16x2 LCD formatting question
So this is a bit screwy using this 16x2 LCD. I want to display the temperature in the following format (for example): 78.35 degrees.
I’m using a Dallas One Wire thingy - and I get good data using the serial monitor. For example, when I open the serial monitor, I get the following: 78.35. Perfect.
Using the 16x2 display, when I use the code: lcd.print(temperature), I get: 78
Now, I realize, that for the 16x2 display, I have to put my own “.” between the first two (or three) digits, followed by a lcd.print(“.”) and then the last two digits.
My question, is how do I get the just the last two digits from my variable “temperature”?
I envision the code to be something like this:
 lcd.print("Temp is: ");
lcd.print(temperature);
lcd.print(".");
lcd.print(temperature); // just need the last two digits of the variable here
and a little degree symbol would be nice too!
Thanks!
That's unrealistic for a sensor that is accurate to +/- 0.5 degrees.
Why? I'd envision it to be:
lcd.print(temperature, 2); // assumes that temperature is a float, which then gets printed to 2 decimal places
On my LCD the character 0xDF comes close to a degree symbol. :wink:
lcd.printByte(0xDF);
Got the degree symbol, that's 337. As far as the accuracy, yah, I suppose you're right, so let's just get it to a tenth. Lemme try your suggestion, although I think I already tried this.
mattress67:
Your display understands 9 bit values?
First thing is first. I triedlcd.print(temperature,2). I get "1001101"
as far as the degree symbol, I successfully used:
lcd.print(337F). That gave me the degree symbol.
So, I still do not have the solution for the decimal display.
This should work at least for positive values.
int val = temperature * 100;
int dec = val % 100;
    lcd.print(val / 100);
    lcd.printByte('.');
    if (dec < 10) {
      lcd.printByte('0');
    lcd.print(dec);
Someday, I imagine you'll post ALL of your code, so we can see what types temperature and lcd are.
mattress67:
lcd.print(337F)
it gave me:
"error: invalid suffix "F" on integer constant
invalid suffix "F" on integer constant"
You're right,
lcd.print("\337F");
Anyhow, we are definitely getting closer - the last code gave me: 78.00 - but the serial monitor had 78.35
:slight_smile:
mattress67:
lcd.print("\337F");
This adds an additional 'F' to the display.
\337 is octal and the same as 0xDF or 223 or 0b11011111
I like my lcd.printByte(0xDF);
@mattress, can you give us your code.
I think we can get this straightened out if we can see the code.
Actually, that gave me "78.00223." So, I switched back to what I had for degree symbol. Anyhow, still not working as I am just getting 78.00 for values other than .00
The following code works.
void lcd_2_dot_2_degrees(float inFloat) {
int head, tail;
    inFloat = inFloat * 100;
    head = inFloat;
    tail = head % 100;
    head = head / 100;
    if (abs(head)<10) {
      lcd.printByte(' ');
    lcd.print(head);
    lcd.printByte('.');
    if (tail < 10) {
      lcd.printByte('0');
    lcd.print(tail);
My code exceeds maximum length. Most of the code is a motion clock, and it works great. I was just adding the temp sensor. And I agree, two decimal points exceeds tolerance, but I'd like to at least have one decimal point.
So now you want "22.8°"?
void lcd_2_dot_1_degrees(float inFloat) {
int head, tail;
    inFloat = inFloat * 10;
    head = inFloat;
    tail = head % 10;
    head = head / 10;
    if (abs(head)<10) {
      lcd.printByte(' ');
    lcd.print(head);
    lcd.printByte('.');
    lcd.print(tail);
Well, got it to work. Thanks for the snippet of code.
When I used the
temperature=(sensors.getTempFByIndex(0));
int val = temperature*100;
  • that didn't work. For some strange reason, I had to use int val = (sensors.getTempFByIndex(0)) * 100
In other words, when I used my variable in the *100, I kept getting values ending in 00 (81.29=8100). Only when I replaced my variable did I get the proper 8129, which the snippet could then work with.
Thanks all.
Probably because temperature was defined as int or long.
You choose to hide your code, so nobody could know or even guess that.
I'm laughing as I write this, but yes, I defined it as an int.
I tried to include the full code as I've seen many before me reprimanded for not doing the same, but it exceeded the message limitation (9000), and I didn't know what to include or not include.
How should have I defined my variable?
:slight_smile:
You can attach the whole .ino :slight_smile:
mattress67:
Obviously not as an int, long, byte,
(you tested the effect of using ints by getting the .00).
Read my snippet (it works) what does it take as parameter?
Take a guess. :wink:
As a basic rule:
Define variables with the minimal range that fit your needs,
type minimum value maximum value
__________ __________ __________
char -128 127
byte 0 255
int -32768 32767
unsigned int 0 65535
long -2147483648 2147483647
unsigned long 0 4294967295
Avoid floats, whenever possible, its much much slower than integer arithmetic.
If you need fractional parts, use 1/10 1/100 1/1000 units maintained in an int/long.
