Overkill on the diodes there. You only need one per battery.
You'll get 5.3V out. The diodes (unless you select schottky diodes) have a 0.7v voltage drop across them.
You will be able to draw the 200mA from the 6v battery. The 800mA from the 0.5v battery will be doing nothing.
The potential at the anode of the diodes will be 5.3V. This is larger than the potential at the cathode of the low-voltage battery diode, so the diode will be not conducting. The low voltage battery will be switched out of the circuit and will therefore be completely pointless.
As indicated, if you tie 2 nodes together, the current between the nodes is related
to the voltage difference between the nodes and the resistance from one to the other.
In your case, V = 6V - 0.5V and R = 0 ohms. Now calculate the current using
I = V / R.
And what type of battery gives 0.5 volts when charged ???
No questions should ever be considered as silly since the asker is obviously seeking an answer to a problem but he/she really needs to consider what is being asked.
In answer to the specific question : the battery with the highest voltage will endeavour to force the voltage of the lower battery up to a point where both batteries have equal voltage. This is accomplished by a current (usually quite high) flowing from the higher into the lower. The nett result is that the higher voltage battery will lose AH capacity and the lower battery will gain AH capacity. However, if the voltages are vastly different, as in this case, and the battery impedances are relatively low (not specified in this query) the high current may catastrophically destroy either or both batteries, ie they may explode. They certainly will heat up unless some device (eg resistor) is used to limit the current.
To be safe, only batteries of similar design and capacity should be paralleled to increase capacity and ideally should have an isolation diode for each battery to prevent one discharging into the other or others.
You also have problems with how to evenly charge batteries in parallel - a whole different topic governed by battery chemistry.
