Then just modify the two delay values to achieve the required duty cycle.
The fan requires a 25Khz input so I can't use the PWM/servo library directly.
At first glance it worked just fine, but looking at the signal with a scope it
has a lot of jitter (frequency can vary from about 20-25Khz).
I'm using a ProMicro 5V/16Mhz from Sparkfun.
It runs with a MEGA32U4, haven't dug into the datasheet yet...
Any thoughts?
Have fun digging into the 32U4 datasheet. You'll see that the timer/counters are different than with the 328P. If you need the delay() function, you'll need to find which timer/counter is being used on 32U4, then select another timer/counter to use, while adjusting its mode and frequency for 25KHz PWM.
Might be quicker to just use a Pro Mini instead, then use the sample code in link provided by teryking228.
