1 dc motor, 1 servo, 2 nrf24l01 doesnt work, please help
I have 2 10k potentiometers nrf24l01 (working with 5v with adapter) connected to my 1 arduino uno circuit. I want to command 1 servo and 1 dc motor on the other arduino with these. but i think there is an error in my transmitter code it is not working. how can i solve it please help.
transmitter;
#include <nRF24L01.h>
#include <RF24.h>
#include <SPI.h>
const uint64_t my_radio_pipe = 0xE8E8F0F0E1LL;
RF24 radio(9, 10);
struct Data_to_be_sent {
byte ch1;
byte ch2;
Data_to_be_sent sent_data;
radio.begin();
radio.openWritingPipe(my_radio_pipe);
sent_data.ch1 = map(analogRead(A0), 0, 1024, 0, 255);
sent_data.ch2 = map(analogRead(A1), 0, 1024, 0, 255);
if (radio.write(&sent_data, sizeof(Data_to_be_sent))) {
Serial.println("Data Sent Successfully");
Serial.println("Data Sending Failed");
delay(10);
receiver;
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
RF24 radio(9, 10);
Servo myservo;
#define in1 3
#define in2 4
#define enA 5
int motorspeed = 0;
struct Received_data {
byte ch1;
byte ch2;
Received_data received_data;
int ch1_value = 0;
int ch2_value = 0;
void reset_the_Data() {
received_data.ch1 = 128;
received_data.ch2 = 0;
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(enA, OUTPUT);
analogWrite(enA, motorspeed);
myservo.attach(2);
reset_the_Data();
radio.begin();
radio.openReadingPipe(1, my_radio_pipe);
radio.startListening();
unsigned long lastRecvTime = 0;
void receive_the_data() {
while (radio.available()) {
radio.read(&received_data, sizeof(Received_data));
lastRecvTime = millis();
receive_the_data();
unsigned long now = millis();
// Veri alındıktan sonra 1 saniye boyunca başka veri alınamazsa verilerin sıfırlanması.
if (now - lastRecvTime > 1000) {
reset_the_Data();
ch1_value = map(received_data.ch1, 0, 255, -127, 127); // İletilen verilerin aralığı değiştirildi (-127 ila 127).
ch2_value = map(received_data.ch2, 0, 255, 0, 180);
myservo.write(ch2_value);
if (ch1_value < -10) {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
motorspeed = map(ch1_value, -127, 0, 0, 255);
} else if (ch1_value > 10) {
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
motorspeed = map(ch1_value, 0, 127, 0, 255);
motorspeed = 0;
Serial.print("Ch1: ");
Serial.print(ch1_value);
Serial.print(" | Ch2: ");
Serial.println(ch2_value);
delay(10);
Welcome to the forum
Why did you start a topic in the Uncategorised category of the forum when its description is
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Your topic has been moved to the Project Guidance category
I have moved your Topic to Project Guidance....Please try not to post in Uncategorised again, If you are unsure about the categories refer to this guide or to the stickies for each category.
Also please paste your code & error messages in code tags(the <CODE/> button).
Thank You.
Schematics might be useful.
Not useful for anythind. Wiring diagram with pin labels, powering and the data for it, please.
