Hello all,
I'm designing a small battery balancing circuit for 18650 lithium-ion cells. I'm using resistors to dissipate energy from un-balanced cells. I'm need help deciding which resistors to use to do this.
I know the voltage obviously, but deciding on the wattage and resistance required here.
Considering just one cell, with resistance in parallel, I'm using simple OHM's law to calculate the resistance I need. Which also depends on what current flows through, this will also decide the amount of energy that will dissipate. I need to know, if there is an imbalance, what is the percentage of imbalance. Here I'm using Samsung's ICR18650_25J cells out of the same batch. The number of cells in series is 4 (at the moment at least).
I've heard there is usually very little imbalance that occurs, when the cell is of good quality & produced from the same batch. I just need an idea as to how much current I'll have to flow in average through the resistors to achieve balance, example 200mA or 250mA or 500mA whatever is required.I need to know how much imbalance usually occurs if cells like this were used and other factors like temperature etc etc are kept optimal/ideal.
I know there are ready made ICs availiable for this, but doing this will help us scale it to massive number of cells if I learn from ground up.
Thanks peeps
