Hello I am working on a code that lets 2 led blink without delay while at the same time allows me to press a push button to allow a 3rd to light up. The problem I am having is the code only runs the first part the 2 blink without delay but it does not run the second part which is to turn the 3rd LED on with a button. I tried to combine the blink without delay code and a push button code to see if it would work but it did not here is my code.
const int LY=9;
const int LR=10;
const int LB=12;
const int BUTTON=11;
const int fade=10;
int ButtonState =0;
int ledState = LOW;
boolean lastButton = LOW;
boolean currentButton = LOW;
boolean ledOn = false;
boolean ledOn1 = false;
unsigned long previousMillis = 0;
const long interval = 1;
pinMode(LY, OUTPUT);
pinMode(LR, OUTPUT);
pinMode(BUTTON, INPUT);
boolean debounce(boolean last)
boolean current = digitalRead(BUTTON);
if (last != current)
delay(5);
void loop(){
currentButton = debounce(lastButton);
if (lastButton == LOW && currentButton == HIGH)
ledOn1 = !ledOn1;
lastButton = currentButton;
digitalWrite(LB, ledOn1);
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledOn == LOW) {
ledOn = HIGH;
ledOn = LOW;
digitalWrite(LR, ledOn);
delay(100);
digitalWrite(LR, LOW);
delay(100);
digitalWrite(LY,ledOn);
delay(100);
digitalWrite(LY, LOW);
delay(100);
Any tips or advice for me?
Thank you for your time.
