yent41
July 16, 2023, 12:03pm
1
Hello,
I'm using the following code:
#include <Wire.h>
#include <RTClib.h>
#include <LiquidCrystal.h>
RTC_DS1307 rtc;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Wire.begin();
rtc.begin();
lcd.begin(16, 2);
analogWrite(6, 100);
if (!rtc.isrunning()) {
Serial.println("RTC-ul nu este pornit!");
DateTime now = rtc.now();
lcd.setCursor(1, 0);
lcd.print("Time: ");
lcd.print(now.hour());
lcd.print(":");
lcd.print(now.minute());
lcd.print(":");
lcd.print(now.second());
lcd.setCursor(0, 1);
lcd.print("Date: ");
lcd.print(now.day());
lcd.print(".");
lcd.print(now.month());
lcd.print(".");
lcd.print(now.year());
Serial.print("Time: ");
Serial.print(now.hour());
Serial.print(":");
Serial.print(now.minute());
Serial.print(":");
Serial.print(now.second());
Serial.print(" Date: ");
Serial.print(now.day());
Serial.print(".");
Serial.print(now.month());
Serial.print(".");
Serial.println(now.year());
It prints the time for about 5 seconds before showing some weird characters and eventually not showing anything.
This code right here works perfectly fine
LiquidCrystal lcd(12,11,5,4,3,2);
analogWrite(6,100);
lcd.begin(16,2);
lcd.setCursor(1,0);
lcd.print("Hello world");
What could be the problem?
we don't see your wiring. nor your schematic.
It might be bad contacts or the missing/not grounded RW line.
yent41
July 16, 2023, 12:18pm
3
I've been thinking about this, but I tried the 2nd code and that is working completely fine.
I am not very competent in the matter but I wanted to tell you that sometimes when it is rewritten over the screen everything gets messed up, try putting an LCD CLEAR at the beginning of the void loop.
The second code works because HELLO WORLD is the same every time, in your code the clock changes.
I'll give a shot at
lcd.clear()
Try this code:
// With LCD Clear()
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc;
Wire.begin();
rtc.begin();
lcd.begin(16, 2);
lcd.print(":");
lcd.print(":");
lcd.print(".");
lcd.print(".");
Serial.print(":");
Serial.print(":");
Serial.print(".");
Serial.print(".");
lcd.clear();
Or this code:
// With if <10
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc;
Wire.begin();
rtc.begin();
lcd.begin(16, 2);
if (now.hour() < 10)
lcd.print(0);
lcd.print(":");
if (now.minute() < 10)
lcd.print(0);
lcd.print(":");
if (now.second() < 10)
lcd.print(0);
if (now.day() < 10)
lcd.print(0);
lcd.print(".");
if (now.month() < 10)
lcd.print(0);
lcd.print(".");
Serial.print(":");
Serial.print(":");
Serial.print(".");
Serial.print(".");
yent41
July 16, 2023, 1:09pm
7
I tried using an I2C converter and that worked
xfpd
July 16, 2023, 6:45pm
8
yent41:
What is on pin 6?
Your original code works as it should. Check your connections, especially grounds (LCD, RTC, Arduino).
https://wokwi.com/projects/370435657847858177
// https://forum.arduino.cc/t/16-2-lcd-problem/1148622/6
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc;
Wire.begin();
rtc.begin();
lcd.begin(16, 2);
// analogWrite(6, 100);
lcd.setCursor(0, 0);
lcd.print("0");
lcd.print(":");
lcd.print("0");
lcd.print(":");
lcd.print("0");
if (now.day() < 10)
lcd.print("0");
lcd.print(".");
lcd.print("0");
lcd.print(".");
Serial.print("0");
Serial.print(":");
Serial.print("0");
Serial.print(":");
Serial.print("0");
if (now.day() < 10)
Serial.print("0");
Serial.print(".");
Serial.print("0");
Serial.print(".");
@xfpd
See what happens when seconds pass 59.......Should show 0, 1, 2.....
but show 09, 19, 29, ......
And when seconds minutes add up to 59.......Should show 0, 1, 2.....
but it shows 0 minutes and 159 seconds............
xfpd
July 17, 2023, 1:12am
10
@ruilviana
Yes, it proceeds strangely... in the Serial Monitor, seconds proceed 1, 3, 5, 7, but in the LCD, 18, 38, 58, 78... (I could not capture it... cheap computer) so it looks like this is needing a "zero pad" and place the cursor before every second, minute, month and day.
Note that the second example I suggested to the OP fixes this problem.
xfpd
July 17, 2023, 1:25am
12
I see your zeropad now. : )
(zeropad on wokwi )
system
Closed
January 13, 2024, 1:26am
13
