One option is to use a quadrature encoder switch (which uses two inputs), as well as a display. The encoder knob increments or decrements a value that is then displayed.
An encoder doesn't hold state, which would mean having to store value in EEPROM, and not being
able to set it without the power on and feedback from the code.
In the back old days a diode matrix would be used for such things I think, but that's rather
permanent. A rotary switch with a resistor chain is possible - just use it as one arm of a
resistor divider.
Even better (more reliable and requiring no calibration), use a shift register such as a 74HC165.
3 pins - clock, latch and data (2 inputs, one output) but the two output pins may be shared with any other function which does not matter if they are set randomly when that function is not immediately in use.
And of course, you can chain them for any reasonable multiple of eight digital inputs. You will need pull-up resistor arrays.
Why do I not like resistor ladders as control inputs? Experience with consumer devices such as computer monitors, TVs, MP3 players and tablet computers where this "kludge" is used.
