Thank you for helping.
I managed to sort the code by going in to the library and downloading neopixel by adafruit.
My next problem is that my LED strip has 4 wires, 1 for 12v and the others for RGB, this code is for 5v LED strip which only has 3 wires, 1 for 5v, 1 for ground and 1 for pin.
Could some one please adjust the code so it works for PIN 11-R ,10-G and 9-B.
I need a pacman light lol!!
Bellow Is the code
#define PIN 6
#define LAMPS 30
// adafruit init for this particular strip (see adafruit.com)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LAMPS, PIN, NEO_GRB + NEO_KHZ800);
// we are lighting max 15 leds at the same time, setting the max brightness lower
// allows us to light all the leds from an arduino board without separate power source
// (15 leds * 33mA = 495 mA)
strip.begin();
strip.setBrightness(120); // overall brightness can be 0 to 255
strip.show(); // Initialize all pixels to 'off'
// white food pixels
setFood();
delay(1500);
// pacman eats the food
eatFood();
delay(1500);
// pacman is chased by ghosts
chasedByGhosts();
delay(1500);
// now pacman is chasing the ghosts
chaseGhosts();
delay(1500);
// the max brightness here can also be reduced to avoid using too much amps
void setFood() {
// fade in
for(int br=0; br<170; br++) {
uint32_t white = strip.Color(br, br, br);
for(int i=0; i<strip.numPixels(); i+=4) {
strip.setPixelColor(i, white);
strip.show();
delay(5);
void eatFood(){
uint32_t yellow = strip.Color(255, 255, 0);
uint32_t off = strip.Color(0, 0, 0);
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, yellow);
if(i>0){
strip.setPixelColor(i-1, off);
strip.show();
delay(60);
strip.setPixelColor(strip.numPixels()-1, off);
strip.show();
delay(60);
void chasedByGhosts() {
uint32_t pacman = strip.Color(255, 255, 0);
uint32_t clyde = strip.Color(249, 154, 0);
uint32_t blinky = strip.Color(244, 7, 8);
uint32_t pinky = strip.Color(249, 161, 166);
uint32_t inky = strip.Color(48, 218, 219);
// run back
for(int i=strip.numPixels(); i>-30; i--) {
// check: color, position, space between pacman and ghost
checkLed(pacman, i, 0);
checkLed(clyde, i, 10);
checkLed(blinky, i, 16);
checkLed(pinky, i, 22);
checkLed(inky, i, 28);
strip.show();
delay(60);
void chaseGhosts() {
uint32_t scaredghost = strip.Color(0, 0, 246);
// run ghost, run!
int maximum = strip.numPixels() + 5;
for(int j = -30; j<maximum; j++) {
checkLed(scaredghost, j, 28);
checkLed(scaredghost, j, 22);
checkLed(scaredghost, j, 16);
checkLed(scaredghost, j, 10);
checkLed(pacman, j, 0);
strip.show();
delay(60);
// check if this position is within the led strip, if yes then show the color
void checkLed(uint32_t color, int i, int offset) {
int pos = i + offset;
if(pos < strip.numPixels() && pos > -1){
strip.setPixelColor(pos, color);
// switch off the pixel before and after this one (depends on direction)
if(pos+1 < strip.numPixels() && pos+1 > -1){
strip.setPixelColor(pos+1, strip.Color(0, 0, 0));
if(pos-1 < strip.numPixels() && pos-1 > -1){
strip.setPixelColor(pos-1, strip.Color(0, 0, 0));
