HI All,
I am very very very new to all this stuff but come here with an open mind and a really taste for learning it!!!
Basically Ive been doing some research online at the RGB strip lights (60LED 5050 5M roll) so that I can run some lights around the bottom side of the coping of my pool. Ive been in chat with a company who will supply the lights, but the RGB control units they use are 8Amp Output MAX, which means I will need a total of nearly 3 of these units for the just under 30M of strip lights I plan to run. This is a little impracticable as I will have 3 units all around the pool and will need an excess of wires to run back to a main control unit that will control the change of colours in 1 remote. Let me know if I have lost anyone.
I have a vague idea that the 4 wires (RGB+earth) control each colour, so applying power to one wire and earthing it will only light up that colour. I also understand that these units will regulate voltage for when the lights dance etc etc etc.
NOW, what I basically want to do, is replicate one of these 8Amp units into a unit that is capable of handling 30Amps, but doing the same job. Including use of the remote.
Would an arduino be useful in doing this and has it been done already???
Would I be better off working out how their unit works and just trying to modify the components to handle 30Amps.
My research didn't turn up alot so far around that amperage...
Hope someone can help...
