16bit Binary
Hopefully I do not come across as too silly on this one. I have an eeprom which is 16X16 serial and I have been able to sucessfully read it and get the 16bit's of binary from each of the 16 address's. But I dont know what to do from there what do I do with all the bits to be able to print it as a decimal number. I hope someone can help me and I hope that made sense.
Thanks
If you post the sketch we can see what form you have read it in, there is not enough information in this post to enable people to see what is happening.
Everything is working with this code all 16 bits are being output on the serial, I need to know how I can collect those bits and convert them to a decimal number.
int SS1 = 10; // set slave select pin
int CLK = 13; // set clock pin
int MOUT = 11; // set master out, slave in pin
int val = 0;
byte rcl = B10000101; // Recall Eeprom data
byte wren = B10000100; // Write Enable Latch
byte add = B11100111; // READ
/* SETUP */
// setup function begins here
Serial.println("Start");
pinMode(SS1, OUTPUT); // set CS pin to output
pinMode(CLK, OUTPUT); // set SCK pin to output
pinMode(MOUT, OUTPUT); // set MOSI pin to output
digitalWrite(SS1, LOW); // hold slave select 1 pin LoW, so that chip is not selected to begin with
void spi_transfer(byte working) {
// function to actually bit shift the data byte out
for(int i = 1; i <= 8; i++) { // setup a loop of 8 iterations, one for each bit
if (working > 127) { // test the most significant bit
digitalWrite (MOUT,HIGH); // if it is a 1 (ie. B1XXXXXXX), set the master out pin high
else {
digitalWrite (MOUT, LOW); // if it is not 1 (ie. B0XXXXXXX), set the master out pin low
digitalWrite (CLK,HIGH); // set clock high, the eeprom will read the bit into its register
working = working << 1;
digitalWrite(CLK,LOW); // set clock low, the pot IC will stop reading and prepare for the next iteration (next significant bit
void spi_read(byte working) {
; // function to actually bit shift the data byte out
for(int i = 1; i <= 7; i++) { // setup a loop of 7 iterations, one for each bit
else {
digitalWrite (CLK,HIGH); // set clock high, the pot IC will read the bit into its register
pinMode(MOUT, INPUT); // set MOSI pin to Input
val = digitalRead(MOUT); // Reading the first bit
Serial.println (val);
for(int i = 1; i <= 15; i++) { // reading the other 15 bits
digitalWrite (CLK,HIGH); //brings the next byte
val = digitalRead(MOUT); // read the byte
Serial.println (val); // Print the byte    = HELP HERE PLEASE !!!!!
digitalWrite (CLK,LOW);
void spi_out(int SS, byte cmd_byte) { // SPI tranfer out function begins here
digitalWrite (SS, HIGH); // set slave select high to enable
work = cmd_byte; // let the work byte equal the cmd_byte, defined in the argument in the main loop
spi_transfer(work); // transfer the work byte, which is equal to the cmd_byte, out using spi
digitalWrite(SS, LOW); // set slave select low
void spi_out1(int SS, byte cmd_byte) { // SPI tranfer out function begins here
spi_read(work); // transfer the work byte, which is equal to the cmd_byte, out using spi
void loop () {
spi_out(SS1, rcl ); // send out data
spi_out(SS1, wren ); // send out data
spi_out1(SS1, add ); // send out data
delay(500000); // delay
marca404,
I am guessing that you are trying to re-assemble the binary bits together back to the number they represents. If this is the case, you can use the following method:
num = i1<<7 | i2 <<6 | i3 <<5 | i4 <<4 | i5 <<3 | i6 << 2 | i7 <<1 | i8
Also this is the eeprom i am accessing
I see what your getting at but the numbers I am dealing with is 16bit
can you just start from the 15th bit then?
num = i1 << 15 | .... i15 << 1 | i16
I'm not really understanding what is happening there I am pretty new to this.
It is bit manipulation, see:-
http://www.arduino.cc/playground/Code/BitMath
OK thanks, looks like I got a bit of reading to do for working this one out.
