and MCP23016 .-. pinout GPIO.1 , 2 , 3 ... 7 selection
Proyecto de Expo joven 2023
Can I still record data in my SD card module even if my arduino is not connected to the laptop, however my arduino is connected to a power source?
How to power arduino Nano with 9v Battery?
BLE ANCS Pairing Failure on ESP32 Using BLEDevice Library – Error 0x66 and Bond Loss on Repeated Connect/Disconnect
Desde una sola bateria obtener 5 y 12 voltios
Separating incoming string through 433 MHZ receiver
Some really basic questions on circuit boards
Avrdude stk500-getsync () : arduino uno and mega 2560 avrdude
Comparing two ds20b18 values
I am trying to interface LM35 temperature sensor and soil moisture sensor
My button is reading from pins that are not declared
How do I declare for "sendCommand" and "getData"
Esp32 Cam A fatal error occurred: Failed to connect to ESP32: No serial data received
How do I send a number from NRF24L01 TX to RX
LMD298 doesnt drive till analogpin has no voltage
ESP8266WiFi Lib Error
Help with my code for making my my project named Routine Ranger
How to turn "off" or black specific pixels on a LED string?
Client.connect help
Message return function
Included library needs to be inculded
Help suddenly cant upload grbl to my arduino boards
Arduino as skills
Parsing numbers from RS232
Request Serial data
Please help, i can't figure out what's wrong with my code [solved]
Coding with 2 sensors and 2 actuators
Convert code from nano to work on mega2560
MAX30105 was not found. Please check wiring/power
Usando exel com módulo SD no arduino
PROPOSAL: Earning "Full Posting Privs" badge format
How to show sketch for getting help
Up Down Counter
How do I switch this from working with TMP36 to DHT11?
Can someone please tell me what I am doing wrong?
Esp32 to log in to windows with ssh key without password and send a shutdown command
Arduino nano analog output not working
Rotary dial pulse counting
La wemos d1 mini no carga pagina, conectada a rduino mega
Using Ds1302 RTC with Servo Motor
Triggering 3 Separate Servos with 3 Separate Sensors
Adafruit 0.96 display won't work with my code
Self driving car with 10 HC-SR04 sensors using millis instead of delays
Programing for N298
ARDUINO uno With Ethernet shield +php
The merits of delay() vs millis()
Loading arduino MIDILibrary
Esp8266 v2 board
Can't get two rf24 to communicate
Control PID de temperatura
Atof() Precision is not accurate
Problem with ds1307 rtc
DHT Library Problems
Add count by 0.5 mm after every pulse recive in digital
Proyecto comedero automatico
Changing baud rate interactively
Millivolt/microvolt measurement
775 heating connecting to bts7960
Codding problem
Using 4fnd (seven segment dispaly) count down from 100 to 0, also buzz once hits 0
RFID data to JSON
Multiple OneWire Buses
Anyone ever did a event handling to use ble and wifi?
Serial communication NodeMcu&Atmega
I uninstalled drivers and updated with CH340 latest driver also i am facing same issue, i selected ESP8266 Generic module code simple LED blink
How can I get my Potentiometer to control everything?
Robot bluetooth control and obstacle avoiding
Arduino with DMX Shield with trigger button
Interfacing Sensors to an Arduino Mega 2560
How to make sensor properly?
I am having the upload error in this code
Arduino with nextion display
Problem with TFT screen while compiling
MFRC522 not Working on ESP8266
Sending numbers with rf 433 MHz rx and tx modules
Can Anyone Help Me Understand What I am Doing Wrong?
68:4: error: #error "Required HOMING_CYCLE_0 not defined." #error "Required HOMING_CYCLE_0 not defined."
Arduino becomes unresponsive after sometime of operation
Implantable Identification Project
Control 4 relays to turn on for a few seconds a day and then turn off
Arduino data transfer to smartphone with NFC
Using a nrf to send button signals to control a servo
MeanWell HLG PWM controll
Charge pump circuit
Wemos D1 external power through 5v pin
Cambiar icono de arduino Leonardo b
Efficient way of programming for a six line signal
Using RGB LED light with all posible colour within 20seconds
Can anyone help me with the coding of fire alert with sms800L
How to get the best out of this forum (short version)
Servo motor only moves from 90 to 180 degrees
Arduino uno exit status 1
How to stop serial monitor
Issue obtaining data from MQ135 Sensor
Arduino uno R4 wifi
ESP32 and RP-S40-ST force sensor
Problems with PulseSensor_Playground libraries
A fatal esptool.py error occurred: Cannot configure port, something went wrong
Using I2C to read the onboard IMU of the Nano33BLE without using the Arduino_LSM9DS1 library
Are my connections correct
IR sensor spitting out multiple different codes for the same button, and occasional 0's?
Having trouble adding 1 to a variable and making lights correspond to those values
Hi guyss can you pls correct this code , this have some mistakes plsss and i cannot find the mistakes
Stepper motor not running
Portenta H7 no matching function for call to 'arduino::MbedI2C::begin(PinName, PinName)'
Hello all, how do I solve ovf bcos after the reciever print the float value it continously print the ovf. Please help
CAN-BUS Shield interface with 7 segment display
Reverse ? error in serial
Photoresistors and LEDs
Trying to turn off an led when temp is reached. (using dht22)
Controlling stepper with buttons. buttons only working at top of loop
Error message - undefined reference
I have a ESP8266 and a website i want it to do something to visit the website
Resetpin on the Arduino micro
Board selection to control 120vac motor
LCD Display not working as planned
Project hardware
Digital RCU tester
Error pops up when I try to use my Arduino
Esp01, gps module connection error
D13 triggers when powering up (simon says)
TFT lcd blank screen
Communication between TWO Arduino nano 33 ble sense
Сompile code error: “undefined Reference to `Num::getNum()`
FastLED and WS2812
Starter experiment/ invalid library
FastLED and WS2812
Sending sensor data to cloud server using Arduino Uno and ESP8266
Sensor de huellas dactilares con ESP32cam
Duplicate rows on 32 x 64 LED Matrix display
FastLED July 4th Red/White/Blue Scrolling Help - Why is this code not working?
Max Leds control arduino nano
Help with Motion Detection using Arduino Nano 33 BLE Sense
Project code sugestion
Hello everyone I am new in arduino how can i solve this problem .. i am trygin to call data from gps function and tracking function
Monitoring project for a small fish farm
Two sequence using a switch and 8LED
Arduino act strange as I pull the cable out
My Arduino gesture control project
Connect 6 Sensirion SFM3013 Gas Flow Sensors to an Arduino
Arduino Uno and Reyax Rylr990 LoRa transceiver
Error in serial communication or uploading of node mcu
Building a Compact WiFi Modem for Electricity Meter with 12-Pin Connector
Simuler une pince amperemetrique
Serial is printing character by character
Need help at coding
Facing problem with EEPROM results
RFIDksj kate bro ha
SoftwareSerial TX problem
Using a class from a separate .cpp is not working
Any idea i got this error ArduinoIoTCloud.h no such file or directory
Pin Voltage Pullup
Arduino Uno not connecting to my PC
Linear Actuator is not working with BTS7960
UART communication issue with NPK sensor and ESP32 LILYGO-t-sim7000g
Sparkfun esp8266 wifi shield not working
Arduino Due with Bluefruit
LSM9DS1: Disable gyroscope
Voltaje Mínimo para pin Aref
Pin Voltage Pullup
Need to run the loop function only when I call any function
How the heck does this work (the Crudest possible way of switching a relay with ESP 01s works!)
Flame sensore detects dire where there isnt
Help fix my code PLEASE
Modifying existing Sketch to trigger PIN 13 LED at set point
Arduino Nano Füllstandsensor
ESP32 : Missing terminating " character
Exit status 1 'Mix' cannot be used as a function
Arduino can communicate via serial monitor but not with softwareserial
Float array print issue
Not able to get data from the optical encoder
Hello i need some help with ultrasonic sensors by communition serial
How to measure voltage of battery using ESP32 internal reference voltage?
Need help quickly! Arduino Code. Fixed
Problem with printing out a random number
RC signal to trigger sounds on DFplayerMini using SparkFun ProMicro
Read SD file into an Array
Unintentional delay with Arduino
HardwareSerial Problem with ESP8266
Problem while integrating Wokwi esp32 simulator with firebase realtime database
Need two more I/O
Xvalue not declared in scope
DHT11 if else statements not working
Error compiling for Arduino uno problem
Arduino as FM receiver
Magnetic hall sensors
Cannot upload Puzzle Box Templet
How would I program this?
Arduino Chessboard
Fingerprint not detected
Compilation error exec
Mobatools limit question
HC-05 Serial Comms - 2 way not working in SoftwareSerial
How do i print this string and float value
Relay module error
MCP4725 sinewave generator
Looking for someone to write a simple program
Script only runs if it is connected with the computer
Necesito ayuda con balanza con celda de carga
Error: expected primary-expression before '<=' token
I need help fixing my code
Conditionals in main function do not detect serial port value
ESP32 Battery Percentage
LN298 motor driver with uno just one motor works
Read values from a 3,5mm jack
Bro, i got stuck with my code. can you solve this code to connecting to website
Here is my Dragonframe CNC Shield V3 Moco Solution & code!
Command for pcm1738
Problems with serial input
Hello guys can you teach me how to connect my flame sensor, smoke sensor, buzzer, dht11 and lcd to my arduino? with the smallest breadboard
UTFT few display connection
Multiplexer issue
LM35 another topic
HP4067 Mux convert Serial to DigitalRead
'uint8_t' does not name a type
Collect2.exe...help me
Pro micro/ sx1509 button box question
Using limit switch
8 Servos with Arduino Mega 2560 R3
Getting low voltage from digital pin (0.5) instead of 5v
External power use problem
Level and quality of forum posts
Smoothing problem
Arduino Parola strolling text font
RF communication problem betwwen ultrsonic and servo motor
Have a problem with control the speed of 2 stepper motor
Boas precisava de ajuda porque quero enviar os dados de 4 sensores ultrassom por comunicação serial
Analog Reading for Temperature sensor Cumulative value
MIDI touch piano with two MPR121
Getting Interupt every time switch press
How to add x1 and x2 button mouse logitech leonardo + usb shield
Waveshare sx1262 HF lora module
How to convert this function to int, is function String?
Sending BMP280 data over 433 mhz
How to add a serial port for instance COMX?
ST7920 Graphical LCD not Working
Converting encoder data to hall sensors data
Error code: 1000
Powering SIM cards with SIM800L
Percent timer by using arduino
Arduino pro mini timing seems to be off
Uploading using programmer doesnt work
Turning string output of function into a String
Pump Control with Mosfet
Connection to Google Sheets failed Help pls :(
Momentary Halo Switch Circuit - Will this work?
DC motor only runs when arduino is connected to pc
433mhz led control button
DragonFrame Motor Only going one way
How to connect to Alexa
Can anyone change this code to use it as a class (preferly mostly private) couse there are some other codes into the code that uses these classes by calling them in swich case or if else
Can't get expected readings using PulseIn command
PIR sensor controlling servo always reading HIGH
8 Channel millisecond timed based relays?
Serial Communication garbage while reading a char
Pull-up or pull-down resistor with PNP/NPN hall sensor?
NAOS (Arduino OS)
Serial Monitor and FDTI connection
GPS data not showing on my web server
Why motors here are not working? They worked on a similar scheme
Arduino motor issues
Can't find zip library for 2.0.0-beta4
Control_Surface.h Library display CC Values in Oled
Pausing code after my if statement
Simple solar tracker
To measure current and volatge
Library of the code
HC-05 Bluetooth module - laggy transmition
Button LED and sound problem
Arduino calculator using adder and xor
Arduino Ev ery and Library DS3231_Simple
Old Landline Phone To Ardiuno
WROOM32 not in IDE
Can anyone please help me to edit the below codes for the sensor (in the link); Arduino; Ammonia sensor; serial communication codes
Water flow sensor does not work correctly when adding a power supply to the circuit
Exit status 2, no serial data received. My first topic
TMRpcm not working (stops playing immediately)
Data request using GSM shield
Problema de conexion entre Modulo AT-09 y dispositivo mobile arduino nano(Problem connecting a AT-09 Bluetooth Module and a Mobile phone arduino nano)
How to make "Hello World" on Oled 128x64 SPI
Ldr sensor problem
Stepper motor 24byj48 vs 28byj48
ADS124S08 data reading problem
HELP WITH WIRING nRF24L01 with esp32s2/LOLIN S2
RFID AND SD MODULE Problem in a project
Painless mesh outside communication
Stepper Motor loosing steps
Port busy (fingerprint as608)
Esp32-(xQueueGenericReceive)- assert failed
3 square wave generater
Arduino is not working stuck on loading screen(Windows 10)
RFID wrong code received over RS232
HX711 with Arduino
Using HC-SR04 sensor to trigger max
AVRDUDE ERROR with the code that ARDUINO's website provides
Calculating frequency through analog pin
Arduino Uno Variable frequency generator
Adding readings of two load cell
usbMIDI problems with the Teensy
7 segment clock multiplexer error
PROBLEM reading from serial monitor
Arduino UNO - increase motor speed (easy)
Serial command and carriage return
Nextion Library and numbers above 65536
5202 Motor Speed with RC Control
How to properly insert delay() function
Arduino IDE code uploading errors
SerialSoftware Problem
Nano 33 IoT I2C BLE
Im very new to this can i get some help please
ESP32 touch pin to control relay
Error library Adafruit_Fingerprint
LCD "Shift" issue
HC05 - ZS-040 board Firmware v1.0.2
How to control multiple LEDs with 74HC595 shift register using millis()
Send SMS once Arduino is triggered via a push sensor
NANO - Uploading forever
(Uno R3)Ultrasonic sensor& servo troubleshooting
Lathe threading problem
Controlling Several LED methods via Bluetooth
Using Uno to control a 5V non addressable led strip
LED Ultrasonic Sensor
RS232 to TTL conversion last bit error
Haxapod arduini mega 2560
Esp32 push Html var to Arduino String var
ESP32 with MCP2515 Not Receiving BMS CANBUS Data (ID 0x100)
Multiple Thermocouples on nano
How to programm a panic button
Received Raw signal displayed in Serial Monitor is different from the sent raw IR signal
Nrf24lo1+ with adafruit fetaher M0
Full Sketch Compilation Error
Rolling Ball device, ball sensor-tripper
MPU6050 connection failing
For loop only runs once
Wiring diagram for limit switchs in cnc shild v3
I cannot compile
Weather station sketch crash after a few hours
Ultrasonic theremin
New and need help with my code
How to display the serial monitor data to an oled display
UBLOX Neo-6M GPS Module not working / not powering on
Strobe Light Effect, HELP PLS!
Arduino Nano digital read/write problem
Random sound on button push with arduino and dfplayer
Scotchy diode dead
Using a dc motor with a photoresistor
Help with P channel transistors
SD Card can't save new Pictures
TSL2591 turn on LED, how do I write the if statement
Stepper Motor turns once when powering up Arduino Mega
Start code with a button
Choosing a battery to power multiple high power servos with different specs
Df mini player with atmega32
Please Help! Programming or Wiring problem
Generating a waveform with two frequencies
Help with Stepper?
Program Files (x86)\Arduino\arduino-builder returned 2 Error compiling for board Arduino Nano 33 BLE
Need help with bypassing the 50 day limit of millis() function
External Interrupt speed for Nano 33 BLE
Creating a multiple pulse generator using arduino
Can someone combine my coding for this Car lighting system
Arduino Not Lighting Up LED
Nightlight LED not working
Unable to create a precompiled Library for ESP32 boards
Multiple servo with multiple sensors
ESP32s2 I2C Scanner not working
Secondary Clock ''СТРЕЛА" made in USSR
6 LEDs have to blink, after a button is pushed, but not held
Nrf24l01 arduino doesnt work
Simple Nano-based music player using an sd card
Vane anemometer from ruoshoi digital anemometer
I need help with my Arduino UNO!
Text Splitting from HM-10 BLE
Proyecto con varios lectores RFID
Fallo pin 13 arduino uno
Triggering events with multiple sensors
Problema para instalar agente Arduino Create Agen
Mqtt return value is -1 (arduino mkr wifi 1010 + microsoft azure iot hub
Problem while compling a WS2811 LED with ESP32
Can't compile code
MPU9250-6500 connection problem
(esp32- cam with module ov7670) Camera probe failed with error
Serial Monitor Not printing with ESP-01
Modulo de bluetooth para audio
Code for Multi turn Pot
Counting the number of distances measured in one minute
Modbus TCP with W5100
Self balancing robot fell down after picking some speed
Read buzzer - piezo with arduino
Compilation error: exit status 1}
Touchscreen connections
"For" statement runs twice in ISR
Self Balancing Robot project- wheels only spin in one direction
3,5mm jack input to digital value in arduino
Stepper 28byj-48
Arduino potentiometer replacement
I get this error how can i fix it
Distance Sensor - False Positives? [solved]
Run Programme When Key Switch Enabled
Keeping the angle measurement the same for holding position
Homework Help Section
Strange problem, after giving lcd.clear();
Help with code on board and blynk reporting
Fix your slow cloud service
Arduino, ESP32 , PS4 controller
Need help solving
Stepper motors not responding
Reading multiple analogue inputs and printing values
I2C protocol + Serial comminication
Frequency measurement using hb100
Two stepper motor
Ada yang bisa bantu?
Play animations on TFT screen when certain buttons are pressed
Struggling in using millis() with ultrasonic sensor and some conditional statements
Keyboard, Leonardo+USB host shield issues
Ide 1.6 geeft fout in 2.1.3
288YJ-48 Motor Continuously Spinning in a 2 Motor (Joystick Controlled) Setup
Magnetic Guide Sensor with RS485 and Mega
TPS Voltage regulator not working
Digital Relay Box
Duplicated libraries
I have connected Lcd ,adruino and breadboard but the lcd display not showing the text that is wrote on the code of arduino
Mini Project Arduino Code help
Can't use digital.Write in void correctly. ''digital was not declared''
Help: Arduino pump that dispenses to a target weight (4×4 keypad + load cell)
I want to stop a moving servo with input from a micro switch
Arduino Mega 2560, and Modbus Slave RTU Library
How to fix this
Using ultrasonic sensor to detect an object with a buzzer
Air flow detection to turn on my Arduino from sleep
Ov7670 and esp8266
IFM pressure sensor
Connecting optocoupler to GPIO
In function 'void setup()': 66:14: error: expected primary-expression before ',' token
Programming Error: expected primary-expression before token
Why is my servo sticking?
DHT Humidity and Temperature Sensor not working
HC-05 Bluetooth module not working correctly (with videos)
OSOYOO smart home mega2560 help
TFT touch Screen+ Serial communication
Error compiling
Current or voltage control by PWM?
Multiple led's random on off
Sensor zmpt101b duda
Red de sensores zigbee
Cnc router uno r3 based
Ir sensor trouble
LCD with shift register issues
Modify GPS tracker coding
HELP Joystick Type Error
I need some urgent coding/circuit guidance for my project!
Help, Encoder EC28A Android Radio
RGB LED controlled using IR Remote
SDI12 and LoRA librarys Problem
Arduino SD module
Thermocouple reading drop for 20C when Motor driver TB6600 is connected which is using 24V PSU
GC9A01 display using 8 bit Parallel on ESP32
Arduino MKR ZERO DAC resolution
What is the error in Adafruit_LiquidCrystal.print(" by L.L. ");
Raw EMG signal does not change with muscle contraction on Arduino / STM32 ADC
Expected intializer before string
Integrating MH-ET Scanner to TFT code in Arduino
Need help with my school project ASAP! expected primary-expression before ')' token
Wemos D1 mini upload failure
Switch With Led
Not declared in scope how can I solve this problem
How to connection arduino nano with modem usb gsm?
Best Sensor for Coin Sorter
Trying to Display Time using time.h
The compiling isn't bieng done!
Duplicate button utilized on button box
I want to extend nrf24 range with antenna to 1km or above. Please help me
"How to control an electric wheelchair using voice and head movement?"
Problem with tft 3.5 ili9844, There is no way to get the Bmp out
Terminate Return()
Where can I find electronic circuits classified by “difficulty level”?
Problema con dos RFID
Can I Use Arduino on a Windows 11 Machine To Connect To Mission Planner?
Esp8266 water flow meter 0.96 OLED screen
Arduino with PC sync problems
Decode data stream from serial
Error: 'FastLED' does not name a type
How to read data from sd card and compare the id from r307 finger print sensor?
Why do I get these errors?
I cant drive my dc motor with arduino and L293D IC
I have problem with project
Error when I upload
Upgrading Issue: RuntimeError: Click will abort further execution because Python 3 was configured to use ASCII as encoding for the environment
I need to help make push button down 4 menu code
Help need for counter status
Exit status 1 Error compiling for board Arduino Nano
LCD Display Problem/Question
Nano Matter on Apple Silicon machine without Rosetta
Lcd progressbar problem help plase
Problem with demultiplexing and multiplexing
Extending available outputs with 20+ kHz PWM
Binary not received by board (MKR1010)
2 DFMini mp3 players not working
Arduino computer serial connection
Main HC05 error solve
Hello, I like some help about this code. I´m having trouble running - It´s for building a Magnetometer. I´m new in arduino programing
Please help me i die in all this errors😥
Arduino Uno with SD card shield not recognizing esp8266
Very simple Ultrasonic sensor and distance sensor
Ethernet_shield not continously working
Seven Segment Display Flickering
RGB LED not lighting up
Firebeetle ESP 32 error or my laptop?
Set up sample rate of arduino
Possible nRF24L01 code Issues on a RC Car
Tortoise vivarium controller
My code so I can have it evaluated? And maybe be guided
How can I duplicate the 5V and GND pins on the Arduino nano board?
Using Speak up click to control motors
Bluno Beetle BLE only works when serial monitor is open
Help with blinking single LED
Energy meter with arduino
The use of millis
Help needed on a project
MH Z19 code sensor testing on arduino uno
Arduino won't compile. I get error message
Arduino UNO y NANO con CH340 (chinos)
How can I create a Water Sensor Vibrator Device?
I made Arduino Korean word clock. Please help me
Variable voltage controller w current sensing
Comparing two output
Serial(bridge MPU-MCU) Serial.available() call hangs mcu for 4.5 to 8ms
How do i wire this stuff?
Expected constructor, destructor, or type conversion before '(' token
Combination of flex sensor and LSM6DS3
Goole Chromecast manufatures code
Servo and MPU6050 IMU problems
Alternative definitions for analog pins
Need help with an 8 step sequencer
Arduino MIDI device issue
Totaling all values of sensors
Color changing neopixel with button ending with2 white LEDs
DNC Via Arduino Serial
Problem in serial communication and i2c lcd display not working togeather
Cant upload code to nan every
How to use Arduino code to get tag coordination?
PPM Sensor result on LCD blinking
How to hack OBD-II to measure steering angle of a CAR?
Nrf24l01 receiving random data
L293D motor speed problem
Comunication with module sim800l
Issues with NRFL24L01+ modules on project
External EEPROM Interfacing With Arduino Uno
Buttonbox not compiling
Looking for someone to check my schematic
Communicating two Arduino Nano using SoftwareSerial
Errors with bytes on sketch
programming different sensors
Serial comms, Micro > Micro Pro
Bend labs one_axis_ads
Second value of Serial.println() is always 0
Plotting points on a cartesian coordinate plane with given degree and distance
Unable to connect to the mqtt
ESP8266 with PxMatrix for P6 RGB 32x32 Matrix
Payload: Arduino - The Things Network (Arduino MKR WAN 1310)
Water flow sensor connection to Uno Board with pull up resistor
Counter implementation on IR sensor
Error compiling LowLatencyLogger
ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]_
Problema con las banderas
Why doesent it work
Keyboard Code Error Arduino
Need help in EEPROM
Using Accel3 from Mikroe
Stupid question I know, but please help
Accelstepper and RF24 compatibility
Adafruit VL53L0X high accuracy with Adafruit_VL53L0X libray
Running two applications at once
I am a beginner and need some help with code and the lcd, and I would really appreciate some help!
Help Error message!
SIM900A and Float Switch
MKR Wifi 1010 doesn't connect!
RFID reader with RC522
Problem sending string using I2C
Updating libraries, boards taking very very long and still not finished
Electrostatic Discharge/ ESD troubles with Wool + Arduino Unos + Ultrasonic Sensors
Control 16 segment to display month
The 3D Magnetic Levitation System: This is a completed, fully working hardware project
Making servo go around while holding a remote button
Problem in Getting Stepper Motor to Rotate
Possible Coding issue
Errors while updating boards
Li-ion Discharge Charge Circuit
Sistema de modulo para bico injetor
Connecting esp32 to wireless headset
Elevator with 4 floors
Capacitive sensor with Arduino and AD7746
Porque no me va este codigo y me da error?
Sainsmart 5 inch display, Compile errors
Inconsistent behavior
Arduino exit status problem
Absolute Noob coding question
HC-05 Master slave latency
Serial communication problem with RS2428 relay module
BLE UUID HELP programming arduino
Joy it 20kg pressure sensor coding/hardware isn't working help!
Sketch not running
SD arduino open&read fails
Need urgent Help On my project someone please help
Controlling 0-5.7v signal dc motor
Arduino uno lcd 16x2 i2c and serial print stuck can't update read data sensor
Arduino Interface with node-red
Connect arduino wirelessly
Mega 2560 r3 wifi esp hangs when not connected to USB port
Water boiler controller help needed
Why is this code not reporting the error more quickly?
Breadboard Voltage Input/Output
Can anyone help me to program a line follower based pick up and place robot
New Errors and Ports Not Working Anymore
Project on automatic parking system
Doorlock.. Proplem with the servo motor
Circuit Diagram and Arduino Coding
Weather Monitoring Station Using Telegram anf Blynk Cloud
Arduino Grbl has not finished uploading. Getting error
Nema 17 with Big easy driver, jittering
How to auto reconnecta client and retry if the connected server disconnects / W5100
Automatically railway crossing system
Problems with receiving data with espnow and sending it to thingerio iot
Arduino - bluetootth
Force sensor with Arduino
Clear interrupt flag using software
Help for Decoding SEA j1939 Using MCP2515 and Arduino Uno
Controlling external circuit with PWM
Code for rolling shade using Uno and Stepper
HELP ME! Arduino don't write SD-Card in the sector 0
Using shift register for serial input
Please Help me In Debug this code
Question about Arduino Nano Every and Button, LED + Serial
Controlling modded servo continuous rotation
Developing an Arduino Uno
COM port not being read
My ESP crashes running my code and restarts itself
Is there a code that counts the number of people in front of the sensor?
Reading load measurments in increments
ESP8266 disconnected
How to measure stator current in 1ph induction motor
Nono + momentary buttons + 2 relay module
Pass data From Arduino to PHP
Df player mini, can any one help me
Invalid conversion from 'const char* to 'char' [-fpermissive]
FSR voltage steadily increasing
Shift register with millis possible?
LCD display show weird character while using Serial port as input
Selfbalancing robot doesn't react fast enough when falling
Portal web seguro w5100 + arduino mega
How to troubleshooting my project
ESP32 SD-Card Stream download, sd card failure?
Preset position of a slider according to video timeframe
Room to optimize code
Concatination of string
Manejo de 4 servos con un solo sensor ultrasonico
My AT command Software Serial is not available when im using a Software Serial for GPS data
LCD display and Rotary encoder to measure distance
Help with making a competition buzzer box
Ribbon cable to pin out
Library 'Servo' is not uploaded to the board
Controlling servo direction using one push button
Controlling a relay with a limit switch
ESP32 camera - serial monitoring font break in output
Issues with 12v and 12v relay to power a pump
LORAWAN device With RFM95 on Arduino Pro Mini
Using step motor for full and half step
Why can't I put my Arduino Mega into dfu mode
nRF24L01+ Transmission failed or timed out
Adafruit 8x8 1.2”
Timeout Error (serial)
Problem with compiling for Nano on IDE
Servo won't respond with ultrasonic sensor
A too long array?
Multiple Dallas onewire busses on a Arduino
Error compiling for board Arduino NANO 33 IoT
Servo keeps shaking
Multiple libaries were found for "SoftwareSerial.h"
Arduino code to read the pins
Temperature Controlled Fan with i2c LED
Random specific colors for NeoPixel
Adafruit BMP388 Board Arduino Code Error
Void Setup error
Control hot water
16 by 2 display with I2c module not working with r4 wifi
Unbekannte Fehlermeldung beim Sketch
GPIO Pins Layout In ESP8266 Motor Shield
Windows 7 fails to install drivers - not even listed in Device Manager
Yet another garbled monitor output
How to fix unstable analog output from A0 pin
Wemos d1 r2 sinric pro contact sensor
Sensor de huella con arduino usando un servidor web
How to create a Random movement for interactive art
Arduino and stepper circuit pin diagram and upload code
A 3d designer Wanted for us
Módulo de Arduino
Board time out issue : Mega 2560 with ESP8266
ESPConnect v1.1.18
I'm beyond help with this Stepper Motor
Pin-Configuration of the ECG-Chip AD8232
Arduino: 2 digit 7 segment display with temperature sensor
Need help with attachinterrupt, it affects other functions under void loop
Did I kill my nano?
Receiving 5 volts as an input, and then sending 5 volts as an Output
Error compiling for ESP32
Programming push button to start timed Servo Sweep
Can anyone help with passing serial command from arduino Mega 2560 to M6e reader. I am getting connecting error
Noisy AC voltmeter
Error " 'lcd' was not declared in this scope "
Arduino con Bluetooth HC-06
Arduino uno midi system exclusive
Exit status 1 error de compilacion en compatible Arduino Nano
Powering a Sparkfun pro micro project from lipo
Arduino lcd display
Me aparece este error
Is it possible to create a wireless transmitter to several people ?
Expected '}' at end of input Arduino Nano Elegoo
Voltage sensor 25V and Arduino IDE serial port (COM)
Help why wont this cod work
Arduino to control 3 DC motors
Optical Bubble Sensor BE-A 401 (Panasonic)
Moving from a USB cable to bluetooth
Controlling a servo with 5 wires
How to use ultrasonic sensor and activate LEDs through it?
Arduino UNO Quadcopter Schematics
Calculate distance Mega Ublox NEO 7M
Need help 3 servo control with arduino uno
Why is my Proximty sensor output being pulled to .1V on pin 11
Servo sweep doesnt work
PIR Motion Sensor
Arduino MKR Wifi 1010 Encoder Issue
How to maintain original data using strchr
Strange behavior in communication with arduino and Tcl/Tk
I keep getting a missing file compile error:
Condition not fulfilled yet it execute
Unable to compile for esp32 dev board module
Making a little "lots of joysticks" device
Unable to access .h files
Arduino lcd display
Create 360 deg with 2 servos
ESP32 not in port. Used wrong board
Can't get LED to flash (like an indicator / blinker) in this sketch
Replacing UNO for OPTA on model trains
Need help at coding
Bluetooth Module not working?
Problema con orientacion de MD_Max72xx
RPM sensing withot causing delay in sketch?
Stepper motor controlling using blynk
Continuous rotation servo with feedback and pulse sensor
Load cell + led arduino uno
Accelstepper: Speed control
DC motor with L293D not spinning
Need pointer to RF reciever control of Relay
Light a LED based on a Sensors activity
Need help with a project (5v .2amp fan system)
Sinusoidal lighting system
Copy to clipboard in a captive portal
Does anyone know the solution for this one? it is already closed so i didnt see the solution. Sadly I am having the same problem
Sending a text file using esp8266 \
3DTouch Auto Leveling Sensor
Urgent help needed to fix the temperature sensor
How to use SWITCH?
RF433 and FastLed, problems with condition
Pressure sensor LCD I2C problem
Esp32 solenoid control problem
Xiaozhi ai on esp32s3 and '96inch display
ESP32 as iBeacon
I want help serial communication between arduino and python
I can't compile my program
Pushbutton Not Activating a Certain Function In My Code
Error compiling for board Arduino Nano 33 BLE : The paging file is too small for this operation to complete
ESP32 Dev, reading a register of an I2C-Device
Limit switch with Nema 17 and A4988
SIM800L prints strange characters ot HTTPPARA="URL"
VMA340 Pulse sensor false data
Problems with a new board that cannot get stufff uploaded
Necesito ayuda para unir estos dos codigos
I want to take data from one device using usb and send to pc . which arduino board I should prefer?
Combinations of relay having delay
Mpu6050 and Servo
Servo motors moving by themselves
Controlling 12v dc fan and light for a classroom prototype
Sincronizar hora de RTC DS3231 con arduino UNo
Final touch the project
Arduino get function pass var from sensor reading
Differential steering with stepper motors
PWM control IGBT
Need help when i was open the aurduino file the massage reflect "error could not create the sketch"
Controlling multiple stepper motor using ESP32
Debugging ESP32-H2 in Arduino IDE 2.3.3
To amplify milliVolts (say 10-100 mV) data into 0-5 Volts using Arduino UNO
Help needed with multiple relay switching issue!
Lcd display A015AN02
Compile error with Razor9dof package
IR receiver cant decode continuous signal from transmitter
Working with DGS spec sensors and Arduino Mega board
Need guidance for selecting appropriate power supply and for connecting a lot of LEDs properly
Send live location using a push button on emergency number
Arduino code won't compile seeking help
Arduino based Oscilliscope
Need help whit code for ir controlled step motor
Serial Port Interrupts?
Basic limit switch question TB6600 Arduino Uno Nema 23 reverse motor direction
Can't send data to ESP8266 via arduino
Pushbutton trigger for advancing Neopixel animations?
L293d with PC fan
atTiny85 internal Vcc analog voltage reference
Project stopped working between Uno Bread Board to ATTiny 85
Looking for someone who can help me troubleshoot a project.
DC Motor Control using Mosfet
Diy Spot welder using Arduino nano
Brushless motor and code
Everything seem to be OKay, but not work normally. pls help!
I type 99999 in keypad, and it shows 4294936223 on my serial computer
M5stic cplus error while verify code
Move Redrex Stepper Motor using Accel
Guide sketch for 2 DC motor , L9110s, and an ultra sonic sensor
Arduino RFID Card System
Arduino UNO + HC05 => weird data transfer
Array passing problem
Multiplexer Issue with FSR Sensors on Arduino Uno
Please help me !
ESP01 8266 not responsive
NO OUTPUT for a proposed project
Running sub-loops causes software to lock up over time
Crgbarray not meshing with crgb in declarations
Arduino uno and esp8266-01 problem while adding an i2c lcd
I2c esclavo respondiendo por varias direcciones
Homing for Stepper Motors with 2 sensors
Arduino code Pick and place with stepper motors nema 17 and TB6600 driver with encoders
Error while compiling the code
Hex serial data receiving problem
Flux Capacitor inside a Track car
High signal detected although nothing is connected
Interrupt execution delay
Error 1 Error compiling for board Arduino Uno
Delay Function Error solution
Im creating a system. Controlling 4 leds with bluetooth module. But i have a error in my code
If statement executes but should not
Assign static IP and set host name
Arduino Nano: Unexpected behavior in switch-case - (Autonomous RC Car Project)
How do you make an LED increase in blinks based total number of times a button has been pressed
Mi modulo RFID no me detecta la tarjeta
analogRead multiple value Problem
My code isnt working?
Esp32 arduino getstring()
Arduino - Bluetooth - Programming problem
How do I make my potentiometer increase the sound of the buzzer?
Arduino Uno reading Modbus holding registers
Arduino pro mini te362 and nRF24L01+
How write sd card cvs in the next column
360 spin photography
Convert code RHT03 to DHT11 ESP8266
Tft display draw number in reverse digit
Smart bottle holder
Error compiling for board DOIT ESP32 DEVKIT V1
Cpp error...please help
LoRa: Initializarion problem that follows the code and not the hardware
Tilt compensated robot compass
How to use sendSMS sketch?
Controlling a stirrer with RS232
Error compiling for board ESP32 Dev Module
Press a button and move the joystick
Mega 2560 wiring question
Do i need digispark drivers on every pc where i plug it in?
FONA not found / SIM7600G
Multiple sensor thermostat
Repost: Serial Monitor Showing Strange Values
Stepper misses steps on low speeds
Please help me !
Expected primary-Expression before 'sonic'
Trouble Using SIM808 with Arduino Uno
Comparing analog signals
Błąd kompilacji dla płytki Generic ESP8266 Module.
4 button's 4 leds debounce
Sensor de Presión LONGWAY LWP040-PSGLC-S
One wire digital temperature sensor read EPPROM
Using 2 sensors advice
Troubleshooting dc motor motion control
How to take 1 bit Input from Bluetooth using ESP32
Cant compile this code
Timer without delay 2
Error in code when compiling
Cómo se soluciona exit status1
Serial2 read ESP32 wroomer wrong characters
WL_IDLE_STATUS' was not declared in this scope, How to Fix?
PID algorithm to control flowrate through a valve
Best way to make a web based configurator tool
Portenta x8 update problem
Using Arduino nano to read serial data from FX 3G PLC (RS485) port we can't get actual data reading
Knight rider PWM
Crear archivo CSV o TXT en memoria externa USB
UNO Q and Nano R4 qwiic port does not support
Arduino Nano R4 window compatible issue
Help on using FC 51 module
MCUFRIEND_kbv Button example incorrect Press with Mega
Avrdude, no response from Atmega328PB
Fastled library help
Trouble on working with shift register 74HC595N
Problemas con WT32 ETH01
CUSTOMBOX1,GET and CELL,GET
Invalid conversion from 'int' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
Arduino UNO, Dfplayer y teléfono analogo
Disable hall effects sensor
Arduinos UNO, SENSORs, LEDs maybe POINTs
My Serial Plotter is not giving any output
Strange Sound Issue with Octobanger Project
Hae . am having trouble ending the while loop, when the sensor value reaches threashold the lcd displays fire alarm but when the value is less than threshold the lcd still display the same text
Code given error
Is it possible to manipulate arrays like this?
Compilation questions
How to control a servo motor using a PID control with input from current sensor. I am not so proficient in arduino and in coding so can anyone please help me. I want to create a closed loop using pid for controlling servo with current sensor acs70331
Wemos ESP32 D1 for UNO --TMC2208--Nema17
4 digit binary counter skipping
Eeprom address loction
Arduino nano 33 iot profibus
Cannot load provided drivers
Honest hire for converting existing sketch?
How to use SDI-12 in MKR WIFI 1010
Read EEG with Arduino
Is Uno R3 still relevant?
MPU6050 (Self balancing Robot)
Adding extra bits when sending instruction to LS7366R
How do I make the timer remember the time that was placed on it, without having to enter the same time every time
Arduino Mega with 2004 Lcd Screen problem
Not loading to LCD
Expected declaration before '}' token
Servo motor not working when connected to Arduino Nano BLE
Problem with Arduino, load cell and LED display
ESP32 - DRV8825 Stepper Driver - NEMA17 - BLE Problems
Pro Mini + GSP + GSM + Blynk
Need help with my calculation to find the stepper the motor that allows for the use right pulley
SPI function calling error for Arduino Leonardo
Libreríaspara joystick
Auto-Closing of topics?
Nano BLE Bootloader Crash?
How do i compare a string if it has been entered two time using serial.read input?
Switch statements within another switch statements
MPU6050 gyro sensor and WS2812B Led Strip Turn Indicator
Convert speech to text with esp32 i2s imp411
DC Current Measurement using Resistor Shunt and OP AMP
Reading & comparing multiple digital inputs
I have a question for Arduino
Bluetooth Controlled Car Problems
AD5292 Digital Pot Help needed
Need help with programming on Blynk
Programming bipolar motor to specific number of steps
Help my code is not doing what I told it to do (ACNH auto nook mile collector)
Millis for two conditions
Help value EEPROM lost after reboot
Mega 2560 is it good to
12v on raw but 0.3v on vcc
Using Arduino IDE to verify a sketch and received this Compilation error: Exit Status 255
Keypad Matrix with Analog Ladder issues
HM-10 Bluetooth Not Responsive
Problem in programming a boxing machine
IoT Cloud and pictures
Sistema de riego automatico con sensor de humedad de suelo yl-100
4x4 matrix keypad with all alphabets code with arduino using i2c with sx1509
Medir 12Kv de cerca electrica
Dht11 program error
Problem with a wemos R1 D2 Board
Comparing strings
Analgue Input gets zeroed when both Digital Outputs High
Using Arduino to count the number of times a water pump starts
Garage Door Opener
Help me connect my flutter with the bluetooth
Yip another noob,trouble with error compiling for board esp32
TTGO esp32 case
Programming Alvik in C
Tx pins not working on my feather
Help with Saving Motor Position and Recovery after Interruptions
AgOpen? Want a 'chicken tractor' to follow a path, like a tractor
I need help to my code
Home automation code
Trying to open a Sketch to blink the on board LED
Problema para cargar sketch
One button library long press
Using Switch in a If if condition
Randomize RGB LED colors
Issues with LVGL and the web editor - "../../lv_conf.h: no such file or directory"
Load Cell of 5 Kg with HX711 Module with Arduino
Arduino uno CNC Shield Co 2 50 Watt Laser fires without usb pluged in
DS3231 Read Time Error
Printing from an array which is a class member
Control of 4-stepper motor + 1-servo motor
Heating Elements via Mosfet + NPN-Transistor
Using Arduino with RS 485 Angle Sensor
Avrdude: ser_open(): can’t open device <port>: access is denied
How to measure power in PID controlled circuit
4004 lcd problems
Why is the SD.h very slow?
No puedo compilar arduinoFFT
Need help with programming this EL125 HK RFID reader
Generalised posting explaining how to change from a LLT-writing style to a productive style
Hi! I have problem with this code.May someone help me!Thank You!
Please help in coding arduino
Powering 12v linear actuators with L9110s
Pin connections for stepper driver Proteus project
Arduino IDE 2.1.2
NeoPixel stops Refreshing after Array Usage
Error: undefined reference to `pinMode'
Press any key every time delay
What to buy ? TWS and bluetooth board
Connecting with HC-05 using SoftwareSerial
2 pwm signals without delay
Arduino could dashboard not shown temperature data
Programm simple battery ok / not led blink
Is it possible to Instantiate more than one object of the same hardware? (OLED SSD1306)
Help with coding for ws2812
I have problems with IDE 2.3.2
Arduino UNO with ADS1293EVM
Serial.available() returning unexpected results
Troubles with if statements in for loops
My RFID doesn't work with Arduino Mega 2560
Problem with infrared remote control and lcd "invalid header file"
Port Not showing up (CH340) in ubuntu (Solution)
Writing AT commands via arduino UNO to SIM7080G module
Touch Input Piano on ESP32, Passive Buzzer with strange output when using Serial print
Insert switch to lcd clock
Help with the 8266 esp-05 version
Sinusoidal signal comparator
COFFEE Needing help with an ESP32 project
My arduino uno is uploading but not working
5v motor activated by IR remote control (HELP for scientific project on bird's conservation)
Getting back to Arduino
Cannot upload project after conecting Wifi shield
Accessing SD card?
Issue with the Neo-pixels
MCP2515 Can controller : getting error while sending message
Two leds blink with one button
First time user, have problem with LCD shield type
Arduino counter need help please
Trouble Shoot Code For “Left Button” is not Working on Arduino Mini Powered PCB
Transmission line fault Detection arduino code
Problemas con mis servos
SDC40 from aliexpress
XBEE Configuration
Programing error , 'class CShiftPWM' has no member named 'SetRGB'
I am having problems with my robot not seeing the white lines on the Mini-sumo arena
Nokia 5110 problem writing variable to screen
Multiple SPI interfaces using arduino NANO 33 BLE sense REV2
Need Help: ESP32C3 won’t communicate with IDE Serial Monitor
PWM output copy value on input (pulseIn)
Sequential Startup - Code Help
How to avoid a if statement running again and again until another else if or else statement becomes true in void loop
Accel Stepper Library Forward and Backward Motion
Understanding Joystick Programming
LCD SNIFFER using Arduino
Complete this code
Unable to compile sketch
My Arduino rfid (rc522) is not reading
Es un proyecto con arduino y app inventor
Arduino setup runs when relay activates
Newbie here- can somebody help me with explaining the code here and the shematics
How to control the LEDs flash using Serial Monitor
Compiling, uploading or resetting outputs HIGH
Sending and receiving bytes through Bluetooth
Cannot find crt1-sim.o: No such file or directory
How to store data and call it out anytime
How to trigger relay for 10 sec and then switch off for 10 mins without time module
Double BTS7960 43A H-Bridge suitable for peltier heat and cool control?
HELP! I am making an under water ROV and am using 4 dc brushless motors with escs
Survey the data transfer speed of ESP32-Wifi
Problem with a basic code
Stuck with NRF24 modules
Who can write this code, I can't figure it out myself
Error push button
Error esp32 upload CAN ANYONE HELP
Arduino nano failed while testing ESC and BLDC
Error in code with arduino and vPython
Different results with same board and code
Need Help with programming this code
Help, my teacher sucks. i need a code
Help about loops
How to send commands without typing it on the serial monitor?
Adding accessories to arduino pro mini
Compilation fails: "ctags: cannot open temporary file : Permission denied"
Arduino code for pin i/o over BLE
Was not declared in this scope23
PLS HELPPP YL-99 can't respond HIGH/LOW on the serial monitor
Error in code using Arduino IDE for reading RFID tag and sending data to SQL
Printing to serial fixes digital reading
Reading messages by Arduino received from SIM800L GSM Module
Is it possible to have an if statement enter a loop that can be broken after doing a few actions
PulseInput.h Did anyone got it to work?
ERROR compiling for board generic ESP8266 (Arduino mega))
Poprawa kodu proszę o pomoc
Programming LMX2306 PLL chip
Collect2.exe: error: ld returned 1 exit status exit status 1
Esp 32 cam not working
Interfacing SD card and RTC to Wemos D1 mini
What is it about this community?
Arduino / Python
Error: macro names must be identifiers #ifdef dobogusinclude
2 Button to 1 PWM output
Copy/Cast char[] to char* and int
Arduino mega 2560 not function !
I need help with my finals project
Arduino SPI Mutual Communication
Wemos D1 mini/ ESP8266 have problem in serial monitor output
Any solution for multiple input shear same pin?
Error Compiling for Generic ESP8266 Module
Need help making arduino robot start and stop when button is pressed in MIT app inventor
How can i power up three individuals L298n motor drive with the same power supply?
Macros for a UNO
'L' build in led not blinking
Beginners seeking help
How do I Implement a first order system on Arduino?
(Beginner) Help with light display
Can communication with can spi module
Is this a complete code or not?
Why Timer Arduino not functioning after I add in the function
RC522 Antenna design
SMS send but no receive.. the available() function takes forever
Problem with matrix display and scrolling text on it with Arduino Uno
Loop ( How I fix it to remember button than when >= $2.50 it then spins motor
Error de programación
Problems displaying oled and lcd at the same timt
Problem reading serial data as integer using hc05 bluetooth module
Datenlogger und LCD Keypad Shield
0-3.3v esp32 to 0-10v for vfd
Circuit and code works in simulation but not doing anything when done it real life
X y pen plotter coding problem
General Guidance and How to use the Forum
No funciona la libreria "arduino FFT"
Nano every upload problem
3 dc motors with 3 encoders, what arduino and shield?
'aes128_cbc_dec' was not declared in this scope
General Guidance and How to use the forum
Cómo puedo utilizar el SDA y el SCL del arduino UNO en vez del A4 y A5
MPU6050 troubleshooting
Please Help me this function doesn't fire from the periperical?
ESP32 ILI9341 SD Card problem
Arduino buzzer and 7 segment display not working
IDE hangs on startup: "Error: 14 UNAVAILABLE: No connection established"
Commands via grbl
MCP4231 Digital Potentiometer Circuit
ESP32 Audio error
Calculate apparent power based on digital filter circuit
Voice recognition V3.1
arduino remote
Problem with cable length interfacing 4x3 Matrix Keypad and ESP8266
FIrebaseArduino Looping setup()
MPU6050 Doesnt get detected
Arduino Mega freezes after sometime
Controllig car led's with pwm
what is the best approche for multi fruit capacitive portable piano
Connecting the "5403-150F Digital Linear Scale" Sensor to an Arduino UNO
Concatenating Strings
Ohm and Potentiometer and Map and is Map a good method
Using a button and a potentiometer to stop/start and change the speed of a dc motor with a h-bridge
How do i connect Multiple wires on a single 5V port?
DELAY FOR PINMODE 1 AND 2
Need help with ping sensor activating Keybord.press
Arduino UNO R3 using two outputs dependent to different inputs
Mobile Rover motors turn on to fast even when tuned properly
How can I control a stepper motor and then a relay
Same string getting rewriten every second, RAM usage issue?
Before I signed up I could copy and paste from an AI
BB-2590/U Battery I2C communication with arduino
Serial.read() print unreadable after include delay()
Small Question About Speakers
M5STACK Serial monitor
Need help understanding where my program is failing
Power-up Passcode to Access Void Loop
Arduino Uno CH340
About hacking neuroskyeeg star wars force trainer toy
Passing char to a function
Using Ramps 1.4 for 3D-Printhead exclusively
Problem with Softpot Ribbon sensors
Arduino nano does not work with battery
Why i am not getting output while using mlx 90614?
Attaching a servo affects pulseIn readings
I cant receive data from BQ76PL455
NodeMcu v3 only works on laptop usb
Animated christmas house
Adding leds to each not
Issue with my Arduino code - delay function
L298N Enable Pin
Relay with lm35 and Nodemcu not working
Multiply float big numbers
digitalRead not working or am i doing something wrong?
What if you get ? on serial monitor
I2C crashes when used in an interrupt routine
Talking device's
Counter goes negative after reaching break point
Can I use ULN2003 driver module to control a linear actuator that requires 1.7A?
How to make a menu with submenus?
Transform value to another value
Lost on how to control multiple led strips with MEGA
HomeKit ESP32 Code Issue homekit/types.h No such File
Four-load cells to be used with arduino (for balance device)
Conectar un nodemcu a plc
HC05 not returning anything from AT commands
Nextion LCD Arduino with DC motor help
I am facing some errors while compiling code. Please help
Controlling a Stepper Motor to run a certain distance
Nano Every connect to Serial1
I am not getting how to use api and get the data to personal app please help me asap
Struggling to read/write to 2nd SD card
Arduino/Genuino UNO no Longer Available, yet Problems Ensue
Problem with getting a Mouse to work with a ESP32
My robot doesn't work
UNO Q - can't get past failed update window to enter Linux password
Help me with code2
Empfangen und Senden eines GPS-Signals
Simple LED code needed for ambient lighting
Unir codigos para control de acceso
How can i control 2 relay in different timings with arduino and pir sensor
Loop problem in method calling
I been trying to convert my decimal input to binary input for my LED condition
Interrumpir void loop con modulo bluetooth
Making a Servo spin for set amount of time
Can't ping Arduino Mega with Ethernet 2 shield
Esp32 communicating over wifi (mqtt)
How I get 100 hz frequency in arduino mega 2560
Gps tracker " No GPS detected, Check wiring"
Hack a DAC project for Audio Techole/Prozor register data handling
Unwanted data stored in SD card
Trouble with pi pico hid keyboard
Problem about mysterious output
Void function: a function-definition is not allowed here before '{' token
Fastled ATTINY85 20U
No More then 7 files on SD Card
Transferring my acceleration data to SD card
Project 09 Motorized Pinwheel - Motor spins continuously
PWM Control Problem
Fix my code for proximity sensor and stepper motors
Receiving an Error with Raspberry Pi board
How to use nrf905 with a mega to switch relays using a remote
PWM with the L298N motor driver
Exit status 1 expected initializer before '.' token
First variable in tab defined as void/error
Potentiometer and 7 Segment
Unsigned int not working on ATTINY1624
Alvik firmware version check
Wifi esp8266 error when use adafruit_neopixel
I'm having a problem connecting multiple soil moisture to turn on relay
Arduino Nano, ADC, Multiple Inputs, Unreliable Measurements
Relay won't stay on "Bool not staying true"
Contador 0 - 99 con dos displays de 7 segmentos
Change the title 'FAQ' to something more appropriate
R503 having communication error randomly
ESP32 Cam no Serial Output
ESP32 DEV with Potentiometer, NEMA 17 Stepper Motor and A4988 Motor Driver
Can't connect my ps2 controller to arduino
Control velocidad de servo 5.5kg giro 360 entre 15 y 30 rpm
Calculate temperature and humidity for 15 minutes
UV ML8511 Sensor
DHT 11 sensor interfering with other sensors
How to read data from Arduino board and use it in python code
Ramp up to speed for steppers
Help whit code for a little project
I am trying to complete a program but I am new in this world if someone can help me with the code I will be so thankfull. Thanks
Need help, display blink when press button or HC SR04
RS485 serial comms failing using different ports on Mega2560
NEED HELP with. New Smart little turtle robot v2.0
WS2811 data corrupted at at connectors between ws2811 string light
How to tell Arduino to do nothing until there's keypad input?
Error compiling for board arduino uno - Airflow, Humidity, Particulate Matter Seonsors
ESP8266 Audio library problem
Arduino Edge control Solid State Relay
How to save .wav file to eeprom
MCP23017 nano problem
Vl53l0x - timeout
Can a multiplexer handle more than one type of input<control surface.h>
How many modules can arduino handle at the same time?
Hi, I'm currently doing my first project and I am facing an error which tells me that there is an error compiling for the board
How to stop continuously servo with push button
Arduino leanardo + Usb shield + logitech mouse
Helpneeded for a project
Arduino Mega R3 Interrupt pins
ArduinoUno with POT HG to control led speed
ESP8266 long term use
Moludo bluetooth HC-06 y Arduino UNO
Expected ')' before string constant
Simplifying harder statements to easier more understandable code
Connecting to Arduino alvik using Nano ESP32
Arduino Mega 2560 not flashing
MAX 485 Modbus request/responce
Temperature on LCD doesn't update
Why am i getting this error : Error /304
Blinking LED for 10 sec when pushbutton pressed
Oled show temperature instead of menu with temperature and Rtc
Variable Score/Points
Compiled for R4, now it doesn't
Nextion display
Set the DS3231 module
Reading 7 external voltages
Bluetooth not working with Windows 10 and not working with Android
How to turn on/off a blinking output from the same button
React Native Error: ENOSPC: System limit for number of file watchers reached
Uno broken because of a link between pins 10 and 11?
Problem uploading to UNO
Error while Compiling
Mechanically modulate keybord input to get analog like control in racing games
Error Compiling on Arduino Uno
Cryptography and Modular Arithmetic Operations
Smartglases with arduino
I cant be able both dfplayer mini and voice recognition module v3.1 to work together
IR remote not working after working for some days
Arduino Uno WiFi R4 prints garbage in serial monitor (IDE 2.x)
Thing Variables Falling Through - Nano 33 IoT
PWM with arduino and L298N
Serial monitor doesn't work. Maybe wrong code?
Ultrasonic Transducer Data collection
Controlling 2 12V DC motors wirlessly with an H bridge
1602 LCD display with I2C module not working
Arduino uno shock
The Arduino does not execute commands when I unplug the Arduino.. It only executes commands when I press the restart button
Scope not declared?
Chinese OLEDs burned Arduino Nano
Counter for turning on/off servo sweep using obstacle sensor?
5v micro buton box
Error opening file on sd card
L LED in low state still emitting light
Building animatronics in a real 1943 biplane
Arduino pro mini problems
Servo Motor, that has to turn 20 degrees every 5 seconds
R305 not working with hardware serial but works with software serial
New to this and have very small experience with using arduinos. Maybe someone can help?
Advice Needed: Connecting Hydrophone and Amplifier to Arduino Board for Data Collection
Ardunio & TB6612FNG Motor Driver
Wrong voltages with DAC MCP4725 driven by Mega250
Voltage divider and floating voltage read
Code isnt working at all
Connecting php with solenoid lock
Serial.Print Matrix 8x8
If Statements not responding when receiving an input
Distance traveled
The problem with starting and stopping the circuit through the 2 buttons
Moving variables from Global to functions
Arduino + Supercollider
Ich brauche Hilfe mit UDP Kommunikation
CallBack MQTT PUBSUB doesn't work
Square pulse wave with a delay and a certain length
Can you help me for my program and explain me
Birectional data transfer via bluetooth
Arduino uno with multiple oled displays
EEProm put and get with Arduino mega
Creating an anti-slip sensor
FSR 402 pressure sensor, Mux with Arduino
SD-WIFI with Card-Reader Module run ESP web Dev Onboard
Relay is being high at starting, Can we make it Low at start up until input matches
Automatic watering project works with usb/macbook power but not 9v external power supply
Using multiple SSRs simultaneously
How to get realtime pt100 sensor data wirelessly
Raspberry display ssh1106 doesn't work
Arduino code help with fade_functions
Why my static qualifier does'nt work
Facing some problem declaring interrupts
EVShield motor control
Fatal error: ArduinoBLE.h: No such file or directory
How to debug my sketch code step-by-step?
SSD1306 works intermittently
Characters backwards and split up [MAX7219]
Unable to use arduino cloud with program running in ide 1.8.19
How does mapping work?
Gyroscope MPU6050
Mcufriend tft not working
Stability of arduino boards
LCD Display arduino uno error ccode
Fm-505 rfid module
Wrong Tinkercad measurements?
Error was not declared in this scope after new computer (windows 11)
Code explanation needed please
Waveshare ESP32-S3 touch lcd 2,1"
Storing serial monitor values in an array
Simple servo control via an RF-Nano
I'm programming the game roulette and a number between 1 and 6 should be written when a button is pressed, but nothing happens when the button is pres
Need advice to make conectionto buttons
Student kit lesson 6 Robot arm
Code upload problem
Error drum arduino nano
RFM95W + Nano Initialization issue
[ SOLVED ] C# win10 serial terminal MISSING FIRST BYTE !
Works fine powered from USB works bad powered externally
I want to write drivers for sensors starting from 0
ESP32-S3 wont work and writes codes on serial
Arduino serial port output messy code
'button_on_release' was not declared in this scope
Teclado matricial
Help, I'm not a C ++ programmer
MQTT is not working in an specific wifi network
Rfid and 2 push buttons Door lock
Seperate a value in arduino
Dht11 program error
Digital read and bluetooth read
FSR sensor comparison data in using Arduino Array
Setting z probe with MEGA
FONAFlashStringPtr
Power steering from Renault Clio - emulate car signals
Newbie Having a programming issue...on HO train project
Creating a menu ,using switch and Serial.read()
Infrared inconsistency
AT Commands doesnt work
Code comArduino: 1.8.5 (Windows 7), Board "Arduino Uno" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardwarepilation error.
How to get data from csv or xls data with specific row and column code
Multi-Dimensional Arrays problem
My Arduino Code Won’t Compile, But it Works on TinkerCad
Is it default that arduino nano gets hot?
Code not woking correctly and i dont know why it wont run the nested if statements
Mi pantalla OLED no enciende del todo
How do make a robot in uno
How to code arduino car
Scrolling text using ws2811 strip
Controlling DC motor using a MOSFET
Need help with my code using color sensor and pressure sensor with Serial monitor
PLX-DAQ version 2 - now with 64 bit support! (and further new features)
Help debugging a **black screen** issue on an **ESP32
NRFL24 SPI works on UNO but not Mega
HELP..... mq2 reading problem
Looking for Help With Troubleshooting Sensor-Activated LED Setup
Port D2 stops working when initializing tft screen
CCS811 airquality sensor
MPU6050 GyroScope Readings Are Drifting
Add led to midi buttons sketch
Problem with using more than one ct by using Multiplexer
Help with coding please
HC-SR04 to sense water flow
Usar 4 servos en arduino uno r3
Project 6 - Tone Not Declared in This Scope
Grove I2C Thermocouple Amplifier (MCP9600) Errors
Arduino Inline ASM With Strings
SSR Relais with arduino
Serial Plotter is not working!
Emi and ultrasonic sensor
About my programing
OBDII Reader and display for hibrid cars
An error occurred wile uploading the sketch
Multiple serial connections (SPI & I2C at the same time) in Nano IOT 33
Bending a flex sensor to get resistance values
Who can help me
ESP32 Audio error
Uno r4 minima rx LED is always on
Help with code, will not work no matter what i try
Esp8266 cant upload to webserver from it's serial monitor..Help
Compile fails on Linux/ChromeOS
Help with activating a Solenoid from a sensor
Arduino nano not working help
The Different of Generating PWM Frequency in Arduino Board
FAQ page misnamed
Control Digital to Analog converter
Axe FX II XL MIDI diy controller
W5500 and UWB not Working Together
Arduinio Nano Error Exit Status 1
Problem using Arduino 2.2" TFT display
Can not get my arduino connected to web first steps works then error no matter what i did i followed all instructions
Touch detection on ESP32
Need help with codes (continuity cable tester with lcd 16x2 i2C)
Newbie need some help, got stuck for whole day
Need a hand loop within case by IR remote
Mega 2650 solar tracker LDR Relay
PIR Sensor and Arduino
Obstacle avoiding robot car -- code issue
Ultrasonic with stepper motor arduino
What's wrong with this coding
Arduino Giga R1 3.5 audio output not stereo
Temperature based controlled fan arduino code
Setting Arduino R3 as primary and communicate with ESP32 Dev Board
ESP12E motorshield
Music Box won't run on battery power?
1 button 1 led fade
Up Key input does not work
Help with AVCLAN_mini Sketch
Single color for WS2812B
Problem with sending data from Arduino to Nextion display
Case in Fastled sketch combining with the previous case
Hall Effect helping
I cant connect AHT20 temp&humd sensor to adafruit io
Help with creating music on arduino with Assembly language
Arduino UNO with L298N and 24V motor
Arduino Pro Micro and multiple MPU6050s
Help with date specific alarm
Verify my project schema by more experienced world
Libraries not Getting included
More crazyness with braces!
BLDC Pump PWM Control
Can't get anything to work
Hello everyone , when i write on in serial monitor song is turn on , but when i press off song still play . Thank every if can help me
Help With Programing!
Hlep me request Serial Monitor "inf"
Problem with nested for loops and servos
12v Relay Module not being powered
NRF24L01 COM problems
USB Sabertooth 2*32 with simply serial mode
Direct Port Manipulation Pins
ESP32 Using placeholders in HTML on SD Card
Not enough ground
MPU6050 Upside Down With DMP
Maximum number of devices used in daisy chained spi configuration
Output PWM without sending a large current
IR transmition forTV is not recognized by the signal receiver
Code not working for self driving car
I need help with my code for my school assignment
Help........ 16*2 LCD display squares
Radiohead tx and rx pins
How to select different loop programs to control Stepper motor with IR remote
Duplicated case value
WiFiClient.available() hangs
Amplificador Pam8403 y 84de 2 canales, 3 w+3 [OFF TOPIC]
'class Button' has no member named 'init'
Cant control servo with potientiometer
Anyone have code for entering multiple passwords with an ir remote to open a lock
Getting a timestamp using Ethernet Shield
Stepper motor controlled rpm
How to add mobiflight library to arduino ide?
Issue in converting the Pixels values to image
Uso de doble comunicacion por I2C con pantalla LCD con modulo I2C y sensor BH1750
I want to be able to open and read windows file
Nano on blocking
I can not find how to fix my code
Use LCD and sd with Uno
Can't upload one thing to Arduino
Motor not moving together (Human following Robot)
Monitoring sensor
Make experienced users help: two ways to quickly post code as a code-section
Can someone help with this code i'm new to arduino and i don't know what i'm suppose to do, there's always an error while uploading the code
I need help with some code I am writing
Display does not start on power on
SPI.transfer problem
Why does this code line not work?
Problem with Serial communications
KiCAD advice please
I Need help on making a Gerber file and a PCB as a beginner
Conveyer Belt Speed
3.95" LCD Module for Mega2560 - Only Half Screen
Problems with using Serial2 communication between 2 esp32
Help me about my car leftback motor doesnt workıng
Why does the led rgb bar light up in pixel order after running the program?
Having trouble sending Analog Data across bluetooth using two ESP32's
How do I change codes made for OLED to lcd
LCD test project print "hello, world", screen goes blank if "o" is inserted anywhere in text
Spaceship error
How to convert photoresistor data to control the brightness of the led
USB Controller Using Aduino Micro pro
Correct use of an a4988
I have problem with code
Gravure printing press registration Project
SPWM phase shfit
How to use Arduino libraries without setup() and loop()
Program error questions
Arduino Microcontroller Board for smart ring
Ir sensor with unstable reading
How to create pwm library
Speaker issues due to coding
Bluetooth module
Help with testing an ESP8266 binary
Help, error: expected primary-expression before '.' token
Números doble alto en LCD
SIM module continuously sending SMS messages after threshold reached
Powersupply setup with sensors, relays and perlistatic pumps
RFID Reader reads only 1 time in range
Led button control
Comunicación I2C
3.2 tft SPI 240x320 14P only shows half the screen
What information do we need to answer a question effectively?
Puente H y Motores con Pwm
Why is does it keep saying expected ';' before 'data'
Different Voltage Values for Turbidity Sensor
Problem in dumping the code of ESP8266?
How to code, i need help with my last smt project
Displaying Compass on OLED SSD1306 (128x64)
Voltaje adecuado para comunicar atmega328p con nodemcu v3
Humidity sensor HS1101LF from TE Connectivity
Conflict between FastLED and PrintEx libraries
NANO IOT 33 Disconnecting after code upload
Sending sketches to my Arduino Nano 33 IOT wirelessly
Programming ESP01
How to save something like array on EEPROM of ESP8266 ?
TX RX between Arduinos
24V DC motor not working with BTS7960 and Arduino nano
Potentiometer output changes random
FFT function, need to output 3 arrays of Frequency, Real and Imaginary values
How to send the ECG signal to the arduino UNO?
Using 6 x MCP23017 Issue
I2C LCD causes problems
Bop It Game, Code Correction
Issues with connecting a slideswitch to change between automatic and manual mode for a fan
My code only runs once ? It seems to get stuck in a function, not allowing my car to move after the first click
Arduino Sensor Kit : arduino_sensorkit 1.0.9 library for I2C buggy?
12V Relay Module Project
Control servo motor with blender
Can you please guide me about analog joystick ? Is it possible to control the directions and speed of two motors just like an RC Car movements with one joystick (VRx, VRy )
Power for servo motor?
New version of an old neopixel sketch not working for me
Code Not working for OLED with arduino Nano
DFPlayer mini random play function - part two
Not loading to LCD
HC-SR04 ultrasonic sensor motion detection
Arduino based home intercom(USING WI FI ONLY)
ESP8266 soil sensor
On/off button for code
12v Relay with ESP32
Stepper motor, encoder and zero angle
Li-Fi based Text Communication between Two Arduino
Multiple DHT22 Sensors with LCD I2C display [SOLVED]
I’m a beginner to arduino programming. I’m trying to develop home automation project based with blynk. I’m trying to memorize commands on the EEPROM.This is my code. Please Help to modify it
I2C LCD(16,2) not displaying text
Command from serial not working
Gyro sensor and 50m Hi-AT laser module for conditional measurement
Auto watering system using 'multi if'
Analog data Serial communication
Gps tracking system by sms
Arduino mit einem UR3 verbinden
How to name the temperature sensors instead of printing address using ds2482-100 and ds18b20 sensor- Help
I need help for servo without delay
My second RTC module, another broken one [Solved]
Measure frequency issue
Tft touch screen and serial data
10 button controls
Displaying error values if no input from Analog ports at MEGA2560
One wire 31850k errors
Can Arduino (UNO) "pass thru" external power to my project?
PWM not working when timer starts
Problem with iot project
Arduino Stepper Code help
Motor won't spin. Please help
Light flicker measurement
10 Motores 1 Arduino Mega
Uno q i2c problemas
Resetting millis
ESP-01 works with USB adapter but not when on breadboard
Rotary encoders with Arduino Uno
14 line error aa raha hai
Six or eight hi-res cameras on the same Rasperri Pi
Driver commands via Ethernet/IP to CKD Linear Actuator using CIP, TCP
Timer interrupt with analogread
Arduino serial esp01
Dartboard code NEED HELP PLEASE
Inverted Rx/Tx signal
LoRa does not transmitting the required data
Trouble with RF24 library
Arduino and Race Coordinator(HELP NEEDED)
DS18B20 gives me only one negative value in every temperature . That value is not even close.It is -127 celcius. I also added 4.7K pullup resistor
GRBL - universal g-code sander
Silly parallel 74HC595 problem
Using an IR remote to control DC motor
Es posible Reproducir palabra no grabada en ISD 1820
Chrome OS Version 96.0.4664.111, no connection via USB port
Using the Bluetooth with the Voice Rec
Request for help in code in line follower robot using 2 IR SENSOR , 1 MOTOR DRIVER, AND 2 DC MOTORS
Assign values before run-time
Solar tracker using gps and rtc
How to make IoT (ESP8266 & Google Firebase & MIT app inventer) projects faster, with no delay
Stop watch arduino code required
Why SD card is not storing the file? I am have to display 6 DS18B20 temperature sensor data and store themin SD Card. But File storing not working
Led turn on when powereing up Nano
Relay and coin acceptor
Button box construction, connection
Parola Scroll text, Brightness
Help with a code that doesnt work
Need to control four audio stages digitally, namely gain, volume, tone & level
Can someone help me correct this coding
Can I Connect Both an I2C LCD and ESP8266 to One Arduino Mega board?
Nedo mcu 8266 serial port display shows broken characters
External Power Supply with LED Matrix
Need help with ESP32 LittleFS configuration with GZIP and Websockets
Ultra slow sketch execution!
Need to be able to pass variable in analogRead
How to add push buttons to the code
(Moved) sample code needed
NODMCU sketch problem
ESP32 with 2 relays and 8 pumps (cocktail bot)
Check wiring on GPS Module
My fathers UNO R3 stopped working all of the sudden
INA219 and PWM DC Motor Speed Controller Problem
Controlling Arduino by MATLAB
EEPROM with ARDUINO UNO, avrdude: stk500_recv(): programmer is not responding
Water pump is not working
IDE Debug Issue GDB Server Quit
ESP-Now with ESP32C3
Humidity and Temperature Controller
How do i combine 2 codes in 1 Arduino mega? (capping machine)
Knock sensor with motor
How to play sound when turning off Arduino via pushbutton & Pololu switch?
8 LEDs, 1 pushbutton
Flame sensor random false detection
Can we set output working duration? Pls help
ILI9341 and SD Card not working
4 bldc motors stuttering
Sketch working on a Micro doesn't work on an Uno?
Problem sending two integers from a master to a slave arduino!
Zooming the image in A. GFX
Midi interface help
HX711 Amplifier with 50kg load cell - Values fluctuating constantly
Ultrasonic sensor range appears to be limited to around 100cm
Error de timeout al ejecutar comando en Modulo de reconocimiento de Voz con Arduino Mega 2560
Multiple neoxipel rings radial fadeing
Active front wing - 1 axis gyro/servo
QueueArray.h: No such file or directory
Unable to install ESP8266 in the board manager
Why can't I install ESP8266 library into arduinodroid?
Dual band wifi module that supports ad hoc mode
Simple Question from relative newbie
DC motor control with Bluetooth
Continuous servo concern
Circuit using pushbutton and 8 leds not working
Hall Effect helping
Constant current load design
How to create a realtime posture detection with mpu6250,esp32 and blynk app
Subroutines and do While Noob questions
How to alter a #define value
Simple Two Button input to LCD output issue
2 stepper motors with independent actions
Sending Data between 2 Node MCU chips using ESP8266 in WiFi
Method active when class not created
DF2301Q wont fail init
Smart door. help me please
Generating ECG Waveform
Arduino Nano and SIM800l, read SMS problem
Help me please :)
Uploading Bootloader to atmega2560
Request for member print in 1 which is of non class type int
Arduino (Making Bad USB) "Enter" command doesn't work
l293D motor shield from adafruit not working
How to extract a random number from an array of values and remove it
Built a small Arduino-style UI/control library for ESP32 (Trellis) — looking for feedback
Please help with oled and leonardo
Trouble whith reading data
Help ultra sonic sensor
Need help with LIN Master
BMP180 using 433MHz modules
Is the problem I have to do with wrong pins or code?
Encoder conection pin 6,7
Thermal printer text font
I have this upload error :(
ESP32 Cam with arduino
Windows instructions for arduino
Cant connect my esp8266 with websockets on localhost
Code for motion tracking with pirs,12v motor
Overvloei functie voor twee projectoren
Make four different inputs = value
LASER DUST SENSOR ---> DLS in water for nano particle measuring?
Read CAN bus data with MCP2515 module
Conectar Esp32 con un Enchufe
Realistic Animatronic Robot Head That Can Talk
Arduino IoT cloud
Stater kit project 13
I'm a noob and need assistance
My arduino blinking so fast and it not working
Arduino Nano & OLED Display Multiple Library Issue
RCSwitch and Loop-Usage
Thingspeak error o arduino
Arduino SIM800L IMEI CHANGER
Digital Write Output not working
El WiFi de la ESP32 no me anda si no conecto desde USB
Fix invalid head of packet error
Synaptics 920-003267-02RevB connection to arduino
Connecting multiple Arduinos (or arduino and other boards): JSON over UART
2 LED & 2 Button on the same time
Soft WDT Reset ESP8266 Lora E220
Someone could give us our own program
Can someone help me with my code for an obstacle avoiding robot
Linear motion with 2 stepper motors using AccelStepper
OLED 5.5 defective?
Peugeot 207 gauges for games
Problema con esp32 con placa de expansión como eliminar el ruido que genera al conectar un pluviometro de pulso, trabaja un sensor magnético mc 38
HC 05 out of range setup
Error with Real Time DS 1302
Can arduino switch on pins commands reading comports?
Extract a number from a gsm module text
New to sketches
1Pump 1Valves with Blynk IoT
MP3 player continue from left off state
Anyone tell me how can we make wireless connection between ardiuno and the mobile app
Sht31 + Arduino
Laser Rangefinder With Arduino
Communication to parallel (not cascade) 74hc595 over common bus lines
How to use arduino nano with NRF24 ?
Arduino uno relay shield as timers
Can you ctrl f on serial monitor
Interrupt quesion
Based on the code shown below, the output of the serial.println should be 1 right, but the results is not. Can anyone explain why this happen for me
Confuision (again) re SpenceKonde ATTinyCore status
Code and diagram help(i dont know why when i run the simulation the motors do not start miving)
IR receiver receives one input but not any more
How to properly move stepper motor with potentiometer
UNO with Micro SD error! Help!
Keep getting an input with push buttons without pressing
fastLED beatsin16 just one way
Pulling pin closer to 0v
I want to change the button with encoder and add another 2 products and add GM65 scanner
Understanding forward/reverse operation of dc motor
"3 value" boolean
Please ideas for my project
I need help coding two servos to be controlled by a PIR sensor
Pantalla blanca con sombras
Read data from RX pin on Arduino UNO
Led fading using Array function
Hi I'm totally new to Arduino and my first real project is to build a stepper motor to control a gas valve via a wifi app page!
'blink' was not declared in this scope need help please
ESP32 XIAO S3 SeeedStudio v1.2 and PMS5003 not working
Servo Motor not responding to program involving photodetectors
Whats the way to send data to server from remote place
Coding a Mozzi synth with LCD display
Problem creating a simple circuit with uno r3
How to control servo motor using switch case statement
Nema 17 Stepper Motor Issue
8x8x8 RGB Led-Cube Programming
Compilation error: 'drawFrame1' was not declared in this scope
CNC shield V3 A4988 Motor Y does not move
Stuck with a TXS0108E logic level shifter
Motor shield driver not providing power
Obstacle Avoidance Robot Not Working
Using 2 IR Sensors at the same time
Can't read api result on Arduino Uno
I am not able to figure out what's wrong with my code
Satellite dish controler with joystick
上传程序的时候就弹出这个编译出错,这是出现了什么问题
Help identifying and removing "phantom" resistor readings from my wiring
I have some problems
Using aurdino nano for temperature control fans
Implementing time delay without delay(), millis() and delayMicroseconds()
Problems using Hosyund .96 in OLED display module
Serial issues in my codes
IR Remote , Some body can help me to review
For Loop Doesn't Stop
7seg and ultrasonic
"sign-compare" warning when compiling a sketch
How do you get the reading from the sensor?
Keyboard input to Flip Flop memory conversion
Standalone programmer
No matching function for call to 'ArduinoJson::StaticJsonBuffer<1000u>::parseObject(SoftwareSerial&)'
Issues with bleKeyboard, ESP32 and windows 11
(help)i have Finger Print Module Serial UART TTL sm12
Can this DO (dissolved oxygen) sensor be still programmed in an Arduino?
Information school bell frame using Arduino
Difference between ESP32 WROOM & MEGA with HC-05
Nesesito ayuda para hacer un ascensor de 3 pisos con arduino 1
Micro SD Module wont work on Arduino Uno Rev2 Wifi
Combining Project 13.1 and 20.1 to have the motor speed displayed on I2C LCD
Why my button didn't worked?
Measuring solar voltage
16x2 LCD not displaying text
Robot arm kit van Lafvin
Line Follow Obstical avoidance Code Issues
Programmation for pulse sensor and adafruit bluefruit le uart friend
Minimum value of an array
ESP32 and Arduino IDE tabs
Where is the problem ?
Compatibility FTDI V2DIP2-32 to provide USB host for Arduino Mega 2560 Rev3
Are there any devices that could make a 3.7v input into 5v output and keep the same current output of 12.5A?
Digitale kazoo speler
Arduino-IDE 2.3.2 Do not read any installed library
Putting 3 codes to 1 code / exit status 1
Waiting loop to decrease variable
Automatic wire cutter with servo and stepper motor
Arduino Adafruit_ST7735 TFT with touch screen (st7735s)
Fingerprint R307 pin5 touch wire connection
Display midi information from ableton to LCD
Powering Arduino efficiently
Errors in executing irrigation system program
Number format in gauge
Having Trouble With RFID.h Library (please help :'( )
Reading array value
MFRC522 freezes after a while (inconsistent)
SIM800L interface directly with Arduino UNO
Arduino UNO Setpoint Issue
SD error- no guarda información - error al abrir el archivo
Making a seismograph with GIGA DISPLAY, how to unite the dots?
ESP-32 ChatGPT robot project
Error coding : two servo motors controlled by button
Arduino RP2040 device id
Analog channel configuration
Limit switches do not work when arduino is connected to computer via usb
Serial Read Data
Serial Read Data
Irregularity in stepper motor
Esp_sleep_enable_timer_wakeup
Error Uploadning ESP8266
Roomba & Arduino Mega
Finger print module not capturing image of my finger
Unable to find network to edit timeout
Code crashes on line, tried to fix added image of serial monitor
Hi can anyone help me on this. Im using servo library for my burshless motor connected to ESC and reciever. How do i add limiter for this?
Hey may i know how to sum up a number up to infinity by 1?
Help regarding project
How to connect Google script to node mcu
I can't run it, please help me
Arduino Mega un sector quemado internamente ?
Error compiling for board ardunino uno
Hall Effect Sensor doing weird things
How do I display image on ER-5517 connected to Arduino Mega
'positive' isn't declared and I can't figure it out
Arduino command; I would like to use 2 different pins to generate 2 different color or same color with different intensity and duration
Increasing Power of HCSR04 Ultrasonic Sensor
Invalid header finle tinkercad
Chinese arduino uno clone doesn't work as it should
How to use serial data to get a digital output
Encoder DC motor
Having problems on Using sensor to read frequnecy of sound signal
Serial Monitor Issue
Coche teledirigido no funciona con pila de 9v pero si enchufado al pc
Arduino nano and neo 6m gps module
Using 4 Transistors seperately
Json - send int
Arduino nano no detectado
DS3231 would not sync
UNO+Arduino Ethernet Shield 2
Arduino Leonardo Serial
Esp32-s3 with USB keyboard
How to perform i2c read from AW9523B breakout. without library
Convert from String to accepted variabel on SD-card
220 vac solenoid valve control with single channel relay module using arduino stuck issue
Long life battery portable
Why does listFiles work but this code doesn't?
Redirect function output from serial monitor to character variable
What's the matter of this Error compiling for board ESP32S3 Dev Module
Connecting HC-08 as master and HC-05 as slave
Working with Sparkfun m6e nano and Arduino mega2560 to read tags
Problema con señal al ruido arduino
@NRF24L01 range problem
Problem in using Voice recognition module v3 to run four DC motors with two TB6612FNG motor driver and Arduino uno
I am trying to run an RC car and a Sensor together, but I am not sure how to fix it
My servo motors are running too weakly
Dont upload arduino pro mini
Building Smarter Embedded Systems with Studio
Servo with pot and micros function
Best first 5 topics to read to reach Trust Level 1?
Problem with St7789
Title: Arduino UNO Q — Cannot read Serial/Monitor output via CLI without App Lab
Loop development for DAC
Proyecto de indicador Inalámbrico
Controlling Stepper and DC Motor with Arduino
On/off switch with a light bulb
The keyboard on one analog pin does not work
Stepper motor tb6600 serial monitor
MAX30102 sensor not sending data
Awful sound on my DAC using i2s
ESP32 Dual Core task keeps crashing
Stm32 internal clock problems with arduino ide
Combinacion de pulsaciones para diferentes acciones
123456789101112
Suitable mosfet for coreless motor 8520
Passing a character string to a routine
Blynk project with dimmer
My Mp3 Doesn't work
Rechecking input after a few seconds
Internal resistance and digital readout time
I dont know what Im doing and need help
My MKR Wifi 1010 w/ MKR ENV shield - SD card not working
I am experiencinga slow sampling frequency whenever i try to print 3 sensor output on the serial monitor
Is there any support for UNO R3?
Proper Use of AccelStepper Library
TFT 2.8″ 240 x 320 display is working weirdly
Use multiple interrupt for flow sensor
Running a two axis lathe program without G-code?
Seven-Segment display module
I want fix this Error
Juntar 4 códigos
Stepper motor Nema 17 stuck when power is supplied
I am having a problem with my code because this code is for 18cm container and i want it to be adjustable to 7 inch or 15 inch
No spi clock when using the SPI library (Uno)
2s complement conversion
Controlling WS2812 to form 7 two segment displays
Is my wiring of a 6v solenoid valve correct?
Not getting enough voltage at ATmega328 pins
Gebruik IRremote.hpp
Unable to connect tmp117 with arduino uno R3
Problem with arduino nano v 3.0
ATMEGA328 Resetting
How to drive a 1W 150mA LED?
How to control servo motor, IR sensor, traffic light if light is red and ir detected object then servo motor works for 10 s
Returning value string from a function, does not work!
One Interrupt too many
MP3 set serial not declared in the scope error
Automatic parallel parking
Attach interrupt getting ISR not defined
[Serial issue] Exact same code wont work on Mega, but works with Uno
Smart Trashbin metal detector with coin reward... need help
16x2 display issue
Off delay timer
How can I get a reliable 5v output from nodemcu v1?
An error that shows up when I verify my source code on the app
How to use the While loop inside the If condition
Programming help for a declaired variable that generates a random number for some reason
Sending data from ESP 8266 Wifi Module to PC using Arduino
An example code created to help beginners with the syntax of using sequences in their code
Is there a limit on serial?
Joystick/4 switch please help me!
HELP NEWBIE ? Using a Nano atmega328p with a panel 64x64
Begginer needs help please!
Existe una libreria para LCD 480X320 controlador ili9486con arduino due
Arduino, solenoid parallel design
Please help with sending and receiving data through hc-06 bluetooth for android
Neo6m not sending data serially to Arduino 2560 Mega Port 0
Program failure after 5 minute pause
If conflict using an l298n (h bridge)
Strange Character display on LCD 763-24064WG-ATMI
Communication error
How many sensors can a motor drive handle?
Arduino: 1.8.19 (Windows 7), Board: "ATmega328, Yes (UART0), EEPROM not retained, 328 / 328A, BOD 4.3V, LTO disabled, Internal 1 MHz" avrdude: Vers
Change I2C SDA and SCL pin of Arduino and Trinket M0
Executingc command: exit status 1
What more do I need to drive a V4 expansion shield
How to keep rfid reader triggered after one tap
Sierra Modem HL7800
How can I SPI transfer without function in Arduino?
Programming the pic16f84a in arduino
Audino pin voltage is low
Arduino IDE 2.0.0 - rc3
How to connect a TF-LUNA to an Arduino Nano?
Let the LED flash 3 times when you press a button
Esp8266 stops sending data to firebase
Push button doesn't work
WiFi.h me da error con softAP ¿Ahí solución?
CAN-BUS READ Problem between Mega2560&Seeed_Arduino_CAN V2.0
Can I connect this two in one arduino?
Serial Monitor Problem (TX and RX only works after open serial monitor)
Temperature and humidity not showing on LCD display but Serial Monitor testing works fine arduino uno
Nixie module for IN17 nixies and bluetooth number keyboard for android telephones
Newby coding problem
Nn4mc: Neural Networks for Microcontrollers
Communication between Arduino due and BQ76PL455A
Voltage and Current measurment using arduino
Arduino Nano Project
Make arduino speakers louder with less noise
Need help with an Arduino Uno Project which should be controlled from a web site
Arduino code for the circuit diagram
Cathode and anode wiring
Is there a problem or something
Error on my board
Reverse Engineering problem, Controlling an unknown coolant valve
Unable to read array item in a for loop with local variable "i"
Trying to sample all 12 ADC inputs but getting error with advanced lib
Communication between DS2482 and DS28E17
Capacitive Soil Moisture Sensor Trouble
Motor stopped working
ESP32 Web Function
Driving PM55L motor with TMC2160 driver
DS3231 - Code that repeat for given no. of X days?
Which statement is used to send CAN data frames?
Unable to compile program
Please help me troubleshoot
No output on Serial (Uno)
Help with coding change
Code Help for Buzzer Timing & relay
Passing file to a function
CAN bus programm code not getting compile
Esp8226 upload error
Help with motor
Como puedo unir un codigo de una calculadora y de un juego en uno mismo
DQ420 MA Stepper Motor Driver - NEMA 17 42BYGH616 - Arduino Code CW/CCW Motion Program
Obstacle Avoidance Smart Car
Power Saving for pins only used during setup
Fuzzy logic to light up leds
Microseconds Timestamps in serial monitor
I'm getting this erro
Arduino project for students
Advice for coding motors
RGB and Photoresistor
Stuck in a while loop (ultrasonic)
Adafruit nokia 5110 display
CC1101 Failure with esp32
Help for merge coding for Rc car HC-05 and Ultrasonic sensor
Delay and sampling rate
Problem in running my code
Code with water pomp and water sensor
Why can't I use if else to change the color of the RGB led?
Blink LED doesn't turn on when start simulating
First write to EEPROM in Nano Every
Discord webhooks
Mkr1000 going shutdown program
Trouble with the Stepper motor utility
UART/Serial connection not interpreting data correctly?
How to send .txt file from Arduino Uno SD Card to phone via HC05?
Problem is robot will avoid the obstacle, but after that no forward again
Not able to connect to esp8266 from device window
When I long press the push button then the led is continually blinking that shod not happen it shod take only on
Problemas en proyecto con librerias VR3+SD+TMRpcm
Using a push button to stop a motor
IRremote sketch compile errors
Esp32cam IP address: 192.168.43.54 E (7496) httpd: httpd_server_init: error in listen (112)
Nano for Stepper Motor
Thingspeak failed to send data
Library error for compass
Arduino uno problem with mpu6050
Analog input value
Port doesn't exist, exit status 2
Void loop() error
Please help newbie struggling for 5days! about using millis
Tolong apa yg garus ditambah supaya motor stepper bisa berjalan 2 2 nya
DM help please why not
Did my nano project destroy my PCI slot?
Serial Transfer has no member named ‘txBuff’
Predictive Fault maintanance project
Sound Level Meter Modbus TCP/IP
Variable output wrong
May I ask about the voltage drop across a diode?
Arduino-based solar power charging station
Error with the EEROM library
How to connect Arduino mega and esp8266 to firebase
Tips and ideas for users
Store data from a digital balance (RS232) in an SD card
MPU9250 gyroscope
Blynk app menu feature Self Watering Plant Pot
Problema Sensor JSN-SR04T en placa Shield Ethernet arduino Uno R3
nRF24 Single Variable Transmission
3 ATOI objects outputs data within a SERIAL 115200 to Arduino, note on and note off
4 reles controlados con un control
Plotting voice from BT input
Serial monitor in Cloud won't display text
IbusBM problem with showing two values
Request for Assistance with Sphygmomanometer Readings Using HX710B Sensor
Getting Error compiling for board arduino uno
Esp8266 nodecmu oled issue
900 LED Infinity Mirror Programming Issue
Analog display and esp32
Question about led cube code
Pcf8574 with telegram bot
My Led burns as it should in test program, but burns dim in the real program
Moding a vacuum
NRF24L01 works on nano but not on uno
Using an Ultrasonic Sensor to start a timer
PTC Heater Control
Tacometro no baja revoluciones a 0 progresivamente
Mapping 4 pin button to keyboard input
Stepper Motors, Limit Switches and buttons
Having trouble storing values within variables over time intervals
Delay l298n arduino
Arduino uploading problems
Control 5 servos 3 joysticks recording coordinates arduino uno
Help Needed – DIY Autonomous Vacuum Cleaner Robot with Arduino Mega (Wi-Fi, Bluetooth, Obstacle Avoidance)
CO2 MG811 logic
Mysterious inclusion of deleted libraries
ESP32_WROOM_30 + Waveshare 4inch Touch Shield
Model of air levitation pingpong ball
Communication with Nextion Display
Connection problem with arduino nano every clone board
(Solved) Nrf24 and ESP32
Hi everyone, i am new and trying to remove keypad code and want to use normal push button instead
Unable to upload code
Help needed in making a scrolling text
Stepper motors not running when connected together CNC shield
485 communication
Need help with connecting 2 servos together
Driving a PMSM (sometimes called BLDC)
433MHz wireless module and push button to send message failed
Data logging shield from TRU components
Help on reading a value from PCF8575
Gear Hobbing with arduino
How to post sketch
Suggestions for using arduino mega to power multiple devices
Arduino Uno and problem with breadboard
Measure motor voltage using arduino uno
Timer in an if statement
ESP32s soc.h problem
NRF communication sometimes does not work
Arduino control voltage up to 100V
Issues with my code
A loop want to wait until a condition become true
RPM printing on lcd shield
Arduino Uno and Ignition SCADA over Ethernet
Conocer el tamaño ocupado de un array
Picture from sd to 128x64
Huge Error on build
How to auto reset
How to auto reset
HC-SRO4 code problems
ESP8266 code merge
Pressure Sensor - Needed Guidance for my Project
Suggest parentheses around comparison in operand of '|' [-Werror=parentheses]
Why dont work? 8 relay board
Problema en programa del casco de iron man
How do I work on a track like this?
Code getting me crazy
Why does this little program occupy 80% storage in my ESP32? any solutions?
Reset needed for sketch to work
NTC 3950 V6 alta temperatura
TMC2130 with Arduino Mega 2560
DRV8825 Setting vRef Issues with High Voltage
Nodemcu making download and upload speed faster
Can someone help me, for my 4in1 5pin probe RS485 THPH+EC Sensor, I have code but it doesn't read anything. I am using arduino uno for this
Juego de Luces para Arduino con leds, pulsador y display
Random Color Strip and Sensor PIR
Arduino Portenta Vision Ethernet Sheild Camera came off slightly
RF frequency problems I think
Ayuda, es posible?
Setting to CRGB::Black is giving random colors
Loop not naming type in project 02
How to match D1 code to Arduino Ono?
This was not declared in this scope
Error en funcion ledcAttachPin
Help me with a lbrary
Wire write buffer duplicating problem
Arduino, Cajero automático
D2 pin needed 12345
LCD and Max7219
Modify this code?
Enter the i value into href= tag
Desactivar alarma en arduino con un boton fijo enclavado
Advice for simplification
Servo with 2 buttons
Rotary Encoder DT pin notworking
Arduino Master Modbus Rtu max485
Bool functions?
I need help adding something in my code. It's urgent
Stop stepper motor from heating when idel
Why my arduino leonardo not working with bluetooth module , However this same code is working with Arduino UNO, Plz suggest me changes
Please help me, i already have the source code for control 1 PIR, but i stil don't know how to edit that source for controlling 2 PIR by using arduino
How to sense activation of a magnetic reed switch
I'm new and need help with code. (NFC to start car)
A question about Arrays
Arduino nano Flysky
HC SR04 to suspend the calculation until a button is pressed
Use another function during the running of Millis
Need help with setting up
Partager ses projets Arduino efficacement
Trying to read serial data from digital scale with arduino IDE
I am unable to use this LED as an indicator for when the temperature exceeds 22℃ and the motor switches on
Some problem with setting PWM (Arduino nano)
How can i add a beep sound every hour.please help
Cronometer in binary
IR remote not working when buttons are pressed
Asking for some guidance of getting data from blood pressure sensor to an arduino or raspberry pi
LoRa module long delay
Associate a serial2 port to megunolink
PIR Sensor and Button Relay Control
Continuously reading from pushbutton while running steppermotor
Timer/ sound Project
WiFi IP in Uno Q problem
CTC 101 VU Meter
Proyecto de robotica
Arduino Project Problem, Black Floating Liquid Switch Level Sensor
Requesting help on using DHT11 Module with NodeMCU
Connecting ESP32 to the WiFi
ESP8266 won't boot up normally
Is it possible to Switch between 2 app images?
Error: expected constructor, destructor, or type conversion before ';' token. Error is occuring at void_mStop
Problem reading RS232 from digital scale
Is it possible to print on one line only?
Esp32 iBeacon read major and minor
Proble with connection with Cubemars motor AK45-10
Can't get output signal from Self Reset Switch
Vibration meter with the MPU 6050
A9 Thinker network garbage text
'lcd' was not declared in this scope. Plz help
Arduino Combining Sketches
Stepper motor vibrates but doesnt turn
Car LCD display on Arduino?
Proportional electro valve control
Mismatch at byte
I'm trying to have multiple inputs but it wont work
Need help on writing a receiver code
Running code on a controller that isn't plugged into my PC
Arduino reads incorrect voltage
Arduino Joystick with car. Can't figure out how to go right or left, I can only go forwards and backwards. Arduino Uno
Control 12V Solenoid with Nano
Issues with changing variable and char.toInt
TFT_Touch_calibrate_v2 example with 800x480 touch screen
C64 Arduino Kernal switcher
Coneccion de Arduino con bluetooth
Arduino 2.0+ has too many problems
Help me please im in need of help
Powering Arduino Uno with DC12v
Compiler bug ? Nonsensical result
2 photoelectric sensors to measure time
If Statement toggles Output
What does it mean when an Arduino is 'in host mode'?
Trouble with batter and dc motor
Leanardo + USB Host Shield Mouse Problem
Ph sensor connect to arduino
TCS3200 Sensor using as a trigger for a mini vibrating motor
Arduino Uno and GPS NEO-7M-0-000 don't show GPS
IRLib2 rawRecv doesn't work
4 motor project :)
Help with running Dobot offline using Arduino Mega 2560 and LOGO!
Sending Serialnumber/IMEI to phone via sms using SIM900a and Arduino uno
Guest counter with Ultrasonic sensors
Wire.read() not updating on Arduino Due
DFPlayer and Ardunio Jawdrino
Line following robot using arduino uno
Cant do mp3 to led stips with drivers
Connecting 10 joysticks to an arduino
About looping an action for certain time
My keyestudio joystick for ks0398 doesn't work
Mikroe 1577 that uses MPU6000
Stuck at 128x32 oled screen working at wrong resolution
Please help as i am new to arduino idk why i am getting this error.: call of overloaded 'abs(long unsigned int)' is ambiguous
ESP setupvariable to HTML tag
LCD and ADC connections and code
Put JSON to API Endpoint using WifiNina Library
How to handle an USB device?
20x4 LCD display text barley visible
Again on Arduino Due and a working LiquidCrystal_I2C
Arduino won't play music
GPS NEO 6M no funciona
I Have No Idea How To Fix This Error, Please Help
"invalid header: 0xffffffff" when I press reset on ESP32-CAM
Arduino UNO R4 interrpts do not work
Relay modules act erratic with load but work fine with no load
Error: cannot convert 'HardwareSerial' to const char*'
Transferring image with infrared communication
Help with coding (PWM + MILLIS)
Create a generic HID that receives data
L298N and Arduino ground
Espacio de almacenamiento de programa
Generador rpm con pantalla shield pad
Code for VFD Clock from Ali
Words not fully showing up on my LCD Screen
Max30102+ESP8266
Arduino UNO R4 & BLE Bike Beacons
RS485 Communication network problem
Digispark Attiny85 İnstall
Can you help me in my code please
Sending user to diffrent pages from same page
How to trigger BLDC compressor with arduino?
Maqueta de habitación con sensores
Support forum for Nextion displays
LED traffic light system with 3 different modes
DIY Automated Clean-In-Place System
Programmer not responding
Df mini player arduino
SD card module and SSD1306 OLED display - how can I display regular text instead of integers?
Help identifying a starter kit
Bait boat with gps
Make a fingerprint sensor turn a 180 sensor and LCD Screen
Random 16 LED's, just 8 will turn on and their representation in binary code
Error with serial for UNO R4 WIFI
Trying to install STM32 based board, can't find the file arduino-cli.yaml
How to see 7 in 1 soil sensor register values (JXCT Soil Moisture Sensor)
How do I do scrolling text on a 5x7 LED Matrix
Arduino Ethernet Shield W5100 Issue
Uno R4 WiFi board is online but no OTA option for upload
Self balancing project
Greetings! I need help for wiring and how to code MHZ19B co2 sensors
Tic tac toe game with OLED display doesn't work
Unable to install library: grbl-master.zip
Fallo con pantalla LCD
I am looking for a sketch
I2c Write issue on ic ch455
Help with Arduino Leonardo, RWS-371 RF Receiver, and 12-Button RF Remote Setup
Arduino freezes after 30-90min
-"Guru Meditation Error"
Me podrian ayudar hacer que un servomotor empieze en 0° espere 5 segundos gire a 90° y que sea un ciclo continuo utilizando la funcion de millis
Switching from Arduino uno 2x16 screen to 4x20 lcd screen
A9g module doesnt seem to work
Arduino project - connection problem
Suitable LED Driver for a 6x8LEDs or 8x6 LEDs String
Switch case horrible teacher task
Stepper motor with IR sensor
Marcador deportivo con 74HC595 y BT HC-05 (En construcción)
Serial Communication to VBA
MeArm (servos) controlling little problem
Whats wrong with this code?
RS 485 half duplex communication problem
Urgent help(stepmotor and DHT11)
Arduino UNO R4 wifi flight sim control panel for mac
Arduino Mega and Magnetic Tape sensor
Using a l293d motor control shield without mounting
Camera_pins.h error
Color OLED code error
Controlling a stepper motor with 3 programs on 1 Arduino Uno
MPU6050 sensitivity how to?
HELP! How to split data on multiple distance sensors?
Arduino I2C recognize variables from master string
Uint_8 e uint_16
Cannot launch IDE
Arduino connection to a coin-operated device
About the problems encountered in using the Ds1302 module
NICLA SENSE ME BSEC ZERO VALUES "comp_t", "comp_h", "comp_g"""
Problem whith I2C digital potentiometer MCP40D18
Problem with Ublox NEO-6M GPS
Projects setup s@cks
SDCARD ISSUEEEE
Writing a set point
Integrating servo with Bluetooth module
COM Port Error With i2c Devices
How to control RGB LED with push switches?
Hi trying to read different types of data from energy meter with meter, NEED HELP
Programming of built in timer of arduino
Why my Servo does not turn?
I have compilation error with any sketch and any board
Basic alarm system activated by keypad
Programming help for MPU6050
Sim800 a liitle help
Trying to adjust intensity of coin motor vibration
2 ultrasonic sensors controlling 2 lights
Arduino Uno CH340
CONTER WORKS IN STEP BY STEP. NOT running CPNTINUSLY
How to send sensors data and control relays from cloud via ESP8266 WiFi Module
Programme with Led
Arduinon Uno loses time sync
Connecting my Arduino with Win cc tia portal using RTU protocol
Expected unqualified-id before 'else' in TinkerCad
Help with arduino, robot, and servo motor
Missing declaration before }
Can't get the RGB LED to work with the IR Remote
Adafruit MQTT client to work with the openweathermap.org 1 client
Flash Arduino without IDE
Generate two square waveforms simultaneously with different frequency
How do i get the end of the line
Input LCD 16x2 name and surname
Counter and storing value in EEPROM
Using A Nextion to Drive an Interrupt
Indoor TDOA system
Why my RFID module is giving access to every ID card of my college students
Need a way to detect if a person is walking into the room
A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
Arduino UNO Blink Light Button System
Receive error message while loading sketch
Receiving some strange characters in console log of xctu when sending data from sensor node to coordinator
It is about the problem on my project..... please help me!
Servo Motor controlled by inductive sensor <HELP>
KalmanFilter Error in Arduino
Proffieboard EXIT STATUS 255
Digital camera with Mega and OV5642 Arducam
Get variables from serial
I can’t find the error in using if
Specific Stroke Control for Linear Actuator
Does not match any class
3 Potentiometers, Arduino Pro Micro & OLED - VCC Chain cause Arduino shut off
My kid created a new design of "LED Bar Graph"
Arduino unable to pick up slave on i2c
I'm new and need some Coding help
Uso del sensor muscular emg para controlar servomotores
Esp32 cam face recognition and detection
ESP 32 16 channel relay control ?
LCD plus OLED in one Arduino
Connecting six stepper motors to my Arduino Mega 2560
Balancing Drone
LDR circuit turns off after some time
QR Code Reader ESP
Trying to find TLP281-4 4 Channel optoIsolator IC for Fritzing part
Controlling Microservo with Pushbutton and External Power Supply
How do I add my keypad code into my PIR alarm code?
Hello friends Arduino ILI9341 2.8 screen text upright
Arduino problems
Code for arduino uno anti-sleep control project
String toInt and cut in pieces in a elegant way
Arduino IoT cloud
Data section exceeds available space in board (tinkercard)
Arduino uno interrupt timer bluetooth
PWM generation on Arduino Uno having Atmega328 P
Making an Ultrasonic Anemometer Using Just 2 Ultrassonic Sensors (HC-SR04)
General Question - Basic Electronics Circuit
Need help with a switch for a led timer
If (gps.encode(gpsSerial.read.())
How to interface arduino (any ) to AD7156 and get the average capacitance value
Error: Cannot convert 'char[33]' to Stream&'
Problem uploading code to esp8266
Arduino Mega and MDB protocol with bill validator NV9 Spectral
Project struggle
Problems with sim900a module
Automatic Card dealer project LCD help
I want to add 2nd sensor for my project. example pir sensor 1 is for gsm and relay and 2nd sensor is for buzzer, I dont know how to do it please help!
Parallel Arduino Mega2560, transmitting Temperature to display on LCDs
Board Not Recognised by Computer/IDE
Display gradient lcd
ESP8266 and display issue?
How to implement wireless communication using arduino pro micro?
Arduino Noob Code
Schets not working
Arduino Noob Code
Limit #'s behind decimal?
Counting number of times a set of LED's flash
My pc can't recognize arduino "copy" after smoke come from it.
Arduino outputting extremely low voltage I/O
Help for an high and low on a pin
I have a problem with void loop() where the x,y,z does not show up when I run my program in Proteus
Stepper motor strange behavior (video included)
Motor Control Using NRF24L01 and Arduino Nano
Automatic curtain code review for improvements and potential pitfalls
Esp32sim7000g manejo de sd
Motor M3 and M4 not working
Arduino leonardo not uploading
Custom CAN Module (MCP2515 Inside) Detects Bus Without Connection
Nodemcu esp8266 domotic
ESP8266 recognization with smartphone
No crypto present
Derivateur de surtension (dimensionnement condensateur?)
Using OLED and rotary encoder on Micro
HC 05 and Ardiuno Mega data received is garbage
Tia circuit with arduino
Trouble with a connection of two pushbutton and one ldr sensor
I transmit data from arduino idle to dwin display(dmg48270c043_04wt4) ,but i didnt transmit any data to dwin display, why? explain me and correct code
How to turn a light if the buzzer makes a sound greater than 500
Datalogger con ESP32 asignar nombre al archivo en micro SD con una variable
Can we reset the on/off delay timer in arduino code
Error arduino pro micro
Joystick button, EEPROM, servo motor
Fitting everything in
ESP32 Cam module capturing photo triggered by Arduino
DC Motor Off in Loop
Image refresh on mcufriend_kbv
Esp8266 stops comunicating
Weird characters on serial monitor Arduino
How Connect arduino with UHF RFID Reader and Send data to my (React js node js) Server
Necesito la Combinacion de motores + Control Remoto Arduino porfavor
Waveshare ESP32 C3 zero from PI Hut
Need Help with MIDI Control Change Messages with Buttons
Modulo sim900 no me responde a los comandos at desde mi arduino
ISSUE : I am preparing 2 separate JSON objects to publish
Reduction in Jitter from Arduino Outputs
Pestaña desaparecio del lugar que frecuentaba
I can not get my code compiling
CH32V003 - Analogwrite()
Finding beam deflection in a Wheatstone bridge using a single strain gauge
P10 board DIMMING AND BRIGHTNING issue
LCD does not show information
Selectable led sequence with push button to run program only one
2 potentiometer 2 stepper motor and 2 switch
Using HTML buttons for web control with data refreshing
SPS30 & SD DataLogger
MCP2515 CAN Module Receiver not working
ArduCAM mini 2MP Erorr
Arduino Project Hub help needed
Motores de coche ESP32 no funcionan
Help with LCD connection to Arduino
Problemas con un proyecto activador de rele por el sensor ultrasonico y leds
Photoresistor and Actuator Extension and Retraction Project
74HC4067 MUX switches all output ports to low after port change
When adding sd card reader, measurement will nog work
Esp kline ecu honda vision K44
Trying to convert Int to string so Oled will display it
Problem with ‘ bool variable ‘
Maqueta de madera, placas arduino, esp32
IRRemote starter kit problem
Displaying Text on Character Lcd with 8051(89c51,89c52) microcontroller
Help with compiling
Relogio (watch)
Pre written code for simple traffic light won't verify or download
Power to arduino uno
Sending data from arduino to processing is not working as intended
Unable to upload sketch to Board
Using millis with a L293D Motor Shield
Custom water monitoring system
ECG two electrode mode - AD8232
Enable a relay but not turning it on until a artnet channel is received for it
Interrupt LED+Fan+DHT11
64x16 MAX7219 LED DOT MATRIX DISPLAY
IRF520 GND/5V issue!
Arduino and Photodiode Array Sensor
Voice Based Public Announcement Board using IoT
Chinese sound sensor Config
Know the rotation/polarity of a DC motor - Beginners
What is the purpose of setLedOn?
LCD mostrar texto en movmiento con millis
Arduino motror controller using interruptions
Global variables taking up too much dynamic memory
My esp32(wifi and bluetooth) is not connecting to the arduino ide
Arduino Nano + Micro Servo with Single Non-Battery Power Source
High and low logic
433mhz Transmitter and receiver without library
Claw Programing Problems
How do you code a Bitmap Image
New to Arduino IDE need help of course
[SOLUCIONADO] Problemas al subir sketch a Arduino Nano V3
Avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa1a
UART to LCD between two Arduino
Code explanation pleas
12volt LiFePO4 battery and buck converter
Windows 10 won't recognize MKR Zero?
How to add Code to your question?
Variation in the voltage value for no input using Arduino
2 L298 con cuatro motores para carrito
Can't open device "\\.\COM3"
How to show binary with 6 leds?
Gps Distance between 2 points (FLYSKY SENSOR)
Wemos D1 Mini Pro to Hilitand MOSFET board
Alguien avezado me puede explicar esto¿?¿?
Traffic lights for emergency vehicle detection
How do i explain coding structure and logic (coding for alarm clock)
Bait boat with gps
Error Help and Displaying Values Simulataneously
Motor driver and test circuit with arduino
How to integrate two pumps for water solution with esp32 and ph sensor
Unclear error in code
Average Pressure Sensor Readings to Boyles Law
Uno - Using 5v and 3.3v pins at the same time?
Melody with delay
DHT22 reading sensor, First post,
Steppermotor with 2 LDR
Need help with drawing part of an image
If statement freezes whole code
Closed loop stepper motor
How do i make lcd wright a variable
Esp32 comunicating data to Arduino uno
Fs-ins-16z-v1-16. Does this film foot pressure sensor work in arduino uno?
Digital pin value
Digital pin value
BUG FIXING in arduino nano
Split code into files
.debug error during compiling in Arduino IDE
Mastering the Arduino UART: From Libraries to Register-Level Magic!"
ESP-12F deep sleep problem
Error use wire.h and twi.h library
5v Relay not taking input from MKR Wifi 1010
Help with mp3 player
I2C sensors stopping after 5-10 seconds
Gimdal by arduino nano
Arduino Uno R4 Wifi
LCD 1602A totally unresponsive
[solved]Problem with stepper motor and seria connection
Error compiling for board Arduino Mega or Mega 2560. Adafruit_GFX
Is it possible to use httpclient library for Arduino mkr wifi 1010
Running a set of CASE statements, turning on LED with static variable, but it turns off at BREAKf when
Arduino COM port problem with PICO and PICO2
Comunicación serial entre dos arduinos
SIM800L module doesn't detect any operators
Possible to code the Arduino to shut off an LED after 20 mins?
Using rotary encoder and serial monitor
Exiting a while loop
Create an Temperature controlled Relais - Help appreciated
Modbus RTU issue using multiple salves
Accoustic source Direction finder using arduino
Arduino Uno and esp8266 module communication
How to connect ultrasonic sensor with ts3200 sensor in Arduino Uno?
Arduino USB Host and Barcode Scanner
I need some help with this error code
How to get precise stable MICRO volt readings?
Digital input filtering advice
Convertir código a maquina de estados
Problem with LedControl library
CAN data detection and processing
Video player in arduino
Display bitmaps from sd
How can I pause stepper motor with ultrasonic sensor?
Switch/Case Programming Question
Serial communication between Esp32 and Arduino one
Any Idea how to read/write from/to specific bytes in RFID?
Laser control using arduino
As5147p hall sensor
Problem with CAN BUS Receive Data CODE
Error In Obstacle Avoiding Car
Temperaturelogging
GPS breaking when adding lots of sensors
UNO R4 WiFi disconnecting/reconnecting continuously when running sketch w/ "LED_Matrix" and "ArduinoBLE" libraries
Controlling Arduino using internet(website)
Sending values via HC12 transmitter
Can A4988 driver run any stepper motors in its voltage range?
Need help in displaying data of device showing on it's LCD on a computer screen
Adafruit custom keypad / EEPROM issue
How To Control Water Flow?
Trettenit electroniqu
Arduino project - pump and ultrasonic sensor
Showcasing an alternative way to code
Questions about reset the Arduino bootloader on the Nano ESP32 s3
Sending IR from a transmitter,
I need to find the highest number from a number array
Bosch Motronic 1.3 Air Flow Meter PiggyBack, HELP :'(
4 stepper and 2 servo with CNC shield
LCD display stop data Flow after hour
Serial communication between esp32 and arduino mega
LOVE-O-Meter fails
Connection between Raspberry Pi + Arduino + Relays gets lock up
How to declare hardware connected to arduino pins
I'm using a state machine, but the states are not switching properly
Mbed_BLE_HID.h - Eclipse
Mi PC no detecta la placa de Arduino
Arduinio stuck at home screen
Brushless betafpv motor with Arduino
Arduino l293d shield issue with motors speed
GM65 Arduino UNO
Compilation of any sketch fails for ESP32: "No module named 'serial'"
Selecting the correct Hardware?
How to get the best out of this forum
Msp430f5529lp double click
How to get the address and command of this ir raw data and header_micros and space
Ardunio automotive gauges
Connecting a controller to an remote controller
PWM pulse generator
Doubt about drones
Hey, Im young and dont know what im doing help please?
Thermistor temperature sensor project(HELP)
I need help my project take so many erorr pls say me What am I doing wrong? :)
Arduino nano RP2040 connects
Email Trigger with Timestamp content
Using Two I2S devices at the same time
WiFiNINA client unreliable on MKR 1010
Noisy AC voltmeter
Noice Z shifting
How to repeat block of code specific no of time?
How to make a Arduino hand
Communication RX TX Arduino PC
Arduino UNO R3 pin 13 led is always on
MEGA 2560 Code problem
Else without previous if PLS helllpppp
Float array print issue
HC06 pairing problems
Rc522 disable when bike starts or horn blowse
Creating a robotic Arm using Arduino and Leap Motion Sensor
Ardunio ethernet shield
My code will not be uploaded to ESP32
Why do all LEDs turn on when I plug in my Arduino
Oled ssd 1306 y sensor de humedad Yl-69
HELP, it's for a school project
Please Help me in decreasing the dynamic memory space of the Arduino Nano for (WATER TANK MONITOR AND PUMP CONTROLLER)
Problema con el nombre de archivo en microSD SOLUCIONADO
How do I use this Arduino code to control Dobot Magician
Code isn't running
Can u say what Arduino board I am using
Realtime Fake Drivers for Microcontrollers – Develop Embedded Code on PC and Hardware Seamlessly
Help with a project
The Atmega328P is going too much fast
CAT5113 Digital Potentiometer
Esp32 DFPlayer mini not connecting
Unojoy mega eror
Communication between RS485 module and esp8266
How to read a 0–60V single-wire pulse signal with Arduino/ESP32?
Lora Based GPS Data Transmission Help
ELM327 and HC-05 connectivity issue
I need help.Arduino Uno keyboard (Piano)
Controlling stepper motors in real time with arduino
360 servo and button
MAX30102 is not working With ESP32 DEVkit V1
Different serial communication with R4
ESP32S3 With Waveshare epaper
HM-10 V3 problems with connecting to smartphone
2 Channel LED strip control with DMX
I2S conflict with Cyberon 'voice recognition' model
Can't get example sketch to run for SSD1327 Display
Debugging is not really working
Esp 32 no es funcional con hfp
Modbus over Arduino
Can I use Two battery of 9V batteries for 2WD arduino car? It show not enough power
Light sensor servo motor
Arduino relay code for 14 in 5 timing
PWM issues on ESP32
Stepper Motor not rotating (oscillating) in a particular range of speed (100-150 RPM)
SPI problem on Example code
7inch HDMI LCD (C)
Servos going crazy/ possible incorrect code wording
Arduino robot problem
IDE hangs on startup: "connectex: A connection attempt failed because the connected party did not properly respond ..."
Esp23 Wroom-32 Bluetooth processing problem
Esp32 not connecting to pc
RPM measuring using proximity sensor
Ultrasonic sensor connected to a joystick controlled car that stops within a predefined distance. I am new to arduino and need help
Arduino mp3 shield with ultrasonic sensor
Arduino Uno Starter Kit DS1307 Problems
Can someone tell me if there's a "stay/don't change state" type function?
NTC test circuit
Error Arduino 0xac
Necesito ayuda por favor!
Buenas noches, omar desde Venezuela
How to show data from a sensor on the serial monitor using arduino WiFI and mqtt broker
Problema conectividad ch376-esp32
IR Remote and motor L293D not working
Self-driving car using Arduino uno
Problems with code in python
SDA and SCL pin are not working for esp32 with max30102 sensor
I built a 3D-printed tracked robot using Arduino Mega, Raspberry Pi and OpenCV — looking for feedback
Error in interfacing robot car speed using speed sensor LM393
Speed capture with Photoelectric Sensors, LCD problems
Control a dc motor with PID control
LCD Sub-Menu Functions with 4x20 OLED?
Reading 12 volt battery using an esp32
Lcd does not name a type?
I want arduino code for TSOP ir read data with using Attiny1606 controller
Question when writing mysql query with Arduino
Arduino Uno not pls helpworking
Attiny 1634 with microSD card libraries
Connecting a V2.4 Cycle Analyst to Arduino
Using a single push button for two servos
Various troubles with CNC
2 servo motors with different rotations
Force Sensing Resistor
Joystick and led
Joystick and led
Ahhhhhhhhhhhhhh i need help a wire is stuck in my 5 volt on my arduino uno!
Real time stepper motor control
Connection problem with my PS4 controller
I have copied my MATLAB code to the Arduino and im using ultrasonic sensor to determine fuel volume in tank..Arduino is not getting correct values
5V and GND Connection?
Exit status 1 on arduino UNO board
Im using tinkercad, so my code doesnt stop in the condition yes/no statement idont know why please someone help me
Bluetooth controlled car - advice on an issue
Appearing the noise by adding the second sensor
New Compilation error in rc-6 and rc-7
Capturar huella de sensor biométrico
Teyleten Robot Mega2560 + WiFi R3 USB-TTL CH340G ATmega2560 ESP8266 Memory 32Mb
Adding a delay to turn off pins after a certain amount of time in a debounce function
Servomotor Project 5 (edited)
Help me please, it was about 4 led blink with 5 seconds interval
Arduino nano pwm varspeed which pins available?
Stoping rgb sensor at specific rgb value
6V 20A power supply for arduino robotic arm project
PCA9685 Burnout Question
[SOLVED} Old Wifly RN-171 Factory Resets Itself at 2 AM
Arduino Touchscreen Inverted touch
How do you create a pcb board?
Do have any idea about this ?
Different inputs, same output
Error compiling for board NodeMCU 1.0 (ESP-12E Module). for MS5837
Servo motor control using esp8266 and IOT
Arduino nrf24l01 AckPayload problem
Starter kit, love-o-meter sensor takes to long to react
Showing DS18B20 temperature sensor data in Nextion screen
Using nano to activated up to 8 songs on a dyhv20t after using a micro switch
Contador de pulsos con tiempo
Bionic Arm for my physically disabled teacher
IOT weather monitoring system using node mcu
Design and implementation of a surveillance agricultural robot
Code uploads to Nano but does not run
Transmit Arduino Sensors Data to Nodemcu using RF Module Transmitter & Receiver
OPTA - RETAIN data space
Expansion Board Kit for Arduino UNO
Pro Micro no funciona
How to combine 3 arduino codes (main code + 2 sensors)
HID Wiegand R40 and strike plate
Switch Always reading as high
Arduino Uno R4 Minima "Freeze" & Connection Issues
Delay is not working for applied filter on serial analog data sample
Working on a gate opener motor driver
I'm getting this error whenever I try to upload code
Using a piezo vibration sensor to detect impact to a target
Trying to modify Fast PWM frequencies on the fly within a running program
Request for member 'startsWith' in 'Serial.HardwareSerial::read()', which is of non-class type 'int'
I need stepper to go back to home switch
What is the best way for Arduino to handle a large amount of continuous data fast?
I want to interface with Chinese Temperature & Humidity Module TTL level Serial Port with Arduino
JS40F Movement Sensor Broken
Beginner RGB led
Nrf24l01 not connecting
Installing Arduino
Coding of a go car with joystck and controller
Trouble with receiving GPS data on UBLOX Neo-6M
I need to get data from different esp32 board to a single esp board or modem and upload that to a cloud .Any idea how can we do this?
ESP32 DEVKIT Weird output
Adding delay using counters in arduino mega
1 led ring 2 pins to data in?
Help to get down current consumption
Gy-max30100 reading BPM is abovw 140
Arduino Nano cannot find ports when I plug my i2c device in
Can we Control DPDT switches by using Arduino/ESP32?
Neopixel controllable groups for Dancing Fountain?
Stepper Driver Motor Vibrating
Tiempo de ejecucion
Can i send signal to two arduino from one rfid?
Replacing a 10k potentiometer with a programmable timer
ESP NOW is where on forum?
** Need Help Using QNDBK1-40 Hall Effect Current Sensor with Arduino Uno and ESP8266**
How to lower voltage 0.33V
Arduino_LED_Matrix should on() only turn on LED and off all the others?
What'svthe problem here
Nodemcu mysql connection library error
Motor drive L298N
DF Mini Player question with Uno
New to Arduino. Need help confirming code works and how to confirm its running
What topic? Where? I have a question. Just want to talk to people about tech problems
Completely new to arduino, please help
Led matrix conflict with i2c
Arduino music instruments
Mprls simpletest
Sistema de monitoreo de calidad del agua
The buzzer sounds only a few times
Killed my laptop it seems
Arduino rocking machine
How to wire this up, what is my mistake?
Button-sketch error. "expected primary-expression before ','token
ESP32 ILI9846 Temperature humidity show the display with 5server 1 client How?
Using motor position inputs (via incremental encoder) to control output signal to mosfet driver to drive motor
Need help in coding a soft AP IP and how to transfer esp8266 circuit connection on breadboard to the motor shield
I need help writing a code that controls multiple servo motors using a matrix keypad
I want to activate an output when my esp32 cam begins streaming
Manual and Internet control of a CNC machine
Arduino Nano connected to a 0-360 degree hall sensor
CAN communication using SNV65HVD230
Lector de iButton y RFID (Escritura y lectura de Datos)
2 DC motor with uno and joystick car not working // Code and pictures
Setting up an E36 Sim cluster
Working with Remote
Working with Remote
Problem Adding Additional Transducers to Single Set
Change element in HTML page hosted on arduino
A4988 Stepper Motor Driver Microstepping
Sensor de calidad del aire
Clear Serial available
Error with the Arduino Serial Monitor
Termination of SD_Card with resistor
Touch Paint! Couldn't start touchscreen controller
LCD How to Parse Carraige Return LF
Auto Refilling Water Tank with Solenoid Valve and Ultrasonic Sensor
Communication between MFRC522 and an ISO 14443-4 Tag
LED strip colors are not correct
No sound PCM5102A
Stable Multiprocessing README
Failed uploading: uploading error: exit status 1
Laser Trip Wire Sensor Connection
How to programming buzzer on NodeMCU ESP8266 with MAX30100 and DS18B20 sensor
Setting Temperature Differential Between 2 x DS18B20's
Arduino air quality display and storage project
How to connect ws2812b leds in strips
Controlling Stepper using incrimental rotary encoder and arduino
New posting - frequent responses
Controlling stepper motors speed Help
Vibration motor control
Ia6b ibus help plss
A special build
How to control a stepper motor with a text file on an SD card
Board disconnects from Serial Monitor after upload
Wind Vane mechanism and sensor
Can't get Stepper to go full speed
Waterproof ultrasonic sensor measurements problems
The OLED Display on SPI communication Stops working after using pulse oximeter library
Newbee needing a little help with a project
Fire fighting robot
Obstacle avoid car
Programa para robot aspirador xfavor
PM2.5 planttower/adafruit - arduino uno r3
Semaforo con sensor ultrasonico y camara 0v7670
I got problem with this code,
PCB Design Feedback Request: ESP32, SIM808, and Sensor Integration
Send data from nodemcu to Arduino
I want to turn on the gyro sensor of Arduino Nano 33 BLE and make a program that transmits information to the nRF connector
First Project, tmc2208 stepper control
Float numbers accuracy
Two Injector Banks Timing
Error while using the psx
Personal Safety Keychain with Mobile App
Problem in controlling stepper
Creating a 3d model of a planes path
Void value not ignored as it ought to be error
Programación de alarma
Reading and analyzing reflected signal in metal detector
How do I stop this?
Compilation error: exit status 1
Arduino MKR Wifi getting disconnected
I don't understand Uno VIN polarity - Help
ESP8266 malfunctioning
Hc05 Bluetooth communication got 2 second delay
ESP32-C3 and P10
Is it possible to make the DC motor turn at a slow speed?
[Solved] IDE not uploading code to Arduino uno
Utilizar la función millis 1 vez
How to keep servo in place using joystick?
Arduino controlled 70s electronic percussion board
ESP32 problemas con ADC usando WIFI
Multisensor portable station, GPS not upgrading
I need to find the error in this system, I simulate and display on Virtual tesmial is wrong, talented people please help!
Why is my circuit not working?
World Map with over 200 Leds (Max. 1280)
Issues with neopixel strip longer than 60 LEDS
I've got some error?
How to send data from the accelerometer using OSC ?
Conexión Fallida Arduino Nano ESP32
Mega : Interrupt on Pin 3
I want some advice
I need help for a solar tracker project
ESP32 - RX320 Serial Port problems
AT commands not responding
Upload my main code to SD Card?
How do I find two part harmony notes for 8 bit songs
Portenta machine control with firmata
How to cascade Hexadecimal no
Can't call function in void setup()
Help compiling sketch for atmega8
NEMA23, TB6600 Not Returning to Original Position After 30 seconds Delay
IR sensor signal detected by different pin from the one connected to
Adding stop button to mobile alarm clock code
Overweight problem
Adafruit NeoPixel won't output a solid color
Adafruit fingerprint 5th and 6th wire should act as a switch
Pantala LCD 20x4 con cuadros negros
Motor control using two ultrasonic distance sensors
Pointers revisited
PWM for LED not working
Success with haptics using cheap ultrasonic transmitters?
Window comparator
Problems with rf modul on ATtiny
Problem when upload config file to board
Send information via TX/RX from an arduino uno to a mega
I want to send array from processing software to arduino
Multiple loops, how can i make it work?
No se guarda el codigo en ARDUINO UNO pirata
Motor Direction reverse using Proximity Sensors
Current measurement
WS2811 LEDs aren't doing what I think they should
Diy coin pusher with arduino
Waveshare oled module is not working
When board powered up led turn on for 1min and meanwhile when button pressed turn off it immediately
RF/TF 433MHZ potentiometer problems
Arduino Nano every "No Native USB support available on this board"
Issue with HC-05 and Serial question marks
Invalid Library ESP32-cam
Why my ESP32 camera doesent give me IP Address
How to use the updated Arduino sketch book
Stepper motor nema 34 revolution project
Arduino Uno no conecta windows 10
Servomotor HS-805BB solo gira un sentido
Value of Array of Custom Classes Doesnt Change
Arduino ide, is there an automated up date
Including another library breaks LEDController
Gas sensor data not reading and output loops in bad and good air quality
APC220 transceiver
Write a program in C to switch on and off an LED
Data Logger Crash
2.8"TFT LCD Sheild- NEED HELP
I want to ask about my thesis
Seeking tutorials & files for easy to build potentiostat
Esp32-s3-wroom e-ink display connection problem
Problema con lectura de dos sensores max6675
Updating firmware through URL
Arduino bluetooth hc-06 car
Keyboard shortcut for find in all files?
Voltage of LED strip
A mi me sigue saliendo OFFLINE en el Arduino IOT Cloud
Library/sample code for REST call?
GPS esp8266 oled
Water level sensor Arduino issue on how to stop water from sitting between contacts
Arduino uno connect to usb 3.0?
Trying to make a wheel go with a ultrasonic ranger
Model railroad crossing signals control
Sync of switch and mit appinventor apps
Help with controlling stepper with buttons. Hold button to rotate etc
Use multiple ds18b20 sensors and calculate average
Water pump crashing system
Multiplexer Supply Voltage
Help with racing game and optical sensor for pinball score counter
Please someone help me
PIR sensor output toggled always even noone near to sensor
How to improve the speed of Python reading MLX90393 through nrf52832?
Motor with L298
Homing CNC without GRBL
http.begin("http://192.168.100.5/NodeMCU_RC522_Mysql/getUID.php"); //Specify request destination
How to wait for a particular IR Signal in Arduino? following code didn't work for me.. your support pls
Need help to understand Keypad and password
IDE 2.2.1 does not recognise header file
SD card is not recognized
Urgently Need Help!
ESP Now on Uno R4 WiFi
How to send a csv file to remote server using gsm900a
DFPlayer+RAdio VHF
Window comparator
Controlling arduino 4WD robot using z-axis"mpu6050 sensor"
Beginner with Grideye, examples not working
Saving ECG data in array
Hold button for 5 seconds before making LED high (SIMPLES WAY)
N424l01 wireless fireworks ignition system
Control Structure problem
Build Error - PlayGround not accessible
Hello World problem
Forum rules - Italians are better
Problem with Serial.print with MPU6050
INPUT Problem for Lcd display
Need code help to replace potentiometer from 250 to 100
Advice on new renewable energy technology
HardwareSerial on Esp 32-Nextion
AccelStepper Cancel moveTo
String in to an array
ESP32 Bluetooth does not reconnect after multiple connection disconnection
Help with types/ overflow
Interface max9814 module to Arduino board
New with ethernet enc28j60
Arduino Nano not uploading
Error at arduino keyboard
If I change the delay time, code not working
Problem: NRF24L01 Mega as receiver, Nano as transmitter
Missing characters in serial monitor prints
digitalWrite doesn't work sometimes
How do I code a Rotary Encoder?
About connecting Arduino Uno board to Wemos d1 r1 board
Interactive menu code little problem
Serial read data from labview to another arduino wirelessly
What is happening with people ?
Missing expression between '(' and ')'
Voltage measuring resulting in wrong outcome if anything else uses power
Electronic Dice
HELP me ARDUINO CODE convert ASSEMBLY LANGUAGE
Selected port is currently closing popup
Questions for powering arduino and other devices connected to arduino
Please help me write the code
Semáforo inteligente xd
Using Multiple FSR's with analogRead
How to make arduino nano iot 33 BLE act as a pendrive
Question about IR Thermometer with 2 Line LCD on Uno
Code Issue - Drawing Robot (Arduino Engineering Kit)
Not able to send CAN messages-Need Help
Solving error Base64 on Arduino IDE
Debug is failed . How to debug correctly?
Please how do i solve this?
NEED HELP, arduino nano keypad
Arduino and Assembly
INPUT_PULLUP not working
ESP8266 and HC-04
Motors not responding to code for sensor
Complement operator turning uint8_t to signed number
Timed servo door for chiken coop
4-Digit Seven-Segment Displays
I am new here, getting below error.kindly point out whats wrong i have done. i am trying to connect m5stack core 2 with aws cloud
Need help to read usb mouse readings from pico
Timer using registers
Issue with nRF24L01 module and arduino uno
Transducer Matrix Delay
Having trouble verifying code
Sensor Timing Disk
Sending tone from Arduino to Iphone 100m
74HC595 - driving higher loads/voltage
Efficient way to save data from arduino sensors
Importing JPG to an Array on Arduino
Is arduino mandatory for L293D motor driver?
How to count coil
Speed measurment with hall effect sensor
Error Esp 32 con keypad 4x4 y LCD 2x16
SdError: 0XC, 0XFF y la sd wireless shield
Trouble when connecting limit switch
Can we measure the AC voltage with Arduino
Arduino doesn't work properly after disconnection from pc
The step motor does not work and beeps
I want to make call using phonebook number
Why is there a voltage drop when I add a resistor?
m5stack_BMPCC6K fix stack smashing protect failure
Load cell sketch errors
Thermostat LCD display doesn't turn on
7-Seg Display, with extra LED's?
[esp32] random outputs with 4*50kg load cell & hx711
RFID Card Reader Serial Monitor
Leer milivoltios con arduino
If statements HELP
The motor of this code are not working
Keyboard keeps disconnecting from Giga R1 WiFi
Store only non-zero values from analog read() and ignore all zeros
Finicky Nano 33 IOT USB (Windows)
IDE hangs on startup: "Failed to initialize the CLI configuration"
Regarding BLDC motor driver controller
Having trouble with setting up the pro micro
Mano robotica y servo motores
Restart the whole system with an interrupt to avoid power surges
Getting error during compile
Pulse Sensor Not Working
i need help with a error
Esp32 error con pantallas y hx711
I need help with Lora
egArray was not declared in this scope
Help ESP-01 with Nano
Simple RTC project
Problema con arduino y controlador l298n
How to move 4 motors efficiently with Arduino Uno?
Subject: Combining PIR Motion Sensor and Soil Moisture Sensor Code
What is your experience with UNO R4 WiFi on Arduino Cloud?
Code to control motors with PS4 controller
Dabble gamepad not working
'void LiquidCrystal_I2C::init()'
No response on AT commands in HC-05bt module
Arduino Uno and ESP8266 will not work
PIR sensor help part counter
HTML/javascript send data to arduino via rs232
UNO / EVERY problem with converting variables?
I2C transmission of sensor data
Need Help to Manually Install Seeeds Board Package
Ht12e encoder with arduino nano
How to use serial to comunication with DAW and PC(C#)
The most basic GET-request with an Ethernet Shield - HELP
Arduino soil moisture sensor without sensor module
Esp 32 Core 1 panic'ed
Problem while combining/compiling code for 2 programs related to same project
A project beat to death by the internet that i (somehow) still require assistance
Sensor and microprocessor
Button box sketch help
Dark Ride - Sabertooth 2x60 with nRF24l01 transceiver
Collect 5 seconds of data from sensor with a gap of 1/60 seconds between each reading
Getting strange low output voltage at Motors
TinyGsm connect failed
MAX31865's VDD and GND short circuit problem
Using Ultrasonic Sensors for NDT
How to connect two ultrasonic sensors with one lcd display?
My LCD screen is overwriting white blocks [wrong wiring]
Can 3.3V damage my body?
How to change directions on MAX7219 DOT MATRIX
I have line follower robot with a sensor with 5 IR AND A MODULE L298N.I have a code but it doesn t work.Can anyone plsss help me
NEMA 34 stepper motor and DQ860MA driver controlled using RC Transmitter with Arduino UNO R3
4x Motor 4x BTS7960 problem, Arduino Uno
Flapping motion for ornithopter
Changing a button to a touch sensor
Stepper motor programming and scsketch
Voltage under over curoff
My joystick doesn't work
MPU 6050 goes wild once motors plugged in
How declare char type array
PC does not recognise Arduino UNO R4 WiFi
LCD not displaying data
Inconsistent pressure readings on my Touchscreen
How to controll servo via imu on nano rp2040
Interference of A4988 (stepper) on MAX31855
DC Motor Control with a single button and H Bridge
Arduino nano se congela
Arduino sorting robot
Programmer is not responding. WHY?
Arduino Diy Drone
Can someone pls tell me where the Potentiometer (for contrast adjustment) thing is
My sketches missing top of sketch
Physical pin number VS Mapped Digital pin number
Can someone help me with this?!
Dh11 working on leonardo and not Uno
Highschool Project Help
Connecting pressure Sensor to arduino via half-duplex
Bluetooth seems to work but not properly?
Ideas and suggestions working with relays
Serial Communication without USB
I Cant figure out the issue
Speed controller for single phase induction motor
Problem with PZEM-004t CT sounds like creak when hooked onto cable
Relay 5v module randomly worked
Keypad gets stuck! Help
Ethernet Programing
I have a small function that used to produce a variety of blinking speeds and rates
Serial data going missing intermitently at end of string
Coding Assistance required :(
Arduino Uno Connecting to Arduino Uno with WiFi Wemos D1 Using Lora
MB102 PSU problem
Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
Ublox neo-7 Gps module
Project won't work upon being powered, but will under other conditions
Read Pulse Of Built In Hall Sensor and Measure speed (RPM)
Some help with Nano BLE
No text appearing
Help understanding a complex code
Arduino IR Help Please
Possible code error?
How to Make Standard function for Leds ON and OFF
Arduino ps2 keyboard
Portenta Machine Control and PlatformIO RS485
Analog inputs reporting 14,15,16
Real-time Monitoring of the quality of water in wells
Sim900 Mexico 2G No conecta red
Dad needs help Fading multiple LEDs
I have Custom made 12 V Arduino motor board, Can I run DC motors on it?
Error: no such file or directory
Using a TMC2209 silent stepper motor driver with an arduino
Avrdude: ser_open(): can't set com-state for "\\.\COM10"
Title: ESP32 + TMC5160A Stepper Motor Jerking at Higher Speeds with Acrylic Plate Load
LED strip not lighting up everything
New user - First post !
Step counter in LIS2DUX12 chip
LCD-Display Life Point Counter
Two data send and store database using firebase with esp8266
Different Values Not printing Simultaneously on the Serial monitor
Help! Wireless doorbell for a school project
Irradiation meter with arduino
Local Mosquito broker and ESP32 does not connect
CO2 readings via I2C not working
Serial connection between ESP-32 and Arduino UNO
Generally Toxic and non informative
My code dosent work nor use any dynamic memory
I'm a fairly new Arduino user, and I need help figuring things out!
Potentiometer with reverse button for stepper
Controlador PID de presión
Two way serial communication between two boards
'class DS3231' has no member named 'getTime'; did you mean 'getA1Time'?
Failed uploading
Serial.println() with Arduino IDE 2.1.0
Questions on stepper 28BYJ-48 to make a kinetic flower
Stop Servo if the certain condition is met
JDY-31 Bluetooth Modules Not Communicating in Master-Slave Mode
ACS712 not accurate with a dimmer on same circuit
Arduino a 100 metros
Reading SD Card, cant get concatenated string reading bytes from SD
Nextion Display Sends inconsistently when not on main Page
Direct addressing to the Arduino Flash Memory
Pro Micro And Piezo Trouble
I have a problem with my arduino pro micro
El módulo MAX6675 me arroja valores de 0°C
My 28byj-48 only vibrates
Invertir palabra en arduino
Need help converting $9.39e-6 number to decimal number please
Does the UNO r4 wifi accept different code to a mega2560?
Arduino Create Agent on Windows 11
Did I fry my tx pin?
Micro-ros arduino ide installation problem
Making voting system
My boards all say NANo on them but come up as unknown?
Controlling WS2812b LEDs with atmega88
FC16-HW control each LED
Serial Communication between ArduinoIDE and Simulink for controlling motor
Arduino lcd ic2 problems
Two push buttons led brightness controller code?
Exploring the Intersection: Arduino Innovation and Administrative Efficiency in Portugal
Code doing loop without condition is true
Using AT24C512 with Arduino I2C and controll the addresses using the serial monitor
Smart Parking System
Sketch won't count input from IR sensor
Arduino sensor and 2 lights code help
Searching for micro controller with 9 or more uart channels
Arduino error during upload
MPU9250/GY-91 Magnetometer is not working
Using DHT11 temp. and humidity sensor to measure & display the temp and humidity using an LCD without using any external libraries
WS2812B single row scrolling Help needed
A one wire communication program with problems
More than one button with a screen
Stop the rotation of stepper motor when the key is pressed
Blink LED stopped working
"What is the solution to this error?"
Motor Control with D1 Mini
Use a different configuration depending on the amount of light in garduino
Help with Motorized faders
Arduino Cloud and User_Setup_Select.h
Int to hex char (0xFF)
Can anyone help me understanding the code to controlling a stepper motor by Arduino interfacing with micromanager
Failed to connect to ESP32: No serial data received
Open Loop BOOST Converter with Arduino
Arduino Nano serial display coding help
Led driver failed
Problems making code repeat
Nextion test sketch
Motor Driver connection to arduino, LCD and sensor and implementation of overriding switch
I am facing issues while connecting the 5 sensors in the ardiuno uno
Using web serial as serial monitor
NeoPixel Lights
Code security with blink
NeoPixel Lights
My L298 Hbridge attacks my PCA9685 servo board
People counter + noise level detector WITH wifi
BLE 33 Sense isn't finding port
Entradas analogicas dejan de funcionar
Blynk do not connect
UNO R3 - Control Relay with Digital Output
CAN shield programming
Arduino to be connected with ultrasonic sensor and electric horn and electromagnetic solenoid for automatic brake system
What is the best way to drive 4 stepper motors using 4 potentiometers and 4 switches for direction
Necesito controlar un balancín con PID
Communication of several devices by serial port
ISR interrupt routine
IDE hangs on startup: "loading json index file ... The system cannot find the file specified."
Getting state change value from analogRead()
Controlling Relay with Dfrobot PH sensor Data using ESP32
RFID Works Independently, but Stops Working When Sending Data via LoRa
Having problems with gy-521
C# Arduino Serial read....I dont know how to read it oustide a while loop, it wont work with the rest of the code outside a while loop
Arduino cloud interfacing in cloud
I cant read fast movements
Force Sensor Setup Guidance
I keep getting error
Joystick analog reading values sometimes changed
Portenta H7 SD.begin() returns 0 systematically
I made a stopwatch with a point counter with a 7 segment of 4 digits, and it blinks when the number is not equal to 0
Forwards and Backwards, Stepper Motor, CNC Sheild, Trying to limit void loop() from continuously looping
Keyboard text to binary output
Arduino resets when relay turns on/of
Why void setup() is called repeatedly?
Tx and rx blinks constantly when connected to the breadboard
Hi! can someone tall me what this line of code does? in UltrasonicDistance
Board's libraries doesn't work offline
Seeking Expert Guidance for Dual-Axis Solar Tracking Robot Prototype Project Using Arduino Uno
No i2c device found
ESP32 - Wifi Connection
Interval between calls to slaves
We have a project smart trashbin but i want to convert the distance to percentage
Potentiometer controlling arduino
How to detect the sd card in arduino portenta x8 with Hat carrier?
I need my led chaser pattern to stop with a push button [with all HIGH LEDs] Help please
Nooby needs help with robot
Reading serial and extract digits
Como obter o melhor desse Fórum
FastLed and Random number
Need help on light detection sensor
Corrupt data, serialport, esp8266 with arduino mega
Arduino nano ESP32-S3 panic resetting [SOLVED]
Display dht22 data on a 4*8*8 led matrix with MAX27XX using esp32
How to control two servo motor each with a potentiometer controlled wirlessly through NRF24L01 and Arduino uno?
How to control two servo motor each with a potentiometer controlled wirlessly through NRF24L01+?
Need Help Adding 16x2 LCD function to Dual IR Temp sensors
Difference between Arduino Mega and Elengo Mega
Help: Serial.printf to lcd.print
I need help on this task!
Need help combining sketches
Stepper motor not turning under load
HC-SR04 wont continue working after one loop
I2C register read on Attiny85 using tinyWireM
Ultrasonic goes off and LCD go crazy and display weird characters when i activate water pump through relay and 9v battery
Programme coflict
Problem with Digital vs Analog Servos
QuantAsylum QA-403
How to change the default pin number in wire.h library
Help detecting a connector
IR LED tv remote signal sender
Ethernet 2 uno setup
Multichannel Gas Sensor Not Detecting Error (not compatible with nodeMCU (ESP8266) )
Hora en oled 128x64 usando un SD1302
El sketch usa... bytes del espacio
Problem with uploading a sketch to a floppy disk
Help me understand please AT response
Interrupt conflict
Help arduino uno r3 panic alarm
Having trouble in saving a sensor value at a specific time
Why does my A4988 burn?
Esp_8_bit arduino trouble NTSC video
Porque mi esp32cam marca un error
Arduino IDE serial monitor and VR module advice
Arduino MFRC522 RFID Continuous Reading
Make an output pin behave like a monostable multivibrator
I can't display what I want on my console
Failed to upload sketch and Tx Rx light is not glowing
I need help setting up my libraries in Arduino
Arduino Step Motor
Rotating the Servo Using PID controller and SONAR
ESP32 video recording on SD card
Looking to program one joystick to be toggled as 2 diffrent inputs
Question About SoftI2CMaster
Only my first serial pin is taking order
Button control through BLE communication
General Expert Advise needed
Swing gates with multiple open command inputs
Can we use an NPK sensor to measure NPK contents in water?
Menu submenu lcd 20x4
Ai assistant stopped answering in just 1 conversation
Dfplayer mini sound module
Identify this smd component
(Newbie) Simple Project with Motion Sensors
Can I use Arduino to silence a barking dog?
General question about DEMUX for 12v motor
I wanted to try the NEO-6M GPS Module but I only see special characters in the Serial Monitor like this: "��������������”
Vibration sensor to activate alexa light
Bluetooth Function I Don't Understand
Serial Monitor for ESP32 S3 Dev kit
Reading ADC with ADC interrupts and Timer Compare
Send recive data separated by comma
Ttgo t-beam v1.1 rst:0x1 (POWERON_RESET),boot:0x7 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2)) waiting for download
ESP-32 CAM not sending get/Post parameter
How to make voltage adder
I connected my BLDC but it doesn't work
Can't find a basic sketch
Como alimentar una bomba peristaltica 12V
Nano33 IOT not working with com ports
Expected numeric before constant error
Device manager-CODE 10 error
Multiples Output on Serial Monitor
Need help for my basic Buzzer Timer code
Using a single momentary button to advance states
Remplace Atemega with Arduino
Esp32 on P8 RGB LED
Getting an error when i try to verify code
My toilet flush project
Recommended tutorials/learning path for animatronics?
Want to make a circus recirculation machine for Kids
Codigo para medir ph
Adding function to a value
Oh no.ST7789 LCD doent work and i didnt even touched when i made it working
Issues with the RFM96W
DHT11 Temperature Sensor, LED Alarm
How to upload photo file for ESP32 over Wi-Fi OTA
Getting out of a cycle in a for loop
ADS1115 showing inverted Reading
How to make a mouse work with USB Host Shield?
ESP32-wroom-38 pin board selection
Stepper motor vibrating but not turning (using an arduino cnc shield)
Help regarding esp32
Pressure sensor ABPDLNN100MG2A3
Sharing Voltage Comparator that can Swing from Positive to Negative
Run code if button held for >20secs
Moving a servo using 2 push buttons without using a delay
Entering number using push buttons
Help me with my project, please
Pull-up resisters not working on Mega 2560
Title: Excessive Power Consumption Issue with ESP32, MPU6050, and Deep Sleep
Mpx 5700 ap esp 32
Demux 120 INPUTS
FS1012 MEMS mass flow sensor
Does the Wire.setClock() function support 10kHz i2c clock frequency?
An error occurred while uploading the sketch
Using ESPAsyncWebServer- web browser cause crash
Arduino y nextion editor
Help me, the gsm module don't send SMS
12v Solenoid valves with arduino
I want to rotate the motor for 3 sec and stop and then wait for ir signal and rotate for 3 sec in reverse and stop,but my motor rotates infinitely
Arduino nano Serial printing out ascii garbage
Help writing code for actuator control
IRremote Infrared Transmitting for IOT Device Control
Arduino + LCD + nRF24L01
Quick Question about millis
Arduino Uno stopped working after I used a charger to power it
Distance measurement using IR sensor FC 51
LilyGo GitHub site requires overwriting some libs in the Arduino folder
ESP32-S3 as USB Host for Quectel EG800Q Modem (CDC Interface Issue)
CAN bus programm code not getting compile
How to interrupt my robotic arm using ISR?
Using LoRa To Control LEDs but cannot get it to work
Running a process
UART in ESP32 With TMC2209
Bulgarian text on Max7219 using Arduino Uno
LoRa E32 433 MHz Communication Problem
Could not open port 'COM1': PermissionError(13, 'Access is denied.', None, 5)
Doing Auto Brightness on a SSD1306 (OLED) Using APDS 9960 any idea how to do that ?
RC522 Authentication failed
Arduino include grbl +ug8lib
Error compiling for board Arduino Uno: IR_Receiver_Module
Estacion meteorologica sensores rs485 y esp32
Need help wiring a button box
Low power consumption on Arduino Nano 33 BLE
ESP32S with S9706
Does not connect to WiFi when country changes
Help with Arduino code pasting
Moving a stepper motor to two places with one command and AccelStepper library
Help a New guy Please
When I call <Adafruit_ADS1115 object>.begin(); my program running on arduino hangs. Any direction or advice?
A7670SA Not working
Blank Serial Monitor Problem
BN0085 module using my ESP32
Threaded Mode Communicate between multiple ESP's with RS485 Modbus
NEO-6m GPS gives me 0.0000 for long and lat. Is it working or not?
WS2812B with FastLED shows only 1 first led
Problem with Wemos D1 mini & Windows 11
Bluetooth Problem
exit status 1 'action2' was not declared in this scope
Nodemcu v3 lolin with 2 ch opto relay
ILI 9341 not showing data
Receiving data problem via bluetooth communication
I tried to change the blinking time but it just didn't connect, says "we can not connect"
Digi_pt_pt problem in powershell
Getting this error even after pressing boot button on esp
Adding code to a code
Stepper motor with the uln2003 board driver
New project Water tank
I have a HCM375B sensor
How to determine watchdog trigger time
Stop incoming UDP on ESP8266
Question about moving servo with voice commands
Educacion erroral compilar cod
I don't understand why I can't flash devices through the Arduino Tx/Rx
Forum screen needs a How To Post link
Designing a schematic for a ESP32 based smartwatch
Need help with motor choice
Arduino IDE 2 stalls on start
Leonardo board --Keyboard press
Problema de Conexión de dos arduinos Mega en modalidad cliente servidor con esp8266
Conectar nextion con ESP32
Can Arduino be used in professional projects?
Arduino 2.0 IDE = spyware?
Cleaning Solar Panels
RC Plane Landing Gear Problems
Code for 2 pir and led arduino
Openweather example
Communication Between Linux and Arduino
Obstacle avoiding car not working properly
Two Metal Gearmotors 37Dx57L mm 12V with 64 CPR Encoders (No End Cap) running with Arduino Mega or Mega 2560
Simulated Boards led not turning off
Automatic Dog Feeder Project 2
SD card read config.txt file to get values
Stepper motor control
LED Pin Controller Help
ESP32 Universal Project Questions/Opinions
Not able to get data from the optical encoder
Simplefoc serial terminal use
Ir Sensor + Vibrating Pad
HELP PLEASE! im new to coding and desperate for help
How can I deliberately make a stepper motor vibrate?
Automatic wire cutter with servo and stepper motor
Tengo problemas para conectar la esp32 a wifi
Error in running code. E (2244)
Encoders not counting properly
6V + Ground Car 10mph trigger light
Policy on editing a post
Two libraries need pin 2 on Nano
Prox switch delay
Transfer data to arduino via audio
Puedo conectar una pila de 12v a 4 servomotores mg995?
My modules randomly start glitching
Not able to configurate my Arduino Nano RP2040 Connect
Rtc ds1302 clock
LED capacitive touch sensor
GxEpd2: How can you use a Waveshare 10in3 e-paper screen with Esp32
Issue with depth of functions
LCD 16x2 com módulo I2C
Unable to get DS18B20 to read on Nano ESP32
CH32V003P4 - Sleep and Wakeup
Arduino UART communication with ESP32
LED's dimming mysterious behavior with Nano
Digital Stethoscope using Arduino
ATMEGA328P-AU + FT232RL USB Not Recognized [solved]
Why serial monitor not working on mobotoolls library?
Hlo pls help me as im not very good im programming iam getting an error with esp 32 programming can you fix this code
Exit status 1 error in compiling
Proyecto domotica, cerradura electronica y control de iluminacion
IPAdress problem
Fatal error in script
Can't connect my ps2 to my arduino uno
Can anyone pls help me merge this two arduino codes so that they can work together?
DY-HV8F windows vs USB
Expected HTML GET response only with cookie statement; And I can't get data for my website
Problemas con max6675 PID y accelstepper
Arduino 2.0 IDE does not launch
XKC-Y25-NPN using without arduino
Help me TCS32745 not working serial monitor ?//
LED circuit won’t function
Controling an ac ac regulator
Arduino NANO powered by solar panel
PMODNAV doesn't work
How to make like the message send water level increase 50% then water level increase 70% then water level is in danger anyone know that help me please
16 Mhz smd crystal oscillator
SPI not working on WinnerMicro W806
Two Nodemcu and LED
Help with my urgent project
I can't seem to install codes to my arduino
Adafruit_SSD1306.h: No such file or directory
ESP8266 with GSM/GPS module
Atmega328 6 digit pixel clock code need
No such file or directory #include <cstdarg>
Hi every one I use mpu6050 for self balancing robot when I Scan the element i use this program but still shaw me 'scannig i2c devise'
Micro not coming up as throttle
Testing Pin Fail
Arduino Nano OLED distortion
Relay does not turn on when I press the button
Error compiling for board ATmega32
ATtiny Run w/o Delay Two Functions from void Loop()
UART constraint between ESP32 and Arduino UNO
Unable to make my code to do what i want to, help please
Timing between 2 events
Simple project to make several lamps to light as traffic lights
MQTT Connection ssl_client error Help!
Temperature dependent time control
Ardoino UNO R3 with 3 Leds and 3 Pushbuttoms with different tasks. Need scheme and code
Please help me on this esp8266 project i't doesn't work and i'm tired
Hoping to fix school code \342 error with this post
How to add button resetting angel of Ultrasonic Sensor and Servo Motor
Talking through Arduino
POE Circuit required
Billy Bass Hack trouble
Esp8266 alimentacion
One wire Communication For 8051 TO Arduino UNO
Arduino 2.0.0 not working
Library for creating robot
TFT LCD screen does not work
SAMD Board Manager 1.6.17: Error
Need LEDs to reset with a timer
What's wrong with this as the picture shown?
Problems with arduniojson code. expected unqualified-I’d before this #HELP PLEASE#
PCA9685 how to get the duty cycles figured out for RGB
Need Help with Dim 7-Segment LED Displays Using PCF8575
Arduino uno programacion de dispensador de croquetas
Sound detector + arduino + processing
Rotary encoder pin out please (3 pins)
Sorting machine by weight - 50 $
Sensor ardoino cnc
Specific DC motor makes l293d shield really hot in matter of seconds
No port shown in Arduino IDE for my board
Need help switching to a different motor driver
Problem uploading to board
I2C issue-Arduino UNO to dim the iw3690 via I2C according to analog voltage input
Arduino Mega Relay Problem
About the discovery of my arduino on my modem router
Arduino digital I/O pins dropping form 5V to 1.2V when i connect a second stepper motor
ESP32 delay() doesn't work
I need help with my project
Controlling several groups of LEDs together
I want to make the 'void AutoRun ()' and 'void Motion()' run automatically without needing input from me
Slot car timer problems
Custom Function
Why this attitude?
Keep getting the "a function-definition is not allowed here before '{' token" error
What is wrong with my code?
How to adapt a function ?
DRV8825 & NEMA 17 Causing massive vibrations & inconsistant spin
Forum member 'ranks' ('Jackson' for example')
analogRead always returns 1023
Libraries folder not showing up anywhere in file explorer
Interrupt function misbehaving when powering up stepper driver
Condition to run void loop from void setup
Esp32 con modulo ch376s SPI
NRF24L01+ Received Garbage
Temperature Humidity Sensor
Using onboard Ethernet (KSZ8081RNB) on i.MX RT1050 with Arduino core – is it supported?
DF ROBOT keypad shield use. Programming question
Ошибка в коде arduino
Reducing the risolution of an optical encoder
Getting error on missing files or no directory
Adurino R3 coding
I share with you a project for light lamp with a light sensor
7 segment display using esp32
Analog pins not being declared with rtc, And iostream and ctime error
Code error I checked everything and didn't understand where I was wrong
Guys i want to send data from my esp32 to node js server but disconnected message appear the port and hostname are correct.i reach server from react
I'm stuck figuring this out
Potentiometer dilemma
How do I make this by using the most basic code possible?
Different Folder than I should have
HC-05 not responding to At command
Grbl 5x Arduino mega Required define homing cycle 0
Code error, mega 2560
Help with Creating a Code
AREF pin on arduino DUE
GSM SIM900A error shown when send a message
How can I control dot matrix
Calculate angles
How to measure stator current in 1ph induction motor
Help for using huskylens
RFID project scan tag or card with LED light without continuously scan
Mac Montery and library update
Two Arduino Pro Micro's connected by only one USB cable
Ideas para crear tapetes/alfombra de presencia
Problema con muestra de resultados en displays 7 segmentos cato
7 segment digital dice
433 MHz communication not working (virtualwire)
Switch case dc motor
Help me understanding how optocoupler works
I want to transmit a 1 or 0 byte with I2C from a slave to a master
Touch sensor is bugging when used 2 if statement
Simple singnal after button click to transmitter and to receiver
IR remote and LEDs
GY-NEO6M V2 GPS and Arduino MEGA 2560 problem
How can I turn on 4 leds and activate 2 servos with 2 push buttons?
Arduino object avoiding car
Signal Distortion Problem
Suddenly no response to FSRs in my project
Controlling diameter of extruded filament
RFID reader not working with LCD
Send Character into Serial Monitor via button press
Node mcu error while compile
Error Connecting to mySQL using arduino
Help me for Modbus RTU Library
Coin Pusher Help - Servo+button+led+matrix+sound
3.5 TFT LCD SHIELD ATMEGA2560 whitescreen
Esp8266 10bit register reading
I need help with arduino project
This library's only send maximum 48 bits i want to send 71 bits
How to program an interrupt code with automatic output pin
Turn on output after a count
Im new here and need help with an array
Compilation error: exit status 1 message on Arduino Uno
Root.ls found file but SD.exists dont
Fuel volume of rectangular tank using Arduino
I can't see my esp32 ip address
Error message when uploading the code
Arduino Long Switch Statement Bug?
Ardinyo123456789
Esp8266 not responding to client
How to setup Busylights for Meeting room
Help needed for Arduino guitar tuner
'mcp_can' does not name a type -CAN BUS problems
NRF24L01 module
How to Use Multiple VL53L0X I2C sensor on a single Arduino UNO
Trying to set relay up in code
How to display sensor data in to TFT LCD DISPLAY?---Add in to the attached code?
Button to cycle through numbers in a 7 segment clock
Midi sysex receive problem
PWM and PI control in dc motor
Control of PN2221A transistor
Weird RFID behaviour
L293D shield won’t turn on any motors on
Arduino IDE 2.3.3 auto format error ?
How to notify email without press reset button
SERIAL.BEGIN(9600); stops the overall arduino when typing the password in keypad
Popcorn coffee roaster
Coding cc+ pls read
Alternate I2C Using PA08 And PA09 On SAMD21 Not Working
What is it about this community?
Nanosecond delay on teensy 4.1
Arduino Nano and L298n Motor Drivers Not working
Help me to recreate this master level project
ZK SMC-01 a Stepper Motor Control switch
Help On Code, error message I can't solve. I am a noob at coding
Control de voltaje variable con arduino pro mini
Automatic School Bell
Problems with Microduino
Nema 23 Stepper Motor with tb6600 driver not moving a full step
MUX to control servos on adafruit pwm servo driver
I2C How to send the adress and a srings data
Highest frequency for digital input pin of arduino
I2c lcd with pi pico
Pushbutton and led
SimHub thinks Nano is a Simhub Dash
Serial write and read don`t work toogether in the same loop
Conceptinetics/CQRobot DMX board
LCD Left Scroll on Row 1 & Right Scroll in Row 2 at a time
Arduino IDE folder structure
ESP32 Foul Shot Keeper
Help with older version of IDE
PWM Fan control - nano
Library doesn’t show up
Point display in 4-digit 7-segment module TM1637
USB TIme out error (Python | PSoC 5) Please help me to sort this out. Why its coming?
Python and compiliation error
Using arduino to generate signals
Original comgrow robo control board
Baseball Pitching Target Project First Thoughts
DHT11 not found
Delay differences in real time example
Arduino used automobile
Arduino Leonardo Disconnecting During Sketch Upload
Lto-wrapper failed (another one)
Can't correctly get the analogRead value
Measure frequency on a power wires of frequency converter
I need a code for turn on and off led with sim800L/arduino
Which is the best blocks software?
Crashed when sending data to ThingSpeak
IR controlled arduino uno car
Controlling an LED Strip with Arduino: Example Code and Wiring?
New to arduino, need help with this code related to ir sensor and motor
Simple circuit with NPN issue
Error compiling for board Arduino Uno. (Arduino IDE 1.8.19)
Making function with parameters in ArduBlock
Storage space please help
Can't upload program but device signature is okay
DfRobot TDS Sensor Faulty Reading
Need Help on my Simple Project on LED!
Heating Elements
Turn of the Load connected via ACS712 using Realy
Could you help me with this code?
Hi I'm new to Arduino and I'm having problems with VarSpeedServo
Esp32 programming help needed
Comunicación serial entre arduino y Esp32
HS-088 Audio effect chip with Arduino
Question about coding
Multiple Sensors Working Together
Board is not responding to code
DFPlayer code help
Arduino Lifetest and Agetest
Help with Voltage to Pressure
LED button arduino
LCD1602 problem running example code
Arduino avr platform is not installing,it is showing error 2 EOF
IR receiver not working with OLED screen
Can I exit main to do some function and then come back to main without using interrupts?
DMD.h libray error p10 panel
Inverter keeps tripping
How to retrieve data simultaneous from three sensors and create a loop system?
Sim900a error, network not recognized
Inputting multiple different variables into the serial monitor
Arduino UNO with more than one stepper
Need help on a school project
Buck converter to power device
MPU6050 high Gyro value
ESP32 Troubleshooting with DIY LED Clock
Resizing a bitmap image on adafruit gfx
Uno R3 No Signal on LED for PWM
Proyecto PT100 y HR202
Error when compiling
Issue on FastLED web client, to control on and off for ws2812
Using Arduino to Switch a Power Supply For Escape Room
Ayuda Circuito Arduino Educativo
【Help】Arduino serial port input operation problem
R4 Renesas RA4M1 processor programming?
Dimming LED using ZCD
Need some help,
Need help understanding the codes of a program
About 2 led random turn on and 2 sec off
Where is the error in my code?
Esp32 with RTC ds1307 - do not work
Message in upload exit status 2
Connect / interface two / multiple ad9833 with Arduino uno
How to troubleshoot Arduino when the board is not connected
NonBlocking code
I get uploading error: exit status 1 when trying to upload my code to an arduino uno. how can i fix this error. below is my code
Cannot set com state error
Miniture RF Radar using Arduino Uno/Nano
Level Gauge using led bar graph
Calculating the Force using FSR and Wheatstone Bridge
Help with program for LED matrix slideshow
Aliens pulse rifle assistance
My code for arduino nano RP2040 connect stopped working HELP! :( #solved
Why is it possible not to declare pin as Input?
Adding more strips in one code #im really new to this
Arithmetic in function call
Arduino power issue/project guidance
Why are these buttons not working
Off Topic Still need your help 89C4051
Nucleo - 64 F103RB with Sharp sensor
AccelStepper Motor Issues
Line follower robot
Issues whith serial dataincome
Serial Plotter - DS18B20 sensor data
Compialtion error on uplaod to Arduino Nano using Arduino IDE 2.3.2
Problem with butttons and i2c lcd
Automatic water pump with PZEM-004T
Sending GPS coordinate to thingspeak using GPS module neo 6 and GSM 900a
Switch case statements
Consistent -1 return from BTSerial
Help me reduce the memory usage of my sketch
Predictive Fault maintanance project
Ready-made sensor conected with arduino
DC motor and audio amp GND interference... help needed
Need wiring diagram for 5pin LED strip
Hilfe benötigt bei Pedalbox programmierung
Program works connected to PC but not battery/bench
How to take analog signal sample at one perticular period
Wrong reading of voltage by analog pin
How to power a 60kg servo
1-channel 5V 30A relay module wirings and cose
Designate TX pin for character transmission
Why the "River water level has reach 50%" sending too many message but others send correctly one time but only this message sending too many time
Press the button and blink differently
Control de cuatro leds, por medio del monitor serial ingresando cadenas
Esp32 Object detection camera
Using 6 x MCP23017 Issue
ESP 32 error compiling board
Best imu with sensor fusion
Error void value not ignored is it ought to be
Using two or more Voltage sensors for recording Battery Data
How to change/increase data rate of ADXL345?
I need help I keep getting 0 cm
I need some help in my fingerprint project
Sonicsee project, that explains to the deaf what the lecturer is saying
Compilation error: expected constructor, destructor, or type conversion before '(' token
NeoSWSerial - how to use my own PCINT?
Python to arduino serial communication to run stepper motor
Why arduino mega is not port
MAX30102 lowering clock speed
I was running this code and this error appear "TypeError: Failed to fetch
HC-06 disconnecting when servos using
Emotiv Insight tutorial
Combine two codes in one for a solar tracking system with voltage and current display using ina 219
Data not transmitting between RF Modules
Connect to Arduino NICLA SENSE ME via Bluetooth
How can i write tempature on lcd screen?
Help with void loop and setup , everytime it pops error
Error message when trying to compile sketch (In file included from.....) (fatal error: functional: No such file or directory)
Need help with TSL2540 light sensor libraries
Using a SD-Card with an ESP32-S3-DEVKITC-1 on HSPI
Project - Alarm of helpers in the use insertion at a power failure
Robo r1 plus 3d printer
How to declare dinamic size String Array?
Stepper Motor will only go in one direction
Double Relay and motor issue: URGENT
How to program a photoresistor to input an LCD display
Water Pump is always on
Controlling a sensorless BLDC vibration motor
Pro micro showing button press when not pressed
ESP32 Wifi Server Receiving Data and Acting on it
Can you help me with this simple button circuit?
Can someone help me with take the time of the event in to code calculation
SRF08 in Arduino
Expected '(' before '{' token
MOSFET in open collector configuration
How to read sensor value (analog read) from arduino to processing ide?
Won't transmit a message after after servo rotates from water detected
Very weird NRF24L01
Problem sending UDP message
AD9833 y servomotor
Unqualified ID before void
Does anybody know whats wrong with my code
Alarm system coding
My Keypad Sends something and doesnt stops
Can someone pls correct this code
Compilation error: a function-definition is not allowed here before '{' token
Laptop Freezes/Lags when powering BTS7960 (DIY FFB Steering Wheel Project)
Solar Inverter communication with max 232 not work properly for all inverter
I have connected my stripLED connected to a pin set as an output and I would like to control it with 3 or more pin inputs and I couldn't. Help me
ESP32 keyboard help
ArduinoFFT library Compute returns NAN on NANO
Need help to configure LED running by preesing switch
Why does my Serial Monitor print per character to the next line?
Sync Back MQTT using ESP32 and SD card module
Arduino Uno and Quectel EC25
Transmit LTC TimeCode SMPTE over distance
Weight sensor triggered display
RGB Led Matrix 32x32
Dual solar tracking coding using 4 ldr , 2 servo motors, arduino
Stepper run and return HELP!
Error while interfacing SD card and Arduino Nano ESP32
I2C LCD display not working
MosFet H-bridge motor control confusion
Dissolved oxygen is reading negative values
How to get an Arduino to send data over WiFi network
Errors measuring voltage
Need help with project
Running Away Alarm Clock w/ a Motion sensor
Problem with domain maximum/minimum for loop
How to Send data from Arduino Nano 33 BLE to BlueLight
Coding stepper motor to specific position based on ultrasonic potensiometer
On/Off/On switch and Stepper Motor
Unable to upload sketch
Hello everyone, I have a question that needs help. I am using the Ubuntu 22 operating system and am configuring the esp8266 development environment. I
Board is not detecting on com suddenly and the board is unoq
Guitar input with op amp not giving output
Arduino and dimmer nativity lights
Implementing PID control using Timerone library
Controll of a motor via wifi (webpage controlled) - can this project be modified?
Connecting sd card and bmp280 via spi interface
Pololu High-Power Stepper Motor Driver 36v4 with Arduino MEGA
HardwareTimer.h no such file or directory
Mosfets and arduino
Unipolar: Bipolar In1:in2 Step & Dir
Nicla Voice Code
I cannot compilate the code
Resolution for error
DS2408 onewire plantage compilation
No me deja iniciar porque?
Voice controlled car project
SG90 Servo Problems
Powering Arduino nano with 18560 battery
Trying to connect pH sensor to esp32
Vacuum fluorescent indicator
IR and smoke sensor for protenta h7
Help me fix this error
What Arduino module can I use to create a 1-meter wireless key?
About sender receiver system
Waveshare Barcode Scanner and Arduino Uno
Adding USK guide codes to Arduino ide 2.3.2
RS232 to TTL uart convertion not working ?
HMC5883L Giving Constant values
Unable to connect STM32 in arduino IDE using bootloader
Millis instead of delay on array of ledstrip
Connecting arduino mega to sparkfun mp3 shield
Calentar alambre de nicrom con cargador de 12 volts
Code error need help
Using Arduino with IRMP to send Mitsubishi Heavy IR protocol
Copy from Serial Monitor - absolutely need solution
What causes my SHT41 to stop working on ESP32
Arduino MEga and dfr0258 and softwareserial.h
Problema con bucle LOOP con matriz led 8x8
Booton box con Arduino Leonardo
Voice recognition module V3.1
Error de Interrupciones caudalimetro
I need hekp whit a problem whit compilations
ILI9486 setup with Arduino MEGA 2560
Sim900a only power led is blinking
Using Servo with GPS module
At comand at gsm900
Guys need help with GY 87
64 Band Stereo Spectrum Analyzer
Juego de rapidez
Print to serial when button pressed
ArduinoBlue App receives but doesn’t transmit
Project that needs radio and remote control
Arduino Uno and 5V Pump without Relay
Unsure how to remove visual aspect of Processing to move project to Arduino
Using Arduino Mega as a Joystick
Arduino Uno 3 way security door lock need help
Problem uploading to board.
How can i fix this error?
Arduino mini pro and nrf24L01 not working plaese help
Problems with arduino uno R3
Reverse loop for model railway`s
Using TVout overlay and PS2keyboard
How to upgrade SI4732 Board from V1.1.5 using Arduino IDE2.1.0 ?
DS1302 based Relay control
Faster digitalWrite
How to Strobe a High-Voltage Light Using Arduino Portenta?
What is this error message and why am I getting it?
L293D output current drop
Removing Sensor Shield V5's V-in pin
Arduino mismatch error
Control Arduino Pins from C/C++ program on PC
Waterlevel with php
Thermometer missing files
SE05X encryption?
Disgusting treatment on this forum
Cursor setting and edit float value
Why doesn't the HTML source apply?
Easy way to read selected bits from byte
LCD light up but did not print out anything
Windows could not find drivers for your device
NodeMcu Firebase Json get data
Motor dc transistor
Problems with my code
Detect key press while running algoirhtm
Please modify the code , stepper motor rotate one direction please modify the code ,when pin 4 ON then stepper motor rotate backward direction
People counter keeps counting add LEDs
How to control ESCs
Error on uploading code
Cannot upload to Arduino Nano
Upload to "Moonpreneur" Uno fails: "avrdude: ser_open(): can't set com-state for "\.\COM3""
Troubles setting up a connection between 2 HC-SR04 sensors and nrf24L01 WiFi module, getting nan on Serial Monitor
How to power an ESP32-S2 AND 2 Motors from the same battery
New beginners kit cant seem to get working.
Does SoftwareSerial support pins 20 and 21 on Mega2560
Upload Error
Arduino 2560 with hc05 no AT commands
Fixing the loop in my code
Automotive integration. (insight and advice for a newcomer)
Upload to Arduino Nano
Trigger Time Delay Relay
Weight with SIM900
MKR1000 Port disappeared
Quien tiene un sensor de ph, especificamente un modulo de ph 4502 que me pueda ayudar
Serial not printing anything
Dual I2C device issues
Esp32 doesnt work with ssd1331 Oled
Problem with firmware
New PC: Setting processor to "ATmega328P (Old Bootloader)"
Problem Uploading To Board after big sur
Problem with SIM808, locating, Arduino
Arduino unable to upload code
RS232 to TTL converter help
Whyy can't our location tracker send a message to the phone number registered?
Code gives unwanted triggers
How to make 1 command be interpretted as multiple
Find detailed information about the fuse bits of the ATmega 168 microcontroller
Is the 5 Volt Pin of the micro short-circuit proof?
Arduino Reaction Lights
I want to understand why its necessary to put (y>700&&y<800 )
Editing sketch keyesstudio micro
How to communicate the IMU sensor with esp32 via SPI communication
Hello all, I want to use PID controller in Arduino. I have to use temperature sensor and in output I wanna use Peltier
Nano+servo stop working
Arduino UNO R4 WiFi is bootlooping
Is The Arduino Create Agent Need?
How to print the content of char array?
Conector trrs esp32
Please review this circuit diagram
Ctcss issue with code
Rs485 soil sensor code needed
Need Help with Arduino Code Errors
Control manual y automatico
Can bus project /// i need help
UNO analog pin not reading zero when grounded?
Voice recognition module v3.1
Steppermotor turns not every turn the same distance
UNO r4 Wifi issues when exporting
Drone Arduino Code
Rtc ds1307 and relay modul for arduino uno
Servo speed HCPCA9675
Interfacing Arduino with the the adc mcp3461
12v Proximity sensor alarm
Error connecting to blynk app
Obstacle avoiding on smart robot v4 using neural network
Attiny841 Bootloading Issues with Arduino Nano
ESP32-S2 RS-485: Error de lectura ModBus Slave
I am creating a project using arduino nano, ESP8266 and DPS310 sensor. I uploaded the code for the same but the serial monitor wasn't displaying
Variable zone/relay Timer
I want a help regarding colour sensor
Officially ban ChatGPT and AI
Como conseguir lo mejor de este foro
How to use ELRS Receiver with Arduino?
ModbusMaster library. Poor performances?
Tft screen and rfid reader failure
analogRead() only gives gibberish unless the A1 pin is connected to an Arduino 5v or ground
Combining IoT Variables
Rc car 2 inputs 1 output
Burning bootloader
HELP, i cant make my 3 servos work
Trying to get automation on a global server, but getting lost
Combine Sen0321 and bme 280 but can't get the data
PLC Siemens S7-1200 y Arduino con ENC28J60
Commenting out printLn breaks program
IDE hangs on startup: "terminator_CreateInstance: Failed to CreateInstance in ICD"
Esp32 rfid real time to mysql
Troubleshooting [Arduino UNO + CNC shield + DRV8825 + steppers]
How to Fix this Arduino Car
Invalid readings from DHT11 sensor
Unable to flash ESP8285
Register a kit gone bad
5x2 Button Matrix With Diodes Doesn't Work
TFT_eSPI printToSprite issue
Putting Arduino under snap on UBUNTU
Running Stepper Motor
Program intermittently freezes after relay is energized
ESP8266 and IoT Cloud Help Request
¿Puedo alimentar mi ESP32 con un regulador 5V - 3A?
Sketch won't upload to Uno, programmer is not responding
How to control a servo motor with potentiometer using PID
Control temp. Meter
Saving stepper motor position with corresponding RSSI value
Help Arduino Compilation error: expected initializer before '.' token. Can any body help me with this
How to rectify this error on esp8266 program for smart farming ?
Nano Serial not working properly
Estara una led encendida al presionar el boton se apagara y prendera el otro led de misma manera viceversa
Solar charging assistance please
Preprocessor Array command creates confusion
4 button's to control 4 relay's
Help with LM3914 resistors
Try to do different things when press push button in first time and the following times
How connect 7 semgent display on ATMEL
Atmega64 not working
How do I use Modbus (TCP) to read PLC's 2word Data?
Ds-co2-20 CO2 sensor
Wel/niet op WIFI ESPC#
Problem whit the code
Help with Stepper Motor and TMC2209 - Microstepping Issue
Brushless motors
Arduino Nano ESP32 no output voltage
Need help with a project
Arduino protogen issues
HI I'm new. I am working on a iron man helmet
Oled clock with pulseoximeter and thermostat
How to install https://github.com/esp8266/Arduino in to Arduino IDE
Enable Pin TB6600
Need help with arduino vending machine
How to Read Speaker values from some device to use as if function
Button-led lights code in project
Keep Frying Boards!
Program showing error
Micropython modules SDcard, USB host and Ethernet missing
I want to get data using Arduino Uno, MPU6050 and SD card
ST7735 touchscreen issues
Need help with motor driver
Joystick jitters
Esp 32 and Fingerprint sensor R307
Sevseg kamu sama dengan aku namun saya susah mengatur desimal nya
Infinity loading
How to Stop BLDC Fast
How to use this forum - please read.
28BYj-48 motor on A4988 returns to int setting
'void LiquidCrystal_I2C::init()' is private within this context
Measure pH, conductivity, temperature, humidity, nitrogen, phosphorus, and potassium using the JXBS-3001-RS485- SOIL SENSOR
Linear Actuator setup help needed (time delay)
Wiring help for project
Vision artificial con arduino uno q
Error adding floats
Millis() won't work with Adafruit NeoPixel library
DC motor, servo motor, & ultrasonic doesn't function at all
ESP32 TTGO TFT_eSPI TDisplay
RC combat wing servo mixing and hardware
Input activates when touched
Wiring a display and mpu
Suggest me a budget-friendly soldering iron & SMD station for prototyping IoT device , soldering QFN, BGA etc
"While" Command
Compilation Error
Jittery encoders on certain ports
Feedback on PCB Design
Struct and setSyncProvider (ESP8266 NodeMCU)
Nema23+tb6600 what code do i need to change
Can the ESP8266-01 send data to thingspeak?
Error verifying code for Mega on Arch Linux
Exit status 2 error message Arduino IDE
How to send SMS with Hc05?
Timer program not working properly
What do you think of this circuit?
"While" Command
Arduino Detecting Wrong Button Press Randomly
getMedianNum is Error! Can someone help me?s Can some one solve? I add code already
Esp8266 nodemcu onboard led help me
Help to continuous run the ultrasonic even the car was turning right or left. Becauses when the car is turning right the ultrasonic is stop scanning h
Arduino not working
Distance measurement through laser transmitter module or laser dot diode module
My code does not work i'm working on making the piezo buzz and led to light up, whenever my servo turns
How to combine 3 different sensor into 1 program and start the program by using one Button , this is the program i created but it seems cannot work
TinyGPS++ Altitude problem
The code is not working even though it loads correctly
Code. Help. Please
Consejos contra interferencias electromagnéticas con Arduino y otros componentes
Little yellow display esp32 NVR storage issuse Fixed
Arduino Leonardo is disconnecting from pc in a few seconds
BMI160 board orientation problem
Turn on and off an output for a specified amount of time?
Arduino uno Keypad with lcd password project
Need Help Writing Code for watering system
Arduino on comX but cannot choose port through Arduino IDE
Can not set radio.setchannel()
Arduino not working
Laser tag board paired with Arduino
Newbie feasibility question
Problem with some sensors but not motors
Unconnecting usb
Seeeduino xiao with hc-05 bluetooth module
Lavado LG inverter
Arduino lcd I2C
Giga R1 /Display bundle
Need too Modify a code
Coding Help! Project with IR, Servo, DC motors and ultrasonic
Web JOYSTICK (need to be fixed)
Incompatibility between libraries ELMduino and adafruits?
[Closed] How to build a remotly controlled winch?
Hi guys, need help with code for stepper motor and keeps coming up with stepper not in library
To program output on and off
Why does SPI turn on the built-in orange LED?
Help! Program for my final project
Arduino-project with color-sensor and rgb-led
L298N Motor Driver with uneven voltage output
Proximity and light sensors Amperk VL6180. Incorrect work with the multiplexer
First home project (newbie)
Arduino Voltage Capacity
Transmit on power up
Frustrating not being able to fix "A fatal error occurred: Failed to connect to ESP32: No serial data received" error
Arduino using leap motion controller
IR sensor trouble
Codes for Education Starter Kit - HELP
DMA Stream to PWM configuration
Low-Power by rocketscream does not work
Arduino Uno resetting itself in specific situation
Can message and mcp2515. I got this from one of the examples for MCP libaries. https://github.com/coryjfowler/MCP_CAN_lib
Arduino Heart Rate Sensor Problems
Connecting Arduino r4 with thingspeak to transmit data from sensors
PCan I program the Arduino Nano 33 BLE Rev2 without having to learn Python?
Arduino program
Webserver (Mega, W5100, include html/css)
I am having error. "Compilation error: redefinition of 'RH_ASK driver'" Any suggestion ?
External power for Sg 90 micor Servo motor
Compilation error: "avr-gcc: error: CreateProcess: No such file or directory"
In my recent project I am trying to use 2 servo motors,dc motor,colour sensor with the help of nodemcu but my motors are not working.what to do?
How to send 512kb of data from stm32 to esp32
Help on coding/wiring a GEARS IDS II and Air cannon
Scrolling text line on Jhd12864E Blue GLCD using openGLCD
BN-880 GPS and Galileo
Document forum post markup
Voltage drop with parallel digital output
Json no such file
Unspecified IDE problem
Attiny85 Battery Tester
Arduino Code 5 motors with 3 boards LN298N and ESP8266
ESP-01 Compilation error: exit status 0xc0000135
I'm having trouble using a TCS3200 Color sensor
Admin Arduino IDE
I2C - Acknowledge and Clock control
Determine the transfer function of dc motor of an arduino?
Software for MAX30100 and MAX30102
Can I have two functions that will be executed based on how long the rfid card is present at the scanner
Fallo con carro Arduino por corriente
Absolute Pressure sensor for SPL Measurment
Yikes! while trying to upload using programmer
Interfacing HB100 Doppler Radar with Arduino
Arduino's Analog Inputs Not Providing Accurate Readings
Programming error
Arduino Nano ADC
Arduino Micro Board Smoke
Why I need to use write() in here
Uploaded blink file from example but no results found
My code gets stuck uploading
Elegoo smart robot car kit 4.0 with camera
ESP32 , arduion iot cloud , after puting ESP32 goes in sleep mode , how to do OTA updates
Mmwave sensor in Arduino uno
Arduino FFT for audio spectrum analyzer
I'm having trouble reading my sensors reading
LCD problem : increasing power of 10 when reading dips below 100
Slow transfer of data with bluetooth module HC-06
Hola buenas tengo una duda sobre el uso de servomotor
Controlling a momentary switch with an on off switch
I got ban from the discord without any reason because of an angry mod
Codigo de arduino de esp32
TensorFlow Lite Micro on Arduino Uno – cstddef: No such file or directory compilation error
Cannot get simple programme working
Optimization Help for Ohmmeter with Modbus and OLED Display on 16 MHz Arduino
Help me merge this two codes together pls
4 semaforos conectados por bluetooth
Trying to create a smart bike lock whats wrong with my code/circuit
¿Cuanto vale el envio hacia argentina
Arduino GIGA R1 Wifi joy stick button issue ERROR code Compilation error: 'USBJoystick_' does not name a type; did you mean 'SysTick'?
16x2 lcd screen crashes after a while
Auto sensor switiching
Arduino_TensorFlowLite library has been declared as precompiled:
6DOF GY-521 3 axis #hardware
Receive & Send OSC data to ESP 32
Arduino ide code for edge impulse esp32_contineous using esp32s3 devkit c1 and inmp441
PC communicate to arudino via the usb
'_circularBuffer' does not name a type
Arduino Pro Mini and NPK Sensor
Need help to factory reset by hardware
Lights code problem
Is there a best pin's for thermistors?
Help uploading my code
Random number on a certain group of numbers
PPM Sensing Issue
Problem installing LiquidCrystal_I2C.h
How do I add L298N and L293 motor shields to the parts list on Arduino IDE so I can simulate and test wiring for my design/programming 4WD Robot car?
Problemas al mostrar datos en LCD
Automatic Cat Feeder
Custom Joystick like bluetooth device connect to VR Headset
I2c : possible to manage multiservo-modul and lcd-panel ?
SD Card Issue with 4x3 Keypad time input
Temprature finding device with arduino uno
Flex sensors problem with arduino uno without breadboard
Three phase current monitor
Código semafóro com bot para Pedestres - ajuda
Alguien me puede ayudar en mi codigo al momento de compilarlo me manda error y no encuentro la falla
Connection of Cardinal 205 to Arduino via Max232
Serial monitor Stop Working
Sequencing Events
Plz guide code that Aruduino MEGA can read from ADC converter
Code modification for measuring Heart Pulse Rate with MAX30102 pulse sensor
Heat measuring device
ESP32s3 and BME680
Help me to convert this fuzzy rules into Arduino IDE base on code i found on web
I am getting error while compiling my code "expected primary-expression before ';' token"
Nextion page value update (EasyNextionLibrary)
Control Relay With RF Controller
Hand positioning with IMU
Multi character constant
Need direct non-invasive flow sensor (<$500) for project
Why doesnt my simple UART code work on ESP32?
Trouble with SPI on custom PCB with SdFat
White display on ILI9341 red board
Sensor for car lift
ESP32-CAM only works while GND jumper is being pulled out
Boat Motor Control
How to connect my mobile device in arduino cloud?
Njw1153 project emergency help
Controling Ultra Torque Hi-tec Servo motors using Arduino
NRF24L01 Module Not Responding - No Output on PrintDetails() or Serial Monitor
Arduino Code Problem!
Instrumentation project
DMX library for Arduino WIFI MKR1010
Servo Control with a traffic light system
MCP23017 Not Working
Arduino code will upload on the board but will not run
Overcurrent in motors driven by IBT2
Help implement RS-485 Modbus on Schneider PM800 on ESP32
Error 13 Arducam_ESP8266_UNO
MAX30100 sensor does not work
I think it would help a lot of people with the same idea as me
Esp-wroom-32 doesn't connect to arduino 2.3.1 windows 10
Here all works well except "delay(1000); digitalWrite(REY, HIGH);"
Error to many arguments in function
USB MIDI from scratch, how?
How can a transistor help and Arduino from getting fried
Retaining a variable in the loop & General code
Estado offline placa esp8266 de arduino iot
Keypad y matriz 8x8
My Motors work differently
DS3231 RTC Question
Problem with IQS7211A and ESP32 while using Wire
What is lap winding
Arduino R3 ,L293D and Brushless motor (Include EsC)
Using an MPU6050 to stop a NEMA 17 stepper motor from spinning
NodeMCU esp8266
How to get tsop arduino
LCD + Water Senser
Having Issues With Blender Talking To Arduino
Turbine type Flow meter give incorrect flow
Hid device programming help
Firebase doesn't receive any updates !
Unqualified id error message
Arduino cloud iot master slave
Exit status 1 - keep getting this error
Fsr + servo motor
Multiple Sensors on GND and 5V
Reutilizar placa de volante para play 2
Control 2 servos, 1 pot
Initialization of the optical flow sensor (pmw3901) failed
External clock/xtal not worked in atmega328p-au 32 pin MLF package
How to get the best out of this forum
RS485 - Arduino
How can I check the output of my code using Arduino IDE and ESP8266 when I want to display the data to a large 7-segment LED
Data Transfer via SoftwareSerial (different Bautrates?)
Read Multi-Signal Pulse-Position modulation using Wemos D1 R1
Comparator not working without Serial.Print or a delay - but works in other areas!
Printing to serial is not as expected
Arduino Uno with Bluetooth HC-05 is not showing the results from sketches
Arduino and AD5206
Troubleshouting my sketch
I need help with i2C code
GigaR1 USB filewrite
Problem Connecting JXCT RS485 Soil PH sensor to Arduino Due using RS485 to TTL Converter (Two Way Converter) Transceiver XY-485
Slow Upload for IDE
I can't manage to send data (a number) from Arduino to Nextion
Aplicar Tarjeta Arduino letrero de despalzamiento led
What is the lowest power ESP in sleep mode
R307 Fingerprint error
Aurdino Skipping some statments in the code
Oppo a17 a Arduino
Analog input to Simulink
LiPo Fuel Gauge Lithium battery power detection MAX17043
Bend labs digital flex sensor 1-axis setI2Caddress
Delay between arduino and nextion display
Arduino due with Wi-Fi Nina W132 module
Is Arduino used in each and every robot?
Arduino Micro -- windows 10 driver?
Weather station project
How can I make alexa discover devices made by Node MCU ESP8266
Cable harness tester with 3 connectors (<30 test points)
Help with juice dispenser
High school robotics project – when does AI actually add value?
Bulding a dump truck using arduino uno
ESP32 Bluetooth Control Motors
Sketch works on Uno, but not on unknown ATmega328 variant
Multifunction robot not working
How to connect two MPU6050
Pca9685 16 channel servo board Questions
Ship style radar display
Squared numbers giving back strange results
Can any one help to correct this code its repeating backward forwar turn lef turn right
Arduino UNO R4 has been released. Do you know when these development boards were released?
Flowchart for school
Steppermotor left right and stop
Envio de tramas por UART de forma incorrecta
4stepmotor with arduino and Accelstepper
Lora BLE bridge
Guru Meditation Error : Alarm codeing
Serial port not available on Mac OS 15
Is it possible to use the arduino library in php?
3 floor elevator
J1939 Message Transmission via MCP2515
How send data to Google sheets using GSM module
Error message : Testing the MATLAB-Arduino USB Connection
Pedal board diode output wiring
Why can't I connect my IR Remote and my oled
Esp32 gets eaten by a monster!
Controlling a 3-Phase Brushless DC Motor and Motor Driver
Help writing script
Radio frequency modules reliability
How do I connect to Bluetooth 5.1?
SD stop after reading and writing a few data
Memcpy or alternative
Biblioteca adecuada para ILI9488
Que tiene mal este circuito, que se prenden las luces?
Creating enhanced solution for bicycle-based warning system
How do you keep track of the position of the servo
Need help with wiring
Error compiling my code
Are bug reports still being taken for IDE 1.X?
This code can not show case 3 and 4
Edge detection on a DC motor
Smartwatch señal
Base de datos con lector rfid en arduino
Python support?
Send Data Nano 33 Ble (peripheral) to esp32(central)
Arduino uno step motors
Sending message from cell phone to PN532
Detectine raindrop and notification me
Variables not declared in this scope
Error expected unqualified-id before 'if
ST7789P3 2.25" 76x284 TFT on DOIT ESP32 DevKit V1
One DC motor is running alone
Content is deleted
Ethernet Shield Fixed IP
Four micro linear actuators simultaneously control in the opposite direction
Is that possible to make a Lens free microscopy system using Arduino?
Datalogger visual studio
Code mixing RH_ASK & BLE-Keyboard failed
Voice recognition v3.1 no se entrena
Direct Port Manipulation Using the Arduino Giga Board
ESP8266 mini (01) is always crashing no matter what
Sync two arduino boards
Analoge waarde opslaan
Compiling error windows 11 - only !
Using ACS712 for VFD
Help me make stethoscope based on Arduino
Set the default relay turn OFF state into 3 seconds
PAC9685,I have used many test codes, but they all failed, I don't know why
How to connect ultrasonic sensor to run pump and measure speed
Problem Adding Additional Transducers to Single Set
Sound simulation
Bad Sketch Prevents Programming in Arduino IDE
Configuring Arduino Nano
Too big g force values even though it's just a little touch(using mpu6050)
Problem with ArduinoJson and UniversalTelegramBot
ESP32 - MAX485 Modbus RTU communication
HTTP response code with -1
How to subscribe to multiple topics at the same time in callback when using pubsubClient library?
Arduino Uno watering system with moisture sensor
Trying to connect my esp8266 (Wemos) to my socket.io server
Help, beginner with almost 0 knowledge
Oops I'm having trouble posting
Request advice on amplifiers for an illuminated wireframe
Need a help with multiple matrix coding [solved]
How do i get a arduino uno to get a stable 500khz
IDE always unnecessarily offers application update and fails to install libraries
EsP32 C3 mini in serial communication not transmitting value
Controlling seven relays one by one
Arduino input lag when building DIY gaming controller — how to reduce delay?
Need help for uploading
How to stop a loop playing on power up
Code not working properly
Pre written code for simple traffic light won't verify or download
A4988 Vref is way too low
Item-locator using arduino
My hc 05 bluetooth module isn't working at all
Problems with PulseSensor_Playground libraries
How to control current inverter on grid
BT car project kinda working
Sending data from arduino uno to ai thinker esp32
Why Is My Arduino Code Not Producing the Expected Output?
What is SAMD11?
About the Getnumber() library
NRF24L01 issues and won't work for whatever reason
Need Help with IR Remote Model Project
Halloween Eyes project issues
Using a TB6600 stepper driver instead of a TB5660 programming difficulty
Chevron Safety Signs
No se de que sale el error
Flag led matrix
Building a cordinate system on robot under 9V
Lectura baja en sensor DHT11
I3G4250D Only Spitting Out Data At Random Times
How to control TENS with ESP32 using PWM?
Uno to Nano 33 BLE code issue
There are many ESP32+TFT board,
PCA9685 not taking external power and code not working
Arduino cloud scheduler issue
Library problem which is not recognized
Application Image
Data from plc to arduino with enc28j60 module
CH32V003 Timer Issue
LCD Cant Write "O" and "o"
Send RFID Reading to phpMyAdmin
Send data online using ESP8266-01 and arduino every 2 hours without using delay
Teknic Clearcore with Arduino wrapper rotary table
Ili9488 a Arduino mega
Uploading to pro mini fails
Flickering too much ... help! SSD1351 128X128 RGB OLED Arduino UNO
CNC shield with A4988 not supplying enough current to the stepper motor
Arduino tft screen problem
How to feed data to multiple i2c masters
Keyboard open source program
OV7670 with Nano33BLE - inconsistent test image
Can the Raspberry Pi 5 compile/accept the Arduino Cloud Create Agent?
Controling servo speed by slider
I2C communication btw esp8266 and arduino nano
Are there websites or apps that support LoRa Shield for Raspi and Arduino?
RFID-Relay-need help
Phase shift between Pins
Hulp gevraagd bij het maken van een module
Help for control W-24BYJ Stepper motor with Arudino uno
Portenta H7 not connecting to iot.arduino.cc
TM1637(4 digit) not working in atmega328p(basic circuit 16Mhz)
Developing a Land Surveying rover using arduino?
Brazo robótico con sensor de proximidad
Esp32-cam and neo6m gps and Arduino connection
Feedback Voltage not being read by A3
Arduino device to control AirPods
My program is not running
Problems driving 4 motors with L298N and Arduino Mega
SIM7000E Arduino NB-IoT / LTE / GNSS / GPRS / GPS Expansion Shield with Arduino
AccelStepper library, stop() function
Has anyone successfully used the the keyestudio 8266 module?
Intento de controlar Matriz 15x5 WS2812b
Shift Register Outputs Flicker During MCU Update
In a circuit with Arduino uno,we have a 433Mhz Transmitter, pir sensor, Light dependent resistor and LED. Can you help me bring up with the calculatio
Building a Time delayed winch
Ds3231 RTC coding
Need to display text from keyboard to Monitor screen
Avrdude: ser_open(): can't open device "\\.\COM5": Acceso denegado
Download drivers
Help me Control temp system
Problemas Con Interrupcion Sensor VL53L0X
Need help publishing data from thingsboard and receiving it on arduino
Code running on USB power but not battery?
Controlling LED brightness with MCP2004
How many components can be connected to arduino uno?
How to connect several modules to arduino
Pass source path to bootloader
Issues in server.begin
My arduino uno stop looping after a random time by it self
Star delta connection with display
Arduino does not connect right
Clone nano not working
No Output from digital pins
Code problems with servos
Problem reading analog inputs with nano
Mix python code with arduino c code in arduino IDE
Modulo Neo-6m V2 pisca mas não passa informação
Usb midi control to arduino with midiusb?
Can you control 4 LED strips (WS2812B) with the Arduino Uno?
What to do while the error occurs What to do while the error occurs while connecting lm393 speed sensor via arduino and Arduino IDE 2 2.1
JAWDUINO con arduino NANO
MPU6050 angle only between 0-90 i want only Z-AXIS should change
Simulador doppler fetal con arduino Uno
Pls help me stop a RGB led loop
SD Card confusion
MQTT payload comes with extra stuff from Home Assistant
Not getting MQ2 sensor value
Problemas con la pantalla usando arduino 2.8 tft spi 240x320 v1.2
I am geting error
Detectar movimiento con un sensor ultrasonico
RFID 125kHz scaner
Problemas con Attiny85
I could use an outside point of veiw
Help me finish writing the code to a working state
Arduino mega SMD board
PN532: Problem with wire connection, libaries and sketch
Arduino with 7-segment display and potentiometer and display is flickering
Consecutive digital inputs trigger output
Can't Break From While Loop
How to control nema 23 stepper motor with driver TB6600 via bluetooth
Cloud Editor Serial Monitor Not working
RF-Nano communication with RF-Nano
[closed, it was a hardware problem] About Shield motor driver l239d
Solucion de un problema
Arduino UNO : digital outputs
Incompatibility with BluetoothSerial library on LilyGo T-Display-S3
Galvo control with esp32 arduino
Programer's responsability not compiler's
Ws2812 troubleshooting
Esp 32s servo not working correctly
Interrupciones arduino mega
ESP32 - What board package is used?
Proyecto Arduino UNO (Maceta móvil con sensor de humedad)
Very new and making wireless and remote controll stuff
Sensor Canon MG2470 MG2570 MG2570s
How can I structure a quadruped robot dog on an Arduino UNO Q (App Lab) to follow specific people? I'm looking for opinions and ideas on this architec
WeMos D1 R1 and NPK Sensor with the use of RS485
Arduino does not open on Macbook M2
Can I program Megawin MG82F6D17 Microcontroller with Arduino?
Hii I am a new user to the community
I have problem in uploading. The code is correct but it tells done uploading but not uploaded
Digital read from switch not working
Buzzer multasking
Esp32 error the std vector
Arduino uno da yeniyim şu hatayı alıyorum
Only DHCP works
Steper motor not moving continuasly with rosserial
What are these resistors called and where can I buy them
Esp32 and Gps Neo 6m Firebase
Trying to figure out power for a Quadruped Robot
Water pump and strain gauges with arduino
Code compilation error in arduino ide 2.0
Compilation error: expected ';' before 'delay' bu hata nasıl düzeltilir?(TR)
Arduino MKR 1400 GPIO current not enough for relay
LCD I2C doesn’t display words
Exit status 1 problem
Connecting the UNO with the elechouse vr3 and L293 adafruit driver to move 2 motors by voice commands
EMG over BLE doesn't give the expected signal in time domain
Flowrate from Pressure in xgzp6897D
Esp-cam [failed to acquire frame]
Azimuth and elevation angle using solar tracker
Es posible conectar de manera simultanea un shield de usb y un shield de ethernet en arduino mega ?
Handling of sketches in IDE 2.2.1
Evelopment and Evaluation of an Arduino-Mega based Active Noise Cancellation Device for Indoor and Outdoor Environments
Negative pressure, no response to touch on X/Y axis ILI9486 ESP32 [SOLVED]
Pulse sensor playground
How to display Date in Scrolling Text
Arduino UNO R3 with MAX30102 sensor and 1.3' OLED display showing Incorrect/No values
Driving a display
Number of Ultrasonic Sensor HC-SR04 Connected
Arduino Uno Wifi Rev2: Serial monitor
Why this nibp program can't control the circuit properly
Esp32 camera connection with arduino
Giga Board lost connection to my laptop
Avrdude in uploading the code with FTDI
Rotary encoder not working properly
Multiple switches with different resistance
How do I make a connection to a host server that has been deployed on a service such as GCP or Railway?
Tuning Internal Oscillator of ATTiny85
Ivalue required as left operand of assignment
Using servo/bluetooth/sensors with different timer
How can I make a specific button run a specific loop?
Where is the Problem in this code?
Problemas con motor y Driver L298N. No trabaja con PMW para manejar velocidad
Exception shown in Serial Monitor when running sketch on ESP8266 board
Gauge temperatura
Sensor de temperatura transistor lm317, 3 led y pantalla lcd con modulador i2c
Hola buenas, quisiera saber en que parte el codigo esta mal redactaeo o donde hay un problema, ya que no encuentro el error
Proyecto para niños sordos
Driving a display
Cannot Resolve Include Paths in PlatformIO for GuruxDLMS Library
ESP32s soc.h problem
Expected initializer before spring
DST with NodeMCU
TB6612FNG driver - i dont get voltage
PID coding using motor driver and voltmeter
Solenoid Valves
Adding delay to sensor
Problema con analogRead
Arduino nano con ch340 causa pantallazo azul
Setting up the Duinotech UNO r3 Main Board with Wi-Fi with ESP
Help combining 3 codes
Error compiling for board NodeMCU 1.0 (ESP-12E Module)
I have just a little problem
Why adding another comment line causes compilation errors?
ESP8266 Reading Google Spread sheet return Null
Ch552 sdcc callback passing values
Project discussion : water level indicator with auto cut off and purity checker
I dont know if my arduino uno is hitting code limit or power limit
Traccar GPS Arduino example error
How to achieve 1km Non-Line-of-Sight Wireless Communication without Internet
HELP! Simple MIDI Buttons and LED's sketch
Why arduino uno reads high or low at digital pin after reseting the board
My two hour delay code only delays seven minutes
TMC2226 Driver Current Limit
The capacitor on my Arduino overheats
Mkr wifi 1010 not recognized
Cálculo da velocidade média com dois sensores ultrassônicos
How to eliminate the VFD noise affecting digital sensor reading?
Avrdude: ser_open(): can't set com-state for "\\.\COM6" Failed uploading: uploading error: exit status 1
Serial.print and Board at null is not available
Arduino not recognized
Set arduino RTC alarm every minute
Animatronic pianist wolf with 7 motions
Adafruit fingerprint store from DB to actual fingerprint memory
RFID struggling to read tags and zeros not properly saving
Garbled text in Editor output
Loop for fault IDE 2.2.1
Mcp can.h cannot receive data with the specified ID
TCA9548A ESP32-S3 Connection Help
Hiwonder ackerman servo not turning
About 18v 3amp DC motor
LiDAR-Luna+Arduino mega+WS2812B
Stepper Motors with Arduino Mega 2560
Excel data read
MAX7219 not responding?
Would you guys help me to fix this? the output shows "Compilation error: too many initializers for 'Perintah'" thank you
Graph sinusoidal on 1.8" tft display using lookup table
How do I combine 2 codes in one program?
Need Help, Code messes up motors
Weird behavior from DFPlayer Mini
Serial communication help between 2 Boards SOLVED
Adafruit Smart RGB Neopixel live colour changes
Mi lcd se apaga a cada rato
How to Power down based on encoder movement?
I need a help Arduino UNO setup of 4 microphones, sound delay, data recording PC
ESPAlexa working with ESP8266 but not ESP32
How to fix ku8MBResponseTimedOut
Scroll number from bottom to top or vice versa
Buzzing sound when accepting call from sim800l module even though dfplayer mini module has audio file(0001.mp3) stored in microSd card
Help with my first Self-Driving Car
Karma is still a Thing!
El monitor serial de Esp8266 no funciona
Esp32 cam no es detectado
Adopting to 2.3.3 from 1.8.19 of your program
My code doesnt work
Using code to adjust I2C LCD
Press any key every time delay
I need help about how to use lcd SPFD5408 with esp32
Energy meter not displaying load
Hello all, please help me, how to program rfid module PN532?
Arduino Board with analog output 0-5vdc
My code doesnt work
Please Help: Compilation error: expression cannot be used as a function
Failed connecting Arduino nano to MP3 player module
Powering Nano 33 BLE
Arduino robot problem
IDE hangs on startup after removing OneDrive
Arduino upload error
Arduino Leonardo DIY Steering Wheel
Why PCA9685 doesn't work?
Electromagnetic wave detection sensor
Why is my circuit not working?
Faster BLE throughput
Trying to communicate with a Simcom A7670E connected to Nano and Uno without avail
Sound board serial to LCD print
BTS7960-M behaves weirdly after using it in if condition
Foutmelding: dsp_info
Ili9341 shield and wemos d1 r32
Finding center of gravity with 4 load cells and 4 hx711
Sending Messages
Arduino UNO pin 2
Macropad - Arduino mini pro I2C communication
ESC Controller for BLDC Motor
Bts7960 driver with arduino
Best Method for Utilizing On-Board Flash?
How to control a 12V ball valve with Arduino and MOSFETs?
Shutting power to model train during current spike
What is the process for fixing bugs in a board package?
How to access the USB port? Is there a special bootloader for Atmega8 to access the USB port?
Unable to upload sketches to UNO
Transducer analog input
Oled digital clock
Push button doesn't work on arduino nano powered by a 9 volts battety
RTC (Real Time Clock) with MKR WiFi 1010 and MKRIoTCarrier Display Display
Help me with my 1st project (my deadline for this is tommorow please help)
Github Archive for ESP32-TTGO-MQTT-Using-Arduino-IDE Projects
Github Archive for Arduino-28BYJ-48_Stepper-Motor projects
Fingerprint doesnt work with HC05
Arduino 1.8.19 Linux 32 on HP Mini with Ubuntu
Using odometer in Ublox M8Q
Stepper Motor doesn't work
Implementing 16-bit PWM on Uno R2
IDE bpreprocessor errro[SOLVED]
Código para robot que evita obstaculos
L298N motor drivers driving me crazy
Arduino nano not working
Node mcu and mobile not connecting
servo.writeMicroseconds() does not seem to yield correct results
My serial monitor does not display anything - Arduino 2.2.1
8-modulereley-urgent!
I sent encrypted command from python code to here using Wifi, but the code here doesn't work with decryption, it doesn't show the original message
IoT Based Soil Nutrient Monitoring
Need HELP with ESP8266 Project NodeMCU
The blinking LEDs wont run in Sequence 3 codes
16 bit data transfer between two arduino uno's
IoT weatherstation
Help with an error message please?
My line follower robot motors not working
The forward and reverse problem of the two automatic doors with DC motors and limit switch sensors
Problema unir codigos
Initialising Error for esp 32 cam on serial monitor
Switching from vacuum actuators to electrical servos
Hc-05 not working
Help with running stepper motor with motor and power shield
Problem with bluetooth controlled cart
analogWrite function is not working in Arduino ver2.2.1
Code cooling fan
Question On Running Same program on two pins
Wifimanager questions
Help w programming electronics for diorama project
Motorized wheelchair mod
Error on LCD 12864
Uno how to define pin13 relative to PB5
How to output to a pin from serial.port
Function generator via Arduino code (sawtooth, sine, and square wave)
Fun project with sensor to make alarm sound when someone gets close to it
İyi günler Nrf modül kaç gb veri gönderebilir
Flasher relay to my car
Esp32 solo funciona con monitor serial
Kinetic Facade Prototype (Academics)
How to connect everything for a button box
Led and push button with sensor
Cambio de pines conexión pantalla OLED
AttachInterrupt breaking my code
Crear un simulador para ECUs Automotriz
Why are my code wont working
While loop looking at 2 push buttons conditions
ESP 32 does not connect to WI FI
Elegoo IR Receiver - unexpected output
Stepper motor at a constant speed of 60 RPMs using the TMC2208 UART
Making pc mouse with joystick and two buttons
Controlling 12v Neon led strip Brightness
"Uploading error: exti status 1" with "avrdude: ser_open(): can't set com-state for "\\.\COM2""
Soil Moisture Sensor On and Off control
SparkFun_TB6612 library
Relays its the better option for me?
PCF8575 cannot control relay switching
Serial port busy
Df player mini and esp32 proyect (horn)
ESP32Cam-MB Issues Uploading
Arduino uno getting power, but not uploading?
2x18650 v8 battery shield
Segitség kérése
What should i do to NOT fry my new Arduino nano
Button on midi controller keeps hanging/ stops working
Connecting arduino nano
Using A4/A5 as analog pins parallel with SCL/SDA pins for I2C with HMC5883L
New esp32 not working !help with esp32 flash !
GY6180 TOF Laser library file
Initializing Adafruit_SSD1306 parent class passes arguments by reference in constructor
Access to the AdvancedWebServer webpage
I got an issue while interfacing steppermotor nema 17 with esp32 using ir remote
ESP8266 NTP error Year 1970
Maze solution with LiDAR technology implanted in a drone
Sim 808 module power on and send no location cordinations
Multiple 12v inputs
Rele Reed always closed
Arduino + pi hybrid swarm experiment (distributed agent test)
Trying to get motors to work
Arduino Nano & HC05 Two Way Communication
No output from MIDI shield
PCF8574 problem - no I2C communication
How to amplify a signal being received from a plant
Code to command 2 stepper motors and a dc motor
New file Extension in Arduino IDE 2.2.1
Using HC-05 module
Fall detector sensor
Close relay1 with Alexa and water flow sensor
Esp32 Wifi problem
Help Needed: 12-Hour RTC Countdown TFT Display and servo
Arduino Uno grounding/wiring incorrectly?
Can an node mcu 32s program a esp 01 ?
HX711 with 4 load cells
Arduino Uno WIFi board not reading temperature sensors, but other boards do
Pushbutton controlling brightness of LED strips with Arduino
Installing .ZIP library doesn't work
Connecting SD Card Module to NodeMCU ESP8266
Pls help me button controll
Se trata sobre servomotores
I want to make a one way communication setup through Bluetooth connection
How to power and control multiple 12V DC cooling fans using PWM signal
Grove emg sensor
Help with object movement using robotic arm
Arduino mega Usb not recognized
Combine multiple state machines
Emulate FreqIN input using Arduino
Solved How to interface rf module 315Mhz with esp01
Monostable non retrigerable with Uno
Deta Space(Struggling to use)
What's the problem here?Forgive me for being a beginner
I need help with transferring a code from arduino uno to esp32
How can I make Fade LED using Tpp223 Touch Sensor and Arduino?
ESP32 with USB Camera
Make my relay on a off state or standby when the sensor catches something
How do I use a T-Plug LiPo battery with L298N
Inputting more than 360 degrees for an encoder
GY 33 - TCS34725 Encendido de leds?
Elegoo v1.1 Smart Car Code Not working
Problemas de conexion entre el Arduino uno y el Esp-01 (Esp8266)
Daisy chain SPI
Program problem
Simple Arduino uno r3 sound sensorkit Chatbot
Error in uploading a code
Lcd display 128*64 blue display
Error when uploading code to board
Error:avrdude: ser_open(): can't set com-state for "\\.\COM10"
I want to design Double Active Bridge bidirectional converter, to control MOSFET I need 18V but arduino only produce 5v
CAN-BUS READ Problem between UNO&Seeed_Arduino_CAN V2.0
Program issue I can't resolve
Pump isn't stopping at the treshold
How to integrate power supply to this
Buttonbox Polska :'[
Using nRF24L01 with I2C expansion board
Built-in orange led flashing 4 times fast and 4 times slow
Serial.print( millis() ); resets my Arduino nano
Compre un carro de 4 motores el cual venia con este codigo, no he logrado hacerlo funcionar
SD Card y biblioteca LedControl
Native serial port
EVSE and ev pwm communication
Timbre de escuela
CS5530 with Arduino
Using Arduino Nano 33 IoT Internal IMU as Interrupt to Wake from Deep Sleep
3 way switch between arduino, 36v 4.4a motor, 36v 5a battery and charger
Opiniones Sensor Halisense NPK
Kit NFC PN532 module
Wakeup STM32L432KC from Shutdown Mode with extern RTC
Looking for smart people for the project
Arduino UNO & RFID-RC522 - Communication Failure
Connecting HCM375B-232-68N with arduino
TinyGPSPlus: isUpdated()-qustion
Transistor is blowing out
LCD1602 Seemingly not working well
Wemos 2560 sketch upload errors
Air pump motor not working
Joystick Shield and HC-05
Uno and Mega communication
BTS7960 Driver burning out on Arduino FFB wheel
Which Arduino would be best for a Quantizer?
Oled display sh1106
Tinkercad Blockcode
Seeking help to build an automatic water auto top system
2x transparent displays with arduino nano pls help
Questions on the stepper_oneRevolution example
ACS712 Reading Too High
PRND321 indicator
Compilation error: expected unqualified-id before 'int'
Encoders is not working when pwm.analog write is lower value
ESP32 Read Serial after wakeup
Board capabilities
Having problems with the libraries in the ESP32 controller
Fingerprint Scanner (GT-521Fxx) Not Working
Problem uploading in IDE
Geolocation finder , I'am using open API
URGENT Help with this project (please!) Urgent!
Visibility calculation
Upgrading wires from jumpers after breadboard
Error exit 137 in Arduino IDE
Servo that points towards object detected by ulstrasonic
NOOB - Help with Arduino code, simple pin state = pin active
How to use Arduino with ZK-5KX dc-dc buck boost converter
My arduino is not uploading any sketches
Cannot print to LCD with Wave file playing
Hi i have this code, but the wifi connection doesnt work, ive enabled the hotspot but nothing happens
Display is not showing the correctly
Servo control with while
Gibberish display on LCD
Making my own PC USB racing pedal
No se me actualiza el firmware
RF Module with only one arduino
Me sale un error al cargar un programa en Arduino Nano RP2040
Encoder nidec 24h404h070
Using RS485 with an analog voltage sampler (R4AVA07)
Controlador RGB/PWM
Pump system for my plants to not die
Lightsaber Sound problems
Error compiling for board ESP32 Wrover Module
CH55x: USB data - Vendor, Product, Serial
Hepl me thanks Compilation error: incomplete type 'std::string' {aka 'std::__cxx11::basic_string<char>'} used in nested name specifier
How to protect the circuit if i use selenoid lock
I2c 0.96 oled display
I am having an error while compiling, what should I do?
Arduino pin - how it is possible to draw 40mA from it ?
Connecting arduino mega to computer via ethernet module
2.8" ISP LCD module white screen with ESP8266MOD Board (NO CS pin) Any help?
How would I go about sending a "Yes or No" prompt from my Arduino Uno to My Phone?
Can't I control my dynamic cell with just an Arduino board without a shield?
Design of an automatic PV panel cleaning system with arduino
Query about INA237 Library
Medir voltaje positivo y negativo
Check if wiring for ESP32 C3 is correct
Stepper Motor delaying other tasks for a long time
Building a gradiometer using fluxgate magnetometers
I Need Help: Connecting SIM808 Module with Arduino Nano
Does not name any type arduino code
Esta en mantenimiento arduino cloud?
Error detected after uploading need help asap thanks
How to devloped ardino one input by using two output alternate condition
ESP8266 - COM not found on MAC
SD Library File Read Write Edit
ESP32 Port problem
l298N motor controller
Como empezar con este problema
Tilt Compensated Compass for Arduino Nano 33 Rev 2
Error: void value not ignored as it ought to be done = radio.read(&Irms, sizeof(float));
How and Which type of Speakers can be used with an Arduino Uno?
Caracteres raros en monitor serie - arduino uno
Invalid Header File TinkerCad
Compilation error: library_name.h: No such file or directory
Feedback Wanted – Improving Arduino Shopping in the UK
Timmer registre on arduino giga R1
New install and setup on Linux mint - cant compile
Multiple 12v inputs
Help me to find out the coding of this project
Project 4 - Color Mixing Lamp
Football-Following camera
Arduino UNO Q – Kein Videosignal über USB-C DisplayPort Alt Mode wegen falschem bevorzugtem Displaymodus
Pressure sensor and sd card initialization failed nano ble 33
Menu en pantalla TFT 3.5
Problema con el puente h L293D
Linear actuator doesn't work by ultrasonic sensor
Merged code doesn't work properly
Adjusting brightness of 1-digit 7-segment indicator with 74HC595
Want to make a simple specs locator when specs are misplaced for which i don't have any knowledge but someone told me to use arduino with buzzer
Alimentación de un robot esquiva odstaculos
10 servos and arduino uno
Pls help me with my school project, idk anything about programming and about hardware
¿Cómo rastrear un objeto precisamente?
Tarjeta de Desarrollo Wifi ESP8266 D1
Hello, I have this error so that my camera can have the IP address for me to see please help me
Problema al medir TDS mandando los datos a Firestore
Editing Arduino Library Files
Calculation of Azimuth and Altitude Angles
Please solve this error
Sensor de turbidez en ESP32
How to remove uninstalled libraries
Dheeraj Sudan Meenu Hinduja How to pass arrays by reference?
ESP32-S Cam connection to telegram failed i heard installing an ssl certificate helps how do i do that exactly?
Need to buy an atmega 328pb
Help MIni Tank Robot Just Spining In Circles (Right Motor Only)
My ESP32 keeps resetting when the motors start
Topics using IoT
ESP8266 pair with L293D motor driver shield for arduino not working
Pololu 3pi downloading programs
Beginner-level Arduino programming
Looking for someone to write a program for Uno
I have robot car with four dc encoder motor (jgb37-520 330rpm) and arduino with moebius motor driver for mega im trying to drive my robot for exact1m
No connection NANO RP2040
Esp8266 con sensores
NANO Humidity-Heat-Co2 Relay control
ESP32-C3 fails to connect to WiFi: "Reason 2 auth_expired"
INPUT pins are always HIGH even if clearly setted LOW
Arduino Nano, solar tracker stop working after a while
Help I need to fix my code!
Nano 33 iot no se conecta y desconecta del puerto
Keyboard emulation
Este tema es para la escuala no haghan casoplis
Coding error needed help ASAP
Searching through arrays
When ı uploud a code to the my clone arduino card for my trouble
Arduino IDE 1.8.19 stopped compiling for Lilygo T-Display S3
Arduino nano error
Help with minimum amperemeter when using dynamixel ax12 a
Voice recognition V3.1
Hello, how are you? I need help. Can you help me with a simple project to design a radiation intensity measuring device? Thank you
I2C communication, controlling how fast can be, using MCP23008
Arduino spilling out result even though it is not connected to sensor
Arduino ile yapılmış projeyi satmak
Programming arduino with mobile application
Unspecified code problem
La verdad no se que hacer para arreglar este error
Arduino combinacion de motores mas control remoto
Portenta H7: use DAC and ADC simultaneously
Error while uploading data on firebase using esp32
Where are the examples that come with Arduino stored?
Camera OV2640 with Arduino
Arduino Uno, air quality sensor, IPhone
Uploading code to ESP
D5 pin on arduino uno pwm problem
My problem not solve
Executing Command: Exit Status 1
Understanding the harmfulness of goto statement referring to Edsger Dijkstra's Journal Paper of ACM-1968
Write commands via I2C to AS5600
Uploaing error to arduino nano 33 BLE sense
ERROR: Expected '}' before 'else'
I am doing walking robot. i wrote my ardunio ide code. but i give an error called "exit status 2, Failed to connect to ESP32: No serial data received"
Un-predictable values of MPU6050 sensor
Couldnt get the PN532 (an NFC/RFID module) working on I2c
Hi I am working on a project that includes a boost converter that is mt3608
Ffb on a controller
Merged code no longer works
Upload only option?
When I enter a digit on the project keyboard, it is overwritten and does not break the line to be displayed on the screen
Hi, totally new here and beginner with Arduino. Please assist
LIDAR sensor serial output
Problem with simulation
Arduino Sensor and Servo motors
Lcd 16x2 con botones
Need help with an Error
Servo Chatter Problem
Controlador MIDI 12 potenciometros ESP32
RP2040 OTA Update with4G module
Thremostat MLX90614 IR Thermometer
ESP32: Servo Motor + DC Motor viaL298N
Servo isnt responding to ir signals in automatic mode pleeease help me urgently i am a newbie
Using arduino uno r3 with esp8266 wifi module upload data on the googlesheet i am try a lot but unable to do plz anyone help me
How to reset arduino
I need help please!
NEED HELP- Burglar Alarm System
I would like to build a safe with RC522
Custom protocol
CONFLICT! driver_ng is not allowed to be used with the legacy driver
For and if else - I'm missing something
Quadcopter PID tuning self balancing problems HELP
Handling large files (or data) through streaming it over a serial port
Error utilizando la función lcd.cols
Analog trigger to MIDI trigger
I can't upload anyesp32 s3 1.85inch
Win11, No Com ports, only libusba
Do I need resistors to pull a pin low? (A4988 Driver)
Initialization of DAC pin in Setup
Procesando la señal de una sonda de Doppler Fetal
Increase Torque of DC motors
How dependable is AI?
Ayuda con mi codigo no tengo espacio
Me ayudan con la programacion?
Arduino R4 Wifi library
Error messages on Mac
Vending Machine Project, LCD No Work :(
Make running led on off with push botton
I'm trying to Modify and program my robot car to sense light and distance. then move forward once it senses light
Using USART0_RXC_vect for Attiny1616
Simple while() loop resets my bool
DIY Car mirror tilt when put in the reverse
FM Band Spectrum Analyzer
Interfacing Lionel train layout switches to UNO for LED lites @ control panel
ERROR CON OLED (ssd1306 oled 128x32) y RELAY
Aislación galvánica de fuentes switching - Switching power source Galvánic isolation
Problème sur connection d'un accéleromètre MPU6050 avec un motorshield
Schneider EM1200 with arduino uno via max485 to ttl module
Communicate with mobile phone using hm-10 as master
Read a scale data via RS232M Mstock
NMEA2000 And serial communication
How do i multi task with an arduino uno
Esp Rainmaker IOS APP problem
Connecting Multiple Modules to one Arduino
Arduino nano reset button
Power Arduino uno error
LilyPad Constellation Troubleshooting
Siemens sentron pac3100 modbus
Slow down servo
Error on sketch
I'm stupid and I hate myself
Arduino spot welder v3
Frecuencia de muestreo RA4M1
I can't get the ESP32 microcontroller to simultaneously read an RFID card and display the UID on a TFT screen
Pin connections between the SIM7600E module and an ESP8266
Can you help me with this code to work
Помогите пожалуйста
Magnetic field sensor help pls? (wont print data into serial monitor)
Arduino UNO R4 WiFi as bootloader burner
Relay switch between 2 power source
Redefinition of void setup
Crear un controlador de reemplazo para un láser alien pro
Question about the efficiency of esp 32 cam
Help me to fix my code to control buzzer and monitor status buzzer on Iot cloud follow signal from hc-05bluetooth module
Im strugling with my esp32 problem in code for about 15 hours
Only one motor is rotating
JBC soldering iron and ATTiny85 digispark -- HELP
Can't see HEX in serial
The Arduino project hub is not working
SoftwareSerial usage
How do , I choose a correct motor
Did my Nano die or what?
It keep saying a function-definition is not allowed here before'{' token. does anyone know what's wrong with my code?
USB Connection Issues
Estaria bien para un seguidor de linea
Timer0 Flag TOV0 reading problem
IR Beam Break Sensors acting up
Push Pull setup for LED
(Arduino newbie) Ide says there is no such library when its right there
Wrong sensor data using 2 multiplexers
Esp32 Wifi error 254
Binary counting code issues
How to program micro Atmega 64 using Arduino Nano
I use to combain 3 sketch in one but loop1 onbeat is not work why
Synth WIP: Atmega328pb crashes outputting PWM signal into unpowered speaker
Hi, I just want to ask for a help, what specifically type of 2 channel relay module that is shown in this diagram, which is connected to 24V supply
Multi turn switch to analog input
I can't Calculate the exact Rpm and current. Pls check the code what i can changes should be done in my code?
Esp32 unknown device issue ?
Handheld video Device challenge with exciting prizes by Government of India
Hello guys, I need to create a arduino project using the 3 in 1 soil sensor that measures moisture , temperature, electrical conductivity. And I do no
Help why my sensor ultrasonic not wroking and my servo move by it own!
Tft text screen width
Arduino Nano Bluetooth MP3 player
pH sensor and Rtc I combine it please help me
Arduino IDE don't recognize the ESP32Servo.h library
Comunicacion arduino-plc siemens s7-1200
NEMA17 Rotary Encoder Control
Nema 34 and dq860ma
Esp32 TTGO and sound analyzer
LDR problem- TL system
I need some help, please
Extract temperature parameters of refrigerated containers
Nano outputs garbage when using analog output
Arduino is not working stuck on loading screen
How to detect cause of Arduino restart
Astro tracker Help
IDE compiles and uploads but execution fails on STM32
Problema Alimentacion ESP32 7.4V
Arduino uno R3's built in LED slowly turns on when pin 12 is on HIGH
Sketch not in storage
How to apply autotune
Using a program written for two different purposes on one uno card
DHT sensor connection
Putting Neo6M gps information onto a webserver with eps32
My arduino R3 is printing only 0 doesnt matter if i flash any code
RFM9X to arduino nano
Reset ESP32 with arduino pro mini
SAMD21 ADC Trigger (Arduino Zero)
Photoresistor circuit to switch off motor
Sd libraray on ttgo, esp32 (t8 v1.7.1
‘LED Control via Shift Register with 4x4 Matrix Button
Electro magnet control using arudino
ACS712 sensor with arduino nano esp32-s3
Servo doesn't works correctly
Project I came up with to help me study
STS3215 problems
Рroblem with transmitting a variable between two Arduino Pro Mini boards via UART
Creality CR10-S Pro V2
Sim808 GPS antenna design
Issue with Heltec LoRa ESP32 V2 Not Connecting to TTN Server
How to show unit "g" Serial.println(scale.get_units(2),2);
Red de sensores IoT Ultrasonicos para monitorear niveles de rio
My code says exit status 1 when i try to upload it
Moludo bluetooth HC-06 y Arduino UNO
Como saber las características de mi esp8266e
How can we execute this idea for TeknoFest (Turkish Technology Fair)?
Why does this #include <AFMotor.h> doesn't work
Hi all help for project using Arduino
Debugging esp32-c6 devkitM-1
*urgent have a couple days to get assignment done* looking to make a aurduino r4 uno minima photoresistor activating servoarm
MIDI Controller
How to increase capacity of bidirectionalperson counter?
IR reviever continuously running after turning on motor
Interfacing MCP23017 E/SP with arrays in Arduino IDE
Compilation fails: "Arduino_GigaDisplay_GFX.h: No such file or directory"
Speech recognization with esp32
How can I make Fading in any seconds?
Fire fighting jeoiegnwkfygmwoy
2x16 lcd troubleshoot
Help with displaying on a tft lcd
Random results, with serial print damaged Arduino?
Bluetooth Car motors are not moving. I need urgent help please
I'm looking for an old Arduino OPC SERVER program
Reloj digital con Esp 32 mini y TM 1637
Lectura de archivo de tarjeta sd y utilizacion del dato leido dentro de una sentencia if
Mkr1310 not joining chirpstack on RAK7244
Three position momentary switch to keyboard input
LCD not turning on
Error after moving functions to different tabs "Compilation error: 'PROGRAM_LED_IDEL_PUMP_UP' was not declared in this scope"
Programming limit switch?
Due friday for school
Mi módulo L298n no enciende
I need help making my motors faster
AC heater temperature control
Reducir cantidad de if
How to connect three proximity sensors to Arduino uno
Can the Arduino nano use 16 RFIDs with the RST pin connected via MPC23017?
Esp01 relay issue
Help digitalread/ write is not working
HC06 no agarra con mi teléfono
Wrong Data in Dashboard and cloud
Voltage divider with op amp
3V Arduino Nano Problem
Mpu6050 quaternion
NRF24 RADIO is never available
How to control bldc motor by arduino
5 Digit 7-Segment Display Writing Error
Upload to ESP32-C3 board fails: "No serial data received"
Solar tracker not working in sunlight
Component needed to project
Stepper motor help
Toy car but it doesn't work properly
HELP NEED ASAP (Hopefully)
Issue in adding ArduImageCapture 1.1 tool
I really need your help/ midi controler mega 2560 ch340g
3.3 relay going crazy
16x2 LCD Display Shows Black Screen - Could It Be a Power Issue?"
Light bulb is about the only demo that works
How to Synchronize 360° Servo Motors for a Bipedal Robot
Nano Matter help required
If voltage is present apply voltage to different wire
Arduino Obstacle Avoding
RTC_DS1307 and Adafruit_I2CDevice libraries errors
Code that measures resistance from 0 Ohm to 50 Ohm
Unable to rewrite sketch on a non-genuine UNO
Conversion via Rx Tx to LCD
Some Arduino - DMX interface advise needed
New to Arduino, Project Requires 5 different Sensors – Please Help
Possible Memory Leak?
8 in 1 sensor need help
PWM control with adding button for start-stop
Data streaming arduino with VisualfoxPro
M5STACK StickC Plus complie error
Arpeggiating Synthesizer (Mosquito I)
How to post in more helpful ways for beginners
WROOM not connectable to pc
Pls help with my ir counter
How to operate a servo motor with a Transmiter and a reciever
Arduino Nano 33 Iot Hang after time
12v motor, relay module, IR sensor wiring
Arduion编译报错求助,编译不成功
Reading and emitting frequencies using arduino
IrReceiver.begin mess up L293D motor shield
Colour mixing lamp
Can the static on my person be enough to disrupt a weak signal/circuit?
Accelerometer Keeps on Giving Me 0s
SPI and I2C problems
Problem Connecting 128x160 TFT Display with PCF8574 Module on Arduino Uno
Nextion Intelligent NX4827P043-011R touchscreen not establishing communication with the Arduino UNO R4 WiFi board
I am getting this error while i connect esp 32 wroom and ov7670 camera. Anyone here can provide me the solution for this?
LVGL v8.3.11 scrolling problem
What to do with GND/COM jumper - 12v pwr supl 8ch relay board, Arduino Uno r4 two DC motors
Signal Seperating
Invalid header file
How to mirror iPhone screen on ESP32_TFT ?
Incorrect reading from MCP9600 amplifier
The application on my phone cannot connect to the Arduino server
SPI Protocol Connection help
Arduino IDE Error
(Neuling) Arduino - Relay mit Münzzähler freischalten!
Struggling to make a nintendo switch hitbox
Making a 3 phase voltage and current measurement system using arduino
Question about multiple concurrent tasks using Serial, and Wire
Overheating Protection for the XL6009E1 Voltage Regulator
OLED display glitches only in one part
About controlling a dc motor which is 6v with pwm control with an arduino
Problem with Husky lens and Servo!
Problem with connecting some arduinos and not being seen as devices connected to my computer (win 11)
Problema con sensor de temperatura Dht11
Tengo un problema con mi arduino nano y servos
Advise for project
Print captured JPG image from filled uint8_t PROGMEM saved in the Flash of esp32
How to convert a differential analog signal (-4/+4V) to single ended analog input at Arduino (0-5V)
Motor Driver (with reverse polarity protection) Not working after reverse connection to 12V battery
Configuring Arduino IDE So That Drivers Are Not Installed by the User When They Launch the Arduino IDE 2.3.4 Application
Zigbee remote failure
Receveiver 433Mhz in mode INTERRUPT
Getting randomly peak data from gyroscope
Colntrolling stepper motor with endstop microswitch
Sensor de oxigeno OCS_3FRL_1.0
Help with stepper motor control on Arduino Mega with Ramp 1.4 Sheild
Facial recognition
CNC shield v3 Arduino Uno Gcode sender is freezing
ESP32 failed to communicate with another ESP32
Arduino 2.3.4 no se ejecuta en win 10
Can anyone please help me with my controls on firebase with ESP32
Issue with Sharing SPI Pins for MicroSD and LCD/TFT on ESP32 (Wroom ESP32)
Esp8266 is freezing after variable time
Fan controller that controls nothing
Strncmp I'm having trouble
First steps arduino and waveshare display
10bit ADC for ESP32 breakout board
DFRodfrobot_INA219 not compiling under arduino 2.3.1 to 2.3.4
[HELP] I2C on ESP32-S2: No Devices Found with PCA Board
ESP32 dual core
Bare Conductive Touch Board
NANO AND GPS I am getting and issue
Need help with incremental encoder
Mouse unresponsive with Arduino and HostShield
Vesc get data failed to get data
Sensor and Buzzer
Please help me if you can :(
Arduino + SimpleFOC smallest footprint
Arduino Uno programing help
How to connect elm327 with esp32
Arduino Mega2560 + Sparkfun TLC5940 LED Driver Not Working
Como se maneja la secrecía de passwords en el codigo que manejo a traves de arduino cloud
I have and error with my esp 32d
Suggestions for ADC with ±10V Input
Fatal error: avr/io.h: No such file or directory
Automatic clothesline system
Variable pressure control
Help in Arduino code! [SOLVED]
Addition of dc motor
PCA9685 Servo Control on ESP32-CAM
Plant project with LCD
My Smart robot car v4 right wheels can only go backwards
Issue: Unable to Detect Simple Linear Movements (Point A to Point B) with ESP32-C6 + LSM6DSOX (AI-generated content)
ESP32-S3 / SDIO and Task
Como proyectar la pantalla de mi celular a una LCD
Long file names SD card [Resolved]
Create a home fully IOT
Arduino micro midi problem
ESP32 STATIC IP IF ON THE IP OF ESP32 an html server is also being hosted
UNO Q Bridge Calls Help
Arcade Button connect to Steppermotor
BMI323 sensor not detected
ESP32 and ESC for spinning a homemade brushless mtoor
Dimer led with eeprom used help me
Can't get two ds18b20 sensors read on different pins
Portenta X8 - Uno Q
HM-10 reads all text as question mark
Dumb motors not running
Device COM5 is not currently available
Seven Segment Displays using MAX7219 and SPI
ESP32 Mini C. error subiendo sketch ide arduino
Two questions about the stack size
Help with 7 segment LED display
Arduino portenta x8 board - localhost unreachable
2 IR sensors for one servo
Error camara index h, i tried anything and i have no solution,please help
Clock with 2 shift registers
ID-12LA RFID Reader not working properly
How to use Capacitive Sensors with Arduino, and communicating with a program on the computer
UNO Q With I2CLCD Display
Circuit not receiving power when disconnected from USB
Esp8266 earlephilhower repeating cycles without pause
RFID Works Independently, but Stops Working When Sending Data via LoRa
GC9A01 1.28" TFT Display Issue
Need Program for Stopwatch for Arduino UNO
Compilation Error
New to arduino, how can i send arduino code without com port
Botella que registra el consumo diario de agua mandando notificaciones a una app
FDC1004 Chip does not meassure with STM32
¿Como deplazar texto verticalmente en una matriz de leds?
Unable to Update Alvik Firmware
Finding resistor and capacitors values / Test circuit
USB-MIDI en Cubase13 pro
NRF24L01 + PA + LNA modules not working
I2C Issue with MPU6050 – ACK received, but WHO_AM_I always returns 0x00
Push button to activate LED light strip animation
Hello everyone, I have a problem. I want to make a peer-to-peer communication between two Arduinos using PN532. I'm using this NDEF code, but not work
Arduino failure
Problema Interrupción Timer ESP32
(Newbie) Issues with IR sensor and OLED screen on Arduino Leonardo
Arduino Line-Follower Won’t Restart at Low Speed—How to Boost Starting Torque Without Sacrificing Line Detection?
Randomly stop my arduino car
Problem with Starter Kit Project 11
Thought I had a Pow function problem but it was a conditional statement error
24Hour instead of AM/PM
Rocking Motor with Arduino
Barcode/qr code sanner with rs232 pins connecting to arduino uno
Arduino controled dc cdi
ESP32 & D1 Mini Not Detecting Any I2C Devices
Help Needed – Displaying Numbers on OLED from Voice Commands Using Nicla Voice
3 Stepper Motor doesnt rotate at the same time
Using TPS2596 eFuse to protect 5 V rail powering ESP32s, SG90 servos, and peripherals
VU METER lcd 20x4
Problema con mi código controlado por Bluetooth
Difficulties using Cubemars AK70-10 serial communication in servo mode
MFRC-522 Works With One Library & Not Another
Led light control with proximity sensor and radiofrequency
Arudino uploading a sketch error
Servo motors MG90S doubt
Building a traffic light controller - which micro controller best suits this project ?
Problem in arduino
Library Background-h
Arduino include problems
Neither of my boards seem to be working but I cannot identify why
Esp32 with servo td8120
Pantalla y esp32
¿Cómo puedo flashear un wemos d1 mini, leer y escribir datos mediante el wemos desde java?
NPK soil sensor 7 in 1 esp32 with thingspeak monitoring
Arduino mega keeps on shutting down
Nano connection to ICBOOST
How to connect esp 32 and MH ET LIVE SCANNER 3.0
Nano won't process until after a USB data connection
Responding Issue
Arduino Sends Correct Temp, ESP32 Receives 0xFF/NaN
A0221AU ultrasound distance sensor
I need to create two buttons onto my webPage, (im using ESP32C3), to calibrate my scale without a phisical button
Help on an ESP32 C3 Super Mini Project (Clock)
Seeking Help – Motor Not Responding in Fixed-Wing Aircraft Project (Arduino-Based)
MEGA keine EMpfang von Strings auf PIN 15 Serieal3
Problem nRF24L01 with Arduino
Connect to WiFi with the M5Stack TAB5
Mega 2560 + TDA7498
IR remote issue
Issue with tachometer
Convert speech to text with esp32 i2s imp411
HT1621 induvidual segment control
Got a problem with a uno and relays
Problem after uploading to waveshare esp32 s3 touch lcd 1 85
PySerial "in_waiting" Almost Never Finding Bytes Sent From Arduino
Ask About Error
Matrice led coordonnées
Change LVGL label text in code
Working on a project with 2 potentiometers 2 push buttons 2 LEDs and 1 buzzer
SoftwareSerial and SH1106 and SSD1306 compatibility
[HELP] Arduino UNO problem "Couldn't find Java Virtual Machine"
TFT_eSPI examples don't run
8 in 1 soil sensor with hex send and receiver
Realtime Fake Drivers for Microcontrollers – Develop Embedded Code on PC and Hardware Seamlessly
I'm working on a project using an isel 2-phase stepper motor controlled by an isel Microstep Controller (iMC-S8) through MATLAB (RS-232 ASCII commands
Error al subir codigo
Memory monitoring uno R4 wifi
Manual PWM changes cause DC motor to momentarily stop
INMP441 doesn't work
SEEED XIAO RP2040 uploads, but does not run
Como pasar un codigo de arduino MEGA a arduino UNO
BMP180 Disrupts Arduino-ESP8266 Communication
Someone plz help my project
Lilygo t-embed esp32 s3 cc1101 with bruce
GPS GY-NEO6MV2 con Helctec Wifi Lora 32 v3
A book library in a TFT display using esp32
Sms +GPS tracking system
TCP communication with Mega Rev3 using USB adapter
Disparity in Measured and Calculated Current through IR LED Driven By MOSFET
Seeking Advice on Coverlay Lamination Overflow Issue in FPC Process
I want know about the arduino uno Q
Arduino Giga Display Shield drawPixel() Not Working
Cannot upload new sketch with tx led on
Connection from esp32 to rs485 to ttl
Esp32s3 + rfid error
Aiduino Temperature, Humidity DHT Sensor and Buzzer
analogRead portamento effect?
Cant understend how to make it
One wire sensor data gets weird when I open the Arduino's serial monitor
Help me my led decoration
Data transmitted doesn't match data received for NRF24L01+
A fatal error occurred: Failed to write to target RAM
Re-programming a very old ATmega8 Arduino
Arduino tag cpp error
Trying to used Compressed Fonts
Nema17 stutters using tmc2208
Partager ses projets Arduino efficacement
About Touch sensitivy values
Petition to never close topics
Sensor EMG no funciona – problema con la etapa de adquisición (basado en proyecto de Joel My Lee)
0-10v Converters Constantly Failing
Hardware to connect a pro mini to control 2 motors
What do you think of this alternate way to wire a DFPlayer mini to speakers?
Vision Artificial con arduino uno q
HI ALL I Have Issues on my program I have 1 Stepper Motor Kit Nema 34 8.0Nm Stepper Motor and 2 buttons 2 limit switches
Need help connecting ps4 controller to esp32
The code provided for sending health data (heart rate, oxygen level, and temperature) to Firebase Realtime Database using ESP32-C3 is not working. Whe
How can i communicate between a teensy 4.0 and an esp32?
Problem With L9637D and ESP32C3 SuperMini or Arduino Nano
Humor with artificial ai
Fail to use psram
Serial communication isuue
What size 3d pen do i need?
Arduino Nano R4 not working with Adafruit Ultimate GPS Breakout V3
Inconsistent sensor values
Is there anyone who can help me?
Title: How to Increase Serial2 RX Buffer Size on Arduino/ESP32 to Receive Large Data
(Code 43) problem in arduino uno
IOT data reads using serial monitor - not in the cloud
Amp Sound from Attiny85
RC522 not reading cards
I am currently working on nucleo 64 F401RE(MCU) microcontroller and ice40hx8k breakout board(FPGA)
SSD1963 + ESP32 (16-bit Parallel)
ESP32 S3 Devkit C1 Arduino IDE Projects and Showcases
Quel transistor pour un solenoide de 3V?
Sound sensor problems
Custom libraries
Need assistance for 16*2 LCD Display
Problemas con las Interrupciones
Bidirectional wiper motor control using arduino nano
How to design 3:1 pulley/belt system for a UGV
UNO R4 minima Modbus TCP
Want to create a diagram of data from a sensor and save/update it permantly on a SD Card
DIY FFB steering wheel Arduino with EMC not sending signals to driver
C:\Users\paul\AppData\Local\Temp\.arduinoIDE-unsaved2026427-21980-hexn6a.99onr\sketch_may27b\sketch_may27b.ino:1:10: fatal error: LiquidCrystal_I2C.h:
ESP Cam issue Error 0x106
Esp32 3c draadloos geluid opvragen
Help with relevant Ethernet tutorials or sample code
Sensor de humedad con arduino. etc
Nano no carga sketch
Project 8 digital hourglass in the arduino starters kit
Syncing ardiuno nano esp32 to mac
Hello, I am working on acquiring raw EEG signals using the MindWave Mobile 2 with Arduino. Although I have the code, I am not confident in the accurac
R4 Minima and GY80
How do you organize libraries and tools across multiple Arduino projects?
No output power from the Arduino UNO R3 from out put 8 to output 2
Windows disconnecting
Need help with my schematic
Carrito evita obstaculos
Regarding Video Processing and Displaying at a time on UI
Custom Ethernet W5500 is not working
Mega output all active on power up !
Nano not reading correctly
4x4 pinpad not working
Communication error of WT32ETH with HMI through ModbusTCP/IP
SDRAM Usage of the GIGA Shield
Forgetfulino - Upload your (compressed) code in the board - IDE 2.x extension
Digital Lightning Sensor Tester Shield AS3935
Arduino Nano with SIM800C always crashing
Ground issue dumping ECU EEPROM, 5V Rail Collapse
Everytime I try to get the status i get an error MAX2870
ESP32 and iphone connectivity issues
Code for distance measurement system
ESP32-S3 + ST7789 SPI + LVGL: severe tearing during scroll, no TE pin available
I need to build an Arduino project to test usb and other such cables for all electronics and computer uses
Arduino uno not syncing, no fix found
Firmware to use ESP8266EX as slave of Arduino Mega 2560
UNO Q: Performing orchestration on arduino
Using AI to write Arduino code
How to calculate sensor reading average on Arduino?
Engine of the motorcycle cutoff of its own with Arduino
Arduino Uno R4 Wi-fi board
Micro-controller selection
Kaggle competitions download -c playground-series-s6e3
Begin maken met arduino
Need equation for setting delay
Arduino and ultrasonic sensors
Controllino Modbus TCP Heidelberger Wallbox
If you have a existing 1602 Lcd board that has a faded display, how do you know what to program in the new one. The original is of a intruder alarm ke
Asasasawsdewr34t54yt54
Narrowing conversion of '4.8e+1' from 'double' to 'uint16_t
Voltage level shifter but from 30v to 3.3v
Push Button LED Control experiment questions?
Arduino UNO-Q HomeWizard ACCU, automatic
Streamlit en app lab
Officially ban ChatGPT and AI
Nano 33 BLE sense rev 2 incorrectly recognized as stella
EM4095 Transmitting at 60 kHz/ rfid reader 125 khz
Présentation d'un passionné d'Arduino du Maroc
Unable to open port
Basura inteligente
How do I modulate a signal ASK
Sistema de seguridad
6 digit seven segment display using TM1637 display interfacing with atmega328
How Do You Organize Larger Arduino Projects as They Grow?
Home Climate Monitoring - example
Connexion arduino r4 uno plug and make et ableton
Update fails: "/home/arduino/Arduino/libraries/Arduino_RPClite already exists"
Unstable Reading of K type Thermocouple attached with 4-20mA SBWZ2462 Temperature Transmitter in Industry Water Chiller
Script or program already loaded to board
3 point load cell help
ESP32 DEVKIT motor DC issue
RTC will only send 6 bytes - Any ideas?
How to use: LED Infrared Remote Control Transmitter 3W High Power Infrared Transmitter Module 940nm
Network Connection Issue
Heltec v4 and servo
ESP32-S3 IR Transmission for Haier KFR-35GW/07ZJL23A-DS AC Not Working
Esp now on esp32 c3 super mini
Cant connect to Arduino Cloud
ESP32 BLE Arduino libraries problem
Looking for Arduino and ESP32 Volunteers to Help Street Cats in the UAE
Arduino - Digitalt in TinkerCad ASAP
Coding HELP needed
Nokia 5110 LCD not working(except backlight)
Mp3 player door chime
Speed controlling of servos using PCA9685
LoRa module RSSI test using arduino
Mood CUE- Servo doesnt move
How to specify the board lib install directory
Led 8x32 dot matrix game need help
Freezing problem on Teenzy 4.1
AnalogWave source code?
Reading int array from serial
Weird time behavior (millis, delay and tune) when the processor runs outside the Arduino board
Esp32-s3 errors
TCA9548A Multiplexer - Arduino Mega
PWM signal to TTL
Five-pin soil multiparameter sensors, PLS HELP!
Output to operate as (and in parallel with) momentary pushbutton
All is okay but wheels not turning/spinning/rotating - self balancing robot
LIN BUS Master Arduino Nano connect to TLE7259-3GE
Sending Modbus write single register from Arduino to pic microcontroller
I need help with this project
MPU6050 and RF module
Beginning Arduino/Circuits - Middle School Age Appropriate
Need Help Wiring Neopixel to Arduino Uno
Days since January 1st, 0 AD (Gregorian calendar)
Connection problem Arduino uno
How do i connect a 12v 7ah battery to an arduino and l298, with what wires
Programming problem with MySQLconnection
Fault detection in an optical fiber using arduino
Servo shaking when LIDAR added
Esp8266 fallo con interrupciones
How to use wemos d1 mini and ds1302 rtc module together
Please help with my project ASAP
Delay() not work in wake up after power down
Swprintf and wchar_t?
Delay within an extra void not working?
Power nrf24L01 without usb
Arduino Code for GPS Data via Lora Node to MQTT Server
Fast.LED lib fade without slowing the loop
Image transmission 0V7670
I want to combine the Arduino program, but there are still problems with the LCD program not being able to change/transition and the sound sensor can'
Ayuda con mi servo
Add arduino read data from sensors
Arduino RPM Light using OBD2
Is it possible to use PWM signal controlled by BLExAR to adjust the frequency of a signal generator?
Seven segment LED for cathode
DS2413 1-Wire 2 GPIO drive relay
Need help with schoolwork, appreciated
Button Start Stop Loop Play Audio
Help With Error Code IRremote
Interrupt on nano and detach
Up Down Counter back direction count issue
Stepper Motor Programming Questions
Atmega328p PCB Led slowly powered
Adding rotary dip switches
How to make 2 pins do the same thing?
Error message byte 2
LCD screen for Arduino UNO onlys shows a row of white boxes on top row
Pls help. Unable to club two different codes in one
Probleme envoie d'une requete Arduino shield ethernet
Reset Arduino Micro? help plz
Soldering station help
Error when trying to send an image via FTP from ESP32-CAM
Arduino& python serial
Combining 360 degree continuous motor and force sensors
Two sensors on the 5V pin
Servo control on ESP32 S2
Getting erratic behavior with RFID reader
How to communicate the IMU sensor with esp32 via SPI communication
ESP32 Wroom and CCS811 sensor
Midi controller with encoders
Replacing an ATMega328p with STM32
Is my esp32 incompatible with my nRF24l01 module ?
Dodgy eBay MAX7219CNG devices
Cannot get code to work with ATmega328P
Urgent Help Needed Please!
SSD1306 display troubleshoot
How can I invert my sensors for my zumo bot?
#include <ESP8266WiFi.h> void setup() { Serial.begin(115200); delay(1000); Serial.println(); Serial.println("Resetting to factory setti
My code keeps repeating from the previous code that I programed
How to control motor
Loss of internet access but not Ethernet Arduino mega with Ethernet shield
Connecting my sensor with NPN Transistor
Arduino and Raspberry Pi Serial Communication
Millis() is wayy off
Servo position hold while operating with Joystick
Water Flow sensor Switch
Project: gas-sensor comparision
Arduino DS3231 RTC coding question
Converting from byte to integer in arduino
RTC ds3231 - 165:165:85
SPI problem with radio and SD devices
Rotary Encoder Not Working in Wheelconfig
Uno, MOSFET, Servo.write issue with digital read
Controlling H-bridge via bluetooth input
No matching function for call to 'HardwareSerial::println(FirebaseJsonData&)'
Please read. Encoder sensor
LCD forgets info one I unplug it from my computer
Problemas con error No such file or directory
Servo shifts to last position of other pwm servo
Neo 6 m in Node mcu
Why does my code not loop?
How can Arduino UNO/Nano generate 3.3 Volt?
How i can save string password in eeprom when i change password
NRF24L01 Causes servo to vibrate
Question about direct current motors
New to coding on Arduino
IDE 2 addition suggestions - open source participation
How do I trigger a continuous servo motor (FS90R) with an ultrasonic sensor (HC-SR04)?
Alarm clock coding error
ATtiny85 + bitmap + OLED
Convert serial printed time format to hours and minutes separate
Help needed to merge two void loops
Need feedback on this code because I am trying to work a Stepper Motor 28BYJ-48 with this code
Problems with program freezing
Advanced chart, grayed out Things while adding variables, Time Zone problem
Esp32 code compiling error
Sending data to multiple slaves to single master via RS485
Any one can help me to know how to fix this error when i used MPU-6050
A bit of help in Modifying the Program
So many error while compiling I dont know where to start
If someone can help me i will be thankful
Robot-Car Projekt mit einem Arduino UNO smd
Please I am new here. I need help with processing serial data on the second Arduino connected to GSM800
Checking my understanding of functions specifically voids
Coding in arduino ide
Add count by 0.5 mm after every pulse recive in digital
MPU printing Zero's on second iteration in for loop
Serial Monitor - Messages from core or libraries
Ruido electrico que resetea al arduino uno o al nano
68:4: error: #error "Required HOMING_CYCLE_0 not defined." #error "Required HOMING_CYCLE_0 not defined."
Twitching servo using softwareserial
SOS sketch needs a pause in LED sequence
Looking for advice: detecting input within a timeframe after output
usbMIDI problems with the Teensy
Problem with printing out a random number
Arduino Mega with Ethernet stops working
Arduino Nano R4 window compatible issue
pinMode() automatically sets digital pin to high
High Current Measuring with ACS712 and Buzzer Module
Arduino code for pin i/o over BLE
Neopixel WS2812B need find code int
BMP180 init fail
Uploading using programmer doesnt work
Arduino Nano not uploading data to Nextion Display
Error compiling for board NondeMCU 1.0 (ESP-12E Module) related to firebase
Verification error, first mismatch at byte 0x0000
Stop file from looping
Port availibility
2.4" TFT LCD TOUCH SHIELD inverted
Need help controlling motor with arduino
HDQ comminication protocol - compile errors
Getting low voltage from digital pin (0.5) instead of 5v
Trying to segregate serial data and drive outputs
Fine tuning fan noise
Problems related to Infra red sensor
Modification of a timelapse program
Im struggling with a delay bug in my code/project
Shaking servos on robotic marionette
Display 128x64 only 15 pins
Stepper Motor will not go through a full rotation
Hi i need help to make this logic design project
PROBLEM reading from serial monitor
Problema en el codigo con conexion wifi mkr wifi 1010
Connecting between two NRF24s
Esp32 cam error
DS3231 Code - Clarification
LilyPad Arduino Pinout
If statement with time condition
Not declared in this scope, sound!
What is the best way to do this project?
Get first 5 digits
SOS - GPRS String Getting Truncated
LCD monitor not working
Serial.println only printing out 0's
Why is variable "r" always one, even if i ground pin 3?
Is my RTC ds3231 dead
Soil moisture combined with Temperature sensor (BME 280)
Using simple feature extraction to control lights
[Solved] Problem with Arduino Logic Analyzer project
Set but not used? Really?
Funciona bien una vez y después se reinicia attiny85
New to arduino and coding
Help with crypto display
UNO+WiFi board / Port disabled
Differing voltages on pin D7 and D8D6D5
Can FS-INS-16Z replace FSR sensors for a Unity/ESP32 squat posture project?
Having trouble sending and reading 2 bytes from Serial Port
Robotic arm using 6 servos by Lithiun ion batteries
Everything in this code works great except for the stepper motor which just vibrates a little but doesn't spin
Prototipo escala con 4 celdas de carga
Arduino Mega 2560, and Modbus Slave RTU Library
Coding error at void set up
Expected primary-expression before 'void' please help
Nodemcu with rs485
Arduino port problem | COM port not found
Problem with my script
Pro Mini 3.3v 8Mhz Died in 5 mins
Looking for easy VR3 for relay shield code help
Digital clock with an OLED 1.3" 128x64
Secondary Clock ''СТРЕЛА" made in USSR
Help - Problem with Green LED not staying lit
Starterkit - Project 14 - Tweak the logo - Processing error
Sketch upload error on arduino
Read sensor connected to USB port via Arduino
Firebeetle ESP 32 error or my laptop?
Set up sample rate of arduino
Bearssl/bearssl_hmac.h: No such file or directory
Program using a button timer
Problem whit this code pls help
Duplicated Row on RGB Matrix 64x32
How to make multiple menu on oled display wth esp32 and button
I need help for programming three voltage sensors
Nema 17 with Big easy driver, jittering
Camera Web Server
External Pin Change Interrupt not working Instantly
Help with programing arduino
On/off button for code
How to stop music on DFPlayer mini
How to display Full text in LCD with i2c board
Serial Prints Average Sensor Read
IR Remote button Push "ON" release "OFF"
Coding help? vfd to LCD or OLED
Linear Voltage Increase
Help with arduino code!
Servo no regresa a la posicion inicial
Doorlock.. Proplem with the servo motor
Hello I am not able to send a binary signal like from python to Arduino
How can print float to a TFT display
Getting an error using the ESP32Servo Library
How to get the best out of this forum
iRobot create movement with arduino
Unable to stream video or capture stills ESP32-CAM
Concatination of string
Washing Maching code doesn' wait for fill water tank after 1st. washing is complete
RX Sketch Nano RP2040 Connect
Three servos controlled by only one digital input
NEED SOME HELP ON "sendeMIDI"
Arduino Uno R4 WiFi connecting Adafruit Sensirion SH40
L298n needs arduino to be connected to pc
pinMode - how come it worked without definition?
Can you make a arduino in to a computer
Does State machine coding work on Nano
Serial monitor is giving wrong values
FastLED Parallel Output (Same Data Different Pins)
Using 2 arduinos and TMP36 to send message
What is exif.h ?
Voltage sharing across multiple peripherals
Libz.so.1: failed to map segment
Unable to compile for esp32 dev board module
While function not repeatedly checking state
NRF24L01 Transceiver Not Working
Ttgo lora32 v2 and ds18b20 temp sensor
Serial.print sends non wanted data
Ouput current dropping down
Codigo para modulo relé doble canal
High Resolution Gyro Question
Problems with int errors
I got an Adafruit feather with DVI output, Now I'm in trouble
Light a LED based on a Sensors activity
When I use the same code how2electronics provides for the NPK sensor, the Max485/Modbus to TTL converter we're using returns only FFFFFF
What Causes the Torque Sensor to Have Unstable Output Signals?
Conversion from 'const char*' to 'char'
Latching Footswitch to MIDI Converter
GPS/Web/WebSocket/Arduino Project
Arduino RFID Card System
Guide sketch for 2 DC motor , L9110s, and an ultra sonic sensor
Logging sensor data from BMP280 and BNO055
Led strip flickering
Servo mouth audio triggered star wars
Temperature controlled actuator
A school project Garbage classification
How to alter the value of a signal via poti?
Problem displaying variables on lcd screen
I2C 20X4 2004 displays 2 lines with blocks only
Conflito entre macro e LiquidCrystal_I2C lcd
Getting rtc time and using this info to label data in sd card
STM32 with AC solenoid valve with relay and hx711 module for load cell
Data too long for SD to Read?
Problem ESP8266
Code doesn't work
Which Arduino device should I use for a capacitive pressure sensor?
Arduino Problems in Coin Acceptor
Code Error while compiling
Math problem "invalid conversion"
iBUSTelemetry.h compile error for STM32
I have trouble with Problem with hc-05 bluetooth connection(Not sending message out through phone app)
Conflit urtouch and sdfat lib
Fatigue Monitoring Device
"Error compiling for board Arduino UNO" message
JawDuino Error SoftRcPulseOut' does not name a type
Nano TMC2209 Stepper Power
Accessing recorded data of Arduino Uno
HELP with send SMS with SIM800L after RFID tag confirm
I need help to my code!
Hexadecimal value divided by 2
Serial string sum comparison
Attiny85 with DC motor and pushbutton
Attiny 85 module not showing up on any port in ide
Trouble with reverse steper motor
Can I increase the resistance of my linear potentiometer?
Changing Pot MIDI Channel by Bank Select
I am having problems with my robot not seeing the white lines on the Mini-sumo arena
BMP280 newby pressure relay
Matlab Fuzzy Logic Conversion to Arduino done but confused
Help , I do something wrong in my sketch
Multiple cards on one RC522
Wiznet W5500-EVB Pico - On board switches
Error Compiling code for esp32
Pairing W2821B Led's into individual Sudo Pixels
How to compare rfid code number with code number in a list on sd card
Analog Read Issues (Interference?)
Weird issue with char
I want to scan 5 different qr code to activate the servo
ST7789 Temp Display
Lavitating water drops
Compiling, uploading or resetting outputs HIGH
I have completed training for Tensorflow lite model on nRF52840 sense. Can you guide me with a basic program for example: Using I2C OLED Display to di
CC1101 Transceiver, and NANO
ESP32 getting BPM to serial monitor isn't working
Ch376 communication error with arduino using spi
Unscented Kalman Filtering to find displacement
Check Wifi Status - Problem
No me reconoce la librería Keyboar el Arduino IDE
Control led brightness using ir remote volume buttons
[CORB] Arduino + NodeMCU (ESP8266) Daten können nicht abgerufen werden
Help in error expected primary-expression before '.' token
Pushbuttons read as LOW although they are activated
Errors when running the servo test with motor carrier
No carga el código de esp32 a firebase
General Guidance and How to use the Forum
ledcDetachPin(Pin) seems not working
Is my code wrong?
Micromouse Simulator (MMS) interface
Complete newbie need startup advice
Error message: no match to operator&' (operand type are Pot** and Pot
How to collect time data and export it into a .CSV file without an RTC module
STM32 nucleo 64 with ST VL53L1X TOF sensor
Extremely unstable analogReads
Arduino IDE not founding right COM
Error while verifying a code into Arduino mega board
How to code, i need help with my last smt project
Controlling Servo Motor with Arduino and PIR Sensor
Problemas de lectura de microSD en OPLA
'si5351_init' was not declared in this scope
How to measure stator current in 1ph induction motor
Push button trigger sequence
WiFi.begin(ssid, password); not workin on my ESP32-S2
Help Buzz Wire Game
Countdown timer 16x2 lcd
Problems displaying oled and lcd at the same timt
Arduino, Ultrasonic, Servo Motor and Capacitor?
LCD Code causes Arduino to not execute void setup AND void loop
Is there a possibility of that using closed loop stepper motors and drivers in 3d printer?
Why on my esp 13 the access point doesn't appear?
can i Integrating Arduino with Google Maps or waze?
FastLED with 2 PIR Switches
I2c lcd display with Arduino using python pyfirmata
Weird wemos D1 R1
Error: expected '=', ',', ';', 'asm' or '__attribute__' before 'void'
Arduino project issue
Cheap ssd1306 oleds not showing i2c address
Cant read an BMP image from SD card using sd.h
Please help arduino code error
Hardware spreadsheet help
Problem with serial monitor on arduino nano with CH340G chip
I2C and Pressure Sensor
Serial.begin woes
Error Asteroid Attack
Problemas con modulo GPS y tarjeta sd
Make Your Uno Audio Synth Only Makes Pop Noise
Motor Driver Problems
Using BMP280 sensor to control servos. Need some guidance with coding
Arduino with adafruit data logger shield
Help with random numbers
My arduinos only connect when i open the serial monitor
Newbie 1st project - Will this work?
Sending URL to android phone though NFC
Temperature controlled Linear Actuator issue with Relay Timer
Parts for ultrasonic directional speaker
Decimal places variables
GSM Based Arduino wireless name board with P10 Led Panel
Receiced serial data is wrong
Arduino Mega Kommunikation C# Programm Fehlerhaft
No Wifi (ELEGOO Smart Robot Car V4.0)
Arduino resets and freezes when connected to computer
Turn on realy in every hour with rtc using arduino
12V Battery for Nanos and Relay Board
Reading data from joystick through bluetooth HC-05 module
Arduino Circuit, 2 buttons, 2 leds, and motor
Arduino Coding for two non-overlapping Clock signals with 50% duty cycle and 900MHz frequency and 1V amplitude
Stopping bomb defusal loop to avoid repeatedly pressing button
Code not woking correctly and i dont know why it wont run the last if statement
Uno R4 WiFi connects, displays IP 0.0.0.0
Scope not declared?
Pixels Animation with sensor - UNO/SENSE/DOPPLER
HD44780 not displaying anything?
How to clear a text before a new text is placed in some spot
Problems using External IRQ's as Slave I2C
Self Balancing Robot Help
4 shift registers in and out getting artifact
Push button to switching Led effects
More crazyness with braces!
Reading 12 volt battery using an esp32
Problem with my Velostat pressure sensor using multiplexers
Sending data from ESP32 to local flask server fails: "send payload failed (-3)"
Else' without a previous 'if'
DWIN dGUS to NPK sensor
Nrf24 bidirectional
Serial Monitor not carriage returning
Error message for code, can't figure it out
Rc excavator project
New to Arduino, Need Help With Turning LED's on after set amount of time
Errors with Arduino 1010 IOT
Arduino IDE - LED Sketch question
Widget weird behavior push button
Amg8833 and nextion NX3224K028 connect arduino uno
Evert definition/declaration is a redifinition
Adapt existing robot code to use SimpleFOC commander & BLDC
Trap timer with RTC
Como les va gente bonita? Estaba haciendo un proyecto de una banda transportadora con sensores infrarrojos, pero no me funciono, Esta bien el código?
Arduino uno sck not working
Serial.read() wont serial read bytes over 128
Heltec Lora esp 32 board V3 libraries
Variar frecuencia de un motor 3F AC
Button counter not incrementing
Current measurement verification method using sct013
Controlling multiple timed relays off buttons
Warning: invalid conversion from 'const char*' to 'word {aka unsigned int}' [-fpermissive]
Arduino UNO + Software vs Hardware Serial Connection with alphanumeric OLED problem
Serial communication between tfmini plus and mrk gsm 1400 doesnt work
How to put a user Id and password to our Arduino webserver
Dk d kql wlw,sl docerl ;dlka s;okoq p;ke asmd; lask;do asd
I want to make a count down time that auto repeats
Powering problem,
Automatically water, soap, hand sanitizer and hand dryer problems
Pantalla lcd de 2 pulgadas no muestra nada
Help with Arduino IDE 2.3.3
Problem with ws2812 neopixel LEDs
Counters not working
Problem parsing serial data
Need to control four audio stages digitally, namely gain, volume, tone & level
How to break out from DO WHILE LOOP
'positive' isn't declared and I can't figure it out
Delayed output using Keyboard.println()
NPK Sensor to Arduino Mega 2560 Keeps Returning 255
Connection to Processing not working
Automatic plants watering system
Bad LCD visualization
Issue with turbidity and pH level readings
TFT LCD Display to Arduino Mega does not work
Controlling groups of pixel leds 4 each by pressing individual 4 buttons but need colours different on different groups. Below code is working good
Use Arduino with MATLAB
Is it possible to turn on a bulb depending on the day (using a rtc)?
WIFI communications with PC
IoT carrier cloud messenger widget
Hyy can some one help me with code # code that runs servos taking input from mpu6050 and controlling servos using pwm servo drive)
Noisy AC voltmeter
Soil Moisture sensor with Arduino board
This my code that needs help
Control LED brightness with IR remote on the ATMega4809
Void loop doesn't work on my recevirer code
How do I calculate how much amps i need
Master-Slave connection Hc-05
Intergrate code with project
Peristaltic Pump with Reverse Polarity Switch
Help me with my project
Compilation probllem(solved) unnistall &install
Multiple Ultrasonic sensor
XBee S2C Rssi value is always zero
ILI9341 Calibration
Help wifi telnet to serial. :)
Wemos notification ifttt
Stepper motors not responding
Time off Delay for pump control without using delay
Why my dc motor cannot run ? (In proteus simulation)
Arduino Uno R3 radio NRF24L01 and DHT22 telemetry
Controlling pump with Digital pin, but use another power source
What is wrong with my code? It want print to the monitor
I made a code and I need help. I need to change the adc to minimum adc and maximum adc instate of adc at diffrent times
String conversion Error
'countof' was not declared in this scope
Controlling several motors
Suggest parentheses around comparison in operand of '|' [-Werror=parentheses]
Paris Street Furniture Walk, Don't Walk Sign. Oh and so New to Arduino I only heard about it recently
I want to send command with Bluetooth from python to esp32
Controlling 1.5Hp motor
Glider flap settting indicator to OLED display
Nema23 stepper motor vibrate when run
Problem with returning Serial.Print ();
Burn bootloader on ATmega2560 using USBasp
Can I use another bracket inside a delay bracket?(Solved:nikoexcited:)
Odometer for 1992 vehicle?
Need help with code that crashes
Verifying a sketch
Serial port interfere with an e-paper panel
Arduino nano 33 iot compilation error
Detecting when an aux cable is conneceted on a TRRS breakout board
Why is my first "if" line only blinking?
How to use different fingers for different relays
DC motor not working correctly
Rc car cant move
I have problem with code
The DC motor does not rotate continuously
Arduino mega 2560 i2c sensores vl53l0x
NRF24L01 with serious data loss
Help me with thissssssssssssss
How to code for Servo using IRremote (1 button, 2 directions)
Dropdown using websocket
Sketch exit status 1 expected '(' before 'unsigned
Dfrobot Dissolved Oxygen meter reading 0 voltage
DS1302 Compile error
How can i connect 3 hx711 to ardunio leonardo r3
Serial Monitor unusable
Continuation on bidirectional rotation counter
Design Bidirectional Buck-boost DC-DC converter using Arduino MEGA
Buttons serial print
Processor on Minima gets hot when it is plugged in
Gaps in a sketch lines
How to monitor battery of Arduino MKR1010 and LiPo 3,7V
Reduce signal noise
Moving 2 servo right, left, up, down
Voltage drops When motor Connected to Drain and +ve of Battery
Error in IoT Cloud
Turnin on light in room with photoresistor
Serial communication with multiple push buttons and multiple leds
Ic acs71020 arduino full code needed
Only able to turn on a certain number of addressable ledsWS2812B
Seems a bit draconian
Newbie problem - why LED only flashes shortly and doen't stay on
I'm trying to have multiple inputs but it wont work
Hardware Serial Port Communication
Problem : expected unqualified-id before 'if'
Communication in Arduino
How to program extra tags for 13.56MHz RC522
ESP32 MH-Z19b CO2 Sensor
Switch task with potentiometer, mulltitasking
Discord webhooks
Potentiometer does not read values
28BYJ-48 – 5V not working with esp8266
L298N direction control does not work
Arduino Cloud, some webhooks do not include all variables
Keurig Water tank
Attach interrupt getting ISR not defined
Missing terminating " character - please help
Error in first data serial communication
Change value variable while in a loop using neopixel library
const char* error
Colorize texts with editor
Help with code, cannot get read out on display
Checking the Connectivity Status of the HC-05 Bluetooth Module
Control 5 servos 3 joysticks recording coordinates arduino uno
Error: missing terminating " character & error: expected ')' before ';' token
Data Logger Crash
Line following and obstecle avoiding
Hello, good day, I have a nema 23 stepper motor that reaches up to 150 RPM, how can I reach higher speeds?
Want to ask, why the serial monitor is not showing the reading/results for esp32 board
Escrever um numero grande na EEPROM
Max31865 that switches a relay by temperature
Need help with code for my project
M5 x timer camera
Mega and external PSU
Can I connect IR sensor to any digital pin?
Re-creating the piano boot
Brownout detector was triggered , rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
I have a problem using the PIR sensor
What's wrong with the signs? I have reviewed the program many times
How can I change keyboard Layout
Pikabot coding problem. speedright has not declared in this scope
How to connect Haiwell Hmi with esp32
Fast measuring Distance Sensor
? Coding for 1RPM constant, Nema 17 through A4988?
Corriente por pines digitales y analogicos
Zigbee,wifi,ble use together in arduino ide
Arduino MKR Zero Keyboard Emulation not working
Crear rutina de cálculos
Help with lcd interfacing to arduino nano board
Hey can anyone tell me whats wrong with my code?
Strftime to useable variables
Ethernet Shield 2 not working on Arduino Mega
Check schematic for errors
Fade out animation with FastLED
File not found "executable" error
Possible for Arduino to read sensor data and wait for user input to turn stepper?
How to use both accelerometer and gyroscope sensors
Screen partially display
Arduino Serial Plotter Not Displaying Negative Values for EMG Signal
2N3904 Transistor partially open when HIGH but closed when Floating
Tendero de ropa automatico
Having issues converting 12v dc power to 5v
How to structure my code
How to control 12V power source with arduino UNO
Issue with button presses displaying on serial monitor
1 dc motor, 1 servo, 2 nrf24l01 doesnt work, please help
NEMA 17: Broken Motor or Too Little Torque?
Konica minolta bizhub c25 With Arduino Uno
Sorting through code from Fiverr programmer
Lcd and rtc project
Arduino Cricket program
I have a problem with my code it should be a water shooting robot by gravity plus mapping
Arduino Nano -Erratic Analog to Digital Conversion
Arduino with ssh
Code doesn't work without port monitor
Data Logger Crash
Charging indicator in the arduino nano motor carrier stops working
SD card + SIM800L failed sending
Errors on Arduino
Some LED Trouble
How to make bluetooth gps spoofing
Only initializing in serial monitor when connecting Max30102 and arduino uno
MODBUS library to read / write the for coil or relay output
Help with arduino, robot, and servo motor
Please help with sending and receiving data through hc-06 bluetooth for android
Repeated transaction happens with esp32
Servo Motor controlled by inductive sensor <HELP>
Why my Servo does not turn?
I am trying to connect MPU9250 with my Arduino UNO and I am getting this error while uploading the code
How Converd string to char
How to program 3 ultrasonic sensors?
Project Guidance for 4 stepper motor system
Serial doesnt showing ip
Arduino IDE 2 pico build process problem
I want to create a Toggle Push Button switch, when LED HIGH, then i want to show " LED IS ON" either "LED IS OFF", Please can any one help me?
How can i read a charieplex with arduino
Push button to adressable LED strip on Arduino Nano
Does not match any class
Adifruit Motor Errors uploading
Yo guys, Need to know the name of that Other IDE
DFPlayer suddenly behaving strange - plays first track only
Problem to link my variable inside my dashboard
Radar project, code error
Communication Issue between Arduino and Python Script in Jupyter Notebook
Serial monitor prints 2
MAX6675 with SMPS (Readings haywire)
Need help with Pi Pico + HID
Can I put clockwise and counterclockwise on photoelectric rotary encoder?
Expected initializer before setup
Looking for code
Looking for code
Balancing Drone
Controlling 4 stepper motors independently with 2 joysticks (for V&H movements) on UNO
RS232 with arduino uno
Help pls, beginner trying to do a project
Dump load controller for hydroelectic purpose
HELP: with wiring for a 2.42 OLED with Arduino Nano 33 IoT
Weird characters on serial monitor Arduino
I want to change x y z movements in software but it won't
Which is better, python or Arduino program(C++)?
Problem of balancing in quadruped robot
Controlling Ledstrip using Wifi
Arduino + bbdd problemas
Poco voltaje hacía los motores
3 digit counter
Stopping a remote control vehicle
Rudder code with potentiometer
Google Coral Dev board
Writing to SD card, 0 bytes written
Downgrading ESP32 board ver
Esp32 error no core dump partition found
Voltage leakage?
An old programming adage… (oops!)
My "loop" function only seems to work for 3 minutes then stops
Amplificador operacional y arduino
How to make the PIN OFF time default to 3 seconds in this code?
ESP32/Arduino - Executing invalid condition
Error uploading cyber falls code to nano
How to code "free" synchronous motor
Help with ps2 controller
Automatic control of feedback linear actuator to a desired position
Tarjeta de relés de 8 canales encienden en orden de mayor a menor
Arduino CanBus data HEX to DEC
I don't know what's wrong with the code
Inline Assembly if statements
An arduino telescope
Counting state changements
Hall effect sensors with a mega 2560 and a relay module to power solenoids
Alimentar 3 servomotores
Wemos D1 Mini - communication to Wemos D1 Minis - wireless
Pre-compiler bug or compiler bug? If defined does not work
I need some help with this error code
Why does this code not run on Arduino Nano ESP32 / Board keeps restarting
Triggering 5 millisecond pulses part #1
I'm not able to read RFID tag with my two arduino UNO with the module RC522 RFID
NRF24L01 Not Working
2 linked IR detection sensors
Sabertooth 2x5 in Simplified Serial Mode
"Error Initializing MCP2515..." using coryjfowler lib
Trying to use UBX on an BE-880 gps chip in Arduino
School bus to display pedestrian crossing
Multiple definitions TinyGPSPlus
8x8 Font editor, for MAXduino type fonts
Delay/Millis use
Can not hear anything from the SDcard
Error quemando bootloader
Arduino mega xlights
Need a code for weather station that sends data to Blynk + display
Problemas con convetidor TTL RS485, Chip Max487
How to control heating rate?
Invalid use of void expression
Issue with Accessing "ESP8266 Sketch Data Upload" Menu Item in Arduino IDE
AT Commands Not Working for HC-05 Bluetooth Modules
DHT buzzer (how to declare the event from the sensor)
The will to help depends on how you present yourself - egoistic demanding or engaged having done the easy things yourSELF
Arduino no registra huellas
Problema con sistema de automatizacion de luz (Arduino Mega)
How to Read Speaker values from some device to use as if function
Why my ESP32 camera doesent give me IP Address
Help With Excercise
How to show my random time on my 4times 7segment display
NodeMCU8266 fails to detect Neo-6M GPS module
P5.serialcontrol connected to p5js - problem with port detection
Arduino Uno code to interface 4 flow meter
Tft st7735 + max 6675 + esp32
Sub-menu not working correctly
Communication protocol
Configuring digital pins only if an input is received in Arduino UNO
Help with switching players in a 2p game
How to put reset, stop, enter key on 4x4 keypad
LCD with I2C does not print more than one character
Smart greenhouse
GPIO output gpio_num error
Stoping rgb sensor at specific rgb value
Read CAN message from a machine
Issues connecting ESP-32 DevKit v1 to Arduino IDE
SHT31 use readTemperature and readHumidity or readBoth
Cronometer with ultrasonic sensor
2 stroke engine RPM counter, that enables an output when an exact rpm value is detected
Fram spi read-write writes to one memory location
Nrf24l01 does not show all characters in the receiver
Request for member 'startsWith' in 'Serial.HardwareSerial::read()', which is of non-class type 'int'
A 50m laser range finder module from Elecbee
Pulse Sensor Not Working
"invalid header: 0xffffffff" when I press reset on ESP32-CAM
Ultrasonic sensor code
How to convert float point into microsecond?
Arduino_LED_Matrix should on() only turn on LED and off all the others?
Replace relay to open 5V signal
Having a problem with cc1101 code
Program ATmega328p using BT module HC-05
How does sd card with rfid card reader work?
Cheapest microcontroller to convert 1000-2000us to 0-100% PWM
Fjern aflæsning
Help coding multiple potentiometers
HELP NEEDED editing code for new display
Controlling multiple servos independently from serial monitor inputs
Fun Robot Project - Code Issue
Probleme with SP610 Pressure sensor
'D8' was not declared in this scope; did you mean 's8'?
Curve Tracer open circuit line
Creating a new partition scheme for ESP32 AI thinker
DYP-A02YY Waterproof sensor
Encoder motor control speed and position remotely
Drone spinning round
Sending a txt file to Arduino via UART interface
Http based project
Getting userinput from serial monitor
222 counter from nothing
GSM Module - SIM800l and NEO-6M Gps module arduino code not working together
Why not equal if(message == "on" ){} in ESP32 bluethooth
Arduino code for flex sensor to count footsteps
Trying to stop the serial monitor at 10 seconds
I've got some error?
Storage space please help
Rfid Tag save data in EPPROM
Lcd muestra cuadrados blancos en circuito de control de acceso por teclado
Liquid crystal I2C
Reducing ESP32C3 Power consumption while still Scanning & Advertising?
Trying to show multiple texts
Powering high and low voltage peripherals with one power supply
2 nano works ok on win. on linux 1 ok the other no
Serial bug(I think)?
Rtc circuit code
SERVO not working, with Nano
Using arduino to make an oscilloscope for automotive use
Hoverboard Arduino flysky
Troubles at breaking from loops
I can print initial sensor value with serial1 but this value doesnt change
Arduino IDE causes a compilation error even if 'extern "C" {' is inside a comment
Can you please explain this code give below?
Logic level hc-sr04 TTL and CMOS
PIR sensor output toggled always even noone near to sensor
Compilation error: 'HIDMouseEvents' was not declared in this scope
I have 3 separated codes for my project but when i try to make them together i keep getting no sense errors that didnt't show before
Im having trubble finishing this code
Ardruino Nano and Pro Micro CH340 Not recognized by Win 11
N424l01 wireless fireworks ignition system
Help me to find out the coding of this project
NRF24l01 broken or I'm just bad?
Iot arduino problem
If I change the delay time, code not working
Uno R4 minima PWM
Encendido de 3 leds con 2 pulsadores con bucle for, array y millis
Push-button Long vs Short press
DC motor 775 and code
Line Following Functionality In Self Balancing Robot
Problema con multireceiver con nrf24l01
How to create threshold and show a value?
What is this yellow/orange chip on arduino pro micro?
Help For Stepper Motor Fluctuations Near Ignition Electrode
If while code compilation problems
How do I make my Mega 2560 check if something has changed ten times a second?
How to control a stepper motor with a text file on an SD card
I have Done Coding in Aurdino UNO but it's not uploading and Yesterday i have to give Presentation on my project. Kindly Please Help
I Cant figure out the issue
Ultrasonic Water Level Indicator Using ESP32 Wi-Fi based
Blue LED not working
Habilitar entrada de micro sd del módulo a9g
What is "sizeof (int)"
Pca9685 moduls powering
Restart delay when press button
Help with programming flex sensor to trigger a relay
How declare char type array
Problem passing arguments to a class function
Unit won't connect to wi-fi when a specific IF statement in loop
Arduino and C programming
Iron Man Box and Loop helmet code issues
How to send messages to Esp32 from pc through Ethernet without internet in physical layer...?
Arduino con matrices LED, al conectar a una fuente de alimentación independiente no funciona
NMRADCC utilisation
I'm got Stucked with this error PlZZZ Help
Try to send "swi01,swi02,swi03,swi04" switching commands to ATEN video switch VS0401 through RS232 TTL converter
How to controll servo via imu on nano rp2040
Please fix status of app on ios
Stepper Motor/LCD coding and wiring help?
On the Byte Limit Problem of AsyncWebServer_ESP32_W5500
Adafruit 2.4" TFT FeatherWing V2
Waveshare oled module is not working
Vba and arduino
Delay in sending data over wifiNINA (arduino nano 33 iot)
How to assign DDRC and PORTC in Arduino code?
Node MCU Challenge
Connecting 5v series lighting to Arduino
Measure a small current of 0 to 4000 microamperes
Problem sending data ph sensor to blynk 2.0
Pull up and pull down resistors
Help me please :(
Totally Frustrated
How to use two tcs34735 i2c color sensors using a single i2c bus ?
Initializing SD-Card… Initialization failed Micro SD card Reader and Arduino Mega 2560
Control Led using MUX & Arduino
DC motor consume to much current
Serial Communication Not Working with SUART pins
How should i connect 3v micro gear motor to arduino?
nRF24L01 Wiring with 10 Pins
Garden project - problem with button
Help using pressure sensor to operate solenoid
Two Ultrasonic sensor 1 is not giving correct readings
More than one button with a screen
Question about IR Thermometer with 2 Line LCD on Uno
Connect arduino with gsm module to freepbx server
Another One: Error Compiling for board Arduino Uno
Write and read char, string, int array for EEPROM
ELMduino - Couldn't get into ELM327 using Arduino Uno and HC05
Rs232 communication but weird character in output ttgo, how to read ascii
Uploads but does not execute
A simple controller for steppers & fans
Arduino cloud interfacing in cloud
Keyboard text to binary output
Arduino + NodeMCU ---- Publishing Data on the Cloud
Hello , I'm new to programming with the Arduino. I'm trying to build an interface but I keep getting this error "expected ')' before numeric constant
Arduino resets when relay turns on/of
Hi everyone, my code keeps stopping after a while. please Help!
Can someone help me with my clock LCD?
Is it possible to do OTA update for the ESP32 using Arduino IDE 2.0.x via Ethernet instead of WiFi?
Help Combining Two ESP8266 Projects with Web Control, Timers, and EEPROM
Interupts aren't working
Laptop to control ardiuno bluetooth car HC-05
Need help with a Arduino project
Hi I would like to know the code to make it count the movements of the servo motor to open the bin thanks
Little problem with my program
23LC1024 manual programming
Not being able to use brushless motor
Help with esp8266 coding l298n
Read 2analog inputs and compare them
Running a fan only when a 48v wire is active
Reprogramming the Elegoo Robot Car V4 and Arduino Learning
General question about DEMUX for 12v motor
Beginner problem help
LCD with i2C connected to Raspberry pi 4 not working
Can it be integrate using Iot in associated with PSoc 5LP
Coding timer help me
I need some help with my code i cant find what is wrong with my code
Question about nextion display and can you hook up more than one speaker
43 servo motors through transistors, jittering
Problem Switch case statements with stepper motors
Pressure sensor ABPDLNN100MG2A3
PH sensorCalibration Issue - Same Voltage for pH 4.0 and pH 7.0
HC-05 not pairing after disconnection
L298N driver heats up very much
Help in interfacing Arduino Mega and Arduino Mini with 12VDC solenoid valve
I want to rotate the motor for 3 sec and stop and then wait for ir signal and rotate for 3 sec in reverse and stop,but my motor rotates infinitely
(5k lines 25 classes)COMPLETELY READY TO GO - API package for esp-idf.Suuuper easy to use, ultra fast and all functionality
Serial print not working in setup, but works in a loop
Combining two codes (IR LED speed gate + LCD display)
Motor speed and count control
Solar inverter output voltage
Arduino - Change background colour of LCD
Counter with arduino
Noob Macro Keyboard Trouble
HC06 ATMega 2560
Storing and comparing SRAM memory address
Sketches stopped uploading on MKR WAN 1300 after running in SPI slave mode
Unusual LED behavior
BLE device connection with ESP 32 using the specified MAC address
ESP32 as a proximity sensor coding help
Pro micro showing button press when not pressed
Irrecv entire class explanation
Esp-01s Relay via firebase
Compilation Error while moving Arduino IDE to another computer
Esp32 cam program upload error
FastLED and IRremote
Using relay on solenoid lock
Code running in false if statement
Wifi connection for esp32
Controlling 3 electromagnets
Rotary encoder for small engine dyno rpm
PIR to Run Blink w/o Delay
Code can't be compiled
PLC Siemens S7-1200 y Arduino con ENC28J60
Designate TX pin for character transmission
8 buttons from 4 buttons and a potentiometer
Код в GPT3 AI нужна помошь ламеру ))
How to trigger actions to even hours?
LED circuit won’t function
An New Problem Occurs in NodeMCU Check the board everyone!
Connecting problem to servo +moisture+ir sensor
Arduino Libraries
Serial Communication from Raspberry Pi to Arduino Stepper Motor not working
3 relay switch based on sensor input using esp 32
Arduino Lifetest and Agetest
ESP8266 crash reading from serial
Flex sesnor not reading if else statement
Hellp with project
1.8 inch TFT with micro sd card
Slot car timer problems
Arduino IDE question
Making a children's toy for a NEA
Hi ,how to solve this problem
Serial2 not receiving bytes on wt32-eth01
SAMD51 multiple SERCOM issue
Dynamic lighting neopixel
Arduino Bluetooth with Stepper
Cant get the mac adress from de esp32
Potentiometer dilemma
How to use a transistor as a switch?
Arduino Micro as Controller
Dual solar tracking coding using 4 ldr , 2 servo motors, arduino
I get no response to AT commands with HC-05 and Arduino Nano Every
Problem for run new code on esp32 based board
Jsn - sr20 - y1
SAMD21 MINI by ROBOT DYNE NOT BEING DETECTED . USB PORT, CABLE , PROPER
Unable to upload when using USBC adapter
Design Question about detecting connections between devices
How much voltage would I need to power 4 tt motors, an SG90 servo and an ultrasonic sensor?
Websocket disconnects during normal operation
IR Remote and toneMelody loop results.value is random
Zabezpečovací systém přidání deaktivace
Need a dc motor working at 40 RPM
I need help with arduino project
Arduino Aggregation Error
ADXL345 false interrupt
How to display sensor data in to TFT LCD DISPLAY?---Add in to the attached code?
Interfacing AHT10 with 7 segment display
Does the UNO r4 wifi accept different code to a mega2560?
Error in Serial Monitor (esp32cam)
Can't receive signals from Flight Controller
Match the speed and position of 2 rotating shafts
Newbe morse trainer
Flashing microPython with Nano 33 BLE Sense Rev2
Powering load and Arduino from 5V
Nrf24l01 with many transmitters and single receiver
Measuring AC current in multiphase supply
Creating Remote Control for LED Animations with IR Remote
Pulse Counter with HEX Output to Pins
I2C communication with portenta breakout with I2C_0 and I2C_2?
Hi i want to use 9v battery for solenoid
USB TIme out error (Python | PSoC 5) Please help me to sort this out. Why its coming?
My Relay isnt working
Potentiometer "Debounce" values?
Anti collision car
Dlpf_cfg mpu6050
Arduino UNO R4 WiFi LVD
7 in one multiparameter soil sensor with esp32
Mi arduino nano, no se conecta
DCMOTOR test not working for Megapi or mbot Ranger
Inconsistent Readings from CNY70 Sensor for Line Detection
ESP8266 will not compile with ESP8266WiFi.h
ESP32 Troubleshooting with DIY LED Clock
Programming Gravity Analog TDS sensor using esp32 with firebase realtime database
How do I use RTC DS3231 to trigger a servo at a specific time of the day
Need help understanding the codes of a program
About Error compiling for board AI Thinker ESP32-CAM
Serial Communication Between ESP32 and TI C2000 microcontroller
How to connect Ultrasonic sensor to run DC motor with Ardino and same time Soil moisture sensor for water pump
Level Gauge using led bar graph
IR sensor don't work, who know's why
Ramps 1.4 sing stepper testrun
Max6675 esd and emi
Escape room help
Help me understand op-amps use
[Arduino Due] Quadrature Decoder Index Counter Does Not Increase
Turning on & off a motor using PWM from a remote control
Two PWM Signal with Dead Time
How to use function RTC.setTime() inside the loop() ?
How to take analog signal sample at one perticular period
Combine two codes in one for a solar tracking system with voltage and current display using ina 219
HC-05 (Bluetooth card) and UNO - HC-05 "not available
When programming AT28c16 it returns all "02" in the field area
Making an object move with a button tft display
Ardunio Mega gets hot With L293D. Need Help (URGENT)
Stopping the car after it goes off the line
Esp32 guru meditation error
HELP how will i integrate this code into this code, I am planning to open the lock from the otherside of the door using serial monitor from my laptop
3D printing filament tension
Lightning sensor AS3935
Can someone pls correct this code
Need help to configure LED running by preesing switch
Aurdino mega have to send data to two mcp2515 can module at a time and other aurdino mega bord with two mcp2515 should receive data but no o/p came
SIM A7670c UART communication is not working
Bridge rectifier GBU8J
Strange Undefined Reference for a function - ESP23
Find holes in flat plate surface with infrared sensor
Code doesn't even work
SD card intializatiom failed error (Arduino nano used)
Tinybee z offset
Error when using count function
Limiting the decimal places of float numbers
Stepper Buzzes but doesn't move
How to use Console app in IDE2
Need help with Nano HC-05 project
Newbie screwup I am Sure
Nema17 and a4988
SoftwareSerial - restrictions on Pins ? (Nano)
Adafruit_ILI9488.h
Esp32 camera is connected to relay, but when connecting to cellphone it will turn off
Reverse loop for model railway`s
Error: 'serial' does not name a type
Módulo de pantalla LCD TFT SSD1963, placa controladora con tarjeta de Panel táctil para Arduino 51 AVR STM32, 5 pulgadas, 5,0 pulgadas, 800x480
Linear encoder from printer, can’t get it to work
BME688 sensor disturbed on relay activation on MKR IoT Carrier Rev2
Diy Steering wheel with Arduino Leonardo and encode ky40
Compass sensor suggestion
I have written a code but it keeps giving me a error MESSAGE
Solar tracker (full size w/ 10 panels) with L298n
Accessing an array in PROGMEM
Question of Sequence Numbers
A4988 driver stops arduino from working
Ethernet.h library Ethernet Network Module
pot to controll on and off multiple led. between value?
eBox 3350MX - Needs older framework
Voltage error ADS
Arduino nano only runs the code when it is connected to the computer
Square Line Studios /w ESP32-S3 Development Board, with 1.28inch Round Touch LCD
Help/Thoughts on project
Elegoo Smart Robot Car v3.0
Trying to run Arduino code on external power
Communicate a shelly pro 3m module with an esp32 devkitv1
Im getting error when verifying the lesson 11 membrane switch module
Issue in establishing two way communication using 2 Arduino uno and 2 xbees
PCA9685 driver issue
Servo speed HCPCA9675
Low battery indicator
Issues integrating a stepper motor with a Arduino Uno
Delay blocking the code
How can i spoof arduino iserial number
Stepper Motor Not Working with Encoder Code
IRremote.h allwasys give FFFFFFFF
ESP32 deep sleep clears RTC memory
Strange Nano behaviour
TTGO display with pulse sensor
The Manchester code data written to arduino board using python can see the flipped output on the RX pin
VL53L1X and AtTiny85 - Run library - help
SoftwareSerial Library Error
Multiple sensors for arduino, is it okay?
How to Fix this Arduino Car
Motor goes on forever!
IR Remote Control
Oled display does not initialise
Help for making a remote control car
Mosi y miso con lector rfid y micro sd
Upload failed, exit status 1
PLX DAQ v2.9 not sending data continuously
MFRC552 not working
Prototipo de Guante para no videntes
Retraso en botón pulsador según el código que ejecute
Wiring an ESP-01S to an Arduino Nano
[solved] One column on keyboard dosen't work right
Power Supply & Amperage - Confirmation of understanding
How to use this forum - please read
Help Arduino Compilation error: expected initializer before '.' token. Can any body help me with this
Formula used to convert temperature, humidity, Ph and pressure of soil into soil NPK without using NPK sensor
Can not get my arduino connected to web first steps works then error no matter what i did i followed all instructions
LCD 16×2 not Lighting Up for Automatic watering system
I have a problem with image classification esp32-cam project with edge impluse studio, can you help me?
Arduino board for programmable Led strips
Open the GPS power failure
I need help to modify my code
Arduino Nano + GPS + GPRS + LoRa + WebSocket + PHP + MySQL
HELP
Arduino robot arm servo ultrasonic sensors not working
Controlling 500 relays
I use ESP32-S3, but Arduino IDE serial monitor doesn't output
How to combine 3 different sensor into 1 program and start the program by using one Button , this is the program i created but it seems cannot work
Max485 modbus rtu
Initializing SD card...initialization failed
Power issues with the HW-130 Motor Shield
Change default key of rfid tag
Could any body help me with the error regarding mouse library
Using Adafruit Ultimate GPS: only logs Lat/Lon when board is reset
Windows doesn't recognise my arduino mkr wan 1310
How to display arduino tft shield lcd
MODULO CH367s con ESP32
Saving stepper motor position with corresponding RSSI value
Arduino Code 5 motors with 3 boards LN298N and ESP8266
MCP23017 to read hall sensors
Problema de arduino reciente
IDE 2.x eats CPU time in Linux
RFID code isn't working as expected
Reaction Wheel Control
I want to print out the value pressure and time to make graph force vs time but when the times 0 the pressure already has value
Cant select port with emitter installed
Please help me rewrite delay with millis
Using ARDUINO mega2560 TO SIM800L SMS not reciving only full in hardware
Servo library problem
Help on Building CNC using Arduino Nano + CNC Shield v4
Why will the edge impulse password say you need authorization
Powering 4 Servos and an RGB LED Strip
Ultrasonic sensor noise
Sensor npk with esp32
L293D motor driver slowing down my motor
Why can't I use if else to change the color of the RGB led?
MIDI recognition issue with Arduino UNO
Ttl to rs485 converter
Connecting nRf24L01 to Atmega328PU with external 8Mhz Crystal problem
Flash BIOS w25q128jv surface pro 4
GUI con Arduino
5V output - battery input
Two L298N and 4 Linear actuators
Vending machine
Ways to draw ~1.5A from a 9W radio battery or some other small battery
Fsr + servo motor
Check string for special characters
Plz guide code that Aruduino MEGA can read from ADC converter
The stepper motor spins only if I touch the STEP pin on the driver A4988
DHT11 Error Code With Arduino Uno
Sound sensor results high reading
Ayuda con el controlador de servo y ph con rf
LCD + Water Senser
I need help for my project
Coding the Arduino Braccio robot
Arduino Code for Joystick for transmitter
ERROR: exit status 1 NEED HELP
Reading Sensor. Do condition with Solenoid and Pump
ESP32 Camera connection error and serial noise
How to rewrite the program that causes the system to crash
Portenta C33 I2C Not working with SparkFun VR IMU Breakout - BNO086
LM 393 thermistor module code
My LED is not working according to the coding
What's wrong with "x += 1"
Esp 01 void setup not working
IR Transmitter Circuit with Arduino FAILED
Proximity and light sensors Amperk VL6180. Incorrect work with the multiplexer
IR remote giving same HEX code FFFFFFFF
Output current 5 volts
Can anyone help me fix this for my ICT project?
UNO R4 ADC resolution
Radio frequency modules reliability
Mount ardunio memory in pc
IR Sensor operation
Why can't I connect my IR Remote and my oled
Help with juice dispenser
Favor problemas en la conexion Modbus-Siemens
Error in lcd.begin;
The Arduino Starter Kit Project 2- Non LED-light
GY-906 MLX90614 infrared temperature sensor not working with Arduino Mega 2560
What board to get for mulitple audio recordings
Library tft 4" ILI9488
Using an IR to control multiple LED strips for a scoreboard?
The problem of entering a 0 value between two different cards while transferring data to a single card with ESP-NOW
Como alimentar mis sensores?
I need help with arduino ESP8266
Arduino wired sensor network
PLC ide sketch issue
ESP32 BLE Bluetooth Examples Confuse Me
Gripper of Braccio robot arm
INMP441 only showing zero value
RC522 RFID Module not working
My program is not running
Folders Name Customization in DF-PLAYER-MINI — The MP3 Player Module
Clock direction too slow. TTL servo motor SC09
How to rear and print received Messages
LCD I2C Glitching on loop()
Math Error, Maybe
Why isn't my IF condition working?
Problem creating a Digital watch (Arduino Project)
Creating a Smart Car
Port disconnects after I upload my sketch
Nhd-0420d3z-nsw-bbw-v3 displaying vertical lines after every character in a sentence
ESP32Servo360 with BLE
TimeTick_Configure
Arduino and finger print sensor
Registers arduino nano
How to handle receive interrupts with ESP32 microcontroller and MCP2515
12v Relay to 240v Connection
After few minutes i cant connect remotely esp-01 in Arduino uno
Drivers for Mac
Having problem uploading to board Arduino UNO R3
Bee scale with Arduino Pro Mini 3.3V, SIM800L, HX711, DHT22, DS3231, ThingSpeak
The issue with the ESP32 connection to the RFID on the RST pin
Chromebook Serial port not detected
Getting a Compilation error
My code and wiring is correct but the IR sensor is not working
Arduino car problems
I want to Rotate stepper Motor only once
MISO problem when controlling an EVB with SPI
ESP32 Camera: Failed uploading: uploading error: exit status 2
Communication problem between arduino nano and df player in perf board
Issues with sensor kit temperature humidity
How can i use arduino meg +wifi +esp8266
Arduino Nano Access Serial Monitor While Supplying 12V Power Source
Engine not stopping for Card Scanner
Finding a way to use an Esp32-cam as a receiver for ELRS or Frsky
PIR motion sensor delay
How to calibrate adafruit icm 20649
Arduino Leonardo problem
Mystery exit status 1, without comment, building from source
One off project builder wanted
How to display Date in Scrolling Text
Sensores qtr-1a y qtr-1rc
Issue lighting up WS2811 strand with Nano 33
Keypad with Arduino IoT Cloud
Nothing to discuss, I already find the solution
Controle de mouvement avec nema17 + TB6600
Help with understanding a sketch and how to implement it
How do I create a point system for a flipper game
Variaciones altas cuando utilizo la configuración de 4 Hx711 con pesos grandes, sen 10245 y ESP32
Program not running
Solenoid Valves
White screen issue ILI9341 2.4 Inch TST
Carro (4 motores) evasor de obstaculos
Voltage sensor not reading right
How to recieve data from BLE sensor via HM-10 bluetooth on Arduino
Connect LED to GND without wire to Arduino?
PCA9685 Servo Pins
Arduino Nano Every and bluetooth module
Bluetooth Low Energy 4.0 Module x Mega 2560 Rev3 and general questions
Voltage For Project
Im having trouble with downloading the Agent and With the port connecting for the hero board
Ps4 controller esp32 rc car
Make servo motor control code
Controlling Servo Speed's
Adopting to 2.3.3 from 1.8.19 of your program
Creating Stereo Audio with Arduino Uno
Please help Instructions on HGC Laser distance sensor
If only runs once
SRXL2 library not recognized after manual install
Liquid Level measurement using copper foils sticked to the steel cylinder with arduino
Exporting serial data from Arduino in real time
Need support in PN532 and NDEF
Powering an Uno project board
Energizing two arduinos
Arduino ramps 1.6+ diconnecting
Need help with code
Controlling multiple outlets with SSR Relay module and Arduino
Github Archive for Arduino-28BYJ-48_Stepper-Motor projects
Wake-up light arduino need help
Esp32 and max30102
2.4" TFT LCD shield ST7789V with Wemos D1 Mini (ESP8266)
Did save as now get this error
Arduino IDE does not start
Pressing joystick centers both x and y servo
Question On Running Same program on two pins
Give a static string to VALUE widget using sketch
Uno R4 problem with FastLED and WS2811
Using push buttons to display two different scrolling messages
Nodemcu gps without gps module error
Spi interrupt issue
How does arduino communication between uno R4 wifi and uno R3 work?
I have 7 segment 2 display 18 pin
Compilation error: redefinition of 'NewPing sonar' for Obstacle Avoiding Arduino 4WD
HELP NEEDED! Issues with PIR motion sensor with servo motor s3003
Problem with USB ports of PC after project burnt
Infrared remote controls LED Multicolour is all ffffffff
LED P10 matrix with arduino mega
W5500 frozen arduino
Oled 1.3" SH1106 I2C display issue
Fingerprint not showing up whilst checking in serial monitor
Not getting desired output frim Arduino UNO analog Read
Modbus RS485 communication Through ATMEGAmega2560p
Fotografía impacto gotas 2
Issue with Incorrect Readings When Connecting Multiple Sensors to Arduino Giga R1 :
Arduino crashes/freezes
About setComponentText
STM32F303K8 analog input and PWM is not working
Serial input value is not readable
Enviar un dato por medio de un pulsador con método post y esp32
TB6612FNG Protección EMF
HELLO, New arduino using esp8266 for P10 LED Display and its not working. here is the code and the result. what do you think is the main cause?
I can't write or reopen my file in sd card
Adept smart car for Arduino
Color was not declared in this scope
Drag racing , calcular tiempo y velocidad
Temperature Recorder
Uploaden mislukt: uploadfaut: exitstatus1
Wemos D1 mini - HC-12 Mhz Module
Air pump motor not working
I need a business idea
Did't not found finger print sensor
Arduino to DWIN Display Serial communication issue
[IMMEDIATE] Esp 01 didn't responding at commands
Issue with the Serial Monitor
ESP32-C3 SuperMini port doesn't show up on ChromeOS machine
Resolving Error "Error compiling for board ESP32-WROOM-DA Module"
Bluetooth app not working on 4WD Robot KS0559
Mpu6050 and sim7600E-H http request
Pregunta de error
Alternatives to a Breadboard
Port Error occuring on device manager and on Arduino IDE
Arduino Wifi 1010 keeps disconnecting
WiFi tone on iPhone
Can't catch UDP datagrams from NANO + ENC28J60 to pc
Failed to create Arduino Create Agent
WiFi Not Working When Arduino nano RP2040 connect is Powered via 5V Adapter
Protocol error in uloading sketch to ender 3 v1.1.4
Build a project with a humidity sensor and LCD screen. Get the data from the humidity sensor and display it on the LCD monitor as follows: If the hu
Loconet and Interface board
Use of GT-U7 GPS
Arduino Nano - Connection Problem
Step counter in LIS2DUX12 chip
Is it possible to achieve accurate multi-camera start record synchronization across two PCs using arduino?
I wanna create wind turbine for capstone
I keep getting errors
IoT, websocket server disconnected
Help with aditional code
Morse code transmitter project not working buttons lcd issue
String manipulation
TMC2209 stepping extremely slow
Help with connecting stepper motor with encoder
ESP 8266 wont initiate my servo sg90
Controlling vibration around encoder motor axis at 10 degree angle
Adding Arduino as device in arduino clod
Problem when using Arduino Ethernet Shield 2
Signal pattern with ARDUSTIM
Hello, how are you? I need help. Can you help me with a simple project to design a radiation intensity measuring device? Thank you
Using U8g2 on RP2040 Pi Pico
Arduino uno never finishes uploading
Timer for illuminating one LED for 1 time only
Soldering tutorials
DS18B20 temperature sensor was showing bad readings. They are above 900, i don't know how convert them to celsius
I want connect to siemens CNC 828D controller to Arduino Esp8266
Need help with connecting a LCD at the UNo Developing board
ESP32 Broadcast NMEA Simulator
Making the ESP32 Computer [SOLVED]
Issue with multi PWM channels in ATMEGA328P
Peatón semáforo dinámico con multiplexación
Arduino Alvik and Chromebook
NEED HELP- Burglar Alarm System
Can't upload, exit stat 1
Can we generate Alternating Current using arduino uno with out any extra component with an input of 9volt DC
Serial use on Mega
Automatically switching of blinker with steering angle sensor
Controlling two BTS7960 motor controllers with arduino joystick
Arduino IDE 2.3.3 setting
20x times the speed with ESP-IDF on a ESP32. What did I do wrong?
No uploading Arduino IDE 2.3.2 in windows11
Problem with datalogger register modbus
Leonardo R3 connection
Lora Sx1278 and HC-SR04 interfacing ESP32
Uno powering from DC supply
NMEA2000 And serial communication
How to protect GPIO from sinking too much current
Problens with arduino size
Mando Ps4 R2 y L2
Program not working after I changed LED circuit
STM8S103 Code Upload / Execution Issue
Error: compiling for node MCU1.0(ESP-12emodule)
Building a rc plane
No response on AT commands from HC-05
How to code in this adruino
Even more arduino nano clone failures
Temperature Status
LEGO Build-to-Sound: Sonifying LEGO Models Using Sensors or Structure Recognition
ESP32 read GPIO0 button
My PC can't see the arduino UNO R3 usb port
Only 11 pins working on Nano
Fixing Compilation Errors
Redes de servidor y servicio
MEGA + TFT + progmem
Ultrasonic sensor responding when connected to esp12 via usb to ttl converter but not working when connected to power supply
DCC _decoder with min 3 sevo angles
Need Help with GY TOF10M Sensor - No Datasheet or Documentation Available
Arduino soldering
Module HC-05 error when sending
Hey Im trying to make a 2 axis robot using IK but im have some issues
Buttons not being read
I am new to arduino UNO R3 but the tx light is blinking and code is not working. Kindly provide a working code. here is the code-
Motor de passo com chave de velocidade e sentido
MCP23017 Suddenly Not Working
HC05 bluetooth module doesn't connect to smartphone
Car controlled with a turnig evolution
I need Help with this Project
Modulo RFID-RC522 error
Şu kod bloğunda şu hatadan kurtulamadım
Please help in rf amplifier code
Negative trigger/pwm
Eeg headphone sensory(Free)!
New to Arduino, help sought
8 bit clock signal in esp32
Lcd display doesnt work
IR transmitter and receiver
Request for PCB Schematic Review
Adafruit SH110X and two Displays
Stepper Motor pulse, direction and speed control
Problem With my Morse code Practice Device
Glad to join in arduino
How to solve full buffer problem when using MATLAB?
Cant get off UI LED
Troubleshooting FSR to speaker across breadboards
How to post in more helpful ways for beginners
REST API POST request ESP32 local network REFUSED
When i plug my escs red wire to arduinos 5V the brushless motor stops spinning
Exit status 1 Error compiling for board Arduino Uno
Can we measure the AC voltage with Arduino
Control rgb led by comparing rgb led pin values
Arduino cloud upload error esptool
How to mirror iPhone screen on ESP32_TFT ?
Tb6612fng and servo doesnt work when i try to control it through esp now
AHT20+ENS160 : ENS160 stuck after 2nd call
How to create a wakeup from deep sleep for multiple pins without delay ?
Esp32-c3 with mpu6050 using macbook air
Error Messages while trying to make a button play a song
Arduino Mini Sumo
Smart Robot Car v4.0(Elegoo kit)
Using of Capacitive Proximity Sensor
Where is the sdk folder ?
Brushless motor controller Allegro a4964
Storing floats and double in the internal EEPROM of Arduino
Why my pump won't work?
Sim module calling
Beginner- Help Needed (Pretty please)
Lora module SX1278 not getting initialized using Arduino Mega 2560nd Arduino Mega
Ds1307rtc library stops any program running on my r4 wifi
Servo arm issue
How to wire a 6 digit 7 segment display
Replacemenent for MKR 1010WiFi + MKR 485 modbus
ESP32-S3-Nano and Huawei R4850
Protocolo de comunicacion JCM
Need Program for Stopwatch for Arduino UNO
Language of the IDE console
D-DESK: Arduino Deck Idea
Controlling multiple stepper motors
Compilation Error
How to make esp32 camera
Servo motor girando descontroladamente
Clang-format: indenting braces
Tactile Switch not activating after Press
I need help I am new. could someone rewrite this for me so it works!?
Fuel Gauge IC for Primary Cell Monitoring
Step motor freezing arduino
Subject: Help Needed with Modifying LoRa Code to Support Two Sensors and Datacake Server
Arbitrary Precision Decimal Arithmetic by Arduino
Freeze up on ESP32 compiler errors
Laser light security system connected with RFID door lock at the both sides of the door
Controlling an Anaheim Automation Stepper motor using Arduino R4 WIFI with RS485 protocol
Sensor Shield V5.0 with servo and DC motor
ESP32 Bluetooth Car – Servo not turning and motor responds to steering commands
My nema 17 motor isnt working with my a4988 and esp32
Where can I find Obsolete datasheet
Arduino Uno R4 WiFi Telegram Nachricht senden
Push Pull setup for LED
Help me assess the correctness of the task
Esp 01 wifi car
PySerial "in_waiting" Almost Never Finding Bytes Sent From Arduino
TFT_eSPI examples don't run
LittleFS malfunction
Reading FS-i6X PWM to make a robot car
ESP32C3 Super Mini Wifi Error
Need Help Connecting Tatsuno Sunny XE to Modbus RS-485
Lesson 1 error upload
Esp32 can't detect at arduino esp32s3
Programming problem
Sae j2012da_202607
Se faire aider par l'IA
Error with RadioHead library
L293D Arduino Motor Driver Shield Problem and new eyes on problem
Stepper Motor Position Using Button Presets
Linear motion detection device with Arduino
Interrupcion con pcf8475 y esp32
Arduino IDE NOT working ?
Arduino UNO Project with 775 Motors fails upload
MKR Wifi 1010 + MKR CAN shield
My 2 wheeled remote controlled ir receiver and hc sr04 robot was working fine but now its taking code of only firstly pressed button but not subsequen
Help with serial UART communication between arduino and a sensor
Remote Control UNO R3
UNO Q: Fail to stop a running App
Help with old startere kit
Arduino UNO wireless relays
ILI9488 3.5" Fermion TFT White Screen + Nano ESP32 Disconnects/Beeps During Upload (Double Press Fix)
Robot mower perimeter wire
Subject: Arduino Nano CH340 not recognized - Upload fails
ESP32 RS485 Modbus CRC Error 227 with PQM1000S
Protocolo mdb vending expendedoras
Tecnologia amy pilliza
Tft ili9488 y esp32-s3
Arduino nano every code issue
2 programs in 1 on a Arduino micro !
ARDUINO nano esp32 board upload issue
Need equation for setting delay
Motor brushless no inicia
Arduino Nano 33 BLE sense rev 2 connect to VL53L0X
Arduino Uno + CNC Shield + A4988: NEMA17 motors buzz and lock shaft but won’t rotate
40X4 LCD Display Vertical Scrolling
Waveshare ESP32S3-POE-ETH with rain sensor RG15, cannot get serial comms going
IDE taking multiple minutes to open
Mi esp32-cam no compiling
Display LCD TFT 2.2" 240x320 SPI ILI9341 con ESP32-WROOM-32 da pantallazo blanco
Arduino to Generate GAIT cycl patters using CubeMars actuators
Instalé la version 2.3.11 de arduino y no puedo guardar los sketches!
