Hello,
I have been looking for a way to get the RPM from a 2 stroke engine.
I am not sure what is the best option so far I found out two ways:
https://forum.arduino.cc/index.php?topic=503027.0
or this one
https://forum.arduino.cc/index.php?topic=618864.15
The opto-coupler sounded like a good idea but I am not sure if I can connect it to my engine.
I am using this kind of ignition coil:
I was thinking first to try to get a square like signal from the oscilloscope then after try to work out the code on the arduino.
I could not find a clear example for a 2 stroke engine.
Thanks,
/Eric
Must be more than just a magneto. How do you stop the engine? Let it run out of gas?
Paul
Paul_KD7HB:
Paul
I'd say offhand the spade terminal goes to a kill switch, that's how most magnetos do their stuff.
Op could use a simple capacitive pickup as described in the video below.
You will also find he has Arduinodyno with a tacho.
I don't see a terminal in the OP's picture. Only the spark plug socket.
IF there is a kill switch, then that lead will likely have a nice pulse you can use for a tach. Check it out.
Paul
Yes I have a kill switch I will check if I can get the signal from there.
I will order the opto- coupler and give it a try.
Thanks,
I did my first test on a 2 stroke Grass Trimmer Cutter
I used that schema:
Here is the live result
First Test video
The rpm reading is way off.
I check the Grass Trimmer Cutter manual .
Idle RPM 2800-3200
Max RPM 10000
Here is my code
#include <SoftwareSerial.h>
SoftwareSerial BTserial(6, 7); // RX | TX
float value=0;
float rev=0;
int rpm;
int oldtime=0;
int time;
void isr()
rev++;
//Initialize Serial Monitor
digitalWrite(2, HIGH);
//Initialize Bluetooth Serial Port
BTserial.begin(9600);
attachInterrupt(0,isr,RISING);
detachInterrupt(0);
time=millis()-oldtime;
rpm=(rev/time)*60000;
oldtime=millis();
rev=0;
Serial.println(rpm);
BTserial.print(rpm);
BTserial.print(";");
I will check with an oscilloscope how the signal looks like after the optocoupler.
Any suggestion ?
Thanks,
/Eric
How are you connected to the coil to get the tach signal?
You might consider winding a wire around the coil wire as a tap, to get the signal then send it through a signal processing circuit to clean it up before trying to count pulses.
Idahowalker:
I have using the kill switch to get the signal not the coil wire.
I read somewhere that you can get cleaner signal.
/Eric
Did you look at the video link i posted above as he has some good pickup ideas already tried and tested.
bluejets:
Nope but I will try next. For me getting the signal from the kill switch would be better as my paramotor have them but it is good to experiment all possibilities.
Here is a picture of my setup:
barnabefi:
Hope you are not thinking of "tinkering" with that one...
bluejets:
I just want to get RPM for it,nothing more.
I run some the oscilloscope at the end of the filtering circuit and it is just garbage signal...
The pulse are completely uneven...
Oscilloscope test
Next test is to check on the real engine ( 185 moster ) to see if I get similar result.
But I will build the circuit you have suggested and give it a try.
Hello.
I am trying to do the same, also for a Monster185 engine. Did you found a circuit that solve the signal issues? I tried one, but the measured rpm is.... awfull!
Regards,
Patricio
patricioruiz:
Hello.
Regards,
Patricio
There's a link in reply 2 above.........
I got a bit lost in trying to use a pca10059 board.
I just got back to the basic last week.
I am now trying this method:
kokoraskostas
and if that does not work I will try BlueJets suggestion.
ArDyno
bluejets:
I will let you know the outcome once I try this solution.
Here is my latest prototype with bluetooth connection.
Please share your findings with the Monster185 as I really would like to get that working :).
