hello everyone,
im having a bit of trouble getting 2 stepper motors to run at variable speeds independently
this is the sketch im using at the moment
#define pin1 6//these are the Arduino pins that we use to activate coils 1-4 of the stepper motor
#define pin2 7
#define pin3 8
#define pin4 9
#define pin5 2
#define pin6 3
#define pin7 4
#define pin8 5
#define delaytime 2 //delay time in ms to control the stepper motor delaytime.
//Our tests showed that 8 is about the fastest that can yield reliable operation w/o missing steps
// initialize the 8 pin as an output:
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
pinMode(pin8, OUTPUT);
void loop(){
int numberOfSteps = 512;
step_OFF(); //turning all coils off
while(numberOfSteps>0){
forward(); //going forward
numberOfSteps -- ;//counting down the number of steps
delay(100);
backward(); //going backward
delay(100);
int numberOfSteps1 = 512;
while(numberOfSteps1>0){
forward1(); //going forward
delay(100);
backward1(); //going backward
delay(100);
with is function tab
void Step_A(){
digitalWrite(pin1, HIGH);//turn on coil 1
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
void Step_B(){
digitalWrite(pin1, LOW);
digitalWrite(pin2, HIGH);//turn on coil 2
void Step_C(){
digitalWrite(pin3, HIGH); //turn on coil 3
void Step_D(){
digitalWrite(pin4, HIGH); //turn on coil 4
void step_OFF(){
digitalWrite(pin1, LOW); //power all coils down
void Step_E(){
digitalWrite(pin5, HIGH);//turn on coil 1
digitalWrite(pin6, LOW);
digitalWrite(pin7, LOW);
digitalWrite(pin8, LOW);
void Step_F(){
digitalWrite(pin5, LOW);
digitalWrite(pin6, HIGH);//turn on coil 2
void Step_G(){
digitalWrite(pin7, HIGH); //turn on coil 3
void Step_H(){
digitalWrite(pin8, HIGH); //turn on coil 4
void step_OFFF(){
digitalWrite(pin5, LOW); //power all coils down
//these functions run the above configurations in forward and reverse order
//the direction of a stepper motor depends on the order in which the coils are turned on.
void forward(){//one tooth forward
Step_A();
delay(3);
Step_B();
delay(3);
Step_C();
delay(3);
Step_D();
delay(3);
void backward(){//one tooth backward
Step_A();
delay(delaytime);
Step_B();
delay(delaytime);
Step_C();
delay(delaytime);
Step_D();
delay(delaytime);
void forward1(){//one tooth forward
Step_E();
delay(2);
Step_F();
delay(2);
Step_G();
delay(2);
Step_H();
delay(2);
void backward1(){//one tooth backward
Step_E();
delay(delaytime);
Step_F();
delay(delaytime);
Step_G();
delay(delaytime);
Step_H();
delay(delaytime);
i got it from this youtube video and edited it - Tutorial: Stepper Motors Controlled with the Arduino - YouTube
it works great at moving one stepper a full rotation at one speed then another rotation at another speed then moving to the second stepper and doing the same then back to the first but what i need is them both to run constantly independent of each other
thank you for listening and any advice will be greatly appreciated
