I am working on a project that has 1 LED blink at small intervals and the other fading in and out. Currently when it runs, the LED that blinks works fine but the LED that is supposed to fade in and out turns on for around 30 seconds and then turns off for 30 seconds. I tried to make seperate loops for the two but I do not have the knowledge for that yet. This is my code so far.
int led2 = 4;
int led = 2;
int brightness = 0;
int fadeAmount = 5;
#include <multiMap.h>
#include <blinker.h>
#define FADE_CYCLE_TIME 10 // how many seconds for a full on/off fade?
#define START_TIME 0 // ms
#define END_TIME FADE_CYCLE_TIME * 1000 // ms
#define MID_TIME END_TIME/2 // Ms
#define FADE_PIN 9 // The fading pin. (Must be pwm out pin)
#define BLINK_PIN 13 // Any digital pin with an LED attached.
#define STEP_TIME 50 // Number of mililseconds per change in brightness.
multiMap fadeMapper; // A non-liner mapper to hold fade over time info.
blinker LEDBlinker(BLINK_PIN); // A fire and forget blinker to take care of the blinking LED.
timeObj frameTimer(STEP_TIME); // A timer for changing the fade value over time.
int frame; // What step in the fading sequence are we in now?
void setup(void) {
analogWrite(FADE_PIN,0);
fadeMapper.addPoint(START_TIME,0); // Starting at zero
fadeMapper.addPoint(MID_TIME,255); // Mid time is at full bright.
fadeMapper.addPoint(END_TIME,0); // End time, back to zero.
LEDBlinker.setOnOff(true); // Fire up blnkings.
frame = 0; // Starting at frame time zero.
int fadeVal;
idle(); // Runs baclground stuff like the bliner.
if (frameTimer.ding()) { // If the frame timer has expired (->ding<-)..
fadeVal = round(fadeMapper.map(frame)); // Caculate a new fade value by mapping the frame time.
analogWrite(FADE_PIN,fadeVal); // Round the fade value to an int and send it out to the PWM pin.
frame = frame + STEP_TIME; // Bump up the frame time for the next reading
if (frame>END_TIME) { // If the frame is beyond the last reading..
frame = 0; // Reset it to zero.
frameTimer.stepTime(); // Restart our frame timer for the next setting.
You'll need LC_baseTools from the library manager to compile this.
Thank you for the help! If you do not mine explaining how to get to the library manager for my arduino that would be awesome. If not it is alright. Have a good day.
For some reason on this code the blinking LED runs perfectly fine but the fade LED now is blinking at the times it is needing to fade. Is there some error on my part? Thank you for your time.
Try this. It uses "millis timing" to give the effect that the blinking and fading are happening at the same time.
* Sketch...: sketch_apr16a.ino
* Target...: Mega2560
* Notes....:
//includes
//defines
//constants
const uint8_t led2 = 4;
const uint8_t led = 2; //note: if using an Uno choose one of pin 3, 5, 6, 9, 10, 11
const uint32_t kDelayBlink = 500ul; //500mS blink time
const uint32_t kDelayFade = 30ul; //30mS between fading LED updates
//variables
int16_t
fadeAmount = 5,
brightness = 0;
uint32_t
timeNow,
timerBlink,
timerFade;
bool
bLEDState = false;
void setup( void )
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
}//setup
void loop( void )
//get the millis count
timeNow = millis();
//blinking LED
//is it time to toggle the blinking LED?
if( (timeNow - timerBlink) >= kDelayBlink )
//yes; save the time for the next toggle
timerBlink = timeNow;
//XOR with 'true' flips bLEDState between true and false each pass
bLEDState ^= true;
//update LED
digitalWrite(led2, bLEDState);
}//if
//fading LED
if( (timeNow - timerFade) >= kDelayFade )
timerFade = timeNow;
brightness = brightness + fadeAmount;
if (brightness <= 0 || brightness >= 255)
fadeAmount = -fadeAmount;
}//if
analogWrite(led, brightness);
}//if
}//loop
Tested on a Mega. Note that pin 2 may not work with analogWrite on an Uno. It's fine on a Mega. See the comment in the code if you're using an Uno on using a different pin for the fading LED.
Thank you so much! It did work but I am a little upset that I wrote over 50 lines before you sent this and this works smoother. Thank you for your time!
