I need to get a attiny85 to output a 25kHz PWM signal while still being able to use I2C and interrupts, but i am not sure how to do it..
I found these two threads and read through them but now i am more confused then ever.
My current plan is to have an attiny per fan, each will supply PWM signals and send back rpm data to an uno using I2C.
The uno will be communicating to a PC through usb so i can manage fan curves, temps, fan RPM.
I need the 25kHz PWM because the Intel specifications are a target frequency of 25kHz, with an acceptable operational range of 21 kHz to 28 kHz
I'm sorry, I don't know which PWM mode should be used. I have used ATtiny chips, but not the ATtiny85.
Perhaps you can get more help at : http://www.avrfreaks.net
Do you have a schematic ? do you have a way to program the chip ? do you know which timer you want to use ?
